path: root/board
2010-03-21mod change 755 => 644 for multiple filesThomas Weber
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;' Signed-off-by: Thomas Weber <swirl@gmx.li> Add some more: neither Makefile nor config.mk need execute permissions. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-12Prepare v2010.03-rc1v2010.03-rc1Wolfgang Denk
Coding style cleanup, update CHANGELOG. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-12mpc82xx: Remove SL8245 board and the now orpahned sk98lin network driver.Detlev Zundel
This code has compile problems and the company does not even exist any more. So we take the liberty to drop support for it. Signed-off-by: Detlev Zundel <dzu@denx.de> CC: Wolfgang Denk <wd@denx.de> CC: Ben Warren <biggerbadderben@gmail.com>
2010-03-12TQM8xx: add device tree support for TQM8xx based boards.Heiko Schocher
Also use hwconfig to configure whether the board has a FEC or not. We then can adjust the DTS to tell Linux if there is a FEC present. syntax: hwconfig=fec:on if hardware has a FEC hwconfig=fec:off if hardware has no FEC Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-07AT91: Update otc570 board to new SoC accessDaniel Gorsulowski
* convert otc570 board to use c stucture SoC access * change gpio access to at91_gpio syntax Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2010-03-07arm: kirkwood: suen3: fixed build warningPrafulla Wadaskar
This patch fixes following build warning Invalid Kwbimage command Type - valid names are: BOOT_FROM, NAND_ECC_MODE, NAND_PAGE_SIZE, SATA_PIO_MODE, DDR_INIT_DELAY, DATA, , spi, nand, sata, pex, uart Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-03-07MX51: removed warnings for the mx51evkStefano Babic
The patch removes warnings at compile time and provides some cleanup code: - Removed comment on NAND (not yet supported) from lowlevel_init.S - Removed NFMS bit definition from imx-regs.h The bit is only related to MX.25/35 and can lead to confusion - Moved is_soc_rev() to soc specific code (removed from mx51evk.c) Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-03-07SPEAr : Supporting new mach ids for spear310 and spear320Vipin Kumar
Supporting new machine ids for SoCs spear310 and spear320 include/asm-arm/mach-types.h has to be updated before applying this patch for build to work Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
2010-03-07arm, suen3: fix compile error, if doing not a local buildHeiko Schocher
2010-03-07arm: add support for the suen3 board from keymileHeiko Schocher
Add support for the ARM part of the mgcoge2, named suen3. This board is based on the Marvell Kirkwood (88F6281) SoC. As there come more board variants, common config options are collected in include/configs/km_arm.h. Also, this board use common code for all keymile boards, which is stored in board/keymile/common/common.c Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Heiko Schocher <hs@denx.de>
2010-03-07Add support for KARO TX25 boardJohn Rigby
This is an i.MX25 base board with only NAND so it uses nand_spl to boot. Signed-off-by: John Rigby <jcrigby@gmail.com> Tune configuration, add support for (redundant) environment in NAND. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> CC: Fred Fan <fanyefeng@gmail.com> CC: Tom <Tom.Rix@windriver.com>
2010-03-07Add initial support for Freescale mx51evk boardStefano Babic
The patch adds initial support for the Freescale mx51evk board. Network (FEC) and SD controller (fsl_esdhc) are supported. Signed-off-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Fred Fan <fanyefeng@gmail.com>
2010-03-07edb93xx: Fix SDRAM initializationMatthias Kaehlcke
edb93xx: Fix SDRAM initialization by issuing a precharge all command before forcing the precharge and select mode register update mode before programming the mode registers. Write to the SDRAM banks in order to force a precharge, reading causes the edb93xx boards to hang Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
2010-03-07ARM change name of defines for AT91 arm926ejsAchim Ehrlich
Configuration defines should be preceeded with CONFIG_SYS_. Renamed some at91 specific defines to conform to this naming convention: AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
2010-03-07VoiceBlue: fix linker errorsLadislav Michl
linking eeprom with libgeneric.a is not really needed and causes following error: ../../lib_generic/libgeneric.a(string.o): In function `strcmp': /home/ladis/src/u-boot-ti/lib_generic/string.c:152: multiple definition of `strcmp' ../../examples/standalone/libstubs.a(stubs.o):include/_exports.h:24: first defined here make[1]: *** [eeprom.srec] Error 1 Fix undefined reference to memset generated by some versions of gcc to zero out initialized structure on the stack: eeprom.o: In function `eeprom': board/voiceblue/eeprom.c:152: undefined reference to `memset' make[1]: *** [eeprom] Error 1 Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-03-07da830evm: Add support for TI EMACNick Thompson
Adds support for ethernet networking on the da830evm platform. This platform uses an SoC EMAC interface and a 3 port ethernet switch as a PHY with an RMII interface. The PHY also has a i2c interface for configuring the switch functions. Signed-off-by: Nick Thompson <nick.thompson@ge.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-03-07NetStar: eeprom - fix linker errorLadislav Michl
linking eeprom with libgeneric.a is not really needed and causes following error: ../../lib_generic/libgeneric.a(string.o): In function `strcmp': lib_generic/string.c:152: multiple definition of `strcmp' ../../examples/standalone/libstubs.a(stubs.o):include/_exports.h:24: first defined here Remove eeprom linker script as well and generate entry point object (to start application by jumping on its beginning) on the fly. Out-of-tree build tested as well. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-03-07NetStar: eeprom - be less verboseLadislav Michl
Use shorter yet descriptive messages, replace printf() with puts() where appropriate. This saves few bytes. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-03-07NetStar: eeprom - undefined reference to `memset'Ladislav Michl
Defining partially initialized struct eth_device on stack means gcc has to zero out it, and some gcc versions optimize this with an implicit call to memset. Move definition to data section to avoid that (it has also nice side effect that we need not to pass it to helper functions anymore) Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12new board (eb_cpux9k2)Jens Scharsig
* new board (eb_cpux9k2) * support for EB+CPUx9K2 board by BuS Elektronik GmbH & Co. KG * select via make eb_cpux9k2_config * this also demonstrates, how to use boards with AT91RM9200 cpu in at91 arch tree Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-12update at91sam9263ek board to new SoC accessJens Scharsig
* convert at91sam9263ek board to use c stucture SoC access * change gpio access to at91_gpio syntax Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
2010-02-12DA830 EVM: Enable NAND support on Spectrum Digital EVMNick Thompson
The EVM UI extender card has a NAND device. This change will enable saveenv to work with NAND and Linux to be booted using: mtdparts default nboot kernel bootm Signed-off-by: Nick Thompson <nick.thompson@ge.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12edb93xx: enable the uart in devicecfg registerAlessandro Rubini
printf goes to uart1, but it will block forever waiting for busy to go off unless the uart is enabled first. Signed-off-by: Alessandro Rubini <rubini@gnudd.com>
2010-02-12edb93xx: change calculation un early_udelay.hAlessandro Rubini
Previous code compiled with gcc-4.2.2 makes a call to __aeabi_uidiv to divide by 20. As a side effect it was not inline any more, and so sdram_cfg used the stack as well, but this is early code that has no stack yet. The patch explicitly removes the division, so no stack is used. The calculation of the counter calls a division by 20 Signed-off-by: Alessandro Rubini <rubini@gnudd.com>
2010-02-12Add support for EDB93xx boardsMatthias Kaehlcke
Added support for the following EDB93xx boards: EDB9301 EDB9302 EDB9302A EDB9307 EDB9307A EDB93012 EDB9315 EDB9315A Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
2010-02-12NetStar: Remove debug junk leaked into eeprom utilityLadislav Michl
This patch removes debug junk leaked into eeprom utility. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12NetStar: make crcit utility more readableLadislav Michl
This patch makes the crcit utility more readable Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12Overo GPMC registersScott Ellis
Use appropriate GPMC timings for the LAN9221 controller on the Gumstix Overo expansion boards not the values in arch-omap3/mem.h which are for a different ethernet controller. Signed-off-by: Scott Ellis <scott@jumpnowtek.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12da830evm: Use table driven pin mux configurationNick Thompson
Tidyup the pin muxer configuration using the Davinci table driven pinmux configuration function and data tables. Signed-off-by: Nick Thompson <nick.thompson@ge.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12at91: Add esd gmbh OTC570 board supportDaniel Gorsulowski
This patch adds support for esd gmbh OTC570 board. The OTC570 is based on an Atmel AT91SAM9263 SoC. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2010-02-03Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2010-02-03Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
2010-02-03Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2010-02-03EXBITGEN: drop support for unmaintained boardWolfgang Denk
The EXBITGEN board has not been maintained for a long time; it has build problems, but no hardware is available any more for testing. Drop support for this board. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-02-03ppc4xx: Fix building for PLU405 boardsMatthias Fuchs
The init_coupler() function from board/esd/plu405/plu405.c got lost somehow! This patch readds it. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2010-01-31new at91_emac network driver (NET_MULTI api)Jens Scharsig
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api) * enable driver with CONFIG_DRIVER_AT91EMAC * generic PHY initialization * modify AT91RM9200 boards to use NET_MULTI driver * the drivers has been tested with LXT971 Phy and DM9161 Phy at MII and RMII interface Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-3183xx, uec: split enet_interface in two variablesHeiko Schocher
There's no sensible reason to unite speed and interface type into one variable. So split this variable enet_interface into two vars: enet_interface_type, which hold the interface type and speed. Also: add the possibility for switching between 10 and 100 MBit interfaces on the fly, when running in FAST_ETH mode. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-27Nand boot: Add nand boot support for MPC8569mds boardLiu Yu
This patch add nand boot support for MPC8569mds board. Signed-off-by: Liu Yu <yu.liu@freescale.com>
2010-01-25ppc/85xx: Add PIB/ATM support for MPC8569mdsLiu Yu
Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-23Merge branch 'master-sync' of git://git.denx.de/u-boot-armWolfgang Denk
2010-01-23at91: Enable slow master clock on meesc boardDaniel Gorsulowski
Normally the processor clock has a divisor of 2. In some cases this this needs to be set to 4. Check the user has set environment mdiv to 4 to change the divisor. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2010-01-23SPEAr : Support added for SPEAr320 boardVipin KUMAR
SPEAr320 SoC support contains basic spear320 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver - emi driver(cfi support) Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : Support added for SPEAr310 boardVipin KUMAR
SPEAr310 SoC support contains basic spear310 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver - emi driver(cfi support) Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : emi controller initialization for CFI driver supportVipin KUMAR
SPEAr310 and SPEAr320 SoCs contain an EMI controller to interface Paraller NOR flashes. This patch adds the support for this IP The standard CFI driver is used to interface with NOR flashes Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : Support added for SPEAr300 boardVipin KUMAR
SPEAr300 SoC support contains basic spear300 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : Support for HW mac id read/write from i2c memVipin KUMAR
This patch adds the support to read and write mac id from i2c memory. For reading: if (env contains ethaddr) pick env ethaddr else pick ethaddr from i2c memory For writing: chip_config ethaddr XX:XX:XX:XX:XX:XX writes the mac id in i2c memory Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23SPEAr : Support added for SPEAr600 boardVipin KUMAR
SPEAr600 SoC support contains basic spear600 support along with the usage of following drivers - serial driver(UART) - i2c driver - smi driver - nand driver(FSMC) - usbd driver Signed-off-by: Vipin <vipin.kumar@st.com>
2010-01-23ppc4xx: Kilauea: Add CPLD version detection and EBC reconfigurationStefan Roese
A newer CPLD version on the 405EX evaluation board requires a different EBC controller setup for the CPLD register access. This patch adds a CPLD version detection for Kilauea and code to reconfigure the EBC controller (chip select 2) for the old CPLD if no new version is found. Additionally the CPLD version is printed upon bootup: Board: Kilauea - AMCC PPC405EX Evaluation Board (CPLD rev. 0) Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Cc: Zhang Bao Quan <bqzhang@udtech.com.cn>
2010-01-18powerpc: keymile boards updatesHeiko Schocher
- malloc size 4 MB for all keymile boards - use generic FDT code for fixing up the DTS - enable unit-led at startup for keymile boards - remove some dts updates for keymile boards - ppc_83xx, kmeter1: take FE/GbE PHYs out of reset - ppc_83xx, kmeter1: change from Intel Strata to Spansion 64MB flash changed from Intel Strata to Spansion 64MB flash and changed flash layout. +---------+----------+-----------------------+-----------------------------+ | name | size | range | description | +---------+----------+-----------------------+-----------------------------+ | u-boot | 768 KB | 0xf0000000-0xf00bffff | for u-boot | | env | 128 KB | 0xf00c0000-0xf00dffff | for environment | | envred | 128 KB | 0xf00e0000-0xf00fffff | for environment (redundant) | | ubi0 | 64512 KB | 0xf0100000-0xf3ffffff | ubi0 for ubi volumes | +---------+----------+-----------------------+-----------------------------+ Signed-off-by: Heiko Schocher <hs@denx.de>
2010-01-17Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
