As only one RAM bank is used we can rely on the code from arch/arm/lib/board.c
Cc: Matthias Weisser <weisserm@arcor.de>
Let common code set the machine ID.
Acked-by: Jason Liu <jason.hui@linaro.org>
Add the initial support for MX25PDK booting from SD card via internal boot.
Avoid the usage of extern in C file as pointed out by checkpatch.
Add NAND SPL support to the devkit8000 config
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Without this change CS's configured for synchronous clocking cannot
read data.
Signed-off-by: Philip Balister <philip@opensdr.com>
The existing timing does not quite meet the minimum requirements
in the LAN9221 datasheet. The timing in this patch solves problems
noticed on some parts. The patch also combines the CS configuration
for the overo and igep0020 boards per request.
This patch adds support for 88E3015 PHY for Marvell GplugD board.
This patch depends on series of patch which adds support for Marvell
GuruPlug-Display.
Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
This patch enables ethernet support for Marvell GplugD board. Network
related commands works.
Update MPC8349EMDS to use unified DDR driver instead of spd_sdram.c.
The unified driver can initialize data using DDR controller. No need to
use DMA if just to initialze for ECC.
Signed-off-by: York Sun <yorksun@freescale.com>
The P2041RDB has almost identical setup for TLB, LAWS, and PCI with
other P-Series CoreNet platforms.
The only difference between P2041RDB & P3041DS/P4080DS/P5020DS is the
CPLD vs PIXIS FPGA which we can handle via some simple #ifdefs in the
TLB and LAW setup tables.
We currently support 4 SoC/Boards from the P-Series of QorIQ SoCs that
are based on the 'CoreNet' Architecture: P2041RDB, P3041DS, P4080DS, and
P5020DS. There is a significant amount of commonality shared between
these boards that we can refactor into common code:
* Initial LAW setup
* Initial TLB setup
* PCI setup
We start by moving the shared code between P3041DS, P4080DS, and P5020DS
into a common directory to be shared with other P-Series CoreNet boards.
We shouldn't be setting execute permissions on TLB entries that will not
actually have any code run from them.
RDIMM has different timing parameters from UDIMM. Create new tables for
RDIMMs. Single-, dual- and quad-rank RDIMMs have been verified with speeds
from 800 to 1333MT/s. Speed table expands to include 1600MT/s for future
use. Single- and quad-rank RDIMM entries are copied into UDIMM tables for
future use.
DDR RCW varies at different speeds. It is common for all platform. Move it
out from corenet_ds.
Move extern of pci_of_setup() into corenet_ds.h
Add support for RGMII, SGMII and XAUI Ethernet on P2041RDB board.
The five dTSEC can be routed to two on-board RGMII phy, three on-board
SGMII phy or four SGMII phy on SGMII riser card according to different
serdes protocol configuration and board lane configuration. Also updated
the device tree to direct the Fmac MAC to the correct PHY.
Removed CONFIG_SYS_FMAN_FW as its not used anywhere.
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
The P1023 has two 1G ethernet controllers the first can run in
SGMII, RGMII, or RMII. The second can only do SGMII & RGMII.
We need to setup a for SoC & board registers based on our various
configuration for ethernet to function properly on the board.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Signed-off-by: Lei Xu <B33228@freescale.com>
Signed-off-by: Ioana Radulescu <ruxandra.radulescu@freescale.com>
Signed-off-by: Shaohui Xie <b21989@freescale.com>
Add support for RGMII, SGMII, and XAUI (10Gb) Ethernet on P3041DS &
P5020DS ("Hydra").
The lane_to_slot[] array is initialized dynamically, since board switches
can be used to control the muxing of SERDES lanes to slots.
The BRDCFG1 PIXIS register is used to route the MII bus to the appropriate
slot. The SERDES configuration is queried to help determine the routing
between MACs and slot/phy combination.
If a XAUI card is inserted, muxing for that card is enabled and never
turned off. The PHY address for the 10G XAUI card depends on the slot in
which it's inserted. If it's in slot 1, the address is 4. If it's in
slot 2, the address is 0.
Update the MDIO routing in the P3041DS and P5020DS device trees based on
the board-level muxing. The SERDES configuration determines which
SGMII/XGMII boards are located in which slots, and so the MDIO bus needs
to be muxed correctly whenever talking to a PHY connected to any Fman MAC.
The Fman Ethernet nodes in the device tree also need to be routed to the
correct PHYs.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Add support for RGMII, SGMII, and XAUI (10Gb) Ethernet on P4080DS.
The board supports add-on cards for SGMII and XAUI functionality. Which
slots on the board these cards are in is a function of the SERDES option
selected and muxes on the board.
Additionally because of the high-configurablity which MDIO bus one is
connected to is "selected" via an FPGA register. We create dummy MDIO
bus for the phy layer and hide the mux manipulation in this dummy layer.
Add fman fdt helper function in board common code it'll be used by several
freescale boards that do various muxing of the MDIO signals based on which
controller/interface one is trying to talk to.
Remove unnecessary or dead code/includes.
Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com>
Boot methods supported: NOR Flash, SPI Flash and SDCARD
This patch adds the following basic interfaces:
DDR3, eTSEC, DUART, I2C, SD/MMC, USB, SATA, PCIe, NOR Flash, SPI Flash.
P1010RDB Overview
1Gbyte DDR3 (on board DDR)
Local Bus (IFC):
32Mbyte 16bit NOR flash
32Mbyte SLC NAND Flash
64KB CPLD device(GPCM interface)
SPI Flash:
128 Mbit SPI Flash memory
SD/MMC:
connector to interface with the SD memory card
SATA:
1 internal SATA connect to 2.5. 160G SATA2 HDD
1 eSATA connector to rear panel
USB 2.0:
x1 USB 2.0 port: connected via a UTMI PHY to Mini-AB interface.
x1 USB 2.0 port: directly connected to Mini-AB interface Ethernet
eTSEC:
eTSEC1: Connected to RGMII PHY VSC8641XKO
eTSEC2: Connected to SGMII PHY VSC8221
eTSEC3: Connected to SGMII PHY VSC8221
eCAN:
Two DB-9 female connectors for Field bus interface
UART:
supports two UARTs up to 115200 bps for console
TDM:
2 FXS ports connected via an external SLIC to the TDM interface.
SLIC:
SPI SLIC
I2C:
Serial EEprom
Real time clock
256 Kbit M24256 I2C EEPROM
PCIe:
PCIe and mPCIe connectors.
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@freescale.com>
The following boards share a common design but with minor variations
between them:
P1020MSBG-PC
P1020RDB-PC
P1020UTM-PC
P1021RDB-PC
P1024RDB
P1025RDB
P2020RDB-PC
The P1020RDB-PC shares its roots in the existing P1020RDB board design,
however uses DDR3 instead of DDR2.
P2020RDB-PC differs from the P102x RDB-PC with 64-bit DDR and 100Mhz SYSCLK.
Key features on these boards include:
* DDR3
* NOR flash
* NAND flash (on RDB's only)
* SPI flash (on RDB's only)
* SDHC/MMC card slot
* VSC7385 Ethernet switch (on P1020MBG, P1020RDB, & P1021RDB)
* PCIE slot and mini-PCIE slots
As these boards use soldered DDR chips not regular DIMMs, an on-board EEPROM
is used to store SPD data. In case of absent or corrupted SPD, falling back
to timing data embedded in the source code will be used. Raw timing data is
extracted from DDR chip datasheet. Different speeds of DDR are supported
with this approach. ODT option is forced to fit this set of boards, again
because they don't have regular DIMMs.
CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS is defined as 5ms to meet
specification for writing timing.
VSC firmware Address is defined by default in config file for eTSEC1.
SD width is based off DIP switch. DIP switch is detected on the
board by reading i2c bus and setting the appropriate mux values.
Some boards have QE module in the silicon (P1021 and P1025). QE and eLBC
have pins multiplexing. QE function needs to be disabled to access Nor Flash
and CPLD. QE-UEC and QE-UART can be enabled for linux kernel by setting "qe"
in hwconfig. In addition, QE-UEC and QE-TDM also have pins multiplexing, to
enable QE-TDM for linux kernel, set "qe;tdm" in hwconfig. Syntax is as below
'setenv hwconfig qe' to enable QE UEC/UART and disable Nor-Flash/CPLD.
'setenv hwconfig 'qe;tdm'' to enalbe QE TDM and disable Nor-Flash/CPLD.
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Zhao Chenhui <b26998@freescale.com>
Signed-off-by: Matthew McClintock <msm@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
Signed-off-by: Tang Yuantian <b29983@freescale.com>
Signed-off-by: ramneek.mehresh <ramneek.mehresh@freescale.com>
Signed-off-by: Xie Xiaobo <X.Xie@freescale.com>
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Signed-off-by: Akhil Goyal <akhil.goyal@freescale.com>
Make it easy for any Blackfin board to enable led/push button tests.
The flash code has been generalized for everyone, and the uart stub
is simply useless.
No need for our custom implementations now that common code supports
the generic gpio layer.
Since commit d388298a59ba375c76597b8f95b560afa971a0fb by
Stefano Babic this file is no longer needed so delete it.
Cc: Loïc Minier <loic.minier@linaro.org>
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Fix build warning
beagle.c:532: warning: initialization from incompatible pointer type
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
CC: Jason Kridner <jkridner@beagleboard.org>
CC: Koen Kooi <koen@dominion.thruhere.net>
CC: Joel A Fernandes <agnel.joel@gmail.com>
Cc: Greg Turner <gregturner@ti.com>
CC: Sandeep Paulraj <s-paulraj@ti.com>
Acked-by: Jason Kridner <jkridner@beagleboard.org>
The MAC address stored in the inventory eeprom begins at offset 1.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Wolfgang Denk <wd@denx.de>
Result of running the following command to address Wolfgang's
comment about camel case:
for file in `find . | grep '\.[chS]$'`; do perl -i -pe
's/(green|yellow|red|blue)_LED_(on|off)/$1_led_$2/g' $file; done
Discussion:
http://patchwork.ozlabs.org/patch/84988/
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com>
omap4: fix pad configuration settings for SDP and Panda
Signed-off-by: Aneesh V <aneesh@ti.com>
Signed-off-by: Sebastien Jan <s-jan@ti.com>
Signed-off-by: David Anders <x0132446@ti.com>
This patch contains updates the sources in the board files
to use the generic API.
Signed-off-by: Sanjeev Premi <premi@ti.com>
Make use of GPIO framework and avoid the following build error:
tx25.c: In function 'tx25_fec_init':
tx25.c:73: error: dereferencing pointer to incomplete type
tx25.c:74: error: dereferencing pointer to incomplete type
tx25.c:75: error: dereferencing pointer to incomplete type
tx25.c:76: error: dereferencing pointer to incomplete type
tx25.c:83: error: dereferencing pointer to incomplete type
tx25.c:84: error: dereferencing pointer to incomplete type
tx25.c:114: error: dereferencing pointer to incomplete type
tx25.c:115: error: dereferencing pointer to incomplete type
tx25.c:116: error: dereferencing pointer to incomplete type
tx25.c:117: error: dereferencing pointer to incomplete type
tx25.c:124: error: dereferencing pointer to incomplete type
tx25.c:125: error: dereferencing pointer to incomplete type
tx25.c:126: error: dereferencing pointer to incomplete type
Fix build problem:
nand_spl/board/davinci/da8xxevm/hawkboard_nand_spl.c: In function 'board_init_f':
nand_spl/board/davinci/da8xxevm/hawkboard_nand_spl.c:132: warning: implicit declaration of function 'nand_boot'
nand_spl/board/davinci/da8xxevm/hawkboard_nand_spl.c:133: warning: 'noreturn' function does return
Cc: Syed Mohammed Khasim <sm.khasim@gmail.com>
Cc: Sughosh Ganu <urwithsughosh@gmail.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Fix these:
cm4008.c: In function 'board_eth_init':
cm4008.c:79: warning: implicit declaration of function 'ks8695_eth_initialize'
cm41xx.c: In function 'board_eth_init':
cm41xx.c:79: warning: implicit declaration of function 'ks8695_eth_initialize'
While we are at it, sort include list in netdev.h
Cc: Greg Ungerer <greg.ungerer@opengear.com>
Trivial conversion of the ks8695eth driver to a CONFIG_MULTI_ETH type
driver.
Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
