It was brought to our attention that U-Boot contains code derived from the
IBM OpenBIOS source code originally provided with some of the older PowerPC
4xx development boards. As a result, the original license of this code has
been carried in the various files for a number of years in the U-Boot project.
IBM is dual-licensing the IBM code contributions already present in U-Boot
under either the terms of the GNU General Public License version 2, or the
original code license already present.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
While at it, remove initialization of variables which will be set
before usage in all cases.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Add mtc state subcommand description to the
help of mtc command.
Remove some newlines in description of commands
for proper help formating.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de>
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Embedd chip select configuration into struct for gpmc config
instead of having it completely separated as suggested by
Wolfgang Denk on
http://lists.denx.de/pipermail/u-boot/2009-May/052247.html
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
This patch is based on a diff created by Phong Vo from AMCC.
Signed-off-by: Phong Vo <pvo@amcc.com>
"All Rights Reserved" conflicts with the GPL.
Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Because twl4030 now has its own device files, move exiting
omap3 power_init_r to a new location.
power_init_r is the only function in board/omap3/common.
It initializes the twl4030 power for the board and enables
the led.
The power part of the the function is moved to twl4030_power_init in
drivers/power/twl4030.c The power compilation is conditional on the
existing config variable CONFIG_TWL4030_POWER.
The led part is moved to twl4030_led_init in the new file
drivers/misc/twl4030_led.c The led compilation is conditional on
the new config variable CONFIG_TWL4030_LED
The directory board/omap3/common was removed because power_init_r
was the only function in it.
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
Acked-by: Heiko Schocher <hs@denx.de>
The Zoom2 power reset button is on the top right side of the
main board. Press and hold for about to 8 seconds to completely
reset the board.
Some of the beta boards have a hardware problem that prevents
using this feature. If is difficult to further characterize the
boards that fail. So disable resetting for all beta boards.
The Zoom1 reset button is the red circle on the top right,
front of the board. Press and hold the button for 8 seconds to
completely reset the board.
After analyzing beagle, it was determined that other boards
that use the twl4030 for power managment can also make use
this function.
The resetting is done by the power management part of the twl4030.
Since there is no existing drivers/power, add one.
The compilation of power/twl4030.h is controlled by the config
This patch fixes the problem, that the current fdt board fixup code only
set's one range, the one for NOR. By this it's overwriting the already
correctly configured values done in __ft_board_setup(). Just remove this
now unneeded NOR fixup and all the ranges are correctly defined.
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Felix Radensky <felix@embedded-sol.com>
This patch adds some I2C bootstrap setting for NAND booting to the Kilauea
chip_config command ("533-nand" and "600-nand").
Additionally some incorrectly indented lines are fixed.
Testing on AMCC Arches with the latest U-Boot version yielded that DDR2
initialization is currently broken. U-Boot hangs upon relocation to SDRAM
or crashes with random traps. This patch fixes this problem. Arches now
uses a different WRDTR and CLKTR default setting than Canyonlands/Glacier.
Board support for the Guntermann & Drunck CompactCenter and
DevCon-Center.
Based on the AMCC Canyonlands board support by Stefan Roese.
This patch adds support for the esd VME8349 board equipped with the
MPC8349. It's a VME PMC carrier board equipped with the Tundra
TSI148 VME-bridge.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Up to this point in time, the sbc8349 board was storing the u-boot
image in flash 2x. One for the HRCW value at the beginning of
flash (0xff80_0000), and once close to the end of flash (0xfff8_0000)
for the actual image that got executed.
This moves the TEXT_BASE to be the beginning of flash, which makes
the second copy of the image redundant, and frees up the flash
from the end of the environment storage to the end of the flash
device itself.
Many (especially ARM) tool chains seem to come with broken or
otherwise unusable (for the purposes of builing U-Boot) run-time
support libraries `libgcc.a'. By using the "USE_PRIVATE_LIBGCC"
setting we allow to use alternative libraries instead.
"USE_PRIVATE_LIBGCC" can either be set as an environment variable in
the shell, or as a command line argument when running "make", i. e.
$ make USE_PRIVATE_LIBGCC=yes
or
$ USE_PRIVATE_LIBGCC=yes
$ export USE_PRIVATE_LIBGCC
$ make
The value of "USE_PRIVATE_LIBGCC" is the name of the directory which
contains the alternative run-time support library `libgcc.a'. The
special value "yes" selects the directory $(OBJTREE)/lib_$(ARCH) .
Note that not all architectures provide an alternative `libgcc.a' in
their lib_$(ARCH) directories - so far, only ARM does.
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
cc: Stefan Roese <sr@denx.de>
This patch updates the support for EB+MCF-EV123 board and needs
the [PATCH 1/2 V3] new video driver for bus vcxk framebuffers
* remove the board framebuffer driver
* use the common bus_vcxk framebuffer driver
* adds bmp support
* adds splashimage support
* fix serveral cosmetical errors
Signed-off-by: Jens Scharsig <esw@bus-elektronik.de>
[agust@denx.de: fixed some style issues before applying]
This patch updates the MIMC200 files to enable the LCD.
Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
This patch removes the "alterpll" command and replaces it with the now
ppc4xx standard "chip_config" command to configure the I2C bootstrap
EEPROM.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch adds a generic command for programming I2C bootstrap
eeproms on PPC4xx. An implementation for Canyonlands board is
included.
The command name is intentionally chosen not to be PPC4xx specific.
This way other CPU's/SoC's can implement a similar command under
the same name, perhaps with a different syntax.
Usage on Canyonlands:
=> chip_config
Available configurations (I2C address 0x52):
600-nor - NOR CPU: 600 PLB: 200 OPB: 100 EBC: 100
600-nand - NAND CPU: 600 PLB: 200 OPB: 100 EBC: 100
800-nor - NOR CPU: 800 PLB: 200 OPB: 100 EBC: 100
800-nand - NAND CPU: 800 PLB: 200 OPB: 100 EBC: 100
1000-nor - NOR CPU:1000 PLB: 200 OPB: 100 EBC: 100
1000-nand - NAND CPU:1000 PLB: 200 OPB: 100 EBC: 100
1066-nor - NOR CPU:1066 PLB: 266 OPB: 88 EBC: 88 ***
1066-nand - NAND CPU:1066 PLB: 266 OPB: 88 EBC: 88
=> chip_config 600-nor
Using configuration:
done (dump via 'i2c md 52 0.1 10')
Reset the board for the changes to take effect
Other 4xx boards will be migrated to use this command soon
as well.
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
The XPedite1000 is an X-ES product thus it can be put in board/xes along
with other X-ES boards. Along with the move, the board was renamed to
XPedite1000 from XPedite1K to fit X-ES's standard naming convention.
Maintainership was also transfered to Peter Tyser.
Enable GPIO pins for an I2C EEPROM write protect, a system reset pin,
and a PMC #MONARCH pin. These pins are not currently used in U-Boot,
but are used in OSes and may be used in U-Boot in the future.
The XPedite1000 can be built with 4 total flashes:
- 512KB AMD socketed
- 16MB Intel soldered
- 2 x 32MB AMD MirrorBit flashes
Add support for the optional 2 32MB CFI-compliant AMD flashes
By default, the XPedite1000 comes installed with xMon, a proprietary
bootloader. xMon stores its MAC address in an onboard EEPROM. Rather
than requiring a non-standard location in the EEPROM to be reserved for
MAC addresses, store the MAC addresses in U-Boot's standard environment.
A U-Boot application or OS application can be used to migrate xMon MAC
addresses to U-Boot's environment if necessary.
All XPedite1000's have SPD EEPROMs present and no fixed configuration
parameters are currently defined or used
