This introduces some minor cleanups, regarding aspects such as board name, code
and headers organization as well as deprecated and missing config options.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Gets propagated into the device tree and then into /proc/cpuinfo where
users often expect it.
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Tested-by: Stephen Warren <swarren@wwwdotorg.org>
Reviewed-by: Stephen Warren <swarren@wwwdotorg.org>
During boot, U-Boot raises the CPU frequency but the CORE and MPU regulators
are not updated. This is not a problem in cold boot since the default values
that the pmic outputs are correct, but if Linux were to switch the module to a
low power OPP, the new voltage values will be retained after a reboot and the
module will likely hang once U-Boot raises the CPU frequency back up.
Set both CORE and MPU regulators to to 1.1V on boot.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
CM-T43 does not have a vtt regulator. Remove the function that's supposed
to enable it.
Set TPS65218 FSEAL bit to 1 so that RTC could be powered using on-board
3V battery. This is necessary so that time and date will survive reboots and
power offs.
Simplify the board file by splitting it to spl portion and u-boot portion.
Some unnecessary includes were identified and removed. No functional changes.
During very early prototype-phase we did boot the AM335x boards
initially from CPSW-EMAC.
Now we don't need this feature anymore.
So we drop it to save MLO-space and having therefore a more quickly
boot.
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
Logic PD makes four different system on modules. This patch will auto
detect the board type and identify the corresponding device tree image.
V2:
Added 'default:' case to switch statement
Since board_late_init() is defined as int, we now return 0
Signed-off-by: Derald Woods <woods.technical@gmail.com>
Compiling the mkorigenspl tool on darwin complains about undefined ulong. Fix
this by using the unified way.
This patch adds support for stm32f7 family & stm32f746 board.
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
This patch removes the gpio clock enable from gpio driver & move it in the
board code, making it possible to use the gpio driver with other socs.
The initialization for smmu and stream id is moved into the common soc
code.
Signed-off-by: Alison Wang <alison.wang@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
QE-HDLC and USB multi-use the pins, modify the pin-muxing code
for them, when set "hwconfig=qe-hdlc" in uboot, assign the pins
to QE-HDLC, if not, assgin it to USB
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
Pin-muxing code should be in config_board_mux, move USB muxing
config to config_board_mux.
Add USB XHCI support for ls1043qds board.
Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com>
As the QE firmware struct is shared with Fman, move the header file
out of drivers/qe/.
As QSPI and IFC are pin-multiplexed on LS1021A, only IFC is supported
in SD boot now. For the customer's demand, QSPI needs to be supported
in SD boot too.
This patch adds QSPI or IFC support in SD boot according to the
corresponding defconfig. For detail, ls1021aqds_sdcard_ifc_defconfig
is used to support IFC in SD boot and ls1021aqds_sdcard_qspi_defconfig
is used to support QSPI in SD boot.
SY8106A is a PMIC which is used on the Allwinner
H3 Orange Pi Pc and Plus board. The VOUT1_SEL register is
implemented to set the default V-CPU voltage to 1200 mV.
This driver is required to ensure the SY8106A V-CPU
voltage is set to 1200 mV after a software reset. On cold
boot the default SY8106A output voltage is selected to be
1200 mV by a pair of resistors on the Orange Pi PC and Plus.
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
Tested-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
OF_CONTROL is setup by default and memory reading is done via DT. Remove
all config files with memory references.
Add board_mmc_getcd function and declare CD_GPIO for SDCard.
Signed-off-by: Julien Corjon <corjon.j@ecagroup.com>
Specify max_bus_width directly in usdhc_cfg static definition instead
of tweaking it in the board_mmc_init() function.
USDHC2 does not exist on mx6quq7 board, as USDHC4 was already been
declared this is probably a typo.
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Implement board specific functions to select the environment device and
partition when booting from SD/MMC.
SD2: mmc 0 0
SD3: mmc 1 0
eMMC: mmc 2 1
Signed-off-by: Soeren Moch <smoch@web.de>
When running the 'ums' command we get:
=> ums 0 mmc 0
UMS: disk start sector: 0x0, count: 0xe18000
g_dnl_register: failed!, error: -22
ERROR: g_dnl_register failed
at common/cmd_usb_mass_storage.c:107/do_usb_mass_storage()
Fix this by initializing USB OTG1 port as USB device mode instead of host.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Use the new NXP email address for the board maintainer.
This adds basic support to Intel Cougar Canyon 2 board, a board
based on Chief River platform with an Ivy Bridge processor and
a Panther Point chipset.
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
The Versatile Industrial Communication platform is a community oriented
board from Landis + Gyr. It comes with:
- an RS-485 port
- 2 Ethernet ports
- a wireless M-BUS
- a 4G modem
- a 4MB SPI flash
- a 4GB eMMC
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
[rebase on current TOT]
Add support for DENX MA5D4 SoM and MA5D4EVK board, based on the
Atmel SAMA5D4 SoC. The SoM contains the SoC, eMMC, SPI NOR, SPI
CAN controllers and DRAM, the baseboard contains UART connectors,
ethernet port, microSD slot, LCD header, 2x CAN connector and a
lot of expansion headers.
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
Due to introducing the PMC_PLLICPR init function, use this
function to clean up the code.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Tested-by: Heiko Schocher <hs@denx.de>
Due to introducing the new PLLB clock handle functions,
use these functions to clean up the PLLB enable code.
Due to introducing the new UTMI PLL clock handle functions,
use the functions to reduce the duplicated code.
Due to introducing the new peripheral clock handle functions,
use these functions to reduce duplicated code.
[Rebased on current master, fixup for at91rm9200ek]
Move this driver over to use driver model. This involves rearranging the
code somewhat. The effect is that everything is run from the probe() method.
Boards which use this are fixed up, but only seaboard is tested.
Acked-by: Anatolij Gustschin <agust@denx.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
This option refers only to the tegra20 video driver, so name it as such
to avoid confusion with tegra124.
Also move this option to Kconfig.
According to Data Manual(SPRS915P) of AM572x, TI QSPI controller on
DRA74 EVM(rev 1.1+) can support up to 64MHz in MODE-0, whereas MODE-3 is
limited to 48MHz. Hence, switch to MODE-0 for better throughput.
Also, add IODelay parameters for the same.
Signed-off-by: Vignesh R <vigneshr@ti.com>
I will take this over from Peter Barada, since I work with it daily
at Logic PD.
Acked-by: Peter Barada <peter.barada@logicpd.com>
There are various different boards with the same hardware sold as LG Optimus
Black, such as P970, P970g and KU5900. Since this port is functional for all
variants, it doesn't make sense to keep references to P970.
Let's set "ethaddr" when we get the ethernet address too, so that
fdt_fixup_ethernet() sets the address in the device tree and the Linux
driver can pick it up.
remove board_eth_init when CONFIG_DM_ETH is defined
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Android Fastboot requires USB. The TWL4030 PMIC on omap3_logic handles USB traffic.
This patch sets up the USB gadget and Android Fastboot to match what is done in the
omap3_beagle project.
Previously, Omap3_logic assumed X-loader was present. With this
patch, we can finally replace X-loader with an MLO generated by
U-Boot. This requires ECC to be setup to match the Linux Kernel
and the PBIAS confgured for the SD card.
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
The P5 header was not present on "Model B" any board prior to Revision 2.0,
there's no need for a separate device tree.
Also, it looks like "rev2" is incorrectly used to only cover the 512MiB
memory models; there also were 256MiB 2.0 boards.
I don't have all of the boards to check this, I'm following this table:
http://elinux.org/RPi_HardwareHistory#Board_Revision_History
This source has been blessed by Dom Cobley at the RPi Foundation, so seems
like the best source to refer to. It's a superset of and consistent with
the other sources.
Cc: Lubomir Rintel <lkundrak@v3.sk>
Cc: Eric Anholt <eric@anholt.net>
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
This patch removes the uart clock enable from serial driver & move it in the
board code.
