This patch adds support for the T3CORP board, based on the
AppliedMicro (APM) PPC460GT.
OMAP3EVM Rev >=E uses external Vbus supply so setting 'extvbus'
to '1' for OMAP3EVM Rev >=E runtime based on EVM revision.
CC: Remy Bohmer <linux@bohmer.net>
Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
Added function to differentiate between the OMAP3EVM revisions. The
chip-id of the ethernet PHY is being used for this purpose.
Rev A to D : 0x01150000
Rev >= E : 0x92200000
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Signed-off-by: Sanjeev Premi <premi@ti.com>
Acked-by: Sandeep Paulraj <s-paulraj@ti.com>
Add USB OHCI support for at91sam9g45ekes/at91sam9m10g45ek boards.
Note that according to errata from Atmel, OHCI is not operational
on the first revision of at91sam9g45 chip. So this patch enables
OHCI support for later revisions.
Signed-off-by: Sergey Matyukevich <geomatsi@gmail.com>
Fix following warnings:
$ ./MAKEALL EVB64260 P3G4 ZUMA
Configuring for EVB64260 board...
mpsc.c: In function 'mpsc_putchar_early':
mpsc.c:121: warning: dereferencing type-punned pointer will break strict-aliasing rules
mpsc.c:127: warning: dereferencing type-punned pointer will break strict-aliasing rules
- Also modified the code to use io accessors.
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
When building some avr32 boards out of tree (e.g. O=..) the linker script could
not be found. This patch references the linker script in source tree.
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
Use a slighly larger value of CLK_CTRL for DDR at 667MHz
which fixes random crashes while linux booting.
Applicable for both NAND and NOR boot.
Signed-off-by: Sandeep Gopalpet <sandeep.kumar@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
The AmigaOneG3SE board has been orphaned or a very long time, and
broken for more than 12 releases resp. more than 3 years. As nobody
seems to be interested any more in this stuff we may as well ged rid
of it, especially as it clutters many areas of the code so it is a
continuous pain for all kinds of ongoing work.
CONFIG_SYS_BUS_HZ has not really been used anywhere except to be
redined as CONFIG_SYS_BUS_CLK; in addition, the mpc7448hpc2 had the
bogus CONFIG_SYS_CONFIG_BUS_CLK setting which duplicated the
funtionality. Change all this to use CONFIG_SYS_BUS_CLK consistently.
Cc: Frank Gottschling <fgottschling@eltec.de>
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Cc: Eran Man <eran@nbase.co.il>
Cc: Stefan Roese <sr@denx.de>
Cc: Nye Liu <nyet@zumanetworks.com>
Cc: Roy Zang <tie-fei.zang@freescale.com>
Makefile
Adds initialization code for SM502 graphics controller
and NL6448BC20-21D LCD panel.
CONFLICT (rename/add): Rename
board/davinci/da830evm/Makefile->board/ti/tnetv107xevm/Makefile
in 89b765c7f6ddfde07ba673dd4adbeb5da391a81b.
board/ti/tnetv107xevm/Makefile added in HEAD
But files were identical, so no problem.
This patch adds support for the LaCie ED Mini V2 product
which is based on the Marvell Orion5x SoC.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
Acked-by: Tom <Tom@bumblecow.com>
This patch adds support for the Samsung Goni board (S5PC110 SoC)
Do not enforce drivers to provide empty video_set_lut()
if they do not implement indexed color (8 bpp) frame
buffer support. Add default function to the cfb_console
driver and remove empty video_set_lut() functions.
Provides initial support for TI OMAP-L138/DA850 SoC devices on
a Logic PD EVM board.
Provides:
Initial boot and configuration.
Support for i2c.
UART support (console).
Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Acked-by: Ben Gardiner <bengardiner@nanometrics.ca>
Reviewed-by: Wolfgang Denk <wd@denx.de>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
DA850/OMAP-L138 is a new SoC from Texas Instruments
(http://focus.ti.com/docs/prod/folders/print/omap-l138.html).
This SoC is similar to DA830/OMAP-L137 in many aspects. Hence
rename the da830 specific files and folders to da8xx to
accommodate DA850/OMAP-L138.
TI's DA850/OMAP-L138 platform is similar to DA830/OMAP-L137
in many aspects. So instead of repeating the same code in
multiple files, move the common code to a different file
and call those functions from the respective da830/da850
files.
Acked-by: Nick Thompson <nick.thompson@ge.com>
Pandora has a capacitor connected as backup battery, which allows
retaining RTC for some time while main battery is removed. Enable backup
battery charge function to charge that capacitor.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
This patch adds basic support for the AM3517EVM.
It includes:
- Board files (.c and .h)
- Default configuration file
- Updates for Makefile
TNETV107X is a Texas Instruments SoC based on an ARM1176 core, and with a
bunch on on-chip integrated peripherals. This patch adds support for the
TNETV107X EVM board.
Signed-off-by: Cyril Chemparathy <cyril@ti.com>
It includes:
Add the new board PM9G45 from Ronetix GmbH.
* AT91SAM9G45 MCU at 400Mhz.
* 128MB DDR2 SDRAM
* 256MB NAND
* 10/100 MBits Ethernet DP83848
* Serial number chip DS2401
The board is made as SODIMM200 module.
For more info www.ronatix.at or info@ronetix.at.
Signed-off-by: Asen Dimov <dimov@ronetix.at>
The ngPIXIS is a board-specific FPGA, but the definition of the registers
is mostly consistent. On boards where it matter, register 9 is called
'brdcfg1' instead of 'dma', so rename the variable in the ngpixis_t
definition.
The nios-32 arch is obsolete and broken. So it is removed.
This patch adds gpio support of Altera PIO component to the
nios2-generic board. Though it drives only gpio_led at the
moment, it supports bidirectional port to control bit-banging
I2C, NAND flash busy status or button switches, etc.
Tested-by: Ian Abbott <abbotti@mev.co.uk>
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
Match style we use almost everywhere else
call to reset PHY chip.
Current PHY Software Reset operation in guruplug does not
poll reset bit in control register to go to 0(auto clearing)
for making sure reset was successful.This patch uses standard
miiphy call miiphy_reset to make sure proper PHY reset operation.
Signed-off-by: Mahavir Jain <mjain@marvell.com>
Commit 15351855 "fsl-diu: Using I/O accessor to CCSR space" caused a
number of "passing argument 2 of 'out_be32' makes integer from pointer
without a cast" warnings; fix these.
Cc: Dave Liu <daveliu@freescale.com>
Cc: Jerry Huang <Chang-Ming.Huang@freescale.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
This patch removes the checkboard function from the build of
the 4k bootstrap section for the SIMPC8313 as it is not needed
in the spl build. This will allow > 100 bytes of extra room
for other uses.
Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
Due to some overlapping sections it's time to update TEXT_BASE
for this board.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Fix MVBLM7 and MVSMR Makefiles for correct out-of-tree building
(create "bootscript.img" in build directory instead of source
directory) and cleanup (remove "bootscript.img" when cleaning up).
Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
On the MPC85xx platform if we have SATA its connected on SERDES.
Determing if SATA is enabled via sata_initialize should not be board
specific and thus we move it out of the MPC8536DS board code.
Additionally, now that we have is_serdes_configured() we can determine
if the given SATA port is enabled and error out if its not in the
driver.
The new is_serdes_configured covers a broader range of devices than the
PCI specific code. Use it instead as we convert away from the
is_fsl_pci_cfg() code.
Additionally move to setting LAWs for PCI based on if its configured.
Also updated PCI FDT fixup code to remove PCI controllers from dtb if
they are configured.
Using PPC I/O accessor to DIU I/O space instead of directly
read/write. It will prevent the dozen of compiler order issue
and PPC hardware order issue for accessing I/O space.
Using the toolchain(tc-fsl-x86lnx-e500-dp-4.3.74-2.i386.rpm)
can show up the order issue of DIU driver.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Add USB commands.
Rename autoscript to bootscript.
Add automatic bootscript image generation to makefile.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Added UPM array table, upmconfig, and Local Bus configuration support for SIMPC8313
Only one file apparently defines this function, and it merely stubs
it out. So if no one is defining/calling it, punt it.
