Signed-off-by: Matthias Fuchs <mf@esd.eu>
Affected boards:
db64360
db64460
katmai
taihu
taishan
yucca
cpc45
cpu87
eXalion
elppc
debris
kvme080
mpc8315erdb
integratorap
ixdp425
oxc
pm826
pm828
pm854
pm856
ppmc7xx
sc3
sc520_spunk
sorcery
tqm8272
tqm85xx
utx8245
Removed initialization of the driver from net/eth.c
Also, wrapped contents of pci_eth_init() by CONFIG_PCI.
Affected boards:
cu824
bab7xx
adciop
dasa_sim
mousse
mpc8540eval
musenki
mvblue
pcippc2/pcippc6
sbc8240
stxssa
Affected boards:
ap1000
mvbc_p
PM854
Affected boards:
purple
Removed initialization of controller from net/eth.c
Modified board_eth_init() functions of boards that have this FEC in addition
to other Ethernet controllers.
Affected boards:
bc3450
icecube
mvbc_p
o2dnt
pm520
total5200
tq5200
Affected boards:
IncaIP
Affected boards:
AmigaOneG3SE
Affected boards:
EVB64260
P3G4
ZUMA
Affected boards:
PN62
sc520_cdp
Affected boards:
a3000
Affected boards:
bc3450
cpci5200
mecp5200
pf2000
icecube
o2dnt
pm520
sandpoint8245
total5200
tqm5200
Affected boards:
mpc7448hpc2
Affected boards:
hidden_dragon
MPC8544DS
MPC8610HPCN
R2DPLUS
TB0229
Affected boards:
linkstation
r7780mp
Removed at91sam9_eth_initialize() from net/eth.c
This addresses all drivers whose initializers have already
been moved to board_eth_init()/cpu_eth_init().
The 8544DS and 8572DS platforms support an optional SGMII riser card to
expose ethernet over an SGMII interface. Once the card is in, it is also
necessary to configure the board such that it uses the card, rather than
the on-board ethernet ports. This can either be done by flipping dip switches
on the motherboard, or by modifying registers in the pixis. Either way
requires a reboot.
This adds a command to allow users to choose which ports are routed through
the SGMII card, and which through the onboard ports. It also allows users
to revert to the current switch settings.
This code does not work on the 8572, as the PIXIS is different.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The 8544 DS has an optional SGMII Riser card, which uses different PHY
addresses. Check if we are in SGMII mode, and invoke the SGMII Riser
setup code if so.
The 8544DS and 8572DS systems have an optional SGMII riser card which
exposes new ethernet ports which are connected to the eTSECs via an
SGMII interface. The SGMII PHYs for this board are offset from the standard
PHY addresses, so this code modifies the passed in tsec_info structure to
use the SGMII PHYs on the card, instead.
AP325RXA is SH7723's reference board.
This has SCIF, NOR Flash, Ethernet, USB host, LCDC, SD Host, Camera and other.
In this patch, support SCIF, NOR Flash, and Ethernet.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
This adds initial support for the RTE RSK+ SH7203 board.
This board has SH7785, 512MB DDR2-SDRAM, NOR Flash,
Graphic, Ethernet, USB, SD, RTC, and I2C controller.
This patch supports the following functions:
- 128MB DDR2-SDRAM (29-bit address mode only)
- NOR Flash
- USB host
- Ethernet
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
SMDK6400 can only boot U-Boot from NAND-flash. This patch adds a nand_spl
driver for it too. The board can also boot from the NOR flash, but due to
hardware limitations it can only address 64KiB on it, which is not enough
for U-Boot. Based on the original sources by Samsung for U-Boot 1.1.6.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
- memsetup.s is changed/merged to lowlevel_init.S
memsetup.S has a global label memsetup that just returns back to caller
- memsetup global label is changed/merged to lowlevel_init
This label is not called from anywhere.
Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
ARM DaVinci: Standardize names of directories/files.
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
ARM DaVinci: Move common functions to board/davinci/common.
MPC5121 rev 2 silicon has a new register for controlling how long
CS is asserted after deassertion of ALE in multiplexed mode.
The default is to assert CS together with ALE. The alternative
is to assert CS (ALEN+1)*LPC_CLK clocks after deassertion of ALE.
The default is wrong for the NOR flash and CPLD on the ADS5121.
This patch turns on the alternative for CS0 (NOR) and CS2 (CPLD)
it does so conditionally based on silicon rev 2.0 or greater.
Signed-off-by: Martha J Marx <mmarx@silicontkx.com>
Signed-off-by: John Rigby <jrigby@freescale.com>
Add FEC pin set and mii reset in __mii_init(). Change
legacy flash vendor from 2 to AMD LEGACY (0xFFF0),
change cfi_offset to 0, and change CFG_FLASH_CFI to
CONFIG_FLASH_CFI_LEGACY. Correct M54451EVB and
M54455EVB env settings in configuration file.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
Signed-off-by: Dejan Minic <minic@freescale.com>
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Signed-off-by: Dave Liu <daveliu@freescale.com>
