path: root/board
2013-05-15Power: remove support for Freescale MPC8220Wolfgang Denk
The Freescale MPC8220 Power Architecture processors have long reached EOL; Freescale does not even list these any more on their web site. Remove the code to avoid wasting maitaining efforts on dead stuff. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Andy Fleming <afleming@gmail.com>
2013-05-13blackfin: bf609: add softswitch config commandBob Liu
Add softswitch_output command for bf609-ezkit to enable softswitches. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-05-13blackfin: bf609: implement soft switchSonic Zhang
Set up soft switch pins properly in board init code. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Scott Jiang <scott.jiang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com>
2013-05-10openrisc: move board linker script(s) to a common in cpu/Stefan Kristiansson
Unifies the openrisc boards linker scripts into a common one. Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2013-05-10openrisc: specify a memory region for u_boot_listsStefan Kristiansson
Since there are two memory areas defined, vectors and ram, the linker will error when neither of them are specified for a section. Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2013-05-10Fix references to the documentation filesAnatolij Gustschin
Many boot image configuration files refer to the appropriate documentation file, but these references contain typos in the directory and file name. Fix them. Also fix reference to doc/README.SPL file. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2013-05-09gpio: Add support for microblaze xilinx GPIOMichal Simek
Microblaze uses gpio which is connected to the system reset. Currently gpio subsystem wasn't used for it. Add gpio driver and change Microblaze reset logic to be done via gpio subsystem. There are various configurations which Microblaze can have that's why gpio_alloc/gpio_alloc_dual(for dual channel) function has been introduced and gpio can be allocated dynamically. Adding several gpios IP is also possible and supported. For listing gpio configuration please use "gpio status" command This patch also remove one compilation warning: microblaze-generic.c: In function 'do_reset': microblaze-generic.c:38:47: warning: operation on '*1073741824u' may be undefined [-Wsequence-point] Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-05-02Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-05-02powerpc/p1_p2_rdb_pc: Add a pin to reset the DDR chip for P1021RDB-PCXu Jiucheng
When P1021RDB-PC reboot system, the board will hung at uboot DDR configuration. For P1021RDB-PC DDR reset pin is multiplex with QE, so uboot will reserve this pin for QE and skip DDR reset. Other platforms without QE will do this reset. This patch adds a slight code to reset DDR chip by QE CE_PB8 pin for NAND and NOR FLASH boot. For booting from SPI FALSH and SD card, it seems possible to use the rom on chip to write to the GPIO pins before configuring the DDR. Signed-off-by: Xu Jiucheng <B37781@freescale.com> Signed-off-by: Xie Xiaobo <X.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02powerpc/p1010rdb: Change flexcan compatible stringShengzhou Liu
Change flexcan compatible string from "fsl,flexcan-v1.0" to "fsl,p1010-flexcan" to match the device tree. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02qoriq/p1_p2_rdb_pc: USB device-tree fixups for P1020Zhicheng Fan
Resolve P1020 second USB controller multiplexing with eLBC - mandatory to mention USB2 in hwconfig string to select it over eLBC, otherwise USB2 node is removed - works only for SPI and SD boot Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Zhicheng Fan <B32736@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02powerpc/b4860qds: Add the tlb entries for SRIO interfacesLiu Gang
Add the tlb entries based on the configuration of the SRIO interfaces. Every SRIO interface has 256M space: #define CONFIG_SYS_SRIO1_MEM_VIRT 0xa0000000 #define CONFIG_SYS_SRIO1_MEM_PHYS 0xc20000000ull #define CONFIG_SYS_SRIO2_MEM_VIRT 0xb0000000 #define CONFIG_SYS_SRIO2_MEM_PHYS 0xc30000000ull Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02powerpc/p1022ds: Add support for NAND and NAND boot using SPLMatthew McClintock
Add defines needed to access NAND, remove second flash bank that is actually connected to NAND. Add nand booting support for P1022DS with hardcoded DDR config using SPL framework from 2011 Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Jiang Yutang <b14898@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02board/freescale/common/cds_pci_ft.c: Fix rotate wrong cells in interrupt-map ↵Jiang Bin
property For linux 3.x, the size of each item in interrupt-map property is 9 not 7. Don't use the static value and calculate the size with following cells: PCI #address-cells, PCI #interrupt-cells, PIC address, PIC #address-cells, PIC #interrupt-cells. Signed-off-by: Bin Jiang <bin.jiang@windriver.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-05-02Merge branch 'master' of git://git.denx.de/u-boot-mpc5xxxTom Rini
2013-05-02mpc5200: a3m071/a4m2k: Miscellaneous updates and fixesStefan Roese
The changes to a3m071/a4m2k in summary are: - Enable CAN1 on I2C in GPS Port Configuration - Enable SPI on PSC2 - Activate network console - New flash partitioning - Fix some typos - Pass host name to Linux - Change rootfs to squashfs,jffs2 - Enable UBI/UBIFS support - Enable FIT support Signed-off-by: Stefan Roese <sr@denx.de>
2013-05-01env_mmc: add support for redundant environmentMichael Heimpold
This patch add support for storing the environment redundant on mmc devices. Substantially it re-uses the logic from the NAND implementation, that means using an incremental counter for marking newer data. Signed-off-by: Michael Heimpold <mhei@heimpold.de>
2013-05-01sandbox: Switch over to generic boardSimon Glass
Add generic board support for sandbox. and remove the old board init code. Select CONFIG_SYS_GENERIC_BOARD for sandbox now that this is supported. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@ti.com>
2013-05-01Merge branch 'microblaze' of git://www.denx.de/git/u-boot-microblazeTom Rini
2013-04-30watchdog: Add support for Xilinx Microblaze watchdogMichal Simek
Watchdog can be used on Microblaze, PPC and Zynq hw designs. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30microblaze: Disable all cpu features before resetMichal Simek
Fix microblaze soft reset function and disable all cpu features. Especially disable caches because IRQs were off by disable_interrupts(). Reported-by: John Williams <john.williams@xilinx.com> Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-04-30microblaze: Fix reset functionMichal Simek
Remove CONFIG_SYS_RESET_ADDRESS macro. It was there from historical point of view when soft reset was just jump to u-boot text start (not used right now). Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-04-22ppc4xx: Add lcd4_lwmon5 supportStefan Roese
This patch adds the fast booting LWMON5 derivat "lcd4_lwmon5". Its a stripped down version of the full blown lwmon5 support, without ECC, USB, POST and some other stuff. It used the newly introduced SPL infrastrucure for SPL from NOR flash booting on the PPC4xx. By setting the environment variable "boot_os" to "yes", Linux will be started from the SPL version. If not, the "normal" U-Boot will be started. Signed-off-by: Stefan Roese <sr@denx.de>
2013-04-17exynos: fdt: Add TMU node for snowSimon Glass
Snow is missing a TMU node, and with TMU support this is not allowed, so it fails to boot. Add it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-04-17Exynos5: Add support for USB download boot modeVivek Gautam
Exynos5250 supports secondary USB device boot mode. If the iROM fails to download u-boot from the primary boot device (such as SD or eMMC), it will try to retrieve from the secondary boot device (such as USB). Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-04-15Tegra: T30: Beaver board support.Tom Warren
Beaver is a Tegra30 board that is nearly 100% compatible w/Cardhu. Add a Beaver build so it can begin to be differentiated, if need be. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-15Tegra: Split tegra_get_chip_type() into soc & sku funcsTom Warren
As suggested by Stephen Warren, use tegra_get_chip() to return the pure CHIPID for a Tegra SoC (i.e. 0x20 for Tegra20, 0x30 for Tegra30, etc.) and rename tegra_get_chip_type() to reflect its true function, i.e. tegra_get_chip_sku(), which returns an ID like TEGRA_SOC_T25, TEGRA_SOC_T33, etc. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-15Tegra: All Tamonten-derived boards use onboard NANDThierry Reding
Move the nand-controller node to the tegra20-tamonten.dtsi so that it can be shared between all derived boards. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-04-14smdk5250, snow: convert to CONFIG_SPL_MAX_FOOTPRINTAlbert ARIBAUD
This target wants to check full SPL size, BSS included. Remove CONFIG_SPL_MAX_SIZE definition and instead define CONFIG_SPL_MAX_FOOTPRINT. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-04-14da850evm, da850_am18xxevm: convert to CONFIG_SPL_MAX_FOOTPRINTAlbert ARIBAUD
2013-04-14cam_enc_4xx: convert to CONFIG_SPL_MAX_FOOTPRINTAlbert ARIBAUD
2013-04-13ARM: Fix __bss_start and __bss_end in linker scriptsAlbert ARIBAUD
Commit 3ebd1cbc introduced compiler-generated __bss_start and __bss_end__ and commit c23561e7 rewrote all __bss_end__ as __bss_end. Their merge caused silent and harmless but potentially bug-inducing clashes between compiler- and linker- generated __bss_end symbols. Make __bss_end and __bss_start compiler-only, and create __bss_base and __bss_limit for linker-only use. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reported-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: drivers/video/exynos_fb.c
2013-04-12Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-04-12arm: Make all linker scripts compatible with per-symbol sectionsBenoît Thébaudeau
Let all ARM linker scripts handle properly -ffunction-sections and -fdata-sections. This will be useful for future changes in order to create symbol-specific sections in common .S files. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: Remove support for smdk6400Benoît Thébaudeau
The migration of boards from Makefile to boards.cfg was due for v2012.03, but smdk6400 did not follow, and it does not build, so move it to scrapyard. It will still be possible to restore it from the Git history before fixing it. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: Remove unused relocate_code() parametersBenoît Thébaudeau
Commit e05e5de7fae5bec79617e113916dac6631251156 made the 2 1st parameters of ARM's relocate_code() useless since it moved the code handling them to crt0.S. So, drop these parameters. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12nand: mxc: Switch NAND SPL to generic SPLBenoît Thébaudeau
This also fixes support for mx31pdk and tx25, which had been broken by commit e05e5de7fae5bec79617e113916dac6631251156. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Acked-by: Scott Wood <scottwood@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-12arm: relocate_code(): Use __image_copy_end for end of relocationBenoît Thébaudeau
Use __image_copy_end instead of __bss_start for the end of the image to relocate. This is the same as commit 033ca72, but applied to all ARM start.S. This is a more appropriate symbol naming for an image copy & relocate feature, and this also saves a useless copy of data put between __image_copy_end and __bss_start in linker scripts (e.g. relocation information, or MMU initialization tables used only before jumping to the relocated image). Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12imx: mx53ard: Add support for NAND FlashBenoît Thébaudeau
Add support for the Samsung K9LAG08U0M NAND Flash (2-GiB MLC NAND Flash, 2-kiB pages, 256-kiB blocks, 30-ns R/W cycles, 1 CS) on mx53ard. eNFC_CLK_ROOT is set up with a cycle time of 37.5 ns (400 MHz / 3 / 5) for this board, which satisfies the 30-ns NF R/W cycle requirement. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-04-10omap5912-osk: Fix device initialisationJon Hunter
In the current u-boot, the device pin multiplexing and clock initialisation needs to be early during the boot process and before board_init() is called. U-boot is currently crashing on this board because this is not being done early enough. Therefore, add a s_init() function for the omap5912-osk board to do this. Also fix the stack pointer so that it is pointing to the end of the internal RAM and not the beginning as this was also causing the device to crash. Signed-off-by: Jon Hunter <jon-hunter@ti.com>
2013-04-10omap5912-osk: Fix booting from NOR flashJon Hunter
The omap5912-osk board is using a RAM based address as the linker location for code. This is causing several problems when attempting to run the latest u-boot code base on this board from flash. Update the default linker location for code to be in NOR flash at address 0x00000000. The omap5912-osk board only has 32MB of RAM and so fix the comment in the omap5912-osk config.mk file as well. Signed-off-by: Jon Hunter <jon-hunter@ti.com>
2013-04-10omap5912-osk: Fix DRAM initialisationJon Hunter
The size of the DRAM for the omap5912-osk board is getting setup in the dram_init() function. However, for the current u-boot release this is too late and needs to be done in dram_init_banksize(). Therefore, add a dram_init_banksize() function for the omap5912-osk board and setup the DRAM size there. Signed-off-by: Jon Hunter <jon-hunter@ti.com>
2013-04-10am335x: Update timings for the beaglebone againTom Rini
After further testing we can run DDR at 400MHz so update the timings again. Tested-by: Koen Kooi <koen@dominion.thruhere.net> Signed-off-by: Tom Rini <trini@ti.com>
2013-04-10nand: Extend nand_(read|write)_skip_bad with *actual and limit parametersTom Rini
We make these two functions take a size_t pointer to how much space was used on NAND to read or write the buffer (when reads/writes happen) so that bad blocks can be accounted for. We also make them take an loff_t limit on how much data can be read or written. This means that we can now catch the case of when writing to a partition would exceed the partition size due to bad blocks. To do this we also need to make check_skip_len count not just complete blocks used but partial ones as well. All callers of nand_(read|write)_skip_bad are adjusted to call these with the most sensible limits available. The changes were started by Pantelis and finished by Tom. Signed-off-by: Pantelis Antoniou <panto@antoniou-consulting.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-04-08ARM: OMAP5: Rename omap5_evm to omap5_uevmSRICHARAN R
The omap5-uevm is the reference board name for OMAP5 soc based platform. So rename it accordingly. Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Sricharan R <r.sricharan@ti.com> Tested-by: Nishanth Menon <nm@ti.com>
2013-04-08omap2420-h4: Fix booting from NOR flashHunter, Jon
The omap2420-h4 board is using a RAM based address as the linker location for code. This is causing several problems when attempting to run the latest u-boot code base on this board from flash. Update the default linker location for code to be in NOR flash. Please note that OMAP maps the NOR flash to address 0x08000000 by default and so use this as the default address for the NOR flash. Also remove legacy code that attempts to calculate where in flash the sdata structure, that holds the memory interface configuration data, is located. By changing the default linker location for code to flash this is no longer necessary. Signed-off-by: Jon Hunter <jon-hunter@ti.com>
2013-04-08omap2420-h4: Fix DRAM initialisationHunter, Jon
The size of the DRAM for the omap2420-h4 board is getting setup in the dram_init() function. However, for the current u-boot release this is too late and needs to be done in dram_init_banksize(). Therefore, add a dram_init_banksize() function for the omap2420-h4 board and setup the DRAM size there. Signed-off-by: Jon Hunter <jon-hunter@ti.com>
2013-04-08asm/omap_gpmc.h: consolidate common definesAndreas Bießmann
arch/arm/include/asm/arch-am33xx/omap_gpmc.h and arch/arm/include/asm/arch-omap3/omap_gpmc.h are almost the same, consolidate the common parts into a new header. Introduce a new asm/omap_gpmc.h which defines the command part and pulls in the architecture specific one. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-08pcm051: Enable DDR PHY dynamic power down bitLars Poeschel
This is done already for am335x in 59dcf970d11ebff5d9f4bbbde79fda584e9e7ad4 and also applies for pcm051. It powers down the IO receiver when not performing read which helps reducing the overall power consuption in low power states (suspend/standby). Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
