path: root/board
2009-03-29NetStar: add RTC supportLadislav Michl
Add RTC support. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2009-03-29NetStar: use generic flash driverLadislav Michl
2009-03-29NetStar: update crcit utilityLadislav Michl
Make crc32 function to match its prototype. Use more meaningful identifiers. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2009-03-29VCMA9: fix compile errorsWolfgang Denk
Fix these: cmd_vcma9.c:82: warning: implicit declaration of function 'eth_getenv_enetaddr' cmd_vcma9.c:89: error: 'enetaddr' undeclared (first use in this function) Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-28Fix implicit declaration of function 'eth_[gs]etenv_enetaddr'Wolfgang Denk
...and some other compile warnings. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-27karef/metrobox/xpedite1k: fix eth_setenv_enetaddr typosMike Frysinger
The function is called "eth_setenv_enetaddr", not "eth_putenv_enetaddr". Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-27ppc: cleanup compiler errors/warningsHeiko Schocher
Current u-boot top of tree builds with warnings/errors for the following boards: ads5121 cpci5200 mecp5200 v38b IAD210 MBX MBX860T NX823 RPXClassic debris PN62 following patch solves this. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-03-26Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-03-26Merge branch 'master' of git://git.denx.de/u-boot-at91Wolfgang Denk
2009-03-26ppc4xx: Sequoia: Fix TLB reassignment in NAND booting codeStefan Roese
This patch fixes a bug in the Sequoia TLB init code to reconfigure the correct TLB (boot space) after running from RAM. This bug was introduced with patch 4d332dbeb08f5863d1ea69d91a00c5499d3a87ed [ppc4xx: Make Sequoia boot vxWorks] which changed the order of the TLB in the Sequoia init.S file. Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-25Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2009-03-24Blackfin: bf537-stamp: split post code out into dedicated post.cMike Frysinger
2009-03-24Blackfin: add support for S25FL128 partsMike Frysinger
2009-03-24Blackfin: overhaul SPI flash handling to speed things upMike Frysinger
2009-03-24Blackfin: add support for SST SPI flashesMike Frysinger
2009-03-24Blackfin: add hack for crappy m25p80Mike Frysinger
2009-03-24Blackfin: bf537-stamp: rewrite MAC-in-flash handlingMike Frysinger
Use the common net eth functions to setup the env/global data with the MAC address, and properly handle the case where CONFIG_SYS_NO_FLASH is defined. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-24Blackfin: bf533-stamp: rewrite startup LED notificationsMike Frysinger
Again, don't clobber pins that we aren't actually using, and use the common LED framework rather than our own hob-job-but-not-really-working. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-23Add multi-chip NAND support for the TQM8548 modulesWolfgang Grandegger
This patches configures the NAND UPM-FSL driver with multi-chip support for the Micron MT29F8G08FAB NAND flash memory on the TQM8548 modules. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-23Add wait flags to support board/chip specific delaysWolfgang Grandegger
The NAND flash on the TQM8548_BE modules requires a short delay after running the UPM pattern like the MPC8360ERDK board does. The TQM8548_BE requires a further short delay after writing out a buffer. Normally the R/B pin should be checked, but it's not connected on the TQM8548_BE. The corresponding Linux FSL UPM driver uses similar delay points at the same locations. To manage these extra delays in a more general way, I introduced the "wait_flags" field allowing the board-specific driver to specify various types of extra delay. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-23Add multi chip support to the FSL-UPM driverWolfgang Grandegger
This patch adds support for multi-chip NAND devices to the FSL-UPM driver. The "dev_ready" callback of the "struct fsl_upm_nand" is now called with the argument "chip_nr" to allow testing the proper chip select line. The NAND support of the MPC8360ERDK is updated as well. No other boards are currently using the FSL UPM driver. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-23Blackfin: kill off LDR jump blockMike Frysinger
The Boot ROM uses EVT1 as the entry point so set that rather than having to use a tiny jump block in the default EVT1 location. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-23Blackfin: bf537-stamp: move CONFIG_POST handling to COBJS-$(...)Mike Frysinger
2009-03-23Merge branch 'mimc200'Haavard Skinnemoen
2009-03-22at91: Support for the at91sam9g20 : Atmel 400Mhz ARM 926ej-s SOC.Nicolas Ferre
AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed. The AT91SAM9G20-EK board is an updated revision of the AT91SAM9260-EK board. It is essentially the same, with a few minor differences. Here is the chip page on Atmel website: http://www.atmel.com/dyn/products/product_card.asp?part_id=4337 Signed-off-by: Justin Waters <justin.waters@timesys.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-03-22cmc_pu2: fix implicit declaration of function 'eth_setenv_enetaddr'Jean-Christophe PLAGNIOL-VILLARD
2009-03-22cmc_pu2: fix misc_init_r prototypeJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move nand drivers to drivers/mtd/nandJean-Christophe PLAGNIOL-VILLARD
2009-03-22atmel/at91/boards: compile dataflash partition only when dataflash isJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common macb initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common usb host initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common led management to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common spi initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-22at91sam9/at91cap: move common serial initialisation to cpuJean-Christophe PLAGNIOL-VILLARD
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-03-20Add support for the digsy MTC board.Grzegorz Bernacki
This is the InterControl custom device based on the MPC5200B chip. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2009-03-20ppc4xx: Use correct io accessors for esd 405/440 boardsMatthias Fuchs
This patch replaces in/out8/16/32 macros by in/out_8/_be16/_be32 macros. Also volatile pointer references are replaced by the new accessors. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: Use correct io accessors for esd 405 boardsMatthias Fuchs
2009-03-20ppc4xx: Cleanup linker scripts of esd 4xx boardsMatthias Fuchs
2009-03-20ppc4xx: Update TEXT_BASE for DASA_SIM boardsMatthias Fuchs
Fix building DASA_SIM boards by increasing U-Boot's size in flash. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20ppc4xx: DU405 maintenance fixMatthias Fuchs
-strip unused features -fix resetting phy Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-20Move ali512x.hGraeme Russ
Moved ali512x.h from include/asm-i386/ic/ to /include Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-03-20Rename SC520 Configuration OptionsGraeme Russ
Options are now all uniformly CONFIG_SYS_SC520_<option> Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
2009-03-20boards: get mac address from env and move load_sernum_ethaddr() to board initMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Rather than have common ppc code call a board-specific function like load_sernum_ethaddr(), have each board call it in its own board-specific misc_init_r() function. The boards that get converted here are: - kup4k/kup4x - pcs440ep - tqm8xx Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Stefan Roese <sr@denx.de>
2009-03-20cmc_pu2: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Also rename load_sernum_ethaddr() to misc_init_r() so we don't need to handle this board specially in common ARM code. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20boards: move board_get_enetaddr() into board-specific initMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Rather than have the common ppc code have board-specific hooks, move the board_get_enetaddr() function into the board-specific init functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20nx823: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. For the nx823, the serial number is moved out of load_sernum_ethaddr() and into misc_init_r() as is the env setup. This lets us kill off the former function in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20boards: get mac address from environmentMike Frysinger
The boards that get converted here to use the environment for the mac address rather than global data: debris mgcoge mgsuvd muas3001 netstal pn62 sixnet vcma9 xilinx (the ones that use xilinx_enet) Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Sangmoon Kim <dogoil@etinsys.com> CC: Heiko Schocher <hs@denx.de> CC: David Mueller <d.mueller@elsoft.ch> CC: Niklaus Giger <niklaus.giger@netstal.com> CC: Wolfgang Grandegger <wg@denx.de> CC: Dave Ellis <DGE@sixnetio.com> CC: Ricardo Ribalda <ricardo.ribalda@uam.es>
2009-03-20AmigaOneG3SE/enet: get mac address from environmentMike Frysinger
Always use the MAC address that is stored in the environment first before falling back to the ROM. This also cuts out any comparison steps: if the mac in the env is sane, the ROM is never consulted. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Thomas Frieden <ThomasF@hyperion-entertainment.com> CC: Ben Warren <biggerbadderben@gmail.com>
