2005-08-31 | Fix problems with ld version 2.16 (dot outside sections problem) | Wolfgang Denk | |
Pointed out by Gerhard Jaeger, 31 Aug 2005; cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html | |||
2005-08-30 | Add keyboard and dot matrix display support for HMI1001 board. | Wolfgang Denk | |
2005-08-23 | Merge with testing-4xx_enet (Create generic 4xx Ethernet code) | Wolfgang Denk | |
2005-08-22 | Add esd cpci5200 and pf5200 boards | Stefan Roese | |
Patch by Reinhard Arlt, 22 Aug 2005 | |||
2005-08-19 | Initialize serial# and ethaddr from manufacturer data in EEPROM on CMC-PU2 | Wolfgang Denk | |
Patch by Martin Krause, 08 Jun 2005 | |||
2005-08-19 | Add new board specific commands for TQM5200/STK52XX | Wolfgang Denk | |
- Sound commands (beep, wav, sound) - Test commands (led, can, backlight, rs232) Patch by Martin Krause, 02 May 2005 | |||
2005-08-19 | Add automatic HW detection for another CMC_PU2 variant | Wolfgang Denk | |
Patch by Martin Krause, 20 Apr 2005 | |||
2005-08-18 | Fix initialization problem on TQM5200 without SM501 | Wolfgang Denk | |
Patch by Martin Krause, 8 Apr. 2005 | |||
2005-08-16 | Merged 405gp_enet.c and 440gx_enet.c to generic 4xx_enet.c | Stefan Roese | |
now handling all 4xx cpu's. Patch by Stefan Roese, 16 Aug 2005 | |||
2005-08-16 | Merge with pollux.denx.org:/home/git/u-boot/.git | ||
2005-08-16 | Enable PCI on hmi1001 board | Wolfgang Denk | |
2005-08-15 | Coding style cleanup | Wolfgang Denk | |
2005-08-15 | Add support for Silicon Turnkey eXpress XTc (mpc87x/88x) board. | Wolfgang Denk | |
Patch by Dan Malek and Pantelis Antoniou, 15 Aug 2005 | |||
2005-08-15 | Add Sandburst Metrobox and Sandburst Karef board support packages. | Stefan Roese | |
Second serial port on 440GX now defined as a system device. Add 'Short Etch' code for Cicada PHY within 440gx_enet.c Patch by Travis B. Sawyer, 12 Jul 2005 Check return value of malloc in 440gx_enet.c Patch by Travis B. Sawyer, 18 Jul 2005 | |||
2005-08-13 | Code cleanup. | Wolfgang Denk | |
2005-08-12 | Remove stale file entry | Wolfgang Denk | |
2005-08-12 | Minor code cleanup | Wolfgang Denk | |
2005-08-12 | Add forgotten new fils from latest VoiceBlue update | Wolfgang Denk | |
2005-08-12 | Fix Murray Jensen's mail address. | Wolfgang Denk | |
Patch by Murray Jensen, 30 Jun 2005 | |||
2005-08-12 | VoiceBlue update: eeprom tool can also store firmware version now. | Wolfgang Denk | |
eeprom.bin is runable by jumping at load address. Patch by Ladislav Michl, 23 May 2005 | |||
2005-08-12 | esd PCI405 board updated | Stefan Roese | |
Patch by Matthias Fuchs, 28 Jul 2005 | |||
2005-08-12 | esd WUH405 and DU405 board updated | Stefan Roese | |
Patch by Matthias Fuchs, 27 Jul 2005 | |||
2005-08-12 | Merge with pollux.denx.org:/home/git/u-boot/.git | ||
2005-08-12 | Merge with /home/wd/git/u-boot/masterLABEL_2005_08_12_0050 | Wolfgang Denk | |
2005-08-11 | Update AMCC Yosemite to get a consistent setup for all AMCC eval | Stefan Roese | |
boards (baudrate, environment...). Flash driver fixed. Patch by Stefan Roese, 11 Aug 2005 | |||
2005-08-11 | Add NAND FLASH support for AMCC Bamboo 440EP eval board | Stefan Roese | |
2005-08-11 | O2DNT: added hardware flash protect support, macros cleanup. | ||
2005-08-10 | Add configuration for IFM AEV FIFO board. | Wolfgang Denk | |
Minor coding style cleanup. | |||
2005-08-09 | O2DNT platform specific code. | ||
2005-08-08 | Add common (with Linux) MTD partition scheme and "mtdparts" command | Wolfgang Denk | |
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning. | |||
2005-08-08 | Fix build problems for PM856 Board | Wolfgang Denk | |
2005-08-06 | Add support for Altera NIOS DK1C20 board | Wolfgang Denk | |
Patch by Shlomo Kut, 13 Dec 2004 | |||
2005-08-06 | Add support for ep8248 board | Wolfgang Denk | |
Patch by Yuli Barcohen, 12 Dec 2004 Minor code cleanup. | |||
2005-08-05 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-08-05 | Merge with /home/wd/git/u-boot/jon_loeliger | Wolfgang Denk | |
2005-08-05 | Add support for MicroSys PM856 board | Wolfgang Denk | |
Patch by Josef Wagner, 03 Aug 2005 | |||
2005-08-05 | Minor fixes to PM854 board | Wolfgang Denk | |
2005-08-05 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2005-08-04 | Add support for AMCC Bamboo PPC440EP eval board | Stefan Roese | |
Patch by Stefan Roese, 04 Aug 2005 | |||
2005-08-04 | (re)enabled scsi commands do_scsi() and do_scsiboot() | Wolfgang Denk | |
Patch by Denis Peter, 06 Dec 2004 | |||
2005-08-03 | Cleanup build problems (on Fedora Core x86_64 build host) | Wolfgang Denk | |
2005-08-02 | Merge with rsync://git-user@source.denx.net/git/u-boot.git | Jon Loeliger | |
2005-08-02 | Coding style cleanup | Wolfgang Denk | |
2005-08-02 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-08-01 | Fix style issues primarily in 85xx and 83xx boards. | Jon Loeliger | |
- C++ comments - Trailing white space - Indentation not by TAB - Excessive amount of empty lines - Trailing empty lines | |||
2005-08-01 | Major cleanup for AMCC PPC4xx eval boards. | Stefan Roese | |
Patch by Stefan Roese, 01 Aug 2005 | |||
2005-08-01 | Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone. | Stefan Roese | |
Patch by Steven Blakeslee, 27 Jul 2005 | |||
2005-07-31 | Minor fixes for PPChameleon Board: | Wolfgang Denk | |
* fix alignment of NAND size * make code do what the comment says | |||
2005-07-30 | Implement h/w sector protection status synchronization at boot. | Wolfgang Denk | |
The code is provided for, and was tested on, the Yukon/Alaska and PM520 boards only. A bug in flash_real_protect() for the Yukon board was fixed by adding a function that tells if two banks are on one flash chip. | |||
2005-07-29 | * Patch by Ron Alder, 11 July 2005 | Lunsheng Wang | |
Add Xianghua Xiao and Lunsheng Wang's support for the GDA MPC8540 EVAL board. |
