This board is the only board that still sticks to OneNAND IPL.
Remove this board, since we have SPL around for a while and
OneNAND is well supported in the SPL framework. The board can
be revived if necessary.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Tom Rini <trini@ti.com>
After removing the Apollon board, remove the OneNAND IPL too.
There are no users for it any more.
Cc: Minkyu Kang <promsoft@gmail.com>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
This commit enables multibus handling at Samsung's Trats development board.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Heiko Schocher <hs@denx.de>
Support for multiple soft I2C buses.
Multibus I2C support is achieved by defining get_multi_{sda|scl}_pin
functions to switch between multiple "soft" I2C buses.
Common definition of I2C_X I2C buses is provided at <i2c.h>.
TEST HW:
Samsung's Exynos4210 evt.0.1 - Trats development board
This patch is derived from an older patch provided by atmel in its
buildroot-avr32-v3.0.0.tar.bz2
cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Move board specific function to board_init function in board/ folder
Remove externs from generic board.c
Use board_init_f function in board.c file.
Acked-by: Stephan Linz <linz@li-pro.net>
* 'master' of git://git.denx.de/u-boot-usb:
MUSB driver: Timeout is never detected as the while loop does not end
usb: fix ulpi_set_vbus prototype
pxa25x: Add UDC registers definitions
USB: Fix strict aliasing in ohci-hcd
usb: Optimize USB storage read/write
ehci: Optimize qTD allocations
usb_stor_BBB_transport: Do not delay when not required
usb_storage: Remove EHCI constraints
usb_storage: Restore non-EHCI support
ehci-hcd: Boost transfer speed
ehci: cosmetic: Define used constants
ehci: Fail for multi-transaction interrupt transfers
arm:trats: Enable g_dnl composite USB gadget with embedded DFU function on TRATS
arm:trats: Support for USB UDC driver at TRATS board.
dfu:cmd: Support for DFU u-boot command
dfu: MMC specific routines for DFU operation
dfu: DFU backend implementation
dfu:usb: DFU USB function (f_dfu) support for g_dnl composite gadget
dfu:usb: Support for g_dnl composite download gadget.
ehci: cosmetic: Define the number of qt_buffers
* 'agust@denx.de' of git://git.denx.de/u-boot-staging:
tx25: Use generic gpio_* calls
config: Always use GNU ld
tools: add kwboot binary to .gitignore file
fdt: Include arch specific gpio.h instead of asm-generic/gpio.h
serial: CONSOLE macro is not used
board/karo/tx25/tx25.c
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Tested-by: voice.shen@atmel.com
A lot of at91 boards have the console_init_f in board_init. This is useless
cause it was called before by generic code in lib/board.c.
cc: Jens Scharsig <esw@bus-elektronik.de>
cc: Stelian Pop <stelian@popies.net>
cc: Sedji Gaouaou<sedji.gaouaou@atmel.com>
cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
cc: Eric Benard <eric@eukrea.com>
Acked-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
Tested-by: Jens Scharsig (BuS Elektronik) <esw@bus-elektronik.de>
fix a bug:
when not boot from NAND, the NAND flash can not be detected.
Using this to fix it
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Support for USB UDC driver at trats board.
The cache snooping feature of Freescale's eSDHC IP is not available on i.MX, so
disable it globally for this architecture. This avoids setting no_snoop for all
i.MX boards, and it prevents setting a reserved bit of a reserved register if
fsl_esdhc_mmc_init() is used on i.MX, like in
arch/arm/cpu/armv7/imx-common/cpu.c/cpu_mmc_init().
Since no_snoop was only used on i.MX, get rid of it BTW.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Kim Phillips <kim.phillips@freescale.com>
The macro to get the gpio number id was renamed to
IMX_GPIO_NR as in kernel. Fix the wrong name in efika.
CC: Matt Sealey <matt@genesi-usa.com>
Acked-by: Matt Sealey <matt@genesi-usa.com>
Signed-off-by: Ashok Kumar Reddy <ashokkourla2000@gmail.com>
production U-Boot
We have no idea where the DCD was derived from for Smartbook support, but they
differ from the Smarttop settings, MX51EVK settings and certainly don't
correspond to any shipped or development version of U-Boot that Genesi has ever
had on any Smartbook.
So, copy the calibrated, verified settings from the U-Boot as shipped with every
Smartbook since retail production. Remove those few settings that just set the
POR defaults which have already been confirmed for the previous Smarttop DCD
change.
One of the lines is specific to i.MX51 TO3 designs and therefore TO2 Smartbooks
will possibly not work so reliably with this new DCD; that said, TO2 Smartbooks
basically don't exist at retail and the number of units in the world is less
than 5 (3 of which are at the Genesi office or owned by Genesi employees).
Many hours of memory testing confirms the new settings are stable.
Patch v2:
* picked the correct commit from our development tree, correcting tuned DDR ODF setting
(which was correct anyway)
Signed-off-by: Matt Sealey <matt@genesi-usa.com>
This is a rework of a previously submitted patchset and bundles the
main board support and USB support into a single commit.
It requires the patch "mx5: add iomux-mx51.h include"
* Use iomux-mx51.h include to simplify board configuration.
* Simplify LED support (remove efikamx_toggle_led, change lit LEDs).
* Simplify MMC support for CD and WP pin differences.
* Fix broken CPU voltage setting - comment said 1.1V but the code set to
1.2V. It should never have been set to 1.2V even on i.MX51 TO2 and
all available Linux kernels would drop the voltage to 1.1V anyway and
work reliably. This should lower power consumption during the boot
process.
* Function renames for readability.
* Some board identification string changes to match actual product names.
* Passes checkpatch (v2)
PCBID pads seem to need time to settle due to external pulldowns, otherwise
we are reading floating GPIO pins with implicit pad pullups and get the wrong
data. However we can't "wait" at the time we need them before relocation,
since timers are not available. The time taken to get from DCD to the code
requiring the pads set seems to be more than long enough (even with caches
enabled).
We have space in the DCD due to the DDR settings changes to configure all
the pad settings we need for this, plus the LED pad settings too which
reduces the amount of code required later on.
Efika MX boards configure their DDR pad settings twice, one in the DCD generated
from imximage_*.cfg and again in init_drive_strength called before relocation.
Rather than doing this, roll the changes it makes into the DCD so DDR is set up
before a single line of code in U-Boot is run.
The settings are identical with this DCD block which is shorter (by 7 entries)
than the old one, and after the output of init_drive_strength since a lot of the
functionality in the existing DCD and init_drive_strength function was just
setting the POR defaults. This goes to explain some now-missing entries.
Several hundred rounds of mtest have been run to test the settings before and
after to confirm DDR is stable and no ill-effects have been found.
for new boards
* Move Efika MX Smarttop and Smartbook boards into a "genesi" vendor directory
* Rename efikamx -> mx51_efikamx since there is an mx53_efikamx and mx6_efikamx to come
Align the SSP clock speed with oscilator to achieve
higher transfer stability.
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
Signed-off-by: Philippe Reynes <tremyfr@yahoo.fr>
The DRAM initialization, after SPL has complete, is exactly the same
for all mxs SoCs so we should name it accordinly.
The following boards has been changed:
* apx4devkit
* m28evk
* mx28evk
* sc_sps_1
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
Each i.MX has its own gpio.h, defining the same structure.
The internal GPIO controller has the same layout
(at least for the register used by u-boot) and can be shared.
Tested-by: Matt Sealey <matt@genesi-usa.com>
This allows a watchdog reset to start the ROM's
usb/serial downloader, or boot from an sdcard.
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
usb downloader, or boot from an sdcard.
Move mx6 specific defines to arch-mx6 directory.
Instead of manipulating gpio registers directly, use the calls
from the gpio library.
Signed-off-by: Vikram Narayanan <vikram186@gmail.com>
Cc: John Rigby <jcrigby@gmail.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
The sys_proto.h functions (except the boot modes) are compatible with
i.MX233 and i.MX28 so we use 'mxs' prefix for its methods.
This patch sets UART3 and MMC channle 0 for Exynos5250 Rev 1.0
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
The patch adds the memory initialization sequence of DDR3.
Signed-off-by: Hatim Ali <hatim.rv@samsung.com>
Add new clock values for Exynos5250 Rev 1.0
Default spl/u-boot-spl.lds created by spl/Makefile resolves
the spl text load addr to 0x0. As 0x0 belongs to iROM addr so
Global variables can not be used.
Adding specific smdk5250-uboot-spl.lds makes possible to use Global Variables
in spl.
Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com>
Define table-driven configuration mechanism for SMDK5250
rather than hard-coding board initialization parameters.
Signed-off-by: Che-Liang Chiou <clchiou@chromium.org>
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org>
Move warmboot_save_sdram_params() to later in the boot sequence. This
code relies on devicetree to get the address of the memory controller
and with upcoming changes for SPL boot it gets called early in the
boot process when devicetree is not initialized yet.
Signed-off-by: Allen Martin <amartin@nvidia.com>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Tested-by: Thierry Reding <thierry.reding@avionic-design.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Don't use timer_init from tegra board.c. This comes out of arm720t
for the SPL build.
Change the mkdir commands for the object directories to be
unconditional. This fixes an issue when building for SPL where
SRCTREE and OBJTREE are the same, but $(obj) is under SPLTREE.
This is make naming consistent with the kernel and devicetree and in
preparation of pulling out the common tegra20 code.
The Raspberry Pi model B uses the BCM2835 SoC, has 256MB of RAM,
contains an SMSC 9512 USB LAN/Hub chip, and various IO connectors.
For more details, see http://www.raspberrypi.org/.
Various portions (cache enable, MACH_TYPE setup, RAM size limit, stack
relocation to top of RAM) extracted from work by:
Oleksandr Tymoshenko <gonzo@bluezbox.com>.
GPIO driver enablement by Vikram Narayanan <vikram186@gmail.com>.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Tom Rini <trini@ti.com>
Configuration in vexpress and u8500.v1 is different from what
is needed in u8500.v2. As such, card configuration specifics need
to reside in the board file rather than the driver.
Signed-off-by: John Rigby <john.rigby@linaro.org>
Signed-off-by: Mathieu Poirier <mathieu.poirier@linaro.org>
