path: root/board
2016-04-13ARM: zynq: Support systems with more memory banksMichal Simek
This is example how to change u-boot to support more memory banks read from DT. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-11rpi: remove redundant board filesStephen Warren
Now that rpi_*defconfig and Kconfig (rather than the config header file) provide the identity of the build, we don't need to separate config headers and board directories for each RPi variant. Set CONFIG_SYS_BOARD and CONFIG_SYS_CONFIG_NAME so that we can get rid of the duplication. This requires a tiny number of extra ifdefs in the config header. The only disadvantage of this approach is that the $board/$board_name environment variables aren't as descriptive as they used to be. This isn't really an issue because those only exist to allow scripts to create DTB filenames at runtime. However, the RPi board code already sets $fdtfile to something more accurate based on FW-reported board ID anyway. While at it, unify some Kconfig select options, and add a MAINTAINERS entry for bcm283x too. Partially-suggested-by: Tom Rini <trini@konsulko.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-11board: ti: am57xx: Prevent init_sata() from being called twiceRoger Quadros
init_sata() is done as part of scsi_init() in arch/arm/cpu/armv7/omap-common/sata.c so no need to duplicate it here. This seems to fix SATA problems in the kernel when CONFIG_TI_PIPE3 is configured as loadable module. Cc: Cooper Jr., Franklin <fcooper@ti.com> Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Roger Quadros <rogerq@ti.com>
2016-04-11ARM: add Raspberry Pi 3 64-bit configStephen Warren
On all Pis so far, the VC FW provides a short stub to set up the ARM CPU before entering the kernel (a/k/a U-Boot for us). This feature is not currently supported by the VC FW when booting in 64-bit mode. However, this feature will likely appear in the near future, and this U-Boot port assumes that such a feature is in place. Without that feature, or a temporary workaround described below, U-Boot will not boot. Once the VC FW does provide the ARM stub, u-boot.bin built for rpi_3 can be used drectly as kernel7.img, in the same way as any other RPi port. The following config.txt is required: # Fix mini UART input frequency, and setup/enable up the UART. # Without this option, U-Boot will not boot, even if you don't care # about the serial console. This option will always be required for # all RPi3 use-cases, unless the PL011 UART is used, which is not # yet supported by rpi_3* builds of U-Boot. enable_uart=1 # Boot in AArch64 (64-bit) mode. # It is possible that a future VC FW will remove the need for this # option, instead auto-setting 32-/64-bit mode based on the "kernel" # filename present on the SD card. arm_control=0x200 Prior to the VC FW providing the ARM boot stub, you can use the following steps to build an equivalent stub into the U-Boot binary: git clone https://github.com/swarren/rpi-3-aarch64-demo.git \ ../rpi-3-aarch64-demo (cd ../rpi-3-aarch64-demo && ./build.sh) Build U-Boot for rpi_3 in the usual way cat ../rpi-3-aarch64-demo/armstub64.bin u-boot.bin > u-boot.bin.stubbed Use u-boot.bin.stubbed as kernel7.img on the Pi SD card. In this case, the following additional entries are required in config.txt: # Tell the FW to load the kernel image at address 0, the reset vector. kernel_old=1 Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-10arm: socfpga: sockit: Use more relaxed DRAM timingsMarek Vasut
The currently present DRAM timings generated from GHRD 14.0 did not work on SoCkit rev. D because they were too tight. Load the DRAM timings from GHRD 13.0 which are more relaxed and work with SoCkit rev. D. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Chin Liang See <clsee@altera.com>
2016-04-06armv8: LS2080A: Consolidate LS2080A and LS2085AYork Sun
LS2080A is the primary SoC, and LS2085A is a personality with AIOP and DPAA DDR. The RDB and QDS boards support both personality. By detecting the SVR at runtime, a single image per board can support both SoCs. It gives users flexibility to swtich SoC without the need to reprogram the board. Signed-off-by: York Sun <york.sun@nxp.com> CC: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2016-04-06armv8: ls1043aqds: make sure fixed-link property is big endianShaohui Xie
When setting fixed-link property to DTS, the values should be converted with using cpu_to_fdt32 so that to have correct value on little endian Soc. Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-04-04Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2016-04-04block: Add support for Ceva sataMichal Simek
Initial Ceva Sata init code. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-04ARM64: zynqmp: Simplify MAINTAINERS file to support more boardsMichal Simek
Handle all Xilinx ZynqMP boards with one fragment. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04ARM64: zynqmp: Read RAM information from DTMichal Simek
Read information about memory from DT. This patch simplify life with synchronization between DT and board files. dram_init() only needs maximum RAM size below 4GB that's why please sort banks in memory node. dram_init_banksize() copies memory setup to bi_dram[]. This will avoid reading information from DT twice. Memory test start/end were changed to DDR location to let memtest still compiled. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04microblaze: Remove !OF_CONTROL code for timer and interruptMichal Simek
OF_CONTROL is enabled by default that's why this is dead code. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04ARM: zynq: Fix default ps7_init_gpl.c/h for ZYBOMichal Simek
There is incorrect setting for USB which didn't work with origin ps7_init_gpl.X files. Use default setting for Digilent Zybo projects with HDMI in PL. Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04net: gem: Allow to set the MAC from an EEPROMJoe Hershberger
Provide board specific option how to read MAC address from ROM. Do it in generic way to be reusable by differnet boards. If this is not enough board specific functions can be created. Signed-off-by: Joe Hershberger <joe.hershberger@gmail.com> # driver part Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-04-04arm: mvebu: Add basic support for Armada 375 eval board db-88f6720Stefan Roese
This patch adds basic support for the Marvell A375 eval board. Tested are the following interfaces: - I2C - SPI - SPI NOR - Ethernet (mvpp2), port 0 & 1 Currently the A375 SerDes and DDR3 init code is not intergrated. So the SPL U-Boot is not fully functional. Right now, this A375 mainline U-Boot can only be used by chainloading it via the original Marvell U-Boot. This can be done via this command: => tftpboot 00800000 a375/u-boot-dtb.bin;go 00800000 Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-04-01board: Add Qualcomm Dragonboard 410C supportMateusz Kulikowski
This commit add support for 96Boards Dragonboard410C. It is board based on APQ8016 Qualcomm SoC, complying with 96boards specification. Features (present out of the box): - 4x Cortex A53 (ARMv8) - 2x USB Host port - 1x USB Device port - 4x LEDs - 1x HDMI connector - 1x uSD connector - 3x buttons (Power, Vol+, Vol-/Reset) - WIFI, Bluetooth with integrated antenna - 8GiB eMMC U-Boot boots chained with fastboot in 64-bit mode. For detailed build instructions see readme.txt in board directory. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Tested-by: Simon Glass <sjg@chromium.org>
2016-04-01usb: Rename ehci-fsl.h to ehci-ci.hMateusz Kulikowski
Most of ehci-fsl header describe USB controller designed by Chipidea and used by various SoC vendors. This patch renames it to a generic header: ehci-ci.h Contents of file are not changed (so it contains several references to freescale SoCs). Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Simon Glass <sjg@chromium.org>
2016-04-01board: ti: DRA7: Add DP83867 TI phy for rev cDan Murphy
Enable the TI DP83867 Giga bit phy on the dra7 rev c board. The rx and tx internal delays are need for this board so the usage of RGMII_ID is required. Signed-off-by: Dan Murphy <dmurphy@ti.com> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01sniper: Change vendor name from lge to lg, matching devicetree vendor prefixPaul Kocialkowski
This moves the sniper board from the lge to lg, in order to match the devicetree vendor prefix already defined in the kernel. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-04-01kc1: Proper reboot mode and boot reason validationPaul Kocialkowski
With the previous implementation, rebooting without registering a recognized reboot mode would end up with U-Boot checking for a valid power-on reason, which might result in the device turning off (e.g. with no USB cable attached and no buttons pressed). Since this approach is not viable (breaks reboot in most cases), the validity of the reboot reason is checked (in turn, by checking that a warm reset happened, as there is no magic) to detect a reboot and the 'o' char is recognized to indicate that power-off is required. Still, that might be overridden by the detection of usual power-on reasons, on purpose. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-04-01sniper: Proper reboot mode and boot reason validationPaul Kocialkowski
With the previous implementation, rebooting without registering a recognized reboot mode (despite registering the magic) would end up with U-Boot checking for a valid power-on reason, which might result in the device turning off (e.g. with no USB cable attached and no buttons pressed). This was designed to catch reboots that are actually intended to be power-off, something that old Android kernels do, instead of properly turning the device off using the TWL4030. However, since this approach is not viable (breaks reboot in most cases), the validity of the reboot mode magic is checked to detect a reboot and the 'o' char is recognized to indicate that power-off is required. Still, that might be overridden by the detection of usual power-on reasons, on purpose. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2016-04-01rpi: BCM2837 and Raspberry Pi 3 32-bit supportStephen Warren
The Raspberry Pi 3 contains a BCM2837 SoC. The BCM2837 is a BCM2836 with the CPU complex swapped out for a quad-core ARMv8. This can operate in 32- or 64-bit mode. 32-bit mode is the current default selected by the VideoCore firmware on the Raspberry Pi 3. This patch adds a 32-bit port of U-Boot for the Raspberry Pi 3. >From U-Boot's perspective, the only delta between the RPi 2 and RPi 3 is a change in usage of the SoC UARTs. On all previous Pis, the PL011 was the only UART in use. The Raspberry Pi 3 adds a Bluetooth module which uses a UART to connect to the SoC. By default, the PL011 is used for this purpose since it has larger FIFOs than the other "mini" UART. However, this can be configured via the VideoCore firmware's config.txt file. This patch hard-codes use of the mini UART in the RPi 3 port. If your system uses the PL011 UART for the console even on the RPi 3, please use the RPi 2 U-Boot port instead. A future change might determine which UART to use at run-time, thus allowing the RPi 2 and RPi 3 (32-bit) ports to be squashed together. The mini UART has some limitations. One externally visible issue in the BCM2837 integration is that the UART divides the SoC's "core clock" to generate the baud rate. The core clock is typically variable, and under control of the VideoCore firmware for thermal management reasons. If the VC FW does modify the core clock rate, UART communication will be corrupted since the baud rate will vary from the expected value. This was not an issue for the PL011 UART, since it is fed by a fixed 3MHz clock. To work around this, the VideoCore firmware can be told not to modify the SoC core clock. However, the only way this can happen and be thermally safe is to limit the core clock to a low/minimum frequency. This leaves performance on the table for use-cases that don't care about a UART console. Consequently, use of the mini UART console must be explicitly requested by entering the following line into config.txt: enable_uart=1 A recent version of the VC firmware is required to ensure that the mini UART is fully and correctly initialized by the VC FW; at least firmware.git 046effa13ebc "firmware: arm_loader: emmc clock depends on core clock See: https://github.com/raspberrypi/firmware/issues/572". Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01rpi: add Raspberry Pi 3 board IDStephen Warren
This allows U-Boot to known the name of the board. The existing rpi_2_defconfig can operate correctly on the Raspberry Pi 3 in 32-bit mode /if/ you have configured the firmware to use the PL011 UART as the console UART (the default is the mini UART). This requires two things: a) config.txt should contain dtoverlay=pi3-miniuart-bt b) You should run the following to tell the VC FW to process DT when booting, and copy u-boot.bin.img (rather than u-boot.bin) to the SD card as the kernel image: path/to/kernel/scripts/mkknlimg --dtok u-boot.bin u-boot.bin.img This works as of firmware.git commit 046effa13ebc "firmware: arm_loader: emmc clock depends on core clock See: https://github.com/raspberrypi/firmware/issues/572". Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01rpi: use constant "unknown board" DT filenameStephen Warren
To simplify support for new SoCs, just use a constant filename for the unknown case. In practice this case shouldn't be hit anyway, so the filename isn't relevant, and certainly doesn't need to differentiate between SoCs. If a user has an as-yet-unknown board, they can override this value in the environment anyway. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-04-01sunxi: Reserve ATF memory space on A64Alexander Graf
On the A64 we usually boot with ATF running in EL3. ATF as it is available today resides in the first 16MB of RAM. So we should make sure we reserve that space in our memory maps. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-01sunxi: Add Pine64+ supportSiarhei Siamashka
The Pine64+ is a system based on the Allwinner A64 SoC. It is capable of running AArch64 code and thus is the first of its kind for the sunxi target. This patch adds a defconfig and device tree chunks for it. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> [agraf: Change patch description] Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-01sunxi: Add support for Allwinner A64 SoCsSiarhei Siamashka
The Allwinner A64 SoC is used in the Pine64. This patch adds all bits necessary to compile U-Boot for it running in AArch64 mode. Unfortunately SPL is not ready yet due to legal problems, so we need to boot using the binary boot0 for now. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> [agraf: remove SPL code, move to AArch64] Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-03-31power: axp818: Add support for FLDOsChen-Yu Tsai
The FLDOs on AXP818 PMIC normally provide power to CPUS and USB HSIC PHY on the A83T/H8. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-03-29Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2016-03-29armv8/ls2080ardb: Enable VID supportRai Harninder
This patch enable VID support for ls2080ardb platform. It uses the common VID driver. Signed-off-by: Rai Harninder <harninder.rai@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29SECURE BOOT: Change fsl_secboot_validate func to pass image addrSaksham Jain
Use a pointer to pass image address to fsl_secboot_validate(), instead of using environmental variable "img_addr". Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29SECURE BOOT: Halt execution when secure boot failSaksham Jain
In case of fatal failure during secure boot execution (e.g. header not found), reset is asserted to stop execution. If the RESET_REQ is not tied to HRESET, this allows the execution to continue. Add esbh_halt() after the reset to make sure execution stops. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: ls2080rdb: ls2080qds: Add secure boot supportSaksham Jain
Sec_init has been called at the beginning to initialize SEC Block (CAAM) which is used by secure boot validation later for both ls2080a qds and rdb. 64-bit address in ESBC Header has been enabled. Secure boot defconfigs are created for boards (NOR boot). Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-29armv8: fsl-lsch3: Add new header for secure bootSaksham Jain
For secure boot, a header is used to identify key table, signature and image address. A new header structure is added for lsch3. Currently key extension (IE) feature is not supported. Single key feature is not supported. Keys must be in table format. Hence, SRK (key table) must be present. Max key number has increase from 4 to 8. The 8th key is irrevocable. A new barker Code is used. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Saksham Jain <saksham.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-27zipitz2: enable cachesVasily Khoruzhick
It speeds up loading kernel from SD or USB a lot. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2016-03-27zipitz2: enable USB host supportVasily Khoruzhick
2016-03-27zipitz2: restore board supportVasily Khoruzhick
zipitz2 was dropped in 49d8899ba9c26335e4a12e01c18028fc5e40c796 Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
2016-03-27board: ti: am57xx: Set ethernet MAC addresses from EEPROM to envRoger Quadros
The MAC addresses for the PRU Ethernet ports will be available in the board EEPROM as an address range. Populate those MAC addresses (if valid) into the u-boot environment so that they can be passed on to the device tree during fdt_fixup_ethernet(). Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-27ARM: bcm283x: don't always define CONFIG_BCM2835Stephen Warren
Currently, CONFIG_BCM2835 is defined for all BCM283x builds and _BCM2836 is defined when building for that SoC. That means there isn't a single define that means "exactly BCM2835". This will complicate future patches where BCM2835-vs-anything-else needs to be determined simply. Modify the code to define one or the other of CONFIG_BCM2835/BCM2836 so future patches are simpler. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-27board: ti: DRA7: Add DRA72-rev C evm pinmuxNishanth Menon
Add the pinmux data for rev C evm. This is different from previous revisions of the platform thanks to the deltas introduced both from silicon side and from SoC side. Based on J6EcoES2_EVM_Base_Config-20160309b and PCT-DRA72x-v1.3.0.7 for SR2.0 silicon. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-27board: ti: DRA72: revC evm: Update sdram timing configuration for SR2.0Ravi Babu
DDR configuration has changes from SR1.1 based Rev-A/B version of evm to the SR2.0 based Rev C of the EVM. Rev C evm now uses the higher density MT41K512M8RH-125-AAT:E (IT) which is of size 2GB. Update the DDR configuration based on data from EMIF configuration tool 1.1.1. NOTE: we use eeprom information (ram_size) to update the configuration. Tested-by: Vishal Mahaveer <vishalm@ti.com> Signed-off-by: Ravi Babu <ravibabu@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-25Merge git://www.denx.de/git/u-boot-marvellTom Rini
2016-03-24armv8: ls2080a: Update fdt path for fsl-mc nodeStuart Yoder
The fsl-mc node has been moved under /soc, so update the path references accordingly. Backwards compatibility is retained for /fsl-mc. Delete backwards compatibility for the completely obsolete /fsl,dprc@0. Signed-off-by: Stuart Yoder <stuart.yoder@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-03-24arm: mvebu: db-88f6820: Drop obsolete binary.0 placeholderAndreas Färber
It has been superseded in kwbimage.cfg in favor of an SPL in commit 9e30b31d20f0b793465d07f056b3d9885f578c0d (arm: mvebu: db-88f6820: Add SPL support with DDR init code). Found via code review. Cc: Stefan Roese <sr@denx.de> Signed-off-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Stefan Roese <sr@denx.de>
2016-03-24arm: mvebu: theadorable: Add StratixV FPGA programming supportStefan Roese
This patch adds support for Altera StratixV bitstream programming. 2 FPGAs are connected to the SPI busses. This patch uses board specific write code to program the bitstream via SPI direct write mode. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Signed-off-by: Stefan Roese <sr@denx.de>
2016-03-23sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/KconfigHans de Goede
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs. This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Turn satapwr on from board_initHans de Goede
There are 2 reasons for doing this: 1) The main reason for doing this is to move it outside of board/sunxi/ahci.c, so that it can be used on boards which use a usb<->sata chip too; 2) While doing this I realized that doing it from board_init also meant doing it much earlier. Some printf get_timer(0) calls show that the time between board_init() and scsi_init() is more then 600 ms, so we can drop the mdelay(500) While at it also drop the printf("SUNXI SCSI INIT\n") AHCI init is noisy enough by itself. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Fix gmac not working due to cpu_eth_init no longer being calledHans de Goede
cpu_eth_init is no longer called for dm enabled eth drivers, this was causing the sunxi gmac eth controller to no longer work in u-boot. This commit fixes this by calling the clock, reset and pinmux setup function from s_init() and enabling the phy power pin (if any) from board_init(). The enabling of phy power cannot be done from s_init because it uses dm and dm is not ready yet at this point. Note that the mdelay is dropped as the phy gets enabled much earlier now, so it is no longer needed. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Tested-by: Karsten Merker <merker@debian.org> Tested-by: Michael Haas <haas@computerlinguist.org>
2016-03-23sunxi: Add support for USB vbus pin for USB3Hans de Goede
The H3 has USB0 - USB3, add support for having a USB vbus pin for USB3. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Add defconfig and dts for Orange Pi 2 SBCHans de Goede
The Orange Pi 2 is a SBC based on the Allwinner H3 SoC with a uSD slot, 4 USB ports connected via a USB-2 hub, a 10/100M ethernet port using the SoC's integrated PHY, Wifi via a RTL8189ETV sdio wifi chip, USB OTG, HDMI, a TRRS headphone jack for stereo out and composite out, a microphone, an IR receiver, a CSI connector, 2 LEDs, a 3 pin UART header and a 40-pin GPIO header. The added dts file is identical to the one submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
