Add support for Toardex specific config block. This data structure
is available on NAND and written at production time. Get MAC
address as well as serial number and board revision from this
structure.
This enables NAND for Colibri VF61/VF50. The environment is now
taken from NAND. The first block, the boot control block, is
definied as a seperate partition in order for easier erasing.
This adds initial support for Colibri VF61 based on Freescale
Vybrid Tower System TWR-VF65GS10:
- New Machine ID
- Default UART_A on SCI0
- FEC1
- Enabled command line editing
- PLL5 based RMII clocking (e.g. no external crystal)
- UART_A and UART_C I/O muxing
- Boot from OCRAM gfxRAM
Tested on Colibri VF61 V1.1 booting using serial loader over
UART.
Set DDR_SEL_PAD_CONTR register explicitly to DDR3 which solves DDR3
issues with newer silicon (1.1). This register was added in revision
4 of the Vybrid Reference Manual.
Commit 890880583d84607e36b52a785a96b167728bbf73 introduced EEPROM parsing and
board detection but faild to return a valid tricorder_eeprom struct for backup
case. When pressing S200 while reading EEPROM we ignore the value. We
returned falsely a tricorder_eeprom struct with uninitialized data which is
just garbage.
Initialize it by zeroing the whole structure.
Signed-off-by: Andreas Bießmann <andreas.biessmann@corscience.de>
Cc: Thomas Weber <thomas.weber@corscience.de>
During switch to device tree, commit 1ecab0f has removed this code.
INFORM4 and INFORM5 registers are used by TRATS2 first stage bootloader for
providing recovery. For normal operation, those two must be cleared out.
This error emerges when one force reset from u-boot's command line for
three times.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
arch/arm/cpu/arm926ejs/mxs/Makefile
include/configs/trats.h
include/configs/trats2.h
include/mmc.h
Get rid of double VF610_PAD_DDR_A15__DDR_A_15 iomux configuration.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Avoids "could not find output section .gnu.hash" ld.bfd errors on openSUSE.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Andreas Färber <afaerber@suse.de>
Clock Manager driver will be called to reconfigure all the
clocks setting based on user input. The input are passed to
Preloader through handoff files
Signed-off-by: Chin Liang See <clsee@altera.com>
CC: Pavel Machek <pavel@denx.de>
Cc: Dinh Nguyen <dinguyen@altera.com>
Acked-by: Pavel Machek <pavel@denx.de>
arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg
arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg
Some eMMC chips may need the RST_n_FUNCTION bit set to a non-zero value
in order for warm reset of the system to work. Details on this being
required will be part of the eMMC datasheet. Also add using this
command to the dra7xx README.
* Whitespace fix by panto
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
The DRAM size can be easily detected at runtime on i.MX53. Implement
such detection on M53EVK and adjust the rest of the macros accordingly
to use the detected values.
An important thing to note here is that we had to override the function
for trimming the effective DRAM address, get_effective_memsize(). That
is because the function uses CONFIG_MAX_MEM_MAPPED as the upper bound of
the available DRAM and we don't have gd->bd->bi_dram[0].size set up at
the time the function is called, thus we cannot put this into the macro
CONFIG_MAX_MEM_MAPPED . Instead, we use custom override where we use the
size of the first DRAM block which we just detected.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
such detection on MX53QSB and adjust the rest of the macros accordingly
Add support for PCIe on MX6 SabreSDP board and enable the support
in the config file.
Cc: Liu Ying <Ying.Liu@freescale.com>
Enable USB0 clock by resetting bit 20 of MSTPCR2. Leave other bits unchanged.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
All pins should be output.
If we build this function in cases where we would be discarding it
anyhow we still end up with maybe unused warnings. Rather than litter
the function with __maybe_unused, just spell out when to build it.
CPU sets DMA buffer descriptors with data required for inetrnal DMA such as:
* Ownership of BD
* Buffer size
* Pointer to data buffer in memory
Then we need to make sure DMA engine of NAND controller gets proper data.
For this we flush buffer rescriptor.
Then we're ready for DMA transaction.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
U-Boot uses the 'mkimage' tool to produce various image types,
not only uImage image type. Rename the invocation name from
UIMAGE to MKIMAGE.
The following command was used to do the replacement:
git grep 'quiet_cmd_mkimage.* = UIMAGE' | cut -d : -f 1 | \
xargs -i sed -i "s@\(quiet_cmd_mkimage\)\(.*\) = UIMAGE @\1\2 = MKIMAGE@" {}
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
I2C protocol requires open-drain IOs. Fix the Dalmore and Venice2 pinmux
tables to configure the IOs correctly. Without this, Tegra may actively
drive the lines high while an external device is actively driving the
lines low, which can only lead to bad things.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Trivial merge conflict, needed to manually remove
local_info as per commit 41364f0f.
board/samsung/common/board.c
Add a simple LCD driver which uses SDL to display the image. We update the
image regularly, while still providing for reasonable performance.
Adjust the common lcd code to support sandbox.
For command-line runs we do not want the LCD to be displayed, so add a
--show_lcd option to enable it.
Tested-by: Che-Liang Chiou <clchiou@chromium.org>
Add board code to set up the Chrome OS EC on startup.
Add a common library for obtaining access to the Chrome OS EC. This is
used by boards which need to talk to the EC.
Reviewed-by: Vadim Bendebury <vbendeb@google.com>
Tested-by: Vadim Bendebury <vbendeb@google.com>
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
romImage is set by CONFIG_ECOVEC_ROMIMAGE_ADDR to 0xA0040000.
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for
pointing to the top of source directory.
(No difference between the two.)
In Kbuild style, $(srctree) is used for instead.
This commit renames SRCTREE to srctree and deletes the
defition of SRCTREE.
Note that SRCTREE in scripts/kernel-doc, scripts/docproc.c,
doc/DocBook/Makefile should be keep.
In Kbuild style, $(srctree) is used instead.
This commit renames TOPDIR to srctree and delete the
defition of TOPDIR.
Cc: David Updegraff <dave@cray.com>
Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
- fix: return-value of 'i2c_set_bus_speed' was interpreted wrong
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
The switch HW reset results in a disconnection of the switch port daisy-
chain for a few seconds. This is not desired in the normal field use
case. So lets remove this switch reset from the normal bootup sequence
and move it into a board specific command. This way it can be executed
in the development environment when really needed.
Cc: Roger Meier <r.meier@siemens.com>
Cc: Lukas Stockmann <lukas.stockmann@siemens.com>
This patch enables to run Trats2 board on device tree.
Signed-off-by: Piotr Wilczek <p.wilczek@samsung.com>
This patch enables to run Trats board on device tree.
CC: Lukasz Majewski <l.majewski@samsung.com>
This patch enables to run Universal board on device tree.
Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
This patch enables to run Origen board on device tree.
Uart, DRAM and MMC init functions are removed as their
generic replacements form the common board file are used.
The config file is modified to contain only board specific options.
Cc: Chander Kashyap <k.chander@samsung.com>
This patch enables sdhci initialisation and misc_init_r in common board
file for all exynos 4 based boards.
This patch moves board specific max77686 init function from
common board to smdk5250 board file.
Cc: Rajeshwari S Shinde <rajeshwari.s@samsung.com>
Cc: Rajeshwari Birje <rajeshwari.birje@gmail.com>
This patch adds common dtsi file and config header for all
Exynos 4 based boards.
Patch additionaly adds board specific (weak) functions for
board_early_init_f and board_power_init functions.
The checkboard function's implementation is common for all
DT supporting boards and should be placed in the board common file.
Cc: Amar <amarendra.xt@samsung.com>
Acked-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Gateworks Ventana is a product family based on the i.MX6. This
patch adds support for all boards in the Ventana family. Where
possible, data from the boards EEPROM is used to determine various
details about the board at runtime.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Many USB host controller drivers contain almost identical copies of the
same virtual root hub descriptors. Put these into a common file to avoid
duplication.
Note that there were some very minor differences between the descriptors
in the various files, such as:
- USB 1.0 vs. USB 1.1
- Manufacturer/Device ID
- Max packet size
- String content
I assume these aren't relevant.
Cc: Thomas Lange <thomas@corelatus.se>
Cc: Shinya Kuribayashi <skuribay@pobox.com>
Cc: Gary Jennejohn <garyj@denx.de>
Cc: Eric Millbrandt <emillbrandt@coldhaus.com>
Cc: Pierre Aubert <p.aubert@staubli.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Rodolfo Giometti <giometti@linux.it>
Cc: Zhang Wei <wei.zhang@freescale.com>
Cc: Mateusz Zalega <m.zalega@samsung.com>
Cc: Remy Bohmer <linux@bohmer.net>
Cc: Markus Klotzbuecher <mk@denx.de>
Cc: C Nauman <cnauman@diagraph.com>
Cc: David Müller <d.mueller@elsoft.ch>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Thomas Abraham <t-abraham@ti.com>
Cc: Andrew Murray <amurray@embedded-bits.co.uk>
Cc: Matej Frančeškin <matej.franceskin@comtrade.com>
Cc: Cliff Cai <cliff.cai@analog.com>
Cc: Bryan Wu <cooloney@gmail.com>
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Acked-by: Rob Herring <robh@kernel.org>
CONFIG_SYS_HZ must be always 1000, but M5271EVB.h defines it
as 1000000 and idmr.h defines it as (50000000 / 64).
When compiling these two boards, a warning message is displayed:
time.c:14:2: warning: #warning "CONFIG_SYS_HZ must be 1000
and should not be defined by platforms" [-Wcpp]
There are no board maintainers for them so this commit just
deletes them.
Cc: Jason Jin <Jason.jin@freescale.com>
Add NAND SPL boot support with hardware PMECC.
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Add SPI SPL boot support for sama5d3xek board.
Add sama5d3 Xplained board support which use Atmel SAMA5D36 SoC.
Now it supports boot from NAND flash and SD/MMC card.
Features support:
- NAND flash
- SD/MMC card
- Two USB hosts
- Ethernet (one GMAC, one EMAC)
[reorder boards.cfg]
