path: root/board
2014-08-30arm: convert Cygnus and NSP boards to KconfigSteve Rae
Convert the bcm958300k and the bcm958622hr boards from "boards.cfg" to Kconfig. Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30arm: add Cygnus and NSP boardsScott Branden
The bcm_ep board configuration is used by a number of boards including Cygnus and NSP. Add builds for the bcm958300k and the bcm958622hr boards. Signed-off-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30MAINTAINERS: change the status of vexpress board to OrphanMasahiro Yamada
The email address of Matt Waddel is no longer working. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Alexei Fedorov <alexie.fedorov@arm.com>
2014-08-30arm: bcm281xx: add board with Ethernet capabilitySteve Rae
Add board which has Broadcom StarFighter2 Ethernet capability. Signed-off-by: Steve Rae <srae@broadcom.com>
2014-08-30ARM: enable ARMv7 virt support for the Arndale boardAndre Przywara
To enable hypervisors utilizing the ARMv7 virtualization extension on the Arndale board, add the simple SMP pen address writer function and add the required configuration variables to switch all cores to HYP mode before launching the OS. This allows booting KVM and Xen directly from u-boot. Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Andre Przywara <andre.przywara@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Andre Przywara <andre.przywara@arm.com>
2014-08-30arm: ep9315: Add .vectors section to lds and remove obsolete ldsSergey Kostanbaev
However ep9315 don't use interrupt vectors during startup, but _startup symbol is used inside uboot to calculate actual monitor size. Signed-off-by: Sergey Kostanbaev <sergey.kostanbaev@gmail.com> Cc: albert.u.boot@aribaud.net
2014-08-30socfpga: initialize designware ethernetPavel Machek
Enable initialization fo designware ethernet controller. With this patch, ethernet works in my configuration, provided I set ethernet address in the environment. Signed-off-by: Pavel Machek <pavel@denx.de>
2014-08-29socfpga: Fix SOCFPGA build error for Altera dev kitChin Liang See
To fix the build error when build for Altera dev kit, not virtual target. At same time, set the build for Altera dev kit as default instead virtual target. With that, U-Boot is booting well and SPL still lack of few drivers. Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Pavel Machek <pavel@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2014-08-29Merge branch 'master' of git://git.denx.de/u-boot-tiTom Rini
2014-08-29Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2014-08-29Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-08-29Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2014-08-28Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-08-25mtd, ubi, ubifs: resync with Linux-3.14Heiko Schocher
resync ubi subsystem with linux: commit 455c6fdbd219161bd09b1165f11699d6d73de11c Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Sun Mar 30 20:40:15 2014 -0700 Linux 3.14 A nice side effect of this, is we introduce UBI Fastmap support to U-Boot. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Cc: Marek Vasut <marex@denx.de> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Scott Wood <scottwood@freescale.com> Cc: Joerg Krause <jkrause@posteo.de>
2014-08-25ARM: DRA: Enable VTT regulatorLokesh Vutla
DRA7 evm REV G and later boards uses a vtt regulator for DDR3 termination and this is controlled by gpio7_11. Configuring gpio7_11. The pad A22(offset 0x3b4) is used by gpio7_11 on REV G and later boards, and left unused on previous boards, so it is safe enough to enable gpio on all DRA7 boards. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2014-08-25am335x_evm: Convert CONFIG_CONS_INDEX into a menu choiceTom Rini
- Drop CONFIG_SERIAL[1-6] and use CONFIG_CONS_INDEX tests instead - Add choice and help text to board/ti/am335x/Kconfig - Correct comment about IDK in board/ti/am335x/mux.c - Remove am335x_evm_uart* defconfig files as they're just variations on a config option now. Signed-off-by: Tom Rini <trini@ti.com>
2014-08-25cm-t54: fix eMMC boot mode checkDmitry Lifshitz
Boot from eMMC boot partition corresponds to BOOT_DEVICE_MMC2 omap_bootmode, while BOOT_DEVICE_MMC2_2 corresponds to the user data partition boot. Fix mmc_get_env_part() boot mode check to use a correct value. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
2014-08-25cm-t54: fix EEPROM read return value checkDmitry Lifshitz
Fix cl_eeprom_read_mac_addr() return value check. Fix long line codding style issue in board_init(). Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
2014-08-25keystone2: use EFUSE_BOOTROM information to configure PLLsVitaly Andrianov
This patch reads EFUSE_BOOTROM register to see the maximum supported clock for CORE and TETRIS PLLs and configure them accordingly. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-08-25board/ti/dra7xx: add support for parallel NORpekon gupta
This patch adds support for parallel NOR device (S29GL512S10) present on J6-EVM. The Flash device is connected to GPMC controller on chip-select[0] and accessed as memory-mapped device. It has data-witdh=x16, capacity-64MBytes(512Mbits) and is CFI compatible. As multiple devices are share GPMC pins on this board, so following board settings are required to detect NOR device: SW5.1 (NAND_BOOTn) = OFF (logic-1) SW5.2 (NOR_BOOTn) = ON (logic-0) /* Active-low */ SW5.3 (eMMC_BOOTn) = OFF (logic-1) SW5.4 (QSPI_BOOTn) = OFF (logic-1) And also set appropriate SYSBOOT configurations: SW3.1 (SYSBOOT[ 8])= ON (logic-1) /* selects SYS_CLK1 speed */ SW3.2 (SYSBOOT[ 9])= OFF (logic-0) /* selects SYS_CLK1 speed */ SW3.3 (SYSBOOT[10])= ON (logic-1) /* wait-pin monitoring = enabled */ SW3.4 (SYSBOOT[11])= OFF (logic-0) /* device type: Non Muxed */ SW3.5 (SYSBOOT[12])= OFF (logic-0) /* device type: Non Muxed */ SW3.6 (SYSBOOT[13])= ON (logic-1) /* device bus-width: 1(x16) */ SW3.7 (SYSBOOT[14])= OFF (logic-0) /* reserved */ SW3.8 (SYSBOOT[15])= ON (logic-1) /* reserved */ Also, following changes are required to enable NOR Flash support in dra7xx_evm board profile:
2014-08-25board/ti/dra7xx: add support for parallel NANDpekon gupta
This patch adds support for x16 NAND device (MT29F2G16AAD) connected to GPMC chip-select[0] on DRA7xx EVM. As GPMC pins are shared by multiple devices, so in addition to this patch following board settings are required for NAND device detection [1]: SW5.9 (GPMC_WPN) = OFF (logic-1) SW5.1 (NAND_BOOTn) = ON (logic-0) /* Active-low */ SW5.2 (NOR_BOOTn) = OFF (logic-1) SW5.3 (eMMC_BOOTn) = OFF (logic-1) SW5.4 (QSPI_BOOTn) = OFF (logic-1) And also set appropriate SYSBOOT configurations SW2.1 (SYSBOOT[0]) = ON (logic-1) /* selects NAND Boot */ SW2.2 (SYSBOOT[1]) = OFF (logic-0) /* selects NAND Boot */ SW2.3 (SYSBOOT[2]) = OFF (logic-0) /* selects NAND Boot */ SW2.4 (SYSBOOT[3]) = OFF (logic-0) /* selects NAND Boot */ SW2.5 (SYSBOOT[4]) = ON (logic-1) /* selects NAND Boot */ SW2.6 (SYSBOOT[5]) = ON (logic-1) /* selects NAND Boot */ SW2.7 (SYSBOOT[6]) = OFF (logic-0) /* reserved */ SW2.8 (SYSBOOT[7]) = OFF (logic-0) /* reserved */ SW3.1 (SYSBOOT[ 8])= ON (logic-1) /* selects SYS_CLK1 speed */ SW3.2 (SYSBOOT[ 9])= OFF (logic-0) /* selects SYS_CLK1 speed */ SW3.3 (SYSBOOT[10])= ON (logic-1) /* wait-pin monitoring = enabled */ SW3.4 (SYSBOOT[11])= OFF (logic-0) /* device type: Addr/Data Muxed */ SW3.5 (SYSBOOT[12])= ON (logic-1) /* device type: Addr/Data Muxed */ SW3.6 (SYSBOOT[13])= ON (logic-1) /* device bus-width: 1(x16) */ SW3.7 (SYSBOOT[14])= OFF (logic-0) /* reserved */ SW3.8 (SYSBOOT[15])= ON (logic-1) /* reserved */ Following changes are required in board.cfg to enable NAND on J6-EVM:
2014-08-25board/ti/am43xx: add support for parallel NANDpekon gupta
This patch adds support for NAND device connected to GPMC chip-select on following AM43xx EVM boards. am437x-gp-evm: On this board, NAND Flash signals are muxed with eMMC, thus at a time either eMMC or NAND can be enabled. Selection between eMMC and NAND is controlled by: (a) Statically using Jumper on connecter (J89) present on board. (a) If Jumper on J89 is NOT used, then selection can be dynamically controlled by driving SPI2_CS0[MUX_MODE=GPIO] pin via software: SPI2_CS0 == 0: NAND (default) SPI2_CS0 == 1: eMMC am43x-epos-evm: On this board, NAND Flash control lines are muxed with QSPI, Thus only one of the two can be used at a time. Selection is controlled by: (a) Dynamically driving following GPIO pin from software GPMC_A0(GPIO) == 0 NAND is selected (default) NAND device (MT29F4G08AB) on these boards has: - data-width=8bits - blocksize=256KB - pagesize=4KB - oobsize=224 bytes For above NAND device, ROM code expects the boot-loader to be flashed in BCH16 ECC scheme for NAND boot, So by default BCH16 ECC is enabled for AM43xx EVMs. Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-08-25board/ti/am335x: add support for beaglebone NOR Capepekon gupta
This patch adds support of NOR cape[1] for both Beaglebone (white) and Beaglebone(Black) boards. NOR Flash on this cape is connected to GPMC chip-select[0] and accesses as external memory-mapped device. This cape has 128Mbits(16MBytes), x16, CFI compatible NOR Flash device. As GPMC chip-select[0] can be shared by multiple capes so NOR profile is not enabled by default in boards.cfg. Following changes are required to enable NOR cape detection when building am335x_boneblack board profile. Signed-off-by: Tom Rini <trini@ti.com>
2014-08-25board/ti/am335x: add support for beaglebone NAND capepekon gupta
Beaglebone Board can be connected to expansion boards to add devices to them. These expansion boards are called 'capes'. This patch adds support for following versions of Beaglebone(AM335x) NAND capes (a) NAND Device with bus-width=16, block-size=128k, page-size=2k, oob-size=64 (b) NAND Device with bus-width=16, block-size=256k, page-size=4k, oob-size=224 Further information and datasheets can be found at [1] and [2] * How to boot from NAND using Memory Expander + NAND Cape ? * - Important: As BOOTSEL values are sampled only at POR, so after changing any setting on SW2 (DIP switch), disconnect and reconnect all board power supply (including mini-USB console port) to POR the beaglebone. - Selection of ECC scheme for NAND cape(a), ROM code expects BCH8_HW ecc-scheme for NAND cape(b), ROM code expects BCH16_HW ecc-scheme - Selction of boot modes can be controlled via DIP switch(SW2) present on Memory Expander cape. SW2[SWITCH_BOOT] == OFF follow default boot order MMC-> SPI -> UART -> USB SW2[SWITCH_BOOT] == ON boot mode selected via DIP switch(SW2) So to flash NAND, first boot via MMC or other sources and then switch to SW2[SWITCH_BOOT]=ON to boot from NAND Cape. - For NAND boot following switch settings need to be followed SW2[ 1] = OFF (SYSBOOT[ 0]==1: NAND boot mode selected ) SW2[ 2] = OFF (SYSBOOT[ 1]==1: -- do -- ) SW2[ 3] = ON (SYSBOOT[ 2]==0: -- do -- ) SW2[ 4] = ON (SYSBOOT[ 3]==0: -- do -- ) SW2[ 5] = OFF (SYSBOOT[ 4]==1: -- do -- ) SW2[ 6] = OFF (SYSBOOT[ 8]==1: 0:x8 device, 1:x16 device ) SW2[ 7] = ON (SYSBOOT[ 9]==0: ECC done by ROM ) SW2[ 8] = ON (SYSBOOT[10]==0: Non Muxed device ) SW2[ 9] = ON (SYSBOOT[11]==0: -- do -- ) [1] http://beagleboardtoys.info/index.php?title=BeagleBone_Memory_Expansion [2] http://beagleboardtoys.info/index.php?title=BeagleBone_4Gb_16-Bit_NAND_Module *IMPORTANT NOTE* As Beaglebone board shares the same config as AM335x EVM, so following changes are required in addition to this patch for Beaglebone NAND cape. (1) Enable NAND in am335x_beaglebone board profile (2) Add CONFIG_SYS_NAND_BUSWIDTH_16BIT to board config because: - AM335x EVM has NAND device with datawidth=8, whereas - Beaglebone NAND cape has NAND device with data-width=16
2014-08-24nios2: remove obsolete PCI5441 and PK1C20 boardsThomas Chou
2014-08-21davinci: orphan some Davinci boardsMasahiro Yamada
Emails to Sandeep Paulraj <s-paulraj@ti.com> have been bouncing. Please assign new maintainer(s) to get these boards back to Maintained. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2014-08-21powerpc: mpc8xx: remove FLAGADM board supportMasahiro Yamada
This board has been orphaned for a while and old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21powerpc: mpc8xx: remove GEN860T, GEN806T_SC board supportMasahiro Yamada
These boards have been orphaned for a while and old enough. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-08-21powerpc: mpc8xx: remove SXNI855T board supportMasahiro Yamada
2014-08-21powerpc: mpc8xx: remove svm_sc8xx boardMasahiro Yamada
2014-08-21powerpc: mpc8xx: remove stxxtc board supportMasahiro Yamada
2014-08-21omap: remove omap5912osk board supportMasahiro Yamada
Emails to the board maintainer "Rishi Bhattacharya <rishi@ti.com>" have been bouncing. Tom suggested to remove this board. Remove also omap1510_udc.c because this is the last board to enable it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Suggested-by: Tom Rini <trini@ti.com>
2014-08-20Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-08-20kmp204x: reset the Zarlink clocking chips at power up onlyValentin Longchamp
There is the requirement on the chassis's backplane that when the clocks have been enabled, they then should not disappear. Resetting the Zarlink clocking chips at unit reset violates this requirement because the backplane clocks are not supplied during the reset time. To avoid this side effect, both the Zarlink clocking chips are reset only at power up. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-08-20powerpc/t4qds: Move doc/README.t4240qds under board/freescale/t4qdsYork Sun
Board specific README file should be moved to board folder. Signed-off-by: York Sun <yorksun@freescale.com>
2014-08-20powerpc/T4240QDS/eth: some fix for XFIShaohui Xie
XFI is supported on T4QDS-XFI board, which removed slot3, and four LANEs of serdes2 are routed to a SFP+ cages, which to house fiber cable or direct attach cable(copper), the copper cable is used to emulate the 10GBASE-KR scenario. So, for XFI usage, there are two scenarios, one will use fiber cable, another will use copper cable. For fiber cable, there is NO PHY, while for copper cable, we need to use internal PHY which exist in Serdes to do auto-negotiation and link training, which implemented in kernel. We use hwconfig to define cable type for XFI, and fixup dtb based on the cable type. For copper cable, set below env in hwconfig: fsl_10gkr_copper:<10g_mac_name> the <10g_mac_name> can be fm1_10g1, fm1_10g2, fm2_10g1, fm2_10g2. The four <10g_mac_name>s do not have to be coexist in hwconfig. For XFI ports, if a given 10G port will use the copper cable for 10GBASE-KR, set the <10g_mac_name> of the port in hwconfig, otherwise, fiber cable will be assumed to be used for the port. For ex. if four XFI ports will both use copper cable, the hwconfig should contain: fsl_10gkr_copper:fm1_10g1,fm1_10g2,fm2_10g1,fm2_10g2 For fiber cable: 1. give PHY address to a XFI port, otherwise, the XFI ports will not be available in U-boot, there is no PHY physically for XFI when using fiber cable, this is just to make U-boot happy and we can use the XFI ports in U-boot. 2. fixup dtb to use fixed-link in case of fiber cable which has no PHY. Kernel requests that a MAC must have a PHY or fixed-link. When using XFI protocol, the MAC 9/10 on FM1 should init as 10G interface. Change serdes 2 protocol 56 to 55 which has same feature as 56 since 56 is not valid any longer. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-08-20mx6sxsabresd: Add Ethernet supportFabio Estevam
mx6sxsabresd board has 2 FEC ports, each one connected to a AR8031. Add support for one FEC port initially. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-08-20mx6sxsabresd: Convert to the new Kconfig styleFabio Estevam
mx6sxsabresd was not in the master branch when the conversion to the new Kconfig style happened, so convert it now so that it can build again. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-08-20samsung: dfu: Provide correct Vendor and Product IDs for UMS gadgetLukasz Majewski
It is necessary to provide the same Vendor and Product IDs as the one in the original Linux kernel code. Without this change the USB mass storage gadget is not working with Windows7. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2014-08-20imx: ventana: add econfig commandTim Harvey
The Gateworks Ventana EEPROM contains a set of configuration bits that affect the removal of device-tree nodes that support peripherals that do not exist on sub-loaded boards. This patch adds: - a structure to define a config bit name, dt node alias, bit position - an array of supported configuration items - an econfig command to get/set/list configuration bits - use of the array when adjusting the FDT prior to boot Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2014-08-20imx: ventana: leave PCI reset de-asserted if PCI enabledTim Harvey
2014-08-20imx: ventana: add iomux for PCISKT_WDIS# gpioTim Harvey
The PCISKT_WDIS# gpio allows for asserting WDIS# going to the various PCIe sockets on the Ventana board. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2014-08-20imx: ventana: enable SION bit on gpio outputsTim Harvey
Enable the SION bit on gpio outputs that we wish to be able to read the value of. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2014-08-20imx: ventana: configure i2c_dis# pin properly for gw53xxTim Harvey
The i2c_dis# pinmux/padconf was missing for the GW53xx (this feature was added to the GW53xx on revB PCB's). Additionally, remove the duplicate config for GW54xx. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2014-08-20imx: ventana: add missing crlf to printTim Harvey
2014-08-20imx: ventana: add video enable gpio pinmux for GW54xxTim Harvey
2014-08-20imx: ventana: add appropriate delay following GSC i2c writeTim Harvey
The Gateworks System Controller EEPROM config is flash based. Add a delay following writes to avoid errors on back-to-back writes. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2014-08-20imx: ventana: remove caam disable per eeprom bitTim Harvey
During manufacturing this bit is not getting enabled when it should be, so we will ignore it. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2014-08-20imx: ventana: set dynamic env var for flash layoutTim Harvey
NAND devices have differing layouts with respect to page size and pages per block. These parameters affect the parameters that need to be passed to mkfs.ubifs and ubinize used to create UBI images. The various NAND chips supported by Gateworks Ventana fall into two different layouts which we refer to as 'normal' and 'large'. This layout is useful when referencing ubi files to download and flash so we create a dynamic env variable for it. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2014-08-20mx6sxsabresd: Update DDR initializationFabio Estevam
Use the latest DDR initialization values suggested by the FSL hardware team. While at it, add some comments for clarification. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
