Signed-off-by: Asen Dimov <dimov@ronetix.at>
This patch fixes the acadia_nand and kilauea_nand linker scripts
which have been missing in commit ee8028b7 [ppc4xx: Cleanup for
partial linking and --gc-sections]
Cc: Bernhard Weirich <Bernhard.Weirich@riedel.net>
On the P1022, the pins which drive the video display (DIU) are muxed with the
local bus controller (LBC), so if the DIU is active, the pins need to be
temporarily muxed to LBC whenever accessing NOR flash.
The code which handled this transition is checking and changing the wrong
bits in PMUXCR.
Also add a follow-up read after a write to NOR flash if we're going to
mux back to DIU after the write, as described in the P1022 RM.
Fix ca9x4_ct_vxp build error
Configuring for ca9x4_ct_vxp board...
board/armltd/vexpress/libvexpress.o: In function `udelay':
u-boot.git/board/armltd/vexpress/ca9x4_ct_vxp.c:161: multiple
definition of `udelay'
lib/libgeneric.o:u-boot.git/lib/time.c:34: first defined here
lib/libgeneric.o: In function `udelay':
zlib.c:(.text+0x1ee8): undefined reference to `__udelay'
Signed-of-by: Dirk Behme <dirk.behme@googlemail.com>
Fixed "pointer from integer without a cast" warnings in Vexpress.
Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
This patch fixes build errors in the vexpress system:
- Removed sys_proto.h requirement from syslib.c.
- Switched vexpress to the default armv7 linker script.
- Renamed TEXT_BASE to CONFIG_SYS_TEXT_BASE.
This patch also removes now unnecessary config.mk in board directory and
make usage of new features in boards.cfg.
Adds support for the EMK TOP9000 CPU Module which is
based on ATMELs ARM926EJS AT91SAM9XE SoC.
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Since the driver is used not only on Freescale boards,
we move it to a common place for video drivers as
suggested by Wolfgang. The patch also cleans up the
top level Makefile.
Since board_hwconfig & cpu_hwconfig are defined as weak and dont have a
default value they will get put into the BSS if they aren't defined
elsewhere. This is problematic as we try to utilize hwconfig before
we've relocated and thus BSS isn't setup.
Instead of giving dummy values in the board files that utilize this
feature, we can just initialize the variables to an empty string and
thus move them out of the BSS if they aren't defined elsewhere.
Also made board_hwconfig & cpu_hwconfig arrays to reduce size associated
with string pointers vs arrays.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Also change the CONFIG_SYS_TEXT_BASE to 0x80008000, required
with relocation support. This is the load address for primary
boot loader (x-loader).
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com>
Use the return value of cmd_usage instead of ignoring this
and returning a 1.
Signed-off-by: Thomas Weber <weber@corscience.de>
* Fix memory initialization. This fixes the problem
with kernel oopses during heavy load.
* Cleanup pinsetup, which for reference is among
other things needed for proper flash erasing.
Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
Cc: Timur Tabi <timur@freescale.com>
This commit adapts 4xx boards for partial linking with --gc-sections.
Cc: Stefan Roese <sr@denx.de>
Cc: Tirumala Marri <tmarri@apm.com>
Cc: David Updegraff <dave@cray.com>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Larry Johnson <lrj@acm.org>
Cc: Peter De Schrijver <p2@mind.be>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Daniel Poirot <dan.poirot@windriver.com>
This change is needed to compile the PPC4xx NAND booting targets
equipped with the IBM DDR2 SDRAM controller.
These boards use an embedded environment, which is not supported by the
generic arch/powerpc/cpu/ppc4xx/u-boot.lds script.
The breakage was introduced by commit 2cd95a2 "ppc4xx: Remove board
specific linker scripts from most PPC4xx boards"
Cc: Andrea Marson <andrea.marson@dave-tech.it>
Fix warnings:
cam5200_flash.c: In function 'write_word_32':
cam5200_flash.c:443: warning: dereferencing type-punned pointer will break strict-aliasing rules
cam5200_flash.c: In function 'write_word_16':
cam5200_flash.c:684: warning: dereferencing type-punned pointer will break strict-aliasing rules
The IDS8247 board is configured to use the CFI flash driver, so drop
the now redundant custom flash.c file.
The barco board appears to be unmaintained since it was added about 5
years ago. The environment location has probably never been correct.
Drop it.
Cc: Marc Leeman <marc.leeman@barco.com>
The ERIC board appears to be unmaintained for more than 9 years. The
environment location has probably never been correct, and has been
definitely broken since for at least a year. Drop it.
Cc: Swen Anderson <sand@peppercon.de>
start with sheevaplug configuration
add modifications by Alexander Holler <holler@ahsoftware.de>
change RAM definitions to one bank (128 MB)
change ident string and prompt
define MTD partitions and default environment variables
add support for LEDs
Signed-off-by: Eric Cooper <ecc@cmu.edu>
The TI DA850/OMAP-L138/AM18x EVM can be populated with devices
having different maximum allowed CPU clock rating.
The maximum clock the chip can support can only be determined from
the label on the package (not software readable).
Introduce a method to pass the maximum allowed clock rate information
to kernel using ATAG_REVISION. The kernel uses this information to
determine the maximum cpu clock rate reachable using cpufreq.
Note that U-Boot itself does not set the CPU clock rate. The CPU
clock is setup by a primary bootloader ("UBL"). The rate setup by
UBL could be different from the maximum clock rate supported by the
device.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
map
Fix the build breakage introduced by the recent relocation
and memory layout changes for ARM.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
Previously some mpc85xx boards printed indented messages such as the
following on bootup:
printf(" eTSEC4 is in sgmii mode.\n");
printf(" Serdes2 disalbed\n");
The bootup appearance looks cleaner if the indentation is removed which
aligns these messages with other bootup output.
CC: galak@kernel.crashing.org
Previously boards used a variety of indentations, newline styles, and
colon styles for the PCI information that is printed on bootup. This
patch unifies the style to look like:
NAND: 1024 MiB
PCIE1: connected as Root Complex
Scanning PCI bus 01
04 01 8086 1010 0200 00
03 00 10b5 8112 0604 00
02 01 10b5 8518 0604 00
02 02 10b5 8518 0604 00
08 00 1957 0040 0b20 00
07 00 10b5 8518 0604 00
09 00 10b5 8112 0604 00
07 01 10b5 8518 0604 00
07 02 10b5 8518 0604 00
06 00 10b5 8518 0604 00
02 03 10b5 8518 0604 00
01 00 10b5 8518 0604 00
PCIE1: Bus 00 - 0b
PCIE2: connected as Root Complex
Scanning PCI bus 0d
0d 00 1957 0040 0b20 00
PCIE2: Bus 0c - 0d
In: serial
CC: wd@denx.de
CC: sr@denx.de
The size of the other bank needed to be added to the br0 setting;
this got dropped in the LBC cleanup.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Tested-by: Wolfgang Denk <wd@denx.de>
Acked-by: Wolfgang Denk <wd@denx.de>
Display the 64-byte Reset Configuration Word (RCW) during boot, so that
there's no confusion as to what RCW U-boot is using.
Reset Configuration Word (RCW):
00000000: 4a500000 00000000 18181818 00008888
00000010: 28402400 00002000 fe800000 01200000
00000020: 00000000 00000000 00000000 000b0000
00000030: 00000000 00000000 00000000 00000000
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
SQW/INT pin in RTC can be used for generating square wave(by default) or
as interrupt line. U-boot is registering this pin for interrupts.
Configuring SQW/INT bit as interrupt line during board initialization
to avoid spurious interrupts generated by square wave.
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
