path: root/board
2013-03-04Merge branch 'master' of git://git.denx.de/u-boot-blackfinTom Rini
2013-03-04blackfin: bf60x: add board and headers files to support bf609Sonic Zhang
Board and config header files for bf609-ezkit support. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-01OMAP3: drop CONFIG_SPL_OS_BOOT_KEY and use local defineStefano Babic
CONFIG_SPL_OS_BOOT_KEY is used only in board files. It is not required to have a general CONFIG_ option. Rename it and define it in board directory. Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-15powerpc/83xx/km: drop uneeded dtt_bus environment varHolger Brunck
There is no need for a environment variable to configure the dtt bus. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15km/scripts: replace hardcoded uImageAndreas Huber
Replace uImage with ${uimage}. If uimage is not set, default it to uImage. Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15powerpc/83xx/km: add MV88E6122 switch support for kmvect1Karlheinz Jerg
kmvect1 has a UEC2 connection to the piggy board and a UEC0 connection to the switch MV88E6122. This switch has a connection to a frontport ethernet interface. The ethernet port used for network booting is automatically selected by u-boot. If a Piggy is plugged, the Piggy port is selected (UEC2, eth1). If the Piggy isn't present, the Frontport is selected (UEC0, eth0). The switch reset is connected to a GPIO on the PRIO3 board FPGA (GPIO28) and released at startup. Signed-off-by: Karlheinz Jerg <karlheinz.jerg@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15km/common/ivm: rework piggy mac adress offset generationHolger Brunck
For the the kmvect1 board we will also need a functionality to add an offset to the IVMs MAC address, because these board will have two valid ethernet ports for debugging purpose. So move the code to an own function. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15km82xx, km83xx: move ethernet_present() from common to cpu specificKarlheinz Jerg
For kmvect1 we need a special solution and for km_arm boards we already have. So move the common code to the architectur specific file. Signed-off-by: Karlheinz Jerg <karlheinz.jerg@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15km/common/ivm: remove CONFIG_SYS_I2C_IVM_BUS related codeHolger Brunck
This define isn't set within our setup files. So we can safely remove the affected code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15km/common/ivm: remove obsolete codeHolger Brunck
EEprom_ivm_addr isn't set in our environment, so remove the usage of this. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-15km/common: remove unneeded ifdefs for I2CHolger Brunck
All boards from this serie use i2c. There is no need to #ifdef the header. Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2013-02-14x86: Remove eNET boardsSimon Glass
These are no longer used and should be removed. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Graeme Russ <graeme.russ@gmail.com>
2013-02-12am335x_evm: Fix CPSW ethernet on GP EVM and EVM-SKTom Rini
In commit cfd4ff6 we implemented part of advisory 1.0.10 (internal delay for RGMII mode not supported). This in turn however requires that we set the tx clock delay feature in the PHY itself. Signed-off-by: Tom Rini <trini@ti.com>
2013-02-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2013-02-11Tegra114: Add/enable Dalmore build (T114 reference board)Tom Warren
This build is stripped down. It boots to the command prompt. GPIO is the only peripheral supported. Others TBD. Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11Tegra114: Add generic Tegra114 build supportTom Warren
This patch adds basic Tegra114 (T114) build support - no specific board is targeted. Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11Tegra114: Dalmore: Add DT filesTom Warren
These are stripped down for bringup, They'll be filled out later to match-up with the kernel DT contents, and/or as devices are brought up (mmc, usb, spi, etc.). Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra: add SPI SLINK driverAllen Martin
Add driver for tegra SPI "SLINK" style driver. This controller is similar to the tegra20 SPI "SFLASH" controller. The difference is that the SLINK controller is a genernal purpose SPI controller and the SFLASH controller is special purpose and can only talk to FLASH devices. In addition there are potentially many instances of an SLINK controller on tegra and only a single instance of SFLASH. Tegra20 is currently ths only version of tegra that instantiates an SFLASH controller. This driver supports basic PIO mode of operation and is configurable (CONFIG_OF_CONTROL) to be driven off devicetree bindings. Up to 4 devices per controller may be attached, although typically only a single chip select line is exposed from tegra per controller so in reality this is usually limited to 1. To enable this driver, use CONFIG_TEGRA_SLINK Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra30: fdt: add SPI SLINK nodesAllen Martin
Add tegra30 SPI SLINK nodes to fdt. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra20: fdt: add SPI SFLASH nodeAllen Martin
Add node for tegra20 SPI SFLASH controller to fdt. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-11tegra: fdt: add back missing host1x nodeAllen Martin
Add back host1x node to seaboard dts file. This got dropped during the tegra fdt sort. Signed-off-by: Allen Martin <amartin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-02-08Clean up libfdt.h includesGerald Van Baren
The libfdt.h file is the definition file for libfdt. It is unnecessary to include other fdt header files (the necessary ones are pulled in by libfdt.h). Signed-off-by: Gerald Van Baren <gvb@unssw.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Stefan Roese <sr@denx.de>
2013-02-07am33xx: Drop gpio0_7_pin_mux from phytec pcm051Tom Rini
This mux is not currently used and appears to be a carry-over from the am335x evm code. Acked-by: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Tom Rini <trini@ti.com>
2013-02-07OMAP3: igep00x0: fix a build warning on IGEP boardsJavier Martinez Canillas
commit b689cd5 OMAP3: use a single board file for IGEP devices introduced the following build warning: igep00x0.h:168:24: warning: backslash-newline at end of file [enabled by default] This patch fixes the issue. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
2013-02-07Add DDR3 support for AM335x-EVM (Version 1.5A)Jeff Lance
AM335x EVM 1.5A uses Micron MT41J512M8RH-125 SDRAM 4Gb (512Mx8) as the DDR3 chip. [Hebbar Gururaja <gururaja.hebbar@ti.com>] - Resolve merge conflict while rebasing. File structure is changed in the mainline. So re-arrange the code accordingly. - Update commit message to reflect the DDR3 part number Signed-off-by: Jeff Lance <j-lance1@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Hebbar Gururaja <gururaja.hebbar@ti.com>
2013-02-07am335x: display msg when reading MAC from efuseLars Poeschel
When ethaddr is not set in environment the MAC address is read from efuse. The message was only printed in debug case, but this message could be of interest for the ordinary user, so printf it. Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2013-02-07pcm051: Add support for Phytec phyCORE-AM335xLars Poeschel
The board is named pcm051 and has this hardware: SOC: TI AM3359 DDR3-RAM: 2x MT41J256M8HX-15EIT:D 512MiB ETH 1: LAN8710AI SPI-Flash: W25Q64BVSSIG RTC: RV-4162-C7 I2C-EEPROM: CAT32WC32 NAND: MT29F4G08_VFPGA63 PMIC: TPS65910A3 LCD Supported: UART 1 MMC/SD ETH 1 USB I2C SPI Not yet supported: NAND RTC LCD Signed-off-by: Lars Poeschel <poeschel@lemonage.de> [trini: Add #define CONFIG_PHY_ADDR 0 to config] Signed-off-by: Tom Rini <trini@ti.com>
2013-02-07OMAP3: igep00x0: add boot status GPIO LEDJavier Martinez Canillas
This patch adds an GPIO LED boot status for IGEP boards. The GPIO LED used is the red LED0 while the Linux kernel uses the green LED0 as the boot status. By using different GPIO LEDs, the user can know in which step of the boot process the board currently is. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-02-07OMAP3: use a single board file for IGEP devicesJavier Martinez Canillas
Even when the IGEPv2 board and the IGEP Computer-on-Module are different from a form factor point of view, they are very similar in the fact that share many components and how they are wired. So, it is possible (and better) to have a single board file for both devices and just use the CONFIG_MACH_TYPE to make a differentiation between each board when needed. This change avoids code duplication by removing 298 lines of code and makes future maintenance easier. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-02-04Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeTom Rini
2013-02-04board sc3: fix warning about nested commentJeroen Hofstee
cc: Heiko Schocher <hs@denx.de> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2013-02-04ppc: Move kbd_status to arch_global_dataSimon Glass
Move this field into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04ppc: Move wdt_last to arch_global_dataSimon Glass
2013-02-04ppc: Move fpga_state to arch_global_dataSimon Glass
2013-02-04ppc: Move mirror_hack to arch_global_dataSimon Glass
2013-02-04ppc: Move mpc5xxx clocks to arch_global_dataSimon Glass
Move ipb_clk and pci_clk into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04ppc: Move lbc_clk and cpu to arch_global_dataSimon Glass
Move these fields into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Update for bsc9132qds.c, b4860qds.c] Signed-off-by: Tom Rini <trini@ti.com>
2013-02-04microblaze: Remove FSL support from generic boardMichal Simek
This code was targetting one specific Microblaze platform configuration which is obsolete and fsl bus isn't used in this way. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-02-04board: xilinx: Remove common folderMichal Simek
All these files was used for ancient xilinx drivers which are finally gone. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Rommel Custodio <sessyargc@gmail.com>
2013-02-04board: xilinx: Remove unused ancient i2c driverMichal Simek
There is new driver in the driver folder. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Tested-by: Rommel Custodio <sessyargc@gmail.com> Acked-by: Heiko Schocher <hs@denx.de>
2013-02-03ARM: highbank: use wfi macro instead of inline asmRob Herring
Older compilers don't recognize v7 wfi instruction, so use wfi macro to fix builds on old compilers. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-02-02arm: rmobile: kzm9g: Adjust ETM trace clockTetsuyuki Kobayashi
Set ETM TRCLK down to 78MHz to get clear wave form. This patch makes difference only when you use ETM trace connecting JTAG debugger. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2013-02-02arm: rmobile: kzm9g: Adjust SDRAM settingTetsuyuki Kobayashi
After stress test, I found some of kzm9g board occures memory failure. This patch adust SDRAM setting. - Enlarge drivability on both SDRAM controller and SDRAM itself - Raise core voltage Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp> Acked-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2013-02-02Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-01-30Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
2013-01-31MIPS: qi_lb60: remove custom u-boot.lds scriptGabor Juhos
Remove the board specific linker script. It is not needed anymore, the unified MIPS linker script can be used instead. The qi_lb60 target produces a slightly different image after the change than before. The value of 'num_got_entries' symbol is different: @@ -49,7 +49,7 @@ 801000b4: 80122d00 lb s2,11520(zero) 801000b8: 80123500 lb s2,13568(zero) 801000bc: 80123ef8 lb s2,16120(zero) -801000c0: 00000139 0x139 +801000c0: 00000136 tne zero,zero,0x4 801000c4 <in_ram>: 801000c4: 8d0bfffc lw t3,-4(t0) This is caused by the different placement of the '__got_start' and '__got_end' symbols between the board specific scrip and the unified script. board specific script: __got_start = .; .got : { *(.got) } __got_end = .; unified script: .got : { __got_start = .; *(.got) __got_end = .; } Despite this difference, the resulting images are functionally identical. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Xiangfu Liu <xiangfu@openmobilefree.net>
2013-01-31MIPS: dbau1x00: remove custom u-boot.lds scriptGabor Juhos
Remove the board specific linker script. It is not needed anymore, the unified MIPS linker script can be used instead. All dbau1x00 targets are producing identical binary images after the change than before. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-01-31MIPS: incaip: remove custom u-boot.lds scriptGabor Juhos
Remove the board specific linker script. It is not needed anymore, the unified MIPS linker script can be used instead. All incaip targets are producing identical binary images after the change than before. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de>
2013-01-31MIPS: vct: remove custom u-boot.lds scriptGabor Juhos
Remove the board specific linker script. It is not needed anymore, the unified MIPS linker script can be used instead. All vct targets are producing identical binary images after the change than before. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Acked-by: Stefan Roese <sr@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-01-31MIPS: pb1x00: remove custom u-boot.lds scriptGabor Juhos
Remove the board specific linker script. It is not needed anymore, the unified MIPS linker script can be used instead. All pb1x00 targets are producing identical binary images after the change than before. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
