With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
The TK885D board uses a TQM885D module from TQ, this port adds an
own configuration file and adds a last_stage_init() method to
configure the two PHYs, depending on the phy_auto_nego environment
variable.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Clear possible errors in MCSR resulting from data-eye-search.
If not done, then we could get an interrupt later on when
exceptions are enabled.
Rework Lime support for lwmon5 using new video driver
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This is MPC8360E based board with:
- 256MB fixed SDRAM;
- 8MB Intel Strata NOR flash;
- StMICRO 64MiB NAND flash;
- two 10/100/1000 ethernet ports connected via Broadcom
BCM5481 PHYs;
- two 10/100 ethernet ports connected via National
DP83848 PHYs;
- one PCI and one miniPCI slots;
- four serial ports (two NS16550-compatible, two UCCs);
- four USB ports working through MPC8360E "FHCI" USB controller;
- Fujitsu MB86277 graphics controller;
- Analog to Digital Converter/Touchscreen controller, AD7843
connected to SPI.
Features not supported in this patch are:
- StMICRO 64MiB NAND flash (patch sent);
- MINT framebuffer initialization (patch is pending);
- Fetching production information from the EEPROM via I2C;
- FHCI USB;
- Two slow UCCs used as RS-485 UARTs.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
vxWorks expects in
TLB 0 a entry for the Machine Check interrupt
TLB 1 a entry for the RAM
TLB 2 a entry for the EBC
TLB 3 a entry for the boot flash
After changing the baudrate to 9600 I had no problems to boot the
vxWorks image as distributed by WindRiver (Revision 2.0/1 from
June 18, 2007)
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
Add support for Instituto Atlantico's ATUM8548 board
Signed-off-by: robert lazarski <robertlazarski@gmail.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
Add support for Wind River's SBC8548 reference board.
Signed-off by: Joe Hamman <joe.hamman@embeddedspecialties.com>
Signed-off by: Andy Fleming <afleming@freescale.com>
To use UART1 on the MPC8568E-MDS, QE pario pins PC[0:3] should
be set up appropriately.
In order to use GETH1 and GETH2 on the MPC8568E-MDS, we should reset
UCCs.
p.s Similar code exists in the Linux kernel board file (for capability
reasons with older U-Boots), but should be removed some day.
The old macros made it difficult to know what WIMGE and perm bits
were set for a TLB entry. Actually use the bit masks for these items
since they are only a single bit.
Also moved the macros into mmu.h out of e500.h since they aren't specific
to e500.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Assumes the presence of the aliases node in the DTS to
locate the pci and serial nodes for fixups.
Use consistent fdtaddr and fdtfile in environment variables.
Turn off DEBUG.
board/tqm5200/tqm5200.c
This patch removes the FPGA subsystem configuration through
the CONFIG_FPGA bitmask configuration option.
See README for the new options:
CONFIG_FPGA,
CONFIG_FPGA_<vendor>,
CONFIG_FPGA_<family>
This patch configures the LWMON5 port to use d-cache as init-ram and
the unused GPT0_COMP6 as POST WORD storage.
Some operating systems rely on assigned PCI interrupts.
This patch updates the PLB/PCI divider when running at
400MHz CPU frequency from 4 to 3 which results in 44MHz PCI sync clock.
..in board pci.c files
need to rm it from pci code, too!
convert to using simpler mpc85xx style fdt update code; streamline by
eliminating macros OF_SOC, OF_CPU, etc. which allows us to rm
the old school FLAT_TREE code from 83xx (since the sbc8349 was just
converted over to using libfdt).
This adds libfdt support code for the Wind River sbc8349 board.
Parallel of commit 3fde9e8b22cfbd7af489214758f9839a206576cb for
the other Freescale 83xx boards.
ECC code is now shared for all 83xx boards, so remove board specific one.
See commit daab8c67d2defef73dc26ab07f0c3afd1b05d019 for reference.
mpc8360emds.c: In function ‘ft_board_setup’:
mpc8360emds.c:335: warning: assignment discards qualifiers from pointer target type
mpc8360emds.c:345: warning: assignment discards qualifiers from pointer target type
rename to fdt_path_offset
u-boot itself uses GMII mode on the 8360. Fix up UCC phy-connection-type
properties in the device tree so the PHY gets configured for internal delay on
RX only by the OS, as prescribed by mpc8360 rev. 2.1 pb mds erratum #2.
The MPC837xEMDS board support:
* DDR2 400MHz hardcoded and SPD init
* Local bus NOR Flash
* I2C, UART, MII and RTC
* eTSEC RGMII
* PCI host
Signed-off-by: Dave Liu <daveliu@freescale.com>
Despite user manual, BCSR9.7 is negated (high) on HRST, so
UART2 is disabled. Fix that and configure QE pins properly.
On Katmai the complete auto-calibration somehow doesn't seem to
produce the best results, meaning optimal values for RQFD/RFFD.
This was discovered by GDA using a high bandwidth scope,
analyzing the DDR2 signals. GDA provided a fixed value for RQFD,
so now on Katmai "only" RFFD is auto-calibrated.
This patch also adds RDCC calibration as mentioned on page 7 of
the AMCC PowerPC440SP/SPe DDR2 application note:
"DDR1/DDR2 Initialization Sequence and Dynamic Tuning"
