include/ppc4xx.h
This patch adds missing pinmux setup for 4 GPIO signals used on the Beagle xM:
- USB hub reset (gpio_56)
- P8 USB hub reset (gpio_63)
- DVI enable (gpio_129)
- P8 DVI enable (gpio_170)
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
This patch corrects the pinmux settings to enable proper functioning
of the wifi/bluetooth module.
Signed-off-by: Thomas Weber <weber@corscience.de>
This change lays the groundwork for the BOOTFLAG_* flags being removed.
This change has the small affect of delaying 100ms on PCI initialization
after a warm boot as opposed to the optimal 1ms on some boards.
included the mpc8308_p1m board.
This patch provides support for MPC8308 P1M board with the following
set of features:
Dual UART is supported
NOR flash is supported
Both TSEC Ethernet controllers are supported
PCI Express initialization is supported
Both I2C controllers are supported
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
This patch cleans up the Freescale MPC8308RDB Development board support.
Things fixed:
- Removed unused PCIE2 definitions from configuration
- SICR{L,H} defines used for System I/O Configuration Registers values
instead of hardcoding
- CONFIG_SYS_SCCR_PCIEXP1CM used to enable PCIE clock instead of
writing to SCCR from the board code
- sleep mode stuff removed as MPC8308 has no support for deep sleep and
PMCCR1 register. board_early_init_f() removed.
- MPC8308 has no ERRATA for DDR controller so workaround removed
- 'assignment in if statement' issues solved
- use LBLAWAR_* defines instead of hardcoding
This patch removes the PPC4xx UART driver. Instead the common NS16550
driver is used, since all PPC4xx SoC's use this peripheral device.
The file 4xx_uart.c now only implements the UART clock calculation
function which also sets the SoC internal UART divisors.
All PPC4xx board config headers are changed to use this common NS16550
driver now.
Tested on these boards:
acadia, canyonlands, katmai, kilauea, sequoia, zeus
This cleanup is done by creating header files for all SoC versions and
moving the SoC specific defines into these special headers. This way the
common header ppc405.h and ppc440.h can be cleaned up finally.
As a part from this cleanup, the GPIO definitions for PPC405EP are
corrected. The high and low parts of the registers (for example
CONFIG_SYS_GPIO0_OSRL vs. CONFIG_SYS_GPIO0_OSRH) have been defined in
the wrong order. This patch now fixes this issue by switching these
xxxH and xxxL values. This brings the GPIO 405EP port in sync with all
other PPC4xx ports.
This patch starts a bit PPC4xx header cleanup. First patch mostly
touches PPC440 files. A later patch will touch the PPC405 files as well.
This patch moves some ppc4xx related headers from the common include
directory (include/) to the powerpc specific one
(arch/powerpc/include/asm/). This way to common include directory is not
so cluttered with files.
This patch changes the behaviour of the fdt_fixup_nor_flash_node()
function. Now it doesn't patch the size of the "reg" property with the
chip-select size, but with the size returned from the new function
flash_get_bank_size(). This function will return per weak default the
flash size of the bank (bank = chip-select numer) detected by the flash
driver. If this does not fit your needs, this function may be overridden
by a board specific one.
For this the parameters needed to be changed. So I intentionally squashed
the PPC4xx stuff using this routine into this patch. Otherwise it would
not be git-bisectable anymore.
The board specific function for the AMCC/APM Ebony eval board is now
included in this patch version.
Tested-by: Detlev Zundel <dzu@denx.de>
Cc: Gerald Van Baren <vanbaren@cideas.com>
Seems these two files were missed during the big lib shuffle.
features
The Freescale MPC8610 and MPC5121 DIU code had re-implement two features that already
existed in U-Boot: bitmap drawing and top-of-screen logo (CONFIG_VIDEO_LOGO).
So delete the 8610-specific code and use the built-in features instead.
This patch modifies jadecpu board so that it is usable
with the relocation patches by Heiko Schocher
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
- Revives POST for blackfin arch;
- Removes redundant code:
arch/blackfin/lib/post.c
arch/powerpc/cpu/ppc4xx/commproc.c
arch/powerpc/cpu/mpc512x/common.c
- fixes up the post_word_{load|store} usage.
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
Acked-by: Detlev Zundel <dzu@denx.de>
Tested-by: Anatolij Gustschin <agust@denx.de>
List of the maintainers of the affected by patch boards:
Cc: Stephan Linz <linz@li-pro.net>
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Larry Johnson <lrj@acm.org>
Cc: Feng Kan <fkan@amcc.com>
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By
moving these optional variables and defines into the common code, board
specific code is minimized. Currently only the following board use
this feature:
APC405, IDS8247, TQM834x
And IDS8247 doesn't seem to really need this feature, since its not
updating the bank number variable at all. So this patch removes the
definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port.
This new framework will be used by the upcoming lwmon5 update as well.
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
Recent changes caused that the HMI10 board now is included in the
boards built by MAKEALL, which revealed that compilation for this
board has been broken for a long time:
ps2ser.c: In function 'ps2ser_init':
ps2ser.c:155: error: 'UART_LCR' undeclared (first use in this function)
ps2ser.c:155: error: (Each undeclared identifier is reported only once
ps2ser.c:155: error: for each function it appears in.)
ps2ser.c:156: error: 'UART_DLL' undeclared (first use in this function)
ps2ser.c:157: error: 'UART_DLM' undeclared (first use in this function)
ps2ser.c:159: error: 'UART_IER' undeclared (first use in this function)
ps2ser.c:160: error: 'UART_MCR' undeclared (first use in this function)
ps2ser.c:161: error: 'UART_FCR' undeclared (first use in this function)
ps2ser.c:162: error: 'UART_FCR_ENABLE_FIFO' undeclared (first use in this function)
ps2ser.c:166: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_putc':
ps2ser.c:198: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c:200: error: 'UART_TX' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_getc_hw':
ps2ser.c:224: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c:225: error: 'UART_RX' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_interrupt':
ps2ser.c:293: error: 'UART_IIR' undeclared (first use in this function)
The board is orphaned, and AFAICT has reached EOL.
Drop support for it.
Recent changes caused thatthe aev board now is included in the boards
built by MAKEALL, which revealed that compilation for this board
canmb.c: In function 'initdram':
canmb.c:109: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness
canmb.c:111: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness
canmb.c:137: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness
canmb.c:140: warning: pointer targets in passing argument 1 of 'get_ram_size' differ in signedness
Fix these.
Split the existing dram_init for da8xx when ARM reloc is enabled, like the
changes to arch/arm/cpu/arm926ejs/orion5x/dram.c in
0f234d263b17ccf1b8fd776eb8c15b7cdb27a887 by Heiko Schocher <hs@denx.de>.
Without these changes gd->ram_size is '0' which leads to incorrect relocation
when CONFIG_SYS_ARM_WITHOUT_RELOC is defined and the board does not boot.
We use get_ram_size to dynamically calculate the available RAM because it runs
on different board version with different ram, as suggested by Heiko in private
communication.
Tested on a da850evm with 128M of DDR2 installed; with both
CONFIG_SYS_ARM_WITHOUT_RELOC defined and undefined.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
Reviewed-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
CC: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
CC: Heiko Schocher <hs@denx.de>
Change the implementation for arm926 to relocate the code to
an arbitrary address in RAM.
Adapt the TX25 (i.MX25), magnesium board to test the changes.
On the tx25 board TEXT_BASE is set to the final relocation
address to prevent one more copying of u-boot code
when relocating. More info see:
doc/README.arm-relocation
da850 board:
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
Portions of this work were supported by funding from
the CE Linux Forum.
Cc: Ben Gardiner <bengardiner@nanometrics.ca>
Change the implementation for ARM V7 to relocate the code to an
Adapt the Beagle board (Cortex A8) to test the changes.
the CE Linux Forum.
Change the implementation for ARM11 to relocate the code to an
Tested on the qong board.
the CE Linux Forum.
Motivation:
* Old environment code used a pessimizing implementation:
- variable lookup used linear search => slow
- changed/added variables were added at the end, i. e. most
frequently used variables had the slowest access times => slow
- each setenv() would calculate the CRC32 checksum over the whole
environment block => slow
* "redundant" envrionment was locked down to two copies
* No easy way to implement features like "reset to factory defaults",
or to select one out of several pre-defined (previously saved) sets
of environment settings ("profiles")
* No easy way to import or export environment settings
API Changes:
- Variable names starting with '#' are no longer allowed
I didn't find any such variable names being used; it is highly
recommended to follow standard conventions and start variable names
with an alphanumeric character
- "printenv" will now print a backslash at the end of all but the last
lines of a multi-line variable value.
Multi-line variables have never been formally defined, allthough
there is no reason not to use them. Now we define rules how to deal
with them, allowing for import and export.
- Function forceenv() and the related code in saveenv() was removed.
At the moment this is causing build problems for the only user of
this code (schmoogie - which has no entry in MAINTAINERS); may be
fixed later by implementing the "env set -f" feature.
Inconsistencies:
- "printenv" will '\\'-escape the '\n' in multi-line variables, while
"printenv var" will not do that.
Advantages:
- "printenv" output much better readable (sorted)
- faster!
- extendable (additional variable properties can be added)
- new, powerful features like "factory reset" or easy switching
between several different environment settings ("profiles")
Disadvantages:
- Image size grows by typically 5...7 KiB (might shrink a bit again on
systems with redundant environment with a following patch series)
Implemented:
- env command with subcommands:
- env print [arg ...]
same as "printenv": print environment
- env set [-f] name [arg ...]
same as "setenv": set (and delete) environment variables
["-f" - force setting even for read-only variables - not
implemented yet.]
- end delete [-f] name
not implemented yet
["-f" - force delete even for read-only variables]
- env save
same as "saveenv": save environment
- env export [-t | -b | -c] addr [size]
export internal representation (hash table) in formats usable for
persistent storage or processing:
-t: export as text format; if size is given, data will be
padded with '\0' bytes; if not, one terminating '\0'
will be added (which is included in the "filesize"
setting so you can for exmple copy this to flash and
keep the termination).
-b: export as binary format (name=value pairs separated by
'\0', list end marked by double "\0\0")
-c: export as checksum protected environment format as
used for example by "saveenv" command
addr: memory address where environment gets stored
size: size of output buffer
With "-c" and size is NOT given, then the export command will
format the data as currently used for the persistent storage,
i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and
prepend a valid CRC32 checksum and, in case of resundant
environment, a "current" redundancy flag. If size is given, this
value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32
checksum and redundancy flag will be inserted.
With "-b" and "-t", always only the real data (including a
terminating '\0' byte) will be written; here the optional size
argument will be used to make sure not to overflow the user
provided buffer; the command will abort if the size is not
sufficient. Any remainign space will be '\0' padded.
On successful return, the variable "filesize" will be set.
Note that filesize includes the trailing/terminating '\0'
byte(s).
Usage szenario: create a text snapshot/backup of the current
settings:
=> env export -t 100000
=> era ${backup_addr} +${filesize}
=> cp.b 100000 ${backup_addr} ${filesize}
Re-import this snapshot, deleting all other settings:
=> env import -d -t ${backup_addr}
- env import [-d] [-t | -b | -c] addr [size]
import external format (text or binary) into hash table,
optionally deleting existing values:
-d: delete existing environment before importing;
otherwise overwrite / append to existion definitions
-t: assume text format; either "size" must be given or the
text data must be '\0' terminated
-b: assume binary format ('\0' separated, "\0\0" terminated)
-c: assume checksum protected environment format
addr: memory address to read from
size: length of input data; if missing, proper '\0'
termination is mandatory
- env default -f
reset default environment: drop all environment settings and load
default environment
- env ask name [message] [size]
same as "askenv": ask for environment variable
- env edit name
same as "editenv": edit environment variable
- env run
same as "run": run commands in an environment variable
TODO:
- drop default env as implemented now; provide a text file based
initialization instead (eventually using several text files to
incrementally build it from common blocks) and a tool to convert it
into a binary blob / object file.
- It would be nice if we could add wildcard support for environment
variables; this is needed for variable name auto-completion,
but it would also be nice to be able to say "printenv ip*" or
"printenv *addr*"
- Some boards don't link any more due to the grown code size:
DU405, canyonlands, sequoia, socrates.
=> cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>,
Stefan Roese <sr@denx.de>,
- Dropping forceenv() causes build problems on schmoogie
=> cc: Sergey Kubushyn <ksi@koi8.net>
- Build tested on PPC and ARM only; runtime tested with NOR and NAND
flash only => needs testing!!
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>,
Cc: Stefan Roese <sr@denx.de>,
Cc: Sergey Kubushyn <ksi@koi8.net>
On some boards (canyonlands, luan, sequoia) we need more room for the
U-Boot image to allow for new features like the new environment code.
Shift TEXT_BASE as needed.
We need more room for the U-Boot image.
The SC520 CDP boards originally implemented by Daniel Engström are now
very broken. Attempts to contact Daniel via the email address on the
copyright notice have failed. Remove these boards from mainline
Coding style cleanup.
Correctly set PAD1_FREF_CLK4_REQ and PAD0_FREF_CLK4_OUT to enable and
activate both LEDs while setting pad mux.
Since this increases the line length, this patch also adjusts the white
space in this section of code to allign the pad mux signal description
comments.
Signed-off-by: Ricardo Salveti de Araujo <ricardo.salveti@canonical.com>
An upcoming version of Overo uses a Wifi/BT module with 1.8V signaling,
eliminating the need for an external transceiver to handle the level
shifting. This patch detects whether an external transceiver is present
and adjusts the pinmux settings as appropriate.
This patch adds support for the Beagle xM. It uses the board ID
GPIO bits to recognize this revision and perform appropriate setup.
Confiures GPMC timings for both chips and also configures pinmux
for GPIO_65, which is used as the interrupt signal for the second chip
Signed-off-by: Scott Ellis <scott@jumpnowtek.com>
This patch enhances the revision detection function and adds
support for the C4 revision. The board revision is printed
and approriate revision specific setup is done automatically.
The latest Overo COM modules encode their revision number on
GPIOs 115, 113, and 112. All boards to date have no pullups on these pins
and hence appear as revision 0.
This patch reads and prints the revision information.
This patch modifies the pinmux setup for MMC1_CLK and MMC3_CLK to enable
the input driver. MMC2_CLK was already properly configured.
From the document, if set all arguments in "OUTPUT_FORMAT" to
"tradbigmips", then even add "-EL" to gcc we still get EB format.
pb1x00 is only used in Little-endian, so its default endian should be
set to LE.
Signed-off-by: Xiangfu Liu <xiangfu@openmobilefree.net>
Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
Use the MMU hardware to set up 1:1 mappings between physical and virtual
addresses. This allows us to bypass the cache when accessing the flash
without having to do any physical-to-virtual address mapping in the CFI
driver.
The virtual memory mappings are defined at compile time through a sorted
array of virtual memory range objects. When a TLB miss exception
happens, the exception handler does a binary search through the array
until it finds a matching entry and loads it into the TLB. The u-boot
image itself is covered by a fixed TLB entry which is never replaced.
This makes the 'saveenv' command work again on ATNGW100 and other boards
using the CFI driver, hopefully without breaking any rules.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
The paging system which is required to set up caching properties has not
yet been initialized when the SDRAM is initialized. So when the
map_physmem() function is converted to return the physical address
unchanged, the SDRAM initialization will break on some boards.
The avr32-specific uncached() macro will return an address which will
always cause uncached accessed to be made. Since this happens in the
board code, using avr32-specific features should be ok, and will allow
the SDRAM initialization to keep working.
Signed-off-by: York Sun <yorksun@freescale.com>
Fix data size.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
