path: root/board
2012-05-15tegra: fdt: Add EMC data for Tegra2 SeaboardSimon Glass
This adds timings for T20 and T25 Seaboards, using the bindings found here: http://patchwork.ozlabs.org/patch/132928/ We supply both full speed options for normal running, and half speed options for testing / development. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-05-15tegra: Add EMC settings for SeaboardJimmy Zhang
Set Seaboard to optimal memory settings based on the SOC in use (T20 or T25). Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Jimmy Zhang <jimmzhang@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-05-15tegra: Turn off power detect in board initWei Ni
Tegra core power rail has leakage voltage around 0.2V while system in suspend mode. The source of the leakage should be coming from PMC power detect logic for IO rails power detection. That can be disabled by writing a '0' to PWR_DET_LATCH followed by writing '0' to PWR_DET (APBDEV_PMC_PWR_DET_0). Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-05-15tegra: Set up warmboot code on Nvidia boardsSimon Glass
Call the function to put warmboot boot in a suitable place for resume. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-05-15tegra: Set up PMU for Nvidia boardsSimon Glass
Adjust PMU to permit maximum frequency operation. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-05-15M28EVK: Implement support for new board V2.0Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2012-05-15mx53loco: Remove unneeded gpio_set_value()Fabio Estevam
There is no need to set the VBUS power enable to 0 first and then to 1. Set it to 1 in the gpio_direction_output() function. While at it, use the standard naming convention for the GPIO comment. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-05-15mx53loco: Add CONFIG_REVISION_TAGFabio Estevam
FSL 2.6.35 kernel assumes that the bootloader passes the CONFIG_REVISION_TAG information. The kernel uses this data to distinguish between Dialog versus mc34708 based boards, and also to distinguish between revA and revB of the mc34708 based boards. Suggested-by: Yu Li <yk@magniel.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-05-15mx53loco: Turn on VUSB regulatorFabio Estevam
On the mx53loco board with mc34708 PMIC it is necessary to turn on VUSB regulator so that the mx53 USBH1 PHY receives the 3.3V voltage. Tested by inserting a USB pen drive in the upper USB slot (USBH1) and then issued the commands: usb start usb info ,which correctly detected and printed the USB pen drive information. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <r64343@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-05-15mx53loco: Add mc34708 support and set mx53 frequency at 1GHzFabio Estevam
Add mc34708 support and set mx53 core frequency at its maximum value of 1GHz. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <r64343@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-05-15pmic: dialog: Avoid name conflictsFabio Estevam
As mx53loco board has two variants: one with Dialog PMIC and another with FSL MC34708 PMIC, we need to be able to build both drivers. Change pmic_init() and PMIC_NUM_OF_REGS names to avoid build conflicts when both drivers are present. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-05-15i.MX6: mx6q_sabrelite: add SATA bindingsEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: stefano Babic <sbabic@denx.de>
2012-05-15mx28evk: add NAND supportLauri Hintsala
NAND support is not enabled by default because Eval Kit is not delivered with NAND chip. To enable NAND support add CONFIG_CMD_NAND to board config. Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com> Acked-by: Marek Vasut <marex@denx.de>
2012-05-15mx53loco: Add support for 1GHz operation for DA9053-based boardsFabio Estevam
There are two types of mx53loco boards: initial boards were built with a Dialog DA9053 PMIC and more recent version is based on a Freescale MC34708 PMIC. Add DA9053 PMIC support and adjust the required voltages and clocks for running the CPU at 1GHz. Tested on both versions of mx53loco boards. In the case of a MC34708-based board the CPU operating voltage remains at 800MHz. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by : Stefano Babic <sbabic@denx.de>
2012-05-15mx53loco: Allow to print CPU information at a later stageFabio Estevam
Print CPU information within board_late_init(). This is in preparation for adding 1GHz support, which requires programming a PMIC via I2C. As I2C is only available after relocation, print the CPU information later at board_late_init(), so that the CPU frequency can be printed correctly. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-05-15i.MX6Q: mx6qsabrelite: Add keypress support to alter boot flowEric Nelson
Uses the 'magic_keys' idiom as described in doc/README.kbd: http://lists.denx.de/pipermail/u-boot/2012-April/122502.html Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-05-15mx6qsabrelite: No need to set the direction for GPIO3_23 againFabio Estevam
There is a 'gpio_direction_output(87, 0);' call previously, so the GPIO direction is already established. Use gpio_set_value() for changing the GPIO output then. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Dirk Behme <dirk.behme@googlemail.com>
2012-05-15MX53: mx53loco: Add SATA supportStefano Babic
Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Jason Liu <jason.hui@linaro.org> Acked-by: Jason Liu <jason.hui@linaro.org>
2012-05-15MX53: Add support to ESG ima3 boardStefano Babic
The ESG ima3-mx53 board is based on the Freescale i.MX53 SOC. It boots from NOR (128 MB) and supports Ethernet (FEC), SATA. Signed-off-by: Stefano Babic <sbabic@denx.de>
2012-05-15EXYNOS: Change bits per pixel value proper for u-boot.Donghwa Lee
vl_bpix of vidinfo_t was changed proper value for u-boot. It is used to multiple of 2 by using NBITS() macro. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-05-15EXYNOS: support TRATS board display functionDonghwa Lee
This patch support TRATS board configuration and display function. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-05-15SMDK5250: fix compiler warningMinkyu Kang
this patch fixed following warning. tzpc_init.c: In function 'tzpc_init': tzpc_init.c:35: warning: assignment from incompatible pointer type Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Chander Kashyap <chander.kashyap@linaro.org>
2012-05-15misc:pmic:samsung Convert TRATS target to use MAX8997 instead of MAX8998Łukasz Majewski
TRATS target uses MAX8997 PMIC device instead of MAX8998. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2012-05-15ARM: Exynos4: ADC: Universal_C210: Enable LDO4 power line for ADC measurementŁukasz Majewski
This patch enables LDO4 power line for preparing proper voltages to be measured by ADC converter. This measurement is used for determination of target board HW revision. Test HW: Universal_C210 (Exynos4210) rev. 0.0 Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-05-15EXYNOS: Rename exynos5_tzpc structure to exynos_tzpcChander Kashyap
TZPC IP is common across Exynos based SoC'c. Renaming exynos5_tzpc in arch/arm/include/asm/arch-exynos/tzpc.h to exynos_tzpc will allow generic usase of tzpc. Also modify board/samsung/smdk5250/tzpc_init.c to use exynos_tzpc. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-05-15arm: ea20: Change macro from BOARD_LATE_INIT to CONFIG_BOARD_LATE_INITNobuhiro Iwamatsu
With almost all the architecture and board BOARD_LATE_INIT does not use. CONFIG_BOARD_LATE_INIT is used instead. This changed CONFIG_BOARD_LATE_INIT from BOARD_LATE_INIT. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> CC: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-05-15cm-t35: add I2C multi-bus supportNikita Kiryanov
Enable I2C multi-bus support and config I2C muxes for I2C2 and I2C3. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-05-15omap3: Introduce weak misc_init_rTom Rini
Introduce a __weak misc_init_r function that just runs dieid_num_r(). Remove misc_init_r from cm_t35, mcx, omap3_logic and mt_ventoux as this was all they did for misc_init_r. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-05-15omap730p2: Remove empty misc_init_rTom Rini
We had a do-nothing misc_init_r, remove along with CONFIG_MISC_INIT_R Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15omap5912osk: Remove empty misc_init_rTom Rini
2012-05-15OMAP3: pandora: revise GPIO configurationGrazvydas Ignotas
Update pandora's GPIO setup code with these changes: - convert to gpiolib - set up dual voltage GPIOs to match supply of 1.8V by clearing VMODE1 - add GPIO_IO_PWRDNZ configuration for DM3730 variation of pandora (required to enable GPIO 126, 127, and 129 I/O cells in DM3730) - add wifi reset pulse as recommended by wifi chip's manufacturer - drop configuration of GPIOs that u-boot doesn't need Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2012-05-15OMAP3: pandora: pin mux updates for DM3730 board variantGrazvydas Ignotas
DM3730 needs some additional pin mux configuration for GPIOs 126-129 to work, add it. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2012-05-15power: twl6035: add palmas PMIC supportSRICHARAN R
palmas/TWL6035 is power IC for omap5 evm boards Signed-off-by: Balaji T K <balajitk@ti.com>
2012-05-15OMAP5: board: Add pinmux data for omap5_evm board.SRICHARAN R
Adding the full pinmux data for OMAP5430 sevm board. Signed-off-by: R Sricharan <r.sricharan@ti.com>
2012-05-15OMAP3: igep00x0: Reduce lines of code for IGEP-based boards.Enric Balletbò i Serra
This is rework on config files of IGEP-based boards with the aim to remove duplicated code to be more maintainable. Basically this patch creates a common configuration file for both boards and only sets the specific option in the board config file. On board files the hardcored mach type was replaced in favour of using the CONFIG_MACH_TYPE option. More than 200 duplicated lines have been deleted. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
2012-05-15OMAP4460: TPS Ensure SET1 is selected after voltage configurationNishanth Menon
TPS SET0/SET1 register is selected by a GPIO pin on OMAP4460 platforms. Currently we control this pin with a mux configuration as part of boot sequence. Current configuration results in the following voltage waveform: |---------------| (SET1 default 1.4V) | --------(programmed voltage) | <- (This switch happens on mux7,pullup) vdd_mpu(TPS) -----/ (OPP boot voltage) --------- (programmed voltage) vdd_core(TWL6030) -----------------------/ (OPP boot voltage) Problem 1) |<----- Tx ------>| timing violation for a duration Tx close to few milliseconds. Problem 2) voltage of MPU goes beyond spec for even the highest of MPU OPP. By using GPIO as recommended as standard procedure by TI, the sequence changes to: -------- (programmed voltage) vdd_mpu(TPS) ------------/ (Opp boot voltage) --------- (programmed voltage) vdd_core(TWL6030) -------------/ (OPP boot voltage) NOTE: This does not attempt to address OMAP5 - Aneesh please confirm Reported-by: Isabelle Gros <i-gros@ti.com> Reported-by: Jerome Angeloni <j-angeloni@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2012-05-15ARM:OMAP+:MMC: Add parameters to MMC initJonathan Solnit
Add parameters to the OMAP MMC initialization function so the board can mask host capabilities and set the maximum clock frequency. While the OMAP supports a certain set of MMC host capabilities, individual boards may be more restricted and the OMAP may need to be configured to match the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example. Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
2012-05-15kirkwood: add support for Cloud Engines Pogoplug E02David Purdy
This patch adds support for Cloud Engines Pogoplug E02 Information regarding the CE Pogoplug E02 board can be found at: http://archlinuxarm.org/platforms/armv5/pogoplug-v2-pinkgray Signed-off-by: Dave Purdy <david.c.purdy@gmail.com> Cc: prafulla@marvell.com Cc: albert.u.boot@aribaud.net
2012-05-15kirkwood: add NAS62x0 board supportLuka Perkov
Add support for new boards RaidSonic ICY BOX NAS6210 and NAS6220. NAS6210 has 1 SATA and 1 eSATA port while NAS6220 has 2 SATA ports. More information about the boards can be found here: http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7036 http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7515 Signed-off-by: Luka Perkov <uboot@lukaperkov.net> Signed-off-by: Gerald Kerma <dreagle@doukki.net> Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
2012-05-15devkit3250: add Timll DevKit3250 board initial supportVladimir Zapolskiy
This change adds a basic support for Embest/Timll DevKit3250 board, NOR and UART are the only supported peripherals for a moment. The board doesn't require low-level init, because the initial SDRAM and GPIO configuration is performed during kickstart bootloader execution. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-04-30Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'agust@denx.de' of git://git.denx.de/u-boot-staging: lin_gadget: use common linux/compat.h linux/compat.h: rename from linux/mtd/compat.h lin_gadget: use common mdelay gunzip: rename z{alloc, free} to gz{alloc, free} fs/fat: align disk buffers on cache line to enable DMA and cache part_dos: align disk buffers on cache line to enable DMA and cache
2012-04-30Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-ppc4xx: powerpc/ppc4xx: Remove typedefs for gdsys FPGA powerpc/ppc4xx: Fix typo in gdsys_fpga.h powerpc/ppc4xx: Update gdsys board configurations powerpc/ppc4xx: Support gdsys dlvision-10g hardware 1.20 powerpc/ppc4xx: Adapt gdsys 405ep boards to platform changes powerpc/ppc4xx: Make gdsys 405ep boards reset more generic powerpc/ppc4xx: Adjust environment size on neo
2012-04-30linux/compat.h: rename from linux/mtd/compat.hMike Frysinger
This lets us use it in more places than just mtd code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-04-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: powerpc/85xx: don't touch MAS7 on e500v1 when relocating CCSR powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during boot cmd_bdinfo: display the address map size (32-bit vs. 36-bit) PowerPC: correct the SATA for p1/p2 rdb-pc platform powerpc/corenet_ds: Slave core in holdoff when boot from SRIO powerpc/corenet_ds: Slave reads ENV from master when boot from SRIO powerpc/corenet_ds: Slave uploads ucode when boot from SRIO powerpc/corenet_ds: Slave module for boot from SRIO powerpc/corenet_ds: Master module for boot from SRIO powerpc/corenet_ds: Document for the boot from SRIO powerpc/corenet_ds: Correct the compilation errors about ENV powerpc/srio: Rewrite the struct ccsr_rio powerpc/85xx:Fix lds for nand boot debug info powerpc/p2041rdb: add env in NAND support powerpc/p2041rdb: add NAND and NAND boot support powerpc/mpc8xxx: Fix CONFIG_DDR_RAW_TIMING for two boards powerpc/85xx:Avoid vector table compilation for nand_spl powerpc/85xx:Fix IVORs addr after vector table relocation powerpc/85xx:Avoid hardcoded vector address for IVORs powerpc/p1023rds: Disable nor flash node and enable nand flash node
2012-04-30powerpc/ppc4xx: Remove typedefs for gdsys FPGADirk Eibach
Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Support gdsys dlvision-10g hardware 1.20Dirk Eibach
In hardware revision 1.20 one more fan controller is added to dlvision-10g. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Adapt gdsys 405ep boards to platform changesDirk Eibach
Print fpga info at last_stage_init on gdsys 405ep boards. Use dtt_init() to startup fans. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-30powerpc/ppc4xx: Make gdsys 405ep boards reset more genericDirk Eibach
In order to add boards that have different hardware for fpga reset, any 405ep gdsys board now provides these functions: void gd405ep_init(void); void gd405ep_set_fpga_reset(unsigned state); void gd405ep_setup_hw(void); int gd405ep_get_fpga_done(unsigned fpga); Signed-off-by: Dirk Eibach <eibach@gdsys.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-04-24powerpc/85xx: don't display address map size (32-bit vs. 36-bit) during bootTimur Tabi
Most 85xx boards can be built as a 32-bit or a 36-bit. Current code sometimes displays which of these is actually built, but it's inconsistent. This is especially problematic since the "default" build for a given 85xx board can be either one, so if you don't see a message, you can't always know which size is being used. Not only that, but each board includes code that displays the message, so there is duplication. The 'bdinfo' command has been updated to display this information, so we don't need to display it at boot time. The board-specific code is deleted. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-04-24powerpc/corenet_ds: Slave uploads ucode when boot from SRIOLiu Gang
When boot from SRIO, slave's ucode can be stored in master's memory space, then slave can fetch the ucode image through SRIO interface. For the corenet platform, ucode is for Fman. Master needs to: 1. Put the slave's ucode image into it's own memory space. 2. Set an inbound SRIO window covered slave's ucode stored in master's memory space. Slave needs to: 1. Set a specific TLB entry in order to fetch ucode from master. 2. Set a LAW entry with the TargetID SRIO1 or SRIO2 for ucode. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
