Select CONFIG_CMD_NET and CONFIG_CMD_SETEXPR by default rather then
needing to have this in every sunxi defconfig file.
This also fixes the Merrii_A80_Optimus defconfig no longer building.
Cc: Maxin B. John <maxin.john@enea.com>
Reported-by: Maxin B. John <maxin.john@enea.com>
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Rename the Astar_MID756 to Et_q8_v1_6 to match the kernel dts name.
The Mele A1000G-quad and the Mele M9 have the same PCB, sofar we've been
using the same defconfig (and dts on the kernel side) for both models.
Unfortunately this does not work for the otg controller, on the M9 this
is routed to a micro-usb connector on the outside, while as on the
A1000G-quad it is connected to an usb to sata bridge.
This commit adds a new defconfig for the Mele-A1000G-quad to allow using
different otg controller settings on the 2 boards.
Fixup include/configs/unipher.h to not set CONFIG_LIB_RAND
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
This updates r8a7794 QoS to revision 0.31 for ES1 and revision 0.321 for ES2.
Signed-off-by: Kouei Abe <kouei.abe.cp@renesas.com>
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
This updates r8a7793 QoS to revision 0.311.
This updates r8a7791 QoS to revision 0.411.
This updates r8a7790 QoS to revision 0.973.
This commit can changed from KConfig to fit contents of the QoS.
Ethernet function of Alt board can select normal and B by DIP switch
on board. But user need to set not only DIP switch but also pin function.
This adds pin function of Ethernet function B. This can select from Kconfig.
Signed-off-by: Mitsuhiro Kimura <mitsuhiro.kimura.kc@renesas.com>
sun8i uses the same PSCI backend as sun6i, without power clamps.
Since there is no secure SRAM, the backend is placed at the end
of DRAM.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Now that we have a PSCI backend for sun6i, enable it.
This commit adds support to the sunxi SPL to load u-boot from the internal
NAND. Note this only adds support to access the boot partitions to load
u-boot, full NAND support to load the kernel, etc. from the nand data
partition will come later.
Signed-off-by: Roy Spliet <r.spliet@ultimaker.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Add initial sun9i (A80) support, only uart + mmc are supported for now.
The latest versions of the fel tool support loading normal u-boot builds
directly, and this is now the preferred way to use the fel boot method.
This commit removes support for the old deprecated standalone fel builds.
Since i've been married, i also have a new surname.
Mr. Petermaier moved to Mr. Schmelzer.
In this patch i update all files in which my (old) name is present.
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
a6b541b090: TI ARMv7: Don't use GD before crt0.S has set it
moves the init of the debug uart at the very end of SPL code.
Enable it for the siemens board earlier, as they print
ddr settings ... all debug output before board_init_r()
is here currently useless. Maybe we must rework this
globally?
arm: + lsxhl
w+board/buffalo/lsxl/lsxl.c: In function 'rescue_mode':
w+board/buffalo/lsxl/lsxl.c:230:8: warning: unused variable 'enetaddr' [-Wunused-variable]
arm: + lschlv2
Remove the unused variable.
DM3730 CPU used on beagleboard-xm doesn't have any gpio
multiplexed with wait0 pin,
but gpio_63 multiplexed with wait1, so it looks like typo.
At current form it has no sense,
because of wait0 have no function "4".
Signed-off-by: Evgneiy A. Dushistov <dushistov@mail.ru>
UART3 RX and TX pins are now moved to support uart download capability
on the platform. Old pins are now GPIOs routed to expansion ports.
All original boards should either have been returned for modifications
or already modified for the required change and maintaining
compatibility for older boards are no longer needed.
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
add support for imx6dl based aristainetos2 board
U-Boot 2015.04-rc5-00066-g60f6ed4 (Apr 10 2015 - 08:46:27)
CPU: Freescale i.MX6DL rev1.1 at 792 MHz
Reset cause: WDOG
Board: aristaitenos2
Watchdog enabled
I2C: ready
DRAM: 1 GiB
NAND: 1024 MiB
MMC: FSL_SDHC: 0
SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB
Display: lg4573 (480x800)
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
Due to licensing issues, the files ps7_init.c/h are not able to be
distributed with U-Boot source code. Recent Xilinx tools also
provide the GPL variants (ps7_init_gpl.c/h), compatible with U-Boot
license.
Prior to this commit, we had to copy ps7_init files into
board/xilinx/zynq/ before the compile.
To be more user-friendly, let's include ps7_init_gpl.c/h for
Zedboard, MicroZed, ZC702, ZC706.
These init code have been taken from the hwplatform_templates
directory of Xilinx SDK 2014.4.
You can still use customized ps7_init_gpl.c/h by enabling
CONFIG_ZYNQ_CUSTOM_INIT. The recommended directory for storing them
is now board/xilinx/zynq/custom_hw_platform, but board/xilinx/zynq
is still supported for backward compatibility. The latter emits
a warning message to prompt users to gradually switch to the new
directory.
Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Prior to this commit, ZC702 and ZC706 shared the same configuration
and were built as follows:
ZC702: make zynq_zc70x_defconfig && make
ZC706: make zynq_zc70x_defconfig && make DEVICE_TREE=zynq-zc706
This commit introduces separate configuration for them, which makes
the next commit much easier.
Going forward, the recommended build commands are:
ZC702: make zynq_zc702_defconfig && make
ZC706: make zynq_zc706_defconfig && make
Although the old work flow is still supported, CONFIG_TARGET_ZC70X
has been marked as deprecated. If used, the warning message is
shown to prompt users to switch to the new scheme.
Falcon mode entails the SPL booting the OS directly instead of U-Boot.
Currently we need to build one U-boot image for each of the wandboard
variants: quad, dual-lite and solo.
By switching to SPL we can support all these variants with a single binary,
which is very convenient.
Based on the work from Richard Hu.
Tested kernel booting on the three boards.
Signed-off-by: Richard Hu <hakahu@gmail.com>
Tested-by: Vagrant Cascadian <vagrant@aikidev.net>
Reviewed-by: Stefano Babic <sbabic@denx.de>
ccsr_ddr structure is already defined in fsl_immap.h. Remove
this duplicated define. Move fixed timing into ls1021atwr.h.
Signed-off-by: York Sun <yorksun@freescale.com>
CC: Alison Wang <alison.wang@freescale.com>
Acked-by: Alison Wang <alison.wang@freescale.com>
Remove the calls to net_random_ethaddr() that some boards and some
drivers are calling. This is now implemented inside of net/eth.c
Enable the feature for all boards that previously enabled it.
Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part)
Series-changes: 2
-Fixed bfin build errors
sunxi_usbc_vbus_detect was renamed to sunxi_usb_phy_vbus_detect but
g_dnl_board_usb_cable_connected was still using the old name, breaking the build
when USB gadget is enabled.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
The ga10h is an 10" tablet with an A33 or A23 soc, 1G RAM, 8G or 16G nand,
sdio wifi, 2 micro usb ports, 1 otg and 1 host and 1 micro sd slot.
This commit adds a defconfig for the v1.1 pcb with an a33 soc.
Make DRAM_ODT_EN Kconfig setting a bool, add a separate DRAM_ODT_CORRECTION
setting for A23 SoCs and use DRAM_ODT_EN Kconfig everywhere instead of
only in dram_sun4i.c and hardcoding odt_en elsewhere.
Note this commit makes no functional changes for existing boards,
its purpose is to allow changing the odt_en value on future A33 boards.
For sun4i/sun5i/sun7i boards which set DRAM_ODT_EN=y (which no defconfigs
currently do) this patch turns on odt for both the DQ and the DQS lines,
whereas previously it was possibly (but not desirable) to turn odt on only
for one of them by setting the in DRAM_ODT_EN option to 1 or 2 instead of 3.
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
We don't need this on sunxi, as we always use calloc or memset when
initialised memory is required. Clearing this shaves some time of our
boot time.
Change PUZE_100_SW1ABCONF to PFUZE100_SW1ABCONF
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
The 'mx6-microsom' directory was only used for the previous mx6solo
hummingboard support, which has been removed in favour of the SPL
version.
Remove the remaining piece of the old mx6solo hummingboard support.
We need to do any PMIC setup in the SPL if we are to bypass U-Boot for
falcon mode.
Certain features we desire require a larger stack than is available by using
iRAM (most notably for us, env_mmc). Relocate the stack to DRAM so that
we can use these features.
If the SPL is to be used for Falcon mode then we need to make sure the SPL
disable the GSC boot watchdog.
If the SPL is to be used for Falcon mode then we need to make sure it
configures basic GPIO (iomux, padconf, and default output levels).
Now that uart and i2c setup functions have been moved to common.c we can
use these and remove code duplication.
Avoid requiring board-model and probe pmic by its i2c address.
This is in preparation for being able to call pmic_setup() from SPL
and not need board type.
Move the code that disables the GSC boot watchdog into gsc.c
Move shared functions used by both SPL and U-Boot to common.c:
- setup_iomux_uart() and uart pad config
- gpio pad config
In the process also moved the following to common.c in preparation for
calling it from the SPL:
- split i2c setup into a shared function
- move pmic init to setup_pmic() function to call directly from
power_init_board()
- split gpio setup into early (iomux and default pin config)
and late (output configuration based on env)
