path: root/board
2015-03-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-03-05mx5: fix get_reset_causeStefano Babic
commit d9f43c8f5c1d7ed27c99a06be85a4bb64b2c73fb sets get_reset_cause() as static, but this conflicts with mx5 where its prototype is in sys_proto.h. Drop it from sys_proto.h and drop print_cpuinfo from mx53_loco, factorizing the call for this board. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Jason Liu <jason.hui@linaro.org>
2015-03-04dm: tegra: Enable driver model in SPL and adjust the GPIO driverSimon Glass
Use the full driver model GPIO and serial drivers in SPL now that these are supported. Since device tree is not available they will use platform data. Remove the special SPL GPIO function as it is no longer needed. This is all in one commit to maintain bisectability. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-03-04Odroid U3: use common code for dram reservationPrzemyslaw Marczak
This commit removes the dram reservation from board file, because it is done in a common code. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-03-04board: samsung: reserve memory for the secure firmwarePrzemyslaw Marczak
Since more than one board requires memory reservation for the secure firmware, the reservation code can be made in a common code. Now, to reserve some part of the the last bank, board config should define: - CONFIG_TZSW_RESERVED_DRAM - len in bytes - CONFIG_NR_DRAM_BANKS - number of memory banks Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Hyungwon Hwang <human.hwang@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-03-04samsung: board: fix: Define loop iterator as an unsigned int to suppress gcc ↵Łukasz Majewski
4.8 warning This patch suppress following warning: board/samsung/common/board.c:95:32: warning: iteration 4u invokes undefined behavior [-Waggressive-loop-optimizations] addr = CONFIG_SYS_SDRAM_BASE + (i * SDRAM_BANK_SIZE); ^ board/samsung/common/board.c:94:2: note: containing loop about possible signed integer overflow at gcc 4.8.2 (odroid board) Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-03-02mpc837xerdb: "fix Calling __hwconfig without a buffer" warningSinan Akman
Signed-off-by: Sinan Akman <sinan@writeme.com>
2015-03-02Merge branch 'xnext/zynqmp' of git://www.denx.de/git/u-boot-microblazeTom Rini
2015-03-02arm64: Add Xilinx ZynqMP supportMichal Simek
Add basic Xilinx ZynqMP arm64 support. Serial and SD is supported. It supports emulation platfrom ep108 and QEMU. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-03-02MAINTAINERS, git-mailrc: Update my email addressTom Rini
2015-03-02Merge git://git.denx.de/u-boot-usbTom Rini
2015-03-02Merge git://git.denx.de/u-boot-pxaTom Rini
2015-03-02warp: Add USB Mass Storage supportFabio Estevam
With UMS support we are able to flash the eMMC from U-boot, which is very convenient. Add UMS support to make the eMMC flashing process easier. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2015-03-02mx6slevk: Provide a proper pad configuration for OTG1_ID pinFabio Estevam
Pass the same pad configuration as done in the kernel so that OTG1_ID pin can properly work in device mode. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-03-02pxa: fix wrong comment about vpac270 being the arch numberMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2015-03-02mx25pdk: Turn on the LCD supplyFabio Estevam
Currently there is no support for MC34704 PMIC in the mainline kernel. Turn on the LCD supply via bootloader for the time being, so that we could use the LCD in the kernel. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-03-02Merge branch 'master' of git://git.denx.de/u-bootStefano Babic
2015-03-01Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2015-02-25Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-02-25odroid: adjust get_dfu_alt_*() functions to new declarationsInha Song
This change is required after updated dfu_alt_system/boot declarations. Signed-off-by: Inha Song <ideal.song@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [Test HW: Odroid U3 (Exynos 4412)] Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2015-02-25dfu: samsung: move call to set_dfu_alt_info() to dfu common codePrzemyslaw Marczak
This common call can be used for setting proper entities based on dfu command arguments. The config: CONFIG_SET_DFU_ALT_INFO, was used only for few configs, and now it is common. The board file should implement: - set_dfu_alt_info() function Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [Test HW: Odroid U3 (Exynos 4412)]
2015-02-25arm: rmobile: silk: Add support SDHIVladimir Barinov
This adds GPIO configuration and initialization function of SDHI on Silk board Signed-off-by: Vladimir Barinov <vladimir.barinov+renesas@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: silk: fix typo in device declarationVladimir Barinov
Fix typo in device declaration Signed-off-by: Vladimir Barinov <vladimir.barinov+renesas@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: silk: Disable ethernet pins pull-upVladimir Barinov
Disable pull-ups on ethrenet lines Signed-off-by: Vladimir Barinov <vladimir.barinov+renesas@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: silk: Fix GPIO4_31 initializationVladimir Barinov
Use gpio_direction_output instead of gpio_set_value since the latter does not set output GPIO direction. Signed-off-by: Valentine Barshak <valentine.barshak+renesas@cogentembedded.com> Signed-off-by: Vladimir Barinov <vladimir.barinov+renesas@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: Add Porter board supportVladimir Barinov
Porter is an entry level development board based on R-Car M2 SoC (R8A7791) This commit supports the following peripherals: - SCIF, I2C, Ethernet, QSPI, SD, USB Host Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: lager: Add support SDHINobuhiro Iwamatsu
Lager board has two SDHI port as SDHI0 and SDHI2. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: gose: Add support SDHINobuhiro Iwamatsu
Gose board has three SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: koelsch: Add support SDHINobuhiro Iwamatsu
Koelsch board has three SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: alt: Add support SDHINobuhiro Iwamatsu
Alt board has two SDHI port. This adds GPIO configuration and initialization function of SDHI, and enables MMC command. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: silk: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Silk board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: alt: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Alt board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: lager: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Lager board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: gose: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Gose board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-25arm: rmobile: koelsch: Migrate serial driver to drivers modelNobuhiro Iwamatsu
This adds drivers model support of serial port to Koelsch board, and migrate serial port to drivers model. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-24ARM: davinci: remove hawkboard supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Syed Mohammed Khasim <sm.khasim@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove tnetv107x board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Chan-Taek Park <c-park@ti.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove a320evb board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Po-Yu Chuang <ratbert@faraday-tech.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove cm4008 and cm41xx board supportMasahiro Yamada
These are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Greg Ungerer <greg.ungerer@opengear.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove dkb board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Lei Wen <leiwen@marvell.com> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24ARM: remove jadecpu board supportMasahiro Yamada
This is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Matthias Weisser <weisserm@arcor.de> Acked-by: Marek Vasut <marex@denx.de>
2015-02-24kconfig: remove unneeded dependency on !SPL_BUILDMasahiro Yamada
Now CONFIG_SPL_BUILD is not defined in Kconfig, so "!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-24arm: ls1021x: Add support for initializing CAAM's stream idAlison Wang
There 4 JRs, 4 RTICs and 8 DECOs, and set them the same stream id for using the same SMMU3 on LS1021A. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-24drivers/mc: Migrated MC Flibs to 0.5.2J. German Rivera
Upgrade Manage Complex (MC) flib API to 0.5.2. Rename directory fsl_mc to fsl-mc. Change the fsl-mc node in Linux device tree from "fsl,dprcr" to "fsl-mc". Print MC version info when appropriate. Signed-off-by: J. German Rivera <German.Rivera@freescale.com> Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-02-24ARMv8/LS2085A: Enable auto precharge for DP-DDRYork Sun
DP-DDR benefits from auto precharge because of its specific application. Signed-off-by: York Sun <yorksun@freescale.com>
2015-02-24armv8/ls2085a: Enable cluster timebase for all clustersYork Sun
LS2085A and its variants can have up to four clusters. It is safe to enable timebase for all even some may be disabled. Signed-off-by: York Sun <yorksun@freescale.com>
2015-02-23warp: Add initial WaRP Board supportOtavio Salvador
The WaRP Board is a Wearable Reference Plaform. The board features: - Freescale i.MX6 SoloLite processor with 512MB of RAM - Freescale FXOS8700CQ 6-axis Xtrinsic sensor - Freescale Kinetis KL16 MCU - Freescale Xtrinsic MMA955xL intelligent motion sensing platform The board implements a hybrid architecture to address the evolving needs of the wearables market. The platform consists of a main board and an example daughtercard with the ability to add additional daughtercards for different usage models. For more information about the project, visit: http://www.warpboard.org/ Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Marek Vasut <marex@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2015-02-23imx:mx6slevk implement power init boardPeng Fan
Implement power_init_board and related I2C interface configuration. After adding this, uboot can successfully detect and configure pmic. " U-Boot 2015.01-00281-ge29eddf (Feb 12 2015 - 09:24:01) CPU: Freescale i.MX6SL rev1.0 at 396 MHz Reset cause: POR Board: MX6SLEVK I2C: ready DRAM: 1 GiB PMIC: PFUZE100 ID=0x10 MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 " Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-02-23board: tbs2910: Gate clock when switching async clock muxesSoeren Moch
According to the i.MX6Q Reference Manual, clocks must be gated when switching input clocks of async clock muxes. So use clock gates. Avoid ldb_di0_ipu clock, because there is no clock gate for this signal. There have never been any complaints about problems with the old code, but the new approach is in line with the recommendations in the manual. Signed-off-by: Soeren Moch <smoch@web.de>
2015-02-21Merge git://git.denx.de/u-boot-sunxiTom Rini
