- added to soft_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
As both the DDR SDRAM and NAND flash connect to EBI on at91sam9n12
and share the lower 8 bits data line. If use low drive of the data
line, it will cause DDR data access corrupt in lower address, so
change the data line to high drive mode
This will fix the Linux kernel boot issue when use Lower address
Signed-off-by: Bo Shen <voice.shen@atmel.com>
Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
The old value of 0x000e0030 will cause ethernet
timeout issues on the sabrelite and possibly other
boards using the KSZ9021.
I have no explanation as to why.
But this is a correct change, the TRM will be updated
to show that 00b is the only valid setting for bits
19-18 of DRAM_RESET.
My thanks go to Liu Hui(Jason) for this information.
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
The gdsys ControlCenter Digital board is based on a Freescale P1022 QorIQ SOC.
It boots from SPI-Flash but can be configured to boot from SD-card for
factory programming and testing.
On board peripherals include:
- 2x GbE
- Lattice ECP3 FPGA connected via PCIe
- mSATA RAID1
- USB host
- DisplayPort video output
- Atmel TPM
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc>
Signed-off-by: Andy Fleming <afleming@freescale.com>
Before setting: mipi_lcd_device.reverse_panel = 1, the Trats's LCD panel
was flipped by 180 degrees.
The flip was caused by following change:
Exynos: Change get_timer() to work correctly
SHA1: 3d00c0cb96ff93a929700b80d89cb905e5ab5315
This commit fixed udelay(), which is necessary (due to HW LCD controller
oddity) for mipi-dsi correct operation. As a result the display orientation
has been switched.
As a follow up, the hwrevision() function has been removed, since it was
used only in this particular place.
Test HW: Trats Exynos4210 rev 0.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
Fix:
mpc8323erdb.c: In function 'mac_read_from_eeprom':
mpc8323erdb.c:198:3: warning: dereferencing type-punned pointer will
break strict-aliasing rules [-Wstrict-aliasing]
cc: Timur Tabi <timur@tabi.org>
cc: Kim Phillips <kim.phillips@freescale.com>
The files board/qi/qi_lb60/qi_lb60.c and include/configs/qi_lb60.h were
licensed under the GPL v3 or later, and not v2 or later. As this is
incompatible with the project, revert this board support until the
responsible parties are available to re-license (if so desired) under
GPL v2.
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and
serial.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Tegra30 and Tegra114 are compatible except PLL parameters.
Tested on Tegra30 Cardhu, and Tegra114 Dalmore
platforms. All works well.
Signed-off-by: Jim Lin <jilin@nvidia.com>
Add DT node for USB EHCI function.
Add support for T30-Cardhu, T30-Beaver, T114-Dalmore boards.
This patch resolves the below mentioned compilation error of i2c driver
for non-FDT case
Compilation error:
s3c24x0_i2c.c: In function 'board_i2c_init':
s3c24x0_i2c.c:544:18: error: 'CONFIG_MAX_I2C_NUM' undeclared (first use
in this function) s3c24x0_i2c.c:544:18: note: each undeclared
identifier is reported only once for each function it appears in
s3c24x0_i2c.c:545:3: warning: implicit declaration of function
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Signed-off-by: Amar <amarendra.xt@samsung.com>
This patch performs the following:
1) Convert the assembly code for memory and clock initialization to C code.
2) Move the memory and clock init codes from board/samsung to arch/arm
3) Creat a common lowlevel_init file across Exynos4 and Exynos5. Converted
the common lowlevel_init from assembly to C-code
4) Made spl_boot.c and tzpc_init.c common for both exynos4 and exynos5.
5) Enable CONFIG_SKIP_LOWLEVEL_INIT as stack pointer initialisation is already
done in _main.
6) exynos-uboot-spl.lds made common across SMDKV310, Origen and SMDK5250.
TEST: Tested SD-MMC boot on SMDK5250 and Origen.
Tested USB and SPI boot on SMDK5250
Compile tested for SMDKV310.
This patch configures the gpio values for UART
on Origen and SMDKV310 using pinmux
smdk5250-uboot-spl.lds is moved to common folder, so that it can be reused.
It is renamed to exynos-uboot-spl.lds
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com>
enum boot_mode is defined twice once in spl.h and also in
spl_boot.c, hence removing the same from spl_boot.c and including
the header file.
Fix:
misc.c: In function 'misc_init_r':
misc.c:210:3: warning: dereferencing type-punned pointer will break
misc.c:211:3: warning: dereferencing type-punned pointer will break
misc.c:212:3: warning: dereferencing type-punned pointer will break
Board specific READMEs should be located inside the respective board directory.
The SabreSD platform is available with i.MX6Q or i.MX6DL. This patch adds the
support of the i.MX6DL. The config file and the board directory are renamed
to remove the reference to the MX6Q.
Signed-off-by: Pierre Aubert <p.aubert@staubli.com>
CC: Stefano Babic <sbabic@denx.de>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
This patch initiates cros-ec in board_init() to enable it for smdk5250.
This patch depends on the patch in the MMC series that brings in exynos5-dt.c.
Refer to http://patchwork.ozlabs.org/patch/240084.
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
Signed-off-by: Hung-ying Tyan <tyanh@chromium.org>
This patch adds cros-ec related device nodes to exynos5250-snow.dts.
It also adds a gpio node to exynos5250.dtsi.
Add support for the Quad version of Wandboard; fix compile warning resulting
from having 2G of memory.
Signed-off-by: Tapani Utriainen <tapani@technexion.com>
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
add network support with ksz8851_16mll on at91sam9n12ek board
re-order the conditions which make the recovery system startup: combine
those conditions which were explicitly initiated (key press, software
request) and those which post-process error conditions (installer issues)
Signed-off-by: Gerhard Sittig <gsi@denx.de>
- minor rewording of diagnostics output
- make diagnostics optional and off by default
fix typos, minor rephrasing, remove obsolete notes and TODO items
getenv() immediately after setenv() may perfectly legally return NULL, so
make sure to not deference an invalid pointer when creating diagnostic output
This patch adds the device node required for serial driver
Signed-off-by: Abhilash Kesavan <a.kesavan@samsung.com>
Some Exynos5250 silicon may require 1.05v on the MIF to be stable, so to be
safe we can default to 1.05v instead of 1.00v. This can be set optimally later
in the boot process by the kernel.
The 0x6 value for 1.05v comes from the MAX77686 datasheet.
Signed-off-by: Bernie Thompson <bhthompson@chromium.org>
This patch adds support for the Palm Treo 680 smartphone. A quick overview of
u-boot implementation on the treo 680...
The treo 680 has a Diskonchip G4 nand flash chip. This device has a 2k region
that maps to the system bus at the reset vector in a NOR-like fashion so that it
can be used as the boot device. The phone is shipped with this 2k region
configured as write-protected (can't be modified) and programmed with an initial
program loader (IPL). At power-up, this IPL loads the contents of two flash
blocks to SDRAM and jumps to it. The capacity of the two blocks is not large
enough to hold all of u-boot, so a u-boot SPL is used. To conserve flash space,
these two blocks and the necessary number of subsequent blocks are programmed
with a concatenated spl + u-boot image. That way, the IPL will also load a
portion of u-boot proper, and when the spl runs, it relocates the portion of
u-boot that the IPL has already loaded, and then resumes loading the remaining
part of u-boot before jumping to it.
The default_environment is used (CONFIG_ENV_IS_NOWHERE) because I didn't think
that having a writable environment was worth the cost of a flash block, although
adding it would be straightforward. I abuse the CONFIG_EXTRA_ENV_SETTINGS
option to specify the usbtty for the console (CONFIG_SYS_CONSOLE_IS_IN_ENV).
Support for the LCD is included, but currently it is only useful for displaying
the u-boot splash screen. But if u-boot is built without the usbtty console, it
does display the auto-boot progress nicely.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
This change is only done where needed: some linker
scripts may contain relocation symbols yet remain
unchanged.
__rel_dyn_start and __rel_dyn_end each requires
its own output section; putting them in relocation
sections changes their flags and breaks relocation.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Tested-by: Lubomir Popov <lpopov@mm-sol.com>
Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
scripts may contain __image_copy_{start,end} yet
remain unchanged.
Also, __image_copy_end needs its own section; putting
it in relocation sections changes their flags and makes
relocation break.
Discard all .dynsym sections from linker scripts
Remove all __dynsym_start definitions from linker scripts
Remove all __dynsym_start references from the codebase
Note: this touches include/asm-generic/sections.h, which
is not ARM-specific, but actual uses of __dynsym_start
are only in ARM, so this patch can safely go through
the ARM repository.
Snow has an internal eMMC and an external SD card. Enable these in the
device tree.
P1023RDB Specification:
Memory subsystem:
512MB DDR3 (Fixed DDR on board)
64MB NOR flash
128MB NAND flash
Ethernet:
eTSEC1: Connected to Atheros AR8035 GETH PHY
eTSEC2: Connected to Atheros AR8035 GETH PHY
PCIe:
Three mini-PCIe slots
USB:
Two USB2.0 Type A ports
I2C:
AT24C08 8K Board EEPROM (8 bit address)
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
Cc: Scott Wood <scottwood@freescale.com>
"pixis_reset help" command prints the message without a new line "\n",
which makes the prompt on the same line.
Signed-off-by: York Sun <yorksun@freescale.com>
PCIe TLB should be created with CONFIG_PCI defined
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
When a T4 board boots from SRIO or PCIE, it needs to finish these processes:
1. Set all the cores in holdoff status.
2. Set the boot location to one PCIE or SRIO interface by RCW.
3. Set a specific TLB entry for the boot process.
4. Set a LAW entry with the TargetID of one PCIE or SRIO for the boot.
5. Set a specific TLB entry in order to fetch ucode and ENV from
master.
6. Set a LAW entry with the TargetID one of the PCIE ports for
ucode and ENV.
7. Slave's u-boot image should be generated specifically by
make xxxx_SRIO_PCIE_BOOT_config.
This will set SYS_TEXT_BASE=0xFFF80000 and other configurations.
For more information about the feature of Boot from SRIO/PCIE, please
refer to the document doc/README.srio-pcie-boot-corenet.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
When a b4860qds board boots from SRIO or PCIE, it needs to finish these
processes:
master.
ucode and ENV.
e500v2 processor does not support 8K page size TLB entries.
So create new TLB entry only during NAND SPL boot.
All the other constants use lowercase 'x' in "MPC85xx", so we
duplicate that here.
