The spd_dram code shifts the base address, then masks 20 bits, but
forgets to shift the base address back. Fix this by just masking the
base address correctly.
Found this bug while trying to relocate a DDR memory at the base != 0.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
Depending on the configuration jumper "SATA SELECT", U-Boot disabled
either one PCIe node or the SATA node in the device tree blob. This
patch removes the unnecessary and even confusing warning, when the node
is not found at all.
Currently U-Boot crashes after relocation to RAM.
Changing the CPO value of the DDR SDRAM TIMING_CFG_2
register to READ_LAT + 1 (to the value it was before
conversion of socrates to new DDR code) fixes the
problem.
Add function of smc911x, pkt_data_pull and pkt_data_push.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
After switching to using the CFI flash driver, the correct remapping
of the flash banks was forgotten.
Also, some boards were not adapted, and the old legacy flash driver
was not removed yet.
This patch is an attempt to implement autoprobing for the Lime
presence on the bus.
Configure GPCM for Lime CS2 and try to access chip ID registers.
Second read atempt delivers register values if the chip is present.
netdev.h was not include by r2dplus.
This patch fixes a problem introdiced with patch
bbeff30c [ppc4xx: Remove superfluous dram_init() call or replace it by
initdram()].
The boards affected are:
- PCI405
- PPChameleonEVB
- quad100hd
- taihu
- zeus
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
add CMD_DATA_SIZE macro to enable it
- #if CFG_ENV_IS_IN_FLASH
- #if (CFG_ENV_IS_IN_FLASH == 1)
- #define CFG_ENV_IS_IN_FLASH 0
This is part of the switch to newer upstream MTD code.
Also set up the port pins for using I2C.
Fix the problem that cannot work RTL8169 on sh7785lcr board.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
We must link with libgeneric now.
This patch solves the problems compiling ml507, v5fx30teval and
ppc440-generic out of tree.
Attempt to bring i386 / sc520 inline with master
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
This patch adds Lime GDC support together with support for the PWM
backlight control through the w83782d chip. The reset pin of the
latter is attached to GPIO, so we need to reset it in
early_board_init_r.
- Update the local bus ranges in the FDT for Linux for the various
devices connected to the local bus via chip-select.
- Set the LCRR_DBYP bit in the LCRR for local bus frequencies
lower than 66 MHz and uses I/O accessor functions consequently.
- UPM data update.
- Update of default environment and configuration. Use I2C multibus
as we do have two I2C buses. Also enable sdram and ext2 commands.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
The new sys_eeprom.c supports both the old CCID EEPROM format and the new NXID
format, and so it obsoletes board/freescale/common/cds_eeprom.c. Freescale
86xx boards already use sys_eeprom.c, so this patch migrates the remaining
Freescale 85xx boards to use it as well. cds_eeprom.c is deleted.
Makefile
This patch moves some 4xx specific prototypes out of include common.h
to a ppc4xx specific header.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch replaces the BOARD_REVISION variable in include/config.mk
by a using a temporary include file in the platform directory.
The former way does not work anymore and the latter is also used by
some other boards.
I didn't try to use drivers/mtd/nand/fsl_upm.c for the NAND driver,
because I have no longer access to the hardware.
Fix compile problems caused by
commit cfa460adfdefcc30d104e1a9ee44994ee349bb7b
This patch provides an unificated way of handling xilinx v5 ppc440 boards.
It unificates 3 different things:
1) Source code
A new board called ppc440-generic has been created. This board includes
a generic tlb initialization (Maps the whole memory into virtual) and
defines board_pre_init, checkboard, initdram and get_sys_info weakly,
so, they can be replaced by specific functions.
If a new board needs to redefine any of the previous functions
(specific initialization) it can create a new directory with the
specific initializations needed. (see the example ml507 board).
2) Configuration file
Common configurations are located under configs/xilinx-ppc440.h, this
header file interpretes the xparameters file generated by EDK and
configurates u-boot in correspondence. Example: if there is a Temac,
allows CMD_CONFIG_NET
Specific configuration are located under specific configuration file.
3) Makefile
Some work has been done in order to not duplicate work in the Main
Makefile. Please see the attached code.
In order to support new boards they can be implemented in the next way:
a) Simple Generic Board (90% of the time)
Using EDK generates a new xparameters.h file, replace
ppc440-generic/xparameters.h and run make xilinx-ppc440-generic_config
&& make
b) Simple Boards with special u-boot parameters (9 % of the time)
Create a new file under configs for it (use ml507.h as example) and
change your paramaters. Create a new Makefile paragraph and compile
c) Complex boards (1% of the time)
Create a new folder for the board, like the ml507
Finally, it adds support for the Avnet FX30T Evaluation board, following
the new generic structure:
Cheap board by Avnet for evaluating the Virtex5 FX technology.
This patch adds support for:
- UartLite
- 16MB Flash
- 64MB RAM
Prior using U-boot in this board, read carefully the ERRATA by Avnet
to solve some memory initialization issues.
