path: root/board
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: select CONFIG_DM* optionsMasahiro Yamada
As mentioned in the previous commit, adding default values in each Kconfig causes problems because it does not co-exist with the "depends on" syntax. (Please note this is not a bug of Kconfig.) We should not do so unless we have a special reason. Actually, for CONFIG_DM*, we have no good reason to do so. Generally, CONFIG_DM is not a user-configurable option. Once we convert a driver into Driver Model, the board only works with Driver Model, i.e. CONFIG_DM must be always enabled for that board. So, using "select DM" is more suitable rather than allowing users to modify it. Another good thing is, Kconfig warns unmet dependencies for "select" syntax, so we easily notice bugs. Actually, CONFIG_DM and other related options have been added without consistency: some into arch/*/Kconfig, some into board/*/Kconfig, and some into configs/*_defconfig. This commit prefers "select" and cleans up the following issues. [1] Never use "CONFIG_DM=n" in defconfig files It is really rare to add "CONFIG_FOO=n" to disable CONFIG options. It is more common to use "# CONFIG_FOO is not set". But here, we do not even have to do it. Less than half of OMAP3 boards have been converted to Driver Model. Adding the default values to arch/arm/cpu/armv7/omap3/Kconfig is weird. Instead, add "select DM" only to appropriate boards, which eventually eliminates "CONFIG_DM=n", etc. [2] Delete redundant CONFIGs Sandbox sets CONFIG_DM in arch/sandbox/Kconfig and defines it again in configs/sandbox_defconfig. Likewise, OMAP3 sets CONFIG_DM arch/arm/cpu/armv7/omap3/Kconfig and defines it also in omap3_beagle_defconfig and devkit8000_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-04-18dm: usb: Drop the EHCI weak functionsSimon Glass
These are a pain with driver model because we might have different EHCI drivers which want to implement them differently. Now that they use consistent function signatures, we can in good conscience move them to a struct. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de> Fix non-driver-model EHCI to set up the EHCI operations correctly: Signed-off-by: Tom Rini <trini@konsulko.com>
2015-04-18dm: usb: Pass EHCI controller pointer to ehci_powerup_fixup()Simon Glass
Adjust this function so that it is passed an EHCI controller pointer so that implementations can look up their controller. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18exynos: cros_ec: Drop unnecessary initSimon Glass
Since driver model will probe the EC when it is first used, we do not need to init it explicitly. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18x86: cros_ec: Drop unnecessary initSimon Glass
2015-04-18sandbox: cros_ec: Drop unnecessary initSimon Glass
2015-04-18cros_ec: Drop unused CONFIG_DM_CROS_ECSimon Glass
Since all supported boards enable this option now, we can remove it along with the old code. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18sandbox: eth: Add support for using the 'lo' interfaceJoe Hershberger
The 'lo' interface on Linux doesn't support thinks like ARP or link-layer access like we use to talk to a normal network interface. A higher-level network API must be used to access localhost. As written, this interface is limited to not supporting ICMP since the API doesn't allow the socket to be opened for all IP traffic and be able to receive at the same time. UDP is far more useful to test with, so it was selected over ICMP. Ping won't work, but things like TFTP should work. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18sandbox: eth: Add a bridge to a real network for sandboxJoe Hershberger
Implement a bridge between U-Boot's network stack and Linux's raw packet API allowing the sandbox to send and receive packets using the host machine's network interface. This raw Ethernet API requires elevated privileges. You can either run as root, or you can add the capability needed like so: sudo /sbin/setcap "CAP_NET_RAW+ep" /path/to/u-boot Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18sandbox: eth: Add network support to sandboxJoe Hershberger
Add basic network support to sandbox which includes a network driver. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2015-04-18dm: x86: pci: Convert coreboot to use driver model for pciSimon Glass
Move coreboot-x86 over to driver model for PCI. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16x86: Add support for panther (Asus Chromebox)Simon Glass
Support running U-Boot as a coreboot payload. Tested peripherals include: - Video (HDMI and DisplayPort) - SATA disk - Gigabit Ethernet - SPI flash USB3 does not work. This may be a problem with the USB3 PCI driver or something in the USB3 stack and has not been investigated So far this is disabled. The SD card slot also does not work. For video, coreboot will need to run the OPROM to set this up. With this board, bare support (running without coreboot) is not available as yet. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-16ti: dwc3: Enable clocks in enable_basic_clocks() in hw_data.cKishon Vijay Abraham I
Commit d3cfcb3 (ARM: DRA7: Enable clocks for USB OTGSS and USB PHY) changed the member names of prcm_regs from cm_l3init_usb_otg_ss_clkctrl to cm_l3init_usb_otg_ss1_clkctrl and from cm_coreaon_usb_phy_core_clkctrl to cm_coreaon_usb_phy1_core_clkctrl in order to differentiate between the two dwc3 controllers present in dra7xx/am43xx and enabled these clocks in enable_basic_clocks() in hw_data.c. However these clocks continued to be enabled in board files/driver files for dwc3 host mode functionality causing compilation break with few configs. Fixed it here by making all the clocks enabled in enable_basic_clocks() and removing it from board files/driver files here. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-04-16Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-04-15sunxi: Complete i2c support for each supported platformPaul Kocialkowski
Sunxi platforms come with at least 3 TWI (I2C) controllers and some platforms even have up to 5. This adds support for every controller on each supported platform, which is especially useful when using expansion ports on single-board- computers. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: iNet 3F supportPaul Kocialkowski
The iNet 3F is an A10 tablet with 1GiB RAM and a 1024x768 screen. Also see: http://linux-sunxi.org/INet_3F Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: iNet 3W supportPaul Kocialkowski
The iNet 3W is an A10 tablet with 1GiB RAM and a 1024x768 screen. Also see: http://linux-sunxi.org/INet_3W Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: Proper iNet board config namingPaul Kocialkowski
The official name for the iNet manufacturer is iNet with a lowercase i and an uppercase N. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Michal Suchanek <hramrach@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: Removed dram files cleanup in MAINTAINERSPaul Kocialkowski
A few dram files were still listed as maintained even though they were removed some time ago Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: Serial number support, obtained from SID bitsPaul Kocialkowski
2015-04-15sunxi: Yones Toptech BD1078 supportPaul Kocialkowski
The Yones Toptech BD1078 is an A20 based 10" tablet with a 1024x600 lcd screen, volume up/down and back buttons, headphones jack, mini hdmi, micro usb (otg), micro usb (host), external micro-sd slot and a separate internal micro-sd slot. Also see: http://linux-sunxi.org/Yones_Toptech_BD1078 Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: Complete mmc pin mux for each supported platform, configured with KconfigPaul Kocialkowski
Sunxi platforms have different possible mmc pin mux setups (except for mmc0), which are different across platforms. This lets users configure which is used through the CONFIG_MMC*_PINS Kconfig options. This is especially relevant when a second (in addition to mmc0) port is used and CONFIG_MMC_SUNXI_SLOT_EXTRA is enabled. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: GPIO pin mux hardware-feature-specific function index definesPaul Kocialkowski
Each hardware feature exposed through the GPIO pin mux is usually using the same function index (for a given port), so there is no need to define one value per pin: one value per hardware feature per port is sufficient, avoids duplication and makes everything easier to understand. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: Ainol AW1 supportPaul Kocialkowski
The Ainol AW1 is an A20 based tablet with a 800x480 lcd screen, sdio wifi, volume up/down and home buttons, micro-sd slot, micro usb (otg), headphones connector and a SPCI modem connector. Also see: http://linux-sunxi.org/Ainol_AW1 Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sunxi: USB download gadget cable detectionPaul Kocialkowski
2015-04-15sunxi: common VBUS detection logic in usbcPaul Kocialkowski
VBUS detection could be needed not only by the musb code (to prevent host mode), but also by e.g. gadget drivers to start only when a cable is connected. In addition, this allows more flexibility in vbus detection, as it could easily be extended to other USBC indexes. Eventually, this would help making musb support independent from a hardcoded USB controller index (0). Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-15sun6i: Add support for the Mixtile LOFT-Q boardHan Pengfei
The Mixtile LOFT-Q is an A31 based board with 2G RAM, 8G EMMC, sdio wifi, 1Gbit ethernet, HDMI display, toslink audio plug, 4 USB2.0 port, external USB2SATA connector, sd card plug, 3x60 external fpic expansion connector, NXP JN5168 zigbee gw, remote support. Also see http://focalcrest.com/en/pc.html#pro02 Signed-off-by: Han Pengfei <pengphei@sina.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-04-14usb: board: goni: Add default board_usb_cleanup() definition for Goni boardLukasz Majewski
This definition is necessary for S5PC110 based GONI board to work properly. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14usb: board: samsung: Add default board_usb_cleanup() definition for Exynos SoCsLukasz Majewski
This definition is necessary for Exynos based boards to work properly. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14usb: modify usb_gadget_handle_interrupts to take controller indexKishon Vijay Abraham I
Since we support multiple dwc3 controllers to be existent at the same time, in order to handle the interrupts of a particular dwc3 controller usb_gadget_handle_interrutps should take controller index as an argument. Hence the API of usb_gadget_handle_interrupts is modified to take controller index as an argument and made the corresponding changes to all the usb_gadget_handle_interrupts calls. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14board: ti: AM43xx: added USB initializtion codeKishon Vijay Abraham I
Implemented board_usb_init(), board_usb_cleanup() and usb_gadget_handle_interrupts() in am43xx board file that can be invoked by various gadget drivers. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-14board: ti: DRA7: added USB initializtion codeKishon Vijay Abraham I
Implemented board_usb_init(), board_usb_cleanup() and usb_gadget_handle_interrupts() in dra7xx board file that can be invoked by various gadget drivers. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com>
2015-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-04-13ARM: rpi: add a couple more revision IDsStephen Warren
According to Gordon Henderson's WiringPi library, there are some more Pi revision IDs out there. Add support for them. http://git.drogon.net/?p=wiringPi;a=blob_plain;f=wiringPi/wiringPi.c;hb=5edd177112c99416f68ba3e8c6c4db6ed942e796 At least ID 0x13 is out in the wild: Reported-by: Chee-Yang Chau <cychau@gmail.com> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-04-10Merge git://git.denx.de/u-boot-arcTom Rini
2015-04-10Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2015-04-10lpc32xx: add support for board work_92105Albert ARIBAUD \(3ADEV\)
Work_92105 from Work Microwave is an LPC3250- based board with the following features: - 64MB or 128MB SDR DRAM - 1 GB SLC NAND, managed through MLC controller. - Ethernet - Ethernet + PHY SMSC8710 - I2C: - EEPROM (24M01-compatible) - RTC (DS1374-compatible) - Temperature sensor (DS620) - DACs (2 x MAX518) - SPI (through SSP interface) - Port expander MAX6957 - LCD display (HD44780-compatible), controlled through the port expander and DACs This board has SPL support, and uses the LPC32XX boot image format. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-04-09odroid-XU3: update board maintainerPrzemyslaw Marczak
At present Hyungwon can't take care of this board in U-Boot, so I will keep it working. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Hyungwon Hwang <human.hwang@samsung.com>
2015-04-09mcx: update maintainer and convert to generic boardAnatolij Gustschin
Remove obsolete email address from MAINTAINERS. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Tom Rini <trini@konsulko.com>
2015-04-09board: axs10x - support v3 mother-boardAlexey Brodkin
There're 2 versions of motherboards that could be used in ARC SDP. The only important difference for U-Boot is different NAND IC in use: [1] v2 board (we used to support up until now) sports MT29F4G08ABADAWP while [2] v3 board sports MT29F4G16ABADAWP They are almost the same except data bus width 8-bit in [1] and 16-bit in [2]. And for proper support of 16-bit data bus we have to pass NAND_BUSWIDTH_16 option to NAND driver core - which we do now knowing board type we're running on. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-04-09ARM: mx5: add support for USB armory boardAndrej Rosano
Add support for Inverse Path USB armory board, an open source flash-drive sized computer based on Freescale i.MX53 SoC. http://inversepath.com/usbarmory Signed-off-by: Andrej Rosano <andrej@inversepath.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Chris Kuethe <chris.kuethe@gmail.com> Cc: Fabio Estevam <festevam@gmail.com> Cc: Vagrant Cascadian <vagrant@debian.org> Tested-By: Vagrant Cascadian <vagrant@debian.org> Tested-by: Chris Kuethe <chris.kuethe@gmail.com>
2015-04-08ARM: zynq: Remove Jagan from list of maintainersMichal Simek
Email address is not longer valid that's why remove it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-08mx53loco: Disable printing cpuinfoFabio Estevam
Since commit 32df39c741788e ("mx5: fix get_reset_cause") we have the following boot messages on a mx53qsb: U-Boot 2015.04-rc5-00029-gd68df02 (Apr 06 2015 - 11:15:39) CPU: Freescale i.MX53 rev2.1 at 800 MHz Reset cause: POR Board: MX53 LOCO I2C: ready DRAM: 1 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial Out: serial Err: serial CPU: Freescale i.MX53 rev2.1 at 1000 MHz Reset cause: unknown reset Net: FEC [PRIME] The CPU and Reset cause lines appear twice. Initially mx53 boots at 800MHz, then at a later point the PMIC is configured via I2C to raise the CPU voltage so that it can run at 1GHz. To avoid such misleading double printings, disable printing cpu info for now. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <r64343@freescale.com>
2015-04-06smdk5420: Remove GPIO enumsAjay Kumar
Remove GPIOs from smdk5420 board file and because the same is already specified via DT. Signed-off-by: Ajay Kumar <ajaykumar.rs@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-04-03Merge git://git.denx.de/u-boot-arcTom Rini
2015-04-03Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
Conflicts: board/armltd/vexpress64/vexpress64.c Signed-off-by: Tom Rini <trini@konsulko.com>
2015-04-03board: AXS10x - update SDIO clock valueAlexey Brodkin
With the most recent board firmware correct SDIO clock is 50MHz as opposed to 25 MHz before. Also set max frequency of MMC data exchange equal to SDIO clock - because there's no way to transfer data faster than interface clock. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-03-31Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
