path: root/board
2009-03-13OMAP3: Add support for OMAP3 die IDDirk Behme
Read and store OMAP3 die ID in U-Boot environment. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-03-09fsl: Remove unnecessary debug printfsAndy Fleming
These were left in accidentally, and are not really useful unless the code is as broken as it was when it was being developed. Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-03-09Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
Conflicts: lib_ppc/board.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-0583xx, kmeter: QE_ENET10 errata for Silicon Revision 2.1Heiko Schocher
old code implemented the QE_ENET10 errata only for Silicon Revision 2.0. New code reads now the Silicon Revision register and sets dependend on the Silicon Revision the values as advised in the QE_ENET10 errata. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-0583xx, kmeter1: autodetect size of DDR II RAMHeiko Schocher
it is possible that some board variants have different DDR II RAM sizes. So we autodetect the size of the assembled RAM. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-0583xx, kmeter1: add I2C, dtt, eeprom supportHeiko Schocher
This patch adds I2C support for the Keymile kmeter1 board. It uses the First I2C Controller from the CPU, for accessing 4 temperature sensors, an eeprom with IVM data and the booteeprom over a pca9547 mux. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-03-05mpc83xx: MPC837XEMDS: Initialize SerDes before negating PCIE reset signalAnton Vorontsov
The SerDes initialization should be finished before negating the reset signal according to the reference manual. This isn't an issue on real hardware, but we'd better stick to the specifications anyway. Suggested-by: Liu Dave <DaveLiu@freescale.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-24Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2009-02-24Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2009-02-24ARM: add an "eet" variant of the imx31_phycore boardGuennadi Liakhovetski
The "eet" variant of the imx31_phycore board has an OLED display, using a s6e63d6 display controller on the first SPI interface, using GPIO57 as a chip-select for it. With this configuration you can display 256 colour BMP images in 16-bit RGB (RGB565) LCD mode. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-02-23mpc83xx: MPC837XERDB: Add PCIe supportAnton Vorontsov
On MPC8377E-RDB and MPC8378E-RDB boards we have PCIe and mini-PCIe slots. Let's support them. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-23mpc8641hpcn: Indicate 36-bit addr map in boot messagesBecky Bruce
If 36-bit addressing is enabled, print a message on the console when we boot. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-02-22OMAP3: Pandora: Update pin muxDirk Behme
Clock pin must have input enabled for MMC3 to work. Also enable pull-ups for cmd/data lines to be consistent with remaining MMC host pin setup. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2009-02-22OMAP3: Add OMAP3 auto detectionDirk Behme
This patch adds OMAP3 cpu type auto detection based on OMAP3 register and removes hardcoded values. Signed-off-by: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-02-22OMAP3: Beagle: Add board revision detectionDirk Behme
With BeagleBoard revision C some HW changes are introduced (e.g. PinMUX) which might need different software handling. For this, GPIO pin 171 (GPIO module 6, offset 11) can be used to check for board revision. If this pin is low, we have a rev C board. Else it must be a revision Ax or Bx board. To handle board differences you can call function beagle_get_revision(). E.g.: if (beagle_get_revision()) { /* do special revision C stuff here */ } Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-02-22OMAP3: Overo: Clean up pin mux and GPIO configurationDirk Behme
* Make Overo GPIO114 an input for touchscreen PENDOWN * Make Overo GPIO144-147 readable * Make Overo EHCI pinmux match beagle rev c setup * Adjust pinmux for SMSC911X network chip support * Remove unnecessary GPIO setup * Fix merge error in Makefile Signed-off-by: Steve Sakoman <sakoman@gmail.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-02-22davinci: fix implicit declaration of function 'davinci_errata_workarounds'Jean-Christophe PLAGNIOL-VILLARD
2009-02-22ARM DaVinci: Add common peripherals and modules enable functions.Hugo Villeneuve
Taken all the duplicated code for enabling common modules and apply software workarounds from the board specific code into common functions. Also added comments explaining the workarounds (from TI errata documents) and replaced some numerical bit numbers with more meaningful defines. Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
2009-02-22Enable Ethernet for Nomadik 8815 Evaluation KitAlessandro Rubini
This trivially enables Ethernet support in the debug board by setting up the proper chip select. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stnwireless.com>
2009-02-22Coding Style cleanup; update CHANGELOGWolfgang Denk
2009-02-1982xx, mgcoge: updates for 2009.03Heiko Schocher
- activate CS4 for accessing the FPGA - activate Rx buf len > 1 on SMC - pram activated - MTDPARTS_DEFAULT defined - update the size of the flashes in the DTS before booting Linux - MONITOR_LEN updated to 384k - added CONFIG_HOSTNAME - added CONFIG_ENV_BUFFER_PRINT - Environment size reduced to 16k Signed-off-by: Heiko Schocher <hs@denx.de>
2009-02-198xx, mgsuvd: updates for 2009.03Heiko Schocher
- activate Rx buf len > 1 on SMC - pram activated - MTDPARTS_DEFAULT defined - update the size of the flash in the DTS before booting Linux - MONITOR_LEN updated to 384k - added CONFIG_HOSTNAME - added CONFIG_ENV_BUFFER_PRINT - Environment size reduced to 16k Signed-off-by: Heiko Schocher <hs@denx.de>
2009-02-19TQM8xxL: make some room in low memory for future needsWolfgang Denk
THe TQM8xxL use a ahnd-optimized linker script to efficiently use the small boot sectors in the flash. This patch makes some room in the first sector to prepare for a size increase of lib_generic/vsprintf.o by a future patch. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-19Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-02-19Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-02-18Fix build errors after making flash_get_info() non-staticWolfgang Denk
Fix for these build problems: error: static declaration of 'flash_get_info' follows non-static declaration Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-18ppc4xx: Some more PMC405 coding-style cleanupStefan Roese
2009-02-18ppc4xx: Update PMC405 board supportMatthias Fuchs
This patch prepares the good old PMC405 board support for upcoming PMC405V2 patches. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-18ppc4xx: Cleanup PMC405 board supportMatthias Fuchs
This patch fixes coding style for PMC405 board support. Also some unneeded features/code is removed. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-1683xx: Add eSDHC support on 8379 EMDS boardAndy Fleming
2009-02-1685xx: Add eSDHC support for 8536 DSAndy Fleming
2009-02-16TQM85xx: Fix a couple warnings in TQM8548 buildAndy Fleming
The ecm variable in sdram.c was being declared for all 8548, but only used by specific 8548 boards, so we make that variable require those specific boards, too The nand code was using an index "i" into a table, and then re-using "i" to set addresses for each upm. However, then it relied on the old value of i still being there to enable things. Changed the second "i" to "j" Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-16MPC85xx: TQM8548: workaround for erratum DDR 19 and 20Wolfgang Grandegger
This patch adds the workaround for erratum DDR20 according to MPC8548 Device Errata document, Rev. 1: "CKE signal may not function correctly after assertion of HRESET". Furthermore, the bug DDR19 is fixed in processor version 2.1 and the work-around must be removed. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548: use cache for AG and BE variantsWolfgang Grandegger
This patch makes accesses to the system memory cachable by removing the caching-inhibited and guarded flags from the relevant TLB entries for the TQM8548_BE and TQM8548_AG modules. FYI, the Freescale MPC85* boards are configured similarly. This results in a big averall performace improvement. TFTP downloads, NAND Flash accesses, kernel boots, etc. are much faster. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548_AG: add 1 GiB DDR2-SDRAM configurationWolfgang Grandegger
This patch add support for the 1 GiB DDR2-SDRAM on the TQM8548_AG module. Signed-off-by: Jens Gehrlein <sew_s@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548: fix SDRAM timing for 533 MHzWolfgang Grandegger
According to new TQM8548 timing specification: Refresh Recovery: 34 -> 53 clocks CKE pulse width: 1 -> 3 cycles Window for four activities: 13 -> 14 cycles Signed-off-by: Jens Gehrlein <sew_s@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548: add support for the TQM8548_BE moduleWolfgang Grandegger
The TQM8548_BE is a variant of the TQM8548 module with NAND and CAN interface. With NAND support, the image is significantly larger and TEXT_BASE is adjusted accordingly. U-Boot can be built for this module with "$ make TQM8548_BE_config". Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM85xx: make standard PCI/PCI-X configurableWolfgang Grandegger
The TQM8548_AG module does not have the standard PCI/PCI-X interface connected but just the PCI Express interface . So far it was not possible to disable it without disabling the complete PCI interface (CONFIG_PCI) including PCI Express. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM85xx: fix flash protection for boot loaderWolfgang Grandegger
As the reset vector is located at 0xfffffffc, all flash sectors from the beginning of the U-Boot binary to 0xffffffff must be protected. On the TQM8548-AG having small sectors at the end of the flash it happened that the last two sector were not protected and an "erase all" left an un-bootable system behind: Bank # 2: CFI conformant FLASH (32 x 16) Size: 32 MB in 270 Sectors AMD Standard command set, Manufacturer ID: 0xEC, Device ID: 0x257E Erase timeout: 8192 ms, write timeout: 1 ms FFFA0000 E RO FFFC0000 RO FFFE0000 RO FFFE4000 RO FFFE8000 RO FFFEC000 RO FFFF0000 RO FFFF4000 RO FFFF8000 E FFFFC000 The same bug seems to be in drivers/mtd/cfi_flash.c:flash_init() and many board BSPs as well. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-1686xx: Reset updatePeter Tyser
Update the 86xx reset sequence to try executing a board-specific reset function. If the board-specific reset is not implemented or does not succeed, then assert #HRESET_REQ. Using #HRESET_REQ is a more standard reset procedure than the previous method and allows all board peripherals to be reset if needed. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-02-1685xx: print boot header info to distinquish 36-bit addr map on MPC8572 DSKumar Gala
Added some info that is printed out when we boot to distiquish if we built MPC8572DS_config vs MPC8572DS_36BIT_config since they have different address maps. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-16Fixup SGMII PHY ids in the device treeAndy Fleming
The device tree's PHY addresses need to be fixed up if we're using the SGMII Riser Card. The 8572, 8536, and 8544 DS boards were modified to call this function. Code idea taken from Liu Yu <yu.liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-1685xx: Fix bug in device tree setup in 36-bit physical confgKumar Gala
In the 36-bit physical config for MPC8572DS when need the start address of memory and it size to be kept in phys_*_t instead of a ulong since we support >4G of memory in the config and ulong cant represent that. Otherwise we end up seeing the memory node in the device tree reporting back we have memory starting @ 0 and of size 0. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-1685xx: Fix address map for 36-bit config of MPC8572DSKumar Gala
When we introduced the 36-bit config of the MPC8572DS board we had the wrong PCI MEM bus address map. Additionally, the change to the address map exposes a small issue in our dummy read on the ULI bus. We need to use the new mapping functions to handle that read properly in the 36-bit config. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-02-12ppc4xx: Fix problem with board_eth_init() vs cpu_eth_init() on AMCC boardsStefan Roese
Some AMCC eval boards do have a board_eth_init() function calling pci_eth_init(). These boards need to call cpu_eth_init() explicitly now with the new eth_init rework. Signed-off-by: Stefan Roese <sr@denx.de>
2009-02-12Coding style cleanup; update CHANGELOGWolfgang Denk
2009-02-10mpc8641hpcn: Clean up PCI mapping conceptsBecky Bruce
Clean up PCI mapping concepts in the 8641 config - rename _BASE to _BUS, as it's actually a PCI bus address, separate virtual and physical addresses into _VIRT and _PHYS, and use each appopriately. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-02-10powerpc: Move duplicated BAT defines to mmu.hBecky Bruce
The BAT fields are architected; there's no need for these to be in cpu-specific files. Drop the duplication and move these to include/asm-ppc/mmu.h. Also, remove the BL_xxx defines that were only used by the alaska board, and switch to using the BATU_BL_xxx defines used by all the other boards. The BL_ defines previously in use had to be shifted into the proper position for use, which was inefficient. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-02-10mpc8641hpcn: Set up outbound pci windows before inboundBecky Bruce
Because the inbound pci windows are mapped generously, set up the more specific outbound windows first. This way, when we search the pci regions for something, we will hit on the more specific region. This can actually be a problem on systems with large amounts of RAM. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-02-10qong: support for Dave/DENX QongEVB-LITE boardIlya Yanok
This patch adds support for Dave/DENX QongEVB-LITE i.MX31-based board. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
