Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
If the testpin is asserted, first check if a test_bank
variable is defined before trying to boot this
test_bank.
Signed-off-by: Thomas Herzmann <thomas.herzmann@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
On kmcoge5ne we have a dip switch present. If this switch
was switched on the actual_bank is set to 0 and this SW
will be booted.
kmcoge5ne starts the post tests if the testpin on
the board was enabled. Currently it does simply a memory
test.
Enabled application buffers in uboot to allow application chipselect
access in uboot.
Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com>
The MAC address begins at offset 1.
This board is a MPC8360 board. Two flashes are present
a NOR flash were u-boot and the u-boot environment is stored
and a NAND flash for the application code. This board has 512MB
SDRAM.
Additionaly we introduce a common km8360.h file and convert kmeter1 to
use this.
Signed-off-by: Christian Herzig <christian.herzig@keymile.com>
cc: Kim Phillips <kim.phillips@freescale.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Gerlando Falauto <gerlando.falauto@keymile.com>
cc: Heiko Schocher <hs@denx.de>
If the ram size isn't locked to 2GiB, the get_ram_size() may hang up.
* 'master' of git://git.denx.de/u-boot-video:
video: atmel/lcd: add LCD driver for new Atmel SoC
video: cfb_console: flush dcache for frame buffer in DRAM
cfb_console: Ignore bell character
cfb_console: Add console_clear_line function
cfb_console: Fix function console_back
omap3_dss: cosmetic changes
omap3_dss: add optional framebuffer
mx53loco: Add LCD support
mx5: Rename mx51_fb_init()
mx53: Allow IPUv3 driver to also work on mx53
mx51evk: Add LCD support
EXYNOS: display 32bpp bitmap TIZEN logo
create lib/tizen directory
LCD: display 32bpp decompressed bitmap image
common/lcd.c: reduce one CONFIG_LCD_LOGO ifdef
common/lcd.c: reduce some CONFIG_LCD_*_LOGO ifdefs
common/lcd.c: use ARRAY_SIZE
cmd_bmp.c: make bmp_display() usable by drivers or board code
LCD: support another s6e8ax0 panel type
LCD: change s6e8ax0 panel gamma value
include/video.h: drop unused video_printf()
* 'master' of git://git.denx.de/u-boot-avr32:
avr32:board.c: fix compile warning
avr32:grasshopper: fix PHY initialisation
This is an sh2a device (max 266MHz) with FPU, video display
controller (VDC), 8 serial ports, 4 I2C channels, 3 CAN ports,
SD and on-chip USB.
The RSK2+SH7269 board uses the SH7269 processor. It is often
referred to as just rsk7269.
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
The AP-SH4A-4A board has SH7734, 64MB DDR2-SDRAM, USB,
Ethernet, and more.
This patch supports the following functions:
- 64MB DDR2-SDRAM
- 16MB NOR Flash memory
- Serial console (SCIF)
- Ethernet (SH-Ether with Gigabit)
- I2C
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
This read MAC address from Serial EEPROM and set.
The r0p7734 board has SH7734, 128MB DDR2-SDRAM, USB,
Ethernet, and more.
- 128MB DDR2-SDRAM
- 32MB NOR Flash memory
- Ethernet (SH-Ether/SMSC)
Add support for CLAA07LC0ACW LCD that connects to the mx53loco board.
Configure the board to show the Linux logo on the LCD.
Also increase the size of CONFIG_SYS_MALLOC_LEN variable to take into account
the framebuffer usage.
Acked-by: Jason Liu <r64343@freescale.com>
The ipuv3 driver is currently only used on mx51, but it can be extended to work
on mx53 and mx6 as well.
Rename mx51_fb_init(), so that it can be used by other SoCs.
Add support for CLAA07LC0ACW LCD that connects to the mx51evk board.
This patch supports drawing 32bpp bitmap TIZEN logo in exynos fb.
"tizen_hd_logo.h" data is compressed from trats_logo.bmp to
trats_logo.bmp.gz by gzip and converted to tizen_hd_logo.h header file
format by some application. The logo data is decompressed in the exynos
fb driver by bmp_display().
Signed-off-by: Donghwa Lee <dh09.lee@samsung.com>
Acked-by: Minkyu Kang <mk7.kang@samsung.com>
s6e8ax0 panel has many panel of types. This patch support another panel
on TIZEN lunchbox board(HWREVISION 2). This panel has reversed panel
display type. So, I had added necessary command.
These are all the files which use the API incorrectly but did not get
built using MAKEALL -a powerpc|arm. I have no compiler for them, but
the remaining issues should be far less than without this patch.
Any outstanding issues are left to the maintainers of boards that use
these drivers.
Some copy/pasted drivers redefine functions
defined in include/net.h. Remove these so that
the definitions can be changed without error.
Fix this:
cpci405.c: In function 'do_get_bpip':
cpci405.c:737:4: warning: format '%ld' expects type 'long int', but argument 3 has type 'IPaddr_t'
cpci405.c:737:4: warning: format '%ld' expects type 'long int', but argument 4 has type 'IPaddr_t'
cpci405.c:737:4: warning: format '%ld' expects type 'long int', but argument 5 has type 'IPaddr_t'
cpci405.c:737:4: warning: format '%ld' expects type 'long int', but argument 6 has type 'IPaddr_t'
cpci405.c:700:8: warning: unused variable 'bd'
* 'master' of git://git.denx.de/u-boot-net:
net: move bootfile init into eth_initialize
net: punt bd->bi_ip_addr
net: cosmetic: netconsole.c checkpatch compliance
net: cosmetic: tftp.* checkpatch compliance
net: cosmetic: sntp.* checkpatch compliance
net: cosmetic: rarp.* checkpatch compliance
net: cosmetic: nfs.* checkpatch compliance
net: cosmetic: net.c checkpatch compliance
net: cosmetic: eth.c checkpatch compliance
net: cosmetic: bootp.* checkpatch compliance
net: cosmetic: net.h checkpatch compliance
net: Remove volatile from net API
This field gets read in one place (by "bdinfo"), and we can replace
that with getenv("ipaddr"). After all, the bi_ip_addr field is kept
up-to-date implicitly with the value of the ipaddr env var.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
If uart2 is enabled during boot, spurious wifi chip transmission will
hang the module and it is impossible to recover from this situation
without hard reset. This will prevent any l4_per domain idle
transitions.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Seaboard uses a QUERTY keyboard. We add key codes for this to
enable key scanning to work.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This adds timings for T20 and T25 Seaboards, using the bindings found here:
http://patchwork.ozlabs.org/patch/132928/
We supply both full speed options for normal running, and half speed options
for testing / development.
Set Seaboard to optimal memory settings based on the SOC in use (T20 or T25).
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Signed-off-by: Jimmy Zhang <jimmzhang@nvidia.com>
Tegra core power rail has leakage voltage around 0.2V while system in
suspend mode. The source of the leakage should be coming from PMC power
detect logic for IO rails power detection.
That can be disabled by writing a '0' to PWR_DET_LATCH followed by writing '0'
to PWR_DET (APBDEV_PMC_PWR_DET_0).
Call the function to put warmboot boot in a suitable place for resume.
Adjust PMU to permit maximum frequency operation.
Cc: Detlev Zundel <dzu@denx.de>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
There is no need to set the VBUS power enable to 0 first and then to 1.
Set it to 1 in the gpio_direction_output() function.
While at it, use the standard naming convention for the GPIO comment.
FSL 2.6.35 kernel assumes that the bootloader passes the CONFIG_REVISION_TAG information.
The kernel uses this data to distinguish between Dialog versus mc34708 based boards,
and also to distinguish between revA and revB of the mc34708 based boards.
Suggested-by: Yu Li <yk@magniel.com>
On the mx53loco board with mc34708 PMIC it is necessary to turn on VUSB regulator
so that the mx53 USBH1 PHY receives the 3.3V voltage.
Tested by inserting a USB pen drive in the upper USB slot (USBH1) and then issued the
commands:
usb start
usb info
,which correctly detected and printed the USB pen drive information.
Add mc34708 support and set mx53 core frequency at its maximum value of 1GHz.
As mx53loco board has two variants: one with Dialog PMIC and another with FSL MC34708 PMIC,
we need to be able to build both drivers.
Change pmic_init() and PMIC_NUM_OF_REGS names to avoid build conflicts when both drivers are present.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
Acked-by: stefano Babic <sbabic@denx.de>
NAND support is not enabled by default because Eval Kit is not delivered
with NAND chip. To enable NAND support add CONFIG_CMD_NAND to board config.
Signed-off-by: Lauri Hintsala <lauri.hintsala@bluegiga.com>
There are two types of mx53loco boards: initial boards were built with a Dialog
DA9053 PMIC and more recent version is based on a Freescale MC34708 PMIC.
Add DA9053 PMIC support and adjust the required voltages and clocks for running
the CPU at 1GHz.
Tested on both versions of mx53loco boards.
In the case of a MC34708-based board the CPU operating voltage remains at 800MHz.
Acked-by : Stefano Babic <sbabic@denx.de>
Print CPU information within board_late_init().
This is in preparation for adding 1GHz support, which requires programming a PMIC
via I2C. As I2C is only available after relocation, print the CPU information
later at board_late_init(), so that the CPU frequency can be printed correctly.
Uses the 'magic_keys' idiom as described in doc/README.kbd:
http://lists.denx.de/pipermail/u-boot/2012-April/122502.html
There is a 'gpio_direction_output(87, 0);' call previously, so the GPIO direction is
already established.
Use gpio_set_value() for changing the GPIO output then.
Acked-by: Dirk Behme <dirk.behme@googlemail.com>
CC: Jason Liu <jason.hui@linaro.org>
Acked-by: Jason Liu <jason.hui@linaro.org>
The ESG ima3-mx53 board is based on the Freescale
i.MX53 SOC. It boots from NOR (128 MB) and
supports Ethernet (FEC), SATA.
vl_bpix of vidinfo_t was changed proper value for u-boot.
It is used to multiple of 2 by using NBITS() macro.
Acked-by: Anatolij Gustschin <agust@denx.de>
This patch support TRATS board configuration and display function.
Signed-off-by: Inki Dae <inki.dae@samsung.com>
