path: root/board
2012-01-16overo: add SPL supportAndreas Müller
* implementation based on ti beagleboard/omap3evm * timing data and i2c workaround for revision 0 boards taken from x-loader * run-tested with overo revision 0 and 1 / boot from NAND and SDcard * run-tested with x-loader Signed-off-by: Andreas Müller <schnitzeltony@gmx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-01-16board/overo/overo.c: replace printf with one argument by putsAndreas Müller
2012-01-16ARM:AM33XX: Add SPL support for AM335X EVMChandan Nath
This patch is added to support SPL feature on AM335X platform. In this patch, MMC1 is configured as boot device for SPL and support for other devices will be added in the next patch series. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Tom Rini <trini@ti.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16ARM:AM33XX: Add mmc/sd supportChandan Nath
This patch add supports for mmc/sd driver on AM335X platform. PLL and pinmux configurations for mmc/sd are configured in this patch. Signed-off-by: Chandan Nath <chandan.nath@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-01-16cm-t35: use the new EEPROM module to read the MAC addressNikita Kiryanov
Switch to the new EEPROM module and fix the problem of MAC address being read from the wrong offset due to lack of distinction between EEPROM layouts. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16cm-t35: pass correct revision information to LinuxNikita Kiryanov
Read revision from EEPROM and pass it to Linux. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16cm-t35: add EEPROM module and pass Linux a serial numberNikita Kiryanov
Add board specific EEPROM handling module, read the serial number from the EEPROM and pass it to Linux. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16cm-t35: various cleanupsNikita Kiryanov
Move #ifdef CONFIG_SMC911X out of board_eth_init() function, simplify the board_mmc_init() function, and enclose handle_mac_address() in the CONFIG_SMC911X. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16beagle: add eeprom expansion board info for bct brettl3Peter Meerwald
this is for a prototyping board vendor/product ids have been added to http://elinux.org/BeagleBoardPinMux#List_of_Vendor_and_Device_IDs
2012-01-16ARMV7: Add support For Logic OMAP35x/DM37x modulesPeter Barada
This patch adds basic support for OMAP35x/DM37x SOM LV/Torpedo reference boards. It assumes U-boot is loaded to SDRAM with the help of another small bootloader (x-load) running from SRAM. Signed-off-by: Peter Barada <peter.barada@logicpd.com> Cc: Tom Rini <tom.rini@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-01-16arm, davinci: Change byte order of RTC kick register valuesChristian Riesch
Now the values in the defines agree with those in the manuals. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de>
2012-01-16i.mx: i.mx6q: add the initial support for i.mx6q Sabre Lite boardJason Liu
Add the initial support for Freescale i.MX6Q Sabre Lite board Signed-off-by: Dirk Behme <dirk.behme@de.bosch.com> Signed-off-by: Jason Liu <jason.hui@linaro.org> CC: Eric Nelson <eric.nelson@boundarydevices.com>
2012-01-16m28evk: Remove 'all' target from MakefileFabio Estevam
Remove 'all' target from Makefile, as this is unused code. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-01-16mx28evk: Remove 'all' target from MakefileFabio Estevam
2012-01-16mx28evk: Add initial support for MX28EVK boardFabio Estevam
Add initial support for Freescale MX28EVK board. Tested boot via SD card and by loading a kernel via TFTP through the FEC interface. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-16mx28: Let dram_init be common for mx28Fabio Estevam
Let dram_init function be a common function, so that other mx28 boards can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2012-01-16mx28: Let imx_get_mac_from_fuse be common for mx28Fabio Estevam
Let imx_get_mac_from_fuse function be a common function, so that other mx28 boards can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-16net: imx: Add multi-FEC support for imx_get_mac_from_fuseFabio Estevam
Add multi-FEC support for imx_get_mac_from_fuse by passing dev_id as a parameter. This feature is important on mx28 SoC for example that has two FEC ports. Cc: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2012-01-16i.mx6q: mx6qarm2: Enable the usboh3 clockEric Nelson
Bits 0 and 1 of CCM_CCGR7 are the usboh3 clock enable bits. Enabling this clock is necessary for the USB download. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> CC: Jason Hui <jason.hui@linaro.org> Acked-by: Jason Hui <jason.hui@linaro.org>
2012-01-16i.mx6q: arm2: Add the enet function supportJason Liu
This enable the network function on the i.mx6q armadillo2 board(arm2), thus we can use tftp to load image from network. Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Jason Liu <jason.hui@linaro.org> Tested-by: Dirk Behme <dirk.behme@de.bosch.com>
2012-01-13openrisc: Add openrisc-generic example boardStefan Kristiansson
Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2012-01-13Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: fsl_lbc: add printout of LCRR and LBCR to local bus regs sbc8548: Fix up local bus init to be frequency aware sbc8548: enable support for hardware SPD errata workaround sbc8548: relocate fixed ddr init code to ddr.c file sbc8548: Make enabling SPD RAM configuration work sbc8548: Fix LBC SDRAM initialization settings sbc8548: enable ability to boot from alternate flash sbc8548: relocate 64MB user flash to sane boundary Revert "SBC8548: fix address mask to allow 64M flash" MPC85xxCDS: Fix missing LCRR_DBYP bits for 66-133MHz LBC eXMeritus HWW-1U-1A: Add support for the AT24C128N I2C EEPROM eXMeritus HWW-1U-1A: Minor environment variable tweaks
2012-01-13Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-ppc4xx: board/mpl/pati: use the CFI driver for the PATI board board/mpl/mip405: use the CFI driver for the MIP405/MIP405T board board/mpl/pip405: use the CFI driver for the PIP405 board board/mpl/common: remove the old legacy flash ppc4xx: Setup HICB on Io64
2012-01-13Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc83xx: mpc8313erdb: fix mtdparts address powerpc/83xx/km: add support for 8321 based tuge1 board powerpc/83xx/km: merge tuxa and tuda1 boards to tuxx1 powerpc/83xx/km: remove obsolete defines for tuda1 powerpc/83xx/km: update SDRAM parameters for km8321 boards mpc8313erdb: Enable GPIO support on the MPC8313E RDB mpc83xx: Add a GPIO driver for the MPC83XX family gpio: Replace ARM gpio.h with the common API in include/asm-generic gpio: Modify common gpio.h to more closely match Linux
2012-01-11sbc8548: Fix up local bus init to be frequency awarePaul Gortmaker
The code here was copied from the mpc8548cds support, and it wasn't using the CONFIG_SYS_LBC_LCRR define, and was just unconditionally setting the LCRR_EADC bit. Snooping with a hardware debugger also showed we had LCRR_DBYP set, since we were setting it based on a read of an uninitialized lcrr read via clkdiv. Borrow from the code in the tqm85xx.c support to add LBC frequency aware masking of these bits. This change will correct reliability issues associated with trying to use the 128MB of LBC 100MHz SDRAM on this board. Thanks to Keith Savage for assistance in diagnosing the root cause of this. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11sbc8548: enable support for hardware SPD errata workaroundPaul Gortmaker
Existing boards by default have an issue where the LBC SDRAM SPD EEPROM and the DDR2 SDRAM SPD EEPROM both land at 0x51. After the hardware modification listed in the README is made, then the DDR2 SPD EEPROM appears at 0x53. So this implements a board specific get_spd() by taking advantage of the existing weak linkage, that 1st tries reading at 0x53 and then if that fails, it falls back to the old 0x51. Since the old dependency issue of "SPD implies no LBC SDRAM" gets removed with the hardware errata fix, remove that restriction in the code, so both LBC SDRAM and SPD can be selected. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11sbc8548: relocate fixed ddr init code to ddr.c filePaul Gortmaker
Nothing to see here, just a relocation of the fixed ddr init sequence to live in the actual ddr.c file itself. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11sbc8548: Make enabling SPD RAM configuration workPaul Gortmaker
Previously, SPD configuration of RAM was non functional on this board. Now that the root cause is known (an i2c address conflict), there is a simple end-user workaround - remove the old slower local bus 128MB module and then SPD detection on the main DDR2 memory module works fine. We make the enablement of the LBC SDRAM support conditional on being not SPD enabled. We can revisit this dependency as the hardware workaround becomes available. Turning off LBC SDRAM support revealed a couple implict dependencies in the tlb/law code that always expected an LBC SDRAM address. This has been tested with the default 256MB module, a 512MB a 1GB and a 2GB, of varying speeds, and the SPD autoconfiguration worked fine in all cases. The default configuration remains to go with the hard coded DDR config, so the default build will continue to work on boards where people don't bother to read the docs. But the advantage of going to the SPD config is that even the small default module gets configured for CL3 instead of CL4. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11sbc8548: Fix LBC SDRAM initialization settingsPaul Gortmaker
These were cloned from the mpc8548cds platform which has a different memory layout (1/2 the size). Set the values by comparing to the register file for the board used during JTAG init sequence: LSDMR1 0x2863B727 /* PCHALL */ LSDMR2 0x0863B727 /* NORMAL */ LSDMR3 0x1863B727 /* MRW */ LSDMR4 0x4063B727 /* RFEN */ This differs from what was there already in that the RFEN is not bundled in all four steps implicitly, but issued once as the final step. The other difference seen when comparing vs. the register file init, is that since the memory is split across /CS3 and /CS4, the dummy writes need to go to 0xf000_0000 _and_ to 0xf400_0000. We also rewrite the final LBC SDRAM inits as macros, as there is no real need for them to be a local variable that is modified on the fly at runtime. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11sbc8548: enable ability to boot from alternate flashPaul Gortmaker
This board has an 8MB soldered on flash, and a 64MB SODIMM flash module. Normally the board boots from the 8MB flash, but the hardware can be configured for booting from the 64MB flash as well by swapping CS0 and CS6. This can be handy for recovery purposes, or for supporting u-boot and VxBoot at the same time. To support this in u-boot, we need to have different BR0/OR0 and BR6/OR6 settings in place for when the board is configured in this way, and a different TEXT_BASE needs to be used due to the larger sector size of the 64MB flash module. We introduce the suffix _8M and _64M for the BR0/BR6 and the OR0/OR6 values so it is clear which is being used to map what specific device. The larger sector size (512k) of the alternate flash needs a larger malloc pool, otherwise you'll get failures when running saveenv, so bump it up accordingly. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11sbc8548: relocate 64MB user flash to sane boundaryPaul Gortmaker
The current situation has the 64MB user flash at an awkward alignment; shifted back from 0xfc00_0000 by 8M, to leave an 8MB hole for the soldered on boot flash @ EOM. But to switch to optionally supporting booting off the 64MB flash, the 64MB will then be mapped at the sane address of 0xfc00_0000. This leads to awkward things when programming the 64MB flash prior to transitioning to it -- i.e. even though the chip spans from 0xfb80_0000 to 0xff7f_ffff, you would have to program a u-boot image into the two sectors from 0xfbf0_0000 --> 0xfbff_ffff so that it was in the right place when JP12/SW2.8 were switched to make the 64MB on /CS0. (i.e. the chip is only looking at the bits in mask 0x3ff_ffff) We also have to have three TLB entries responsible for dealing with mapping the 64MB flash due to this 8MB of misalignment. In the end, there is address space from 0xec00_0000 to 0xefff_ffff where we can map it, and then the transition from booting from one config to the other will be a simple 0xec --> 0xfc mapping. Plus we can toss out a TLB entry. Note that TLB0 is kept at 64MB and not shrunk down to the 8MB boot flash; this means we won't have to change it when the alternate config uses the full 64MB for booting, in TLB0. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-11MPC85xxCDS: Fix missing LCRR_DBYP bits for 66-133MHz LBCPaul Gortmaker
These boards were meaning to deploy this value: #define LCRR_DBYP 0x80000000 but were missing a zero, and hence toggling a bit that lands in an area marked as reserved in the 8548 reference manual. According to the documentation, LCRR_DBYP should be used as: PLL bypass. This bit should be set when using low bus clock frequencies if the PLL is unable to lock. When in PLL bypass mode, incoming data is captured in the middle of the bus clock cycle. It is recommended that PLL bypass mode be used at frequencies of 83 MHz or less. So the impact would most likely be undefined behaviour for LBC peripherals on boards that were running below 83MHz LBC. Looking at the actual u-boot code, the missing DBYP bit was meant to be deployed as follows: Between 66 and 133, the DLL is enabled with an override workaround. In the future, we'll convert all boards to use the symbolic DBYP constant to avoid these "count the zeros" problems, but for now, just fix the impacted boards. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2012-01-09mpc8313erdb: Enable GPIO support on the MPC8313E RDBJoe Hershberger
Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-01-09board/mpl/pati: use the CFI driver for the PATI boardDavid Müller
Signed-off-by: David Mueller <d.mueller@elsoft.ch> Signed-off-by: Stefan Roese <sr@denx.de>
2012-01-09board/mpl/mip405: use the CFI driver for the MIP405/MIP405T boardDavid Müller
2012-01-09board/mpl/pip405: use the CFI driver for the PIP405 boardDavid Müller
2012-01-09board/mpl/common: remove the old legacy flashDavid Müller
2012-01-09ppc4xx: Setup HICB on Io64Dirk Eibach
The FPGA High-Speed Interconnect Bus (HICB) is now setup by u-boot. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2012-01-08mmc: Change board_mmc_getcd() function prototype.Thierry Reding
The new API no longer uses the extra cd parameter that was used to store the card presence state. Instead, this information is returned via the function's return value. board_mmc_getcd() returns -1 to indicate that no card-detection mechanism is implemented; 0 indicates that no card is present and 1 is returned if it was detected that a card is present. The rationale for this change can be found in the following email thread: http://lists.denx.de/pipermail/u-boot/2011-November/110180.html In summary, the old API was not consistent with the rest of the MMC API which always passes a struct mmc as the first parameter. Furthermore the cd parameter was used to mean "card absence" in some implementations and "card presence" in others. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Tested-by: Jason Liu <jason.hui@linaro.org>
2012-01-05ARM: highbank: enable networking and pxeRob Herring
This enables the XGMAC ethernet driver and networking related config options. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2011-12-24tegra2: Optimize out-of-tree build for Ventana.Thierry Reding
As proposed by Mike Frysinger, mkdir can take more than one argument. Instead of spawning two processes, create both the common and seaboard directories in one go. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra: Move boards over to use arch-level board UART functionSimon Glass
Now that we can set up the UART in common tegra code, make the boards use it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra: Move clock_early_init() to arch_cpu_init()Simon Glass
The clock init is not board specific, so move it into the cpu code. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra: Move cpu_init_cp15() to arch_cpu_init()Simon Glass
This call is more of an architecture requirement than a board one, so move it there. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24arm: Tegra: Fix Harmony and Ventana builds in u-boot-tegra/masterTom Warren
Seaboard changes have removed the need for common/board.o in the Makefile. Propagate this change to the other Tegra2 builds. Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Add Avionic Design Medcom support.Thierry Reding
The Medcom is a 16:9 15" terminal that is used for patient infotainment in hospitals. Changes in v3: * Remove unused implementation of gpio_config_uart(). * Implement MMC/SD card detection. * Drop board_mmc_getcd() which is now implemented by common Tegra2 code. * Add MAINTAINERS entry. Changes in v2: * No longer override the default CONFIG_SYS_TEXT_BASE setting. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Add Avionic Design Plutux support.Thierry Reding
The Plutux is a set-top box device based on the Tamonten processor module. It can be connected to a display via an HDMI output. Changes in v3: * Remove unused implementation of gpio_config_uart(). * Implement MMC/SD card detection. * Drop board_mmc_getcd() which is now implemented by common Tegra2 code. * Add MAINTAINERS entry. Changes in v2: * No longer override the default CONFIG_SYS_TEXT_BASE setting. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Add common Avionic Design Tamonten support.Thierry Reding
Tamonten is an NVIDIA Tegra2-based SO-DIMM processor module that is derived from the Harmony reference design. Changes in v3: * Remove unused gpio_config_uart(). * Remove call to tegra2_start(). * Use new tegra2_mmc_init(). Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Move tegra2_mmc_init() prototype to public header.Thierry Reding
tegra2_mmc_init() is implemented by the Tegra2 MMC driver. Since most of the Tegra2-based boards will need to call it, this commit exports it in the new public asm/arch/mmc.h header file to prevent each board from providing its own prototype. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Plumb in SPI/UART switch codeSimon Glass
On Seaboard the UART and SPI interfere with each other. This causes the UART to receive spurious zero bytes after SPI transactions and also means that SPI can corrupt a few output characters when it starts up if they are still in the UART buffer. This updates the board to use the SPI/UART switch to avoid the problem. For now this feature is turned off since it needs changes to the NS16550 UART to operate. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
