The NMDK8815 board is distributed by ST Microelectornics.
Other (proprietary) code must be run to unlock the CPU before
U-Boot runs. doc/README.nmdk8815 outlines the boot sequence.
This is the initial port, with basic infrastructure and
a working serial port.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stnwireless.com>
Brings i386 in line with other CPUs with a reset vector and frees up reset.c
for CPU reset functions
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
Check the presence of the PIGGY on the keymile boards mgcoge,
mgsuvd and kmeter1. If the PIGGY is not present, dont register
this Ethernet device.
Acked-by: Ben Warren <biggerbadderben@gmail.com>
This patch adds support for the kmeter1 board from Keymile,
based on a Freescale MPC8360 CPU.
- serial console on UART 1
- 256 MB DDR2 RAM
- 64 MB NOR Flash
- Ethernet RMII Mode over UCC4
- PHY SMSC LAN8700
The wake up ARP feature need use the memory to process
wake up packet, we enable auto self refresh to support it.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Acked-by: Andy Fleming <afleming@freescale.com>
For light loaded system, we use the 1T timing to gain better
memory performance, but for some heavily loaded system,
you have to add the 2T timing options to board files.
Introduce a new define to seperate out the virtual address that PCI
IO space is at from the physical address. In most situations these are
mapped 1:1. However any code accessing the bus should use VIRT.
memory is at from the physical address. In most situations these are
Use the _MEM_PHYS defines instead of _MEM_BUS for LAW and real address fields
of TLBs. This is what we should have always been using from the start.
Use CONFIG_SYS_PCI*_IO_BUS for the bus relative address instead
of _IO_BASE so we are more explicit.
Use CONFIG_SYS_{PCI,RIO}_MEM_BUS for the bus relative address instead
of _MEM_BASE so we are more explicit.
Added a CONFIG_SYS_FLASH_BASE_PHYS for use as the physical address and
maintain CONFIG_SYS_FLASH_BASE as the virtual address of the flash.
This allows us to deal with 36-bit phys on these boards in the future.
Added a PIXIS_BASE_PHYS for use as the physical address and maintain
PIXIS_BASE as the virtual address of the PIXIS fpga registers.
This patch will create a new board, SIMPC8313, from Sheldon Instruments. This
board boots from NAND devices and is configureable for either large or small
page devices. The board supports non-soldered DDR2, one ethernet port, a
Marvell 88E1118 PHY, and PCI host support. The board also has a FPGA connected
to the eLBC providing glue logic to a TMS320C67xx DSP.
Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
MPC837XEMDS boards can support PCI-E via "PCI-E riser card". The card
provides two PCI-E (x2) ports. Though, only one port can be used in x2
mode. Two ports can function simultaneously in x1 mode.
PCI-E x1/x2 modes can be switched via "pex_x2" environment variable.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
MPC8315ERDB boards features PCI-E x1 and Mini PCI-E x1 ports. Let's
support them.
When running in PCI agent mode, the PCI_CLK_OUT signals are not used, so do
not enable them. See the MPC8349EA Reference Manual, Section 4.4.2
"Clocking in PCI Agent Mode".
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
lowlevel_init of SH was corrected to use the write/readXX macro.
However, there was a problem that was not able to be compiled partially.
This patch corrected this.
Fix up rsk7203 target to build successfully using out-of-tree build.
Signed-off-by: Kieran Bingham <kbingham@mpc-data.co.uk>
This patch adds esd's loadpci BSP command to CPCI4052 and
CPCI405AB board. This requires CONFIG_CMD_BSP and CONFIG_PRAM.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch cleans up CPCI405 board support:
- wrap long lines
- unification of spaces in function calls
- remove dead code
Use correct io accessors on peripherals.
This patch turns on the auto RS485 mode in the 2nd external
uart on PLU405 boards. This is a special mode of the used
Exar XR16C2850 uart. Because these boards only have a 485 physical
layer connected it's a good idea to turn it on by default.
Signed-off-by: Matthias Fuchs <mf@esd.eu>
- Move the TLB entry of PIXIS_BASE from TLB0 to TLB1[8], because in CAMP mode,
all the TLB0 entries will be invalidated after cpu1 brings up kernel, thus cpu0
can not access PIXIS_BASE anymore (any access will cause DataTLBError exception)
- Set CONFIG_SYS_DDR_TLB_START to 9 for MPC8572DS board.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
The IO port selection for MPC8544DS board:
Port cfg_io_ports
PCIE1 0x2, 0x3, 0x4, 0x5, 0x6, 0x7
PCIE2 0x4, 0x5, 0x6, 0x7
PCIE3 0x6, 0x7
This patch changes the PCIE12 and PCIE2 logic more readable.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
PCIE2 and PCIE3 should be decided by corresponing bit in devdisr instead of
PCIE1 bit.
On MPC8572DS board, PCIE refers to PCIE1.
The IO port selection is not correct on MPC8572DS and MPC8544DS board.
This patch fixes this issue.
For MPC8572
Port cfg_io_ports
PCIE1 0x2, 0x3, 0x7, 0xb, 0xc, 0xf
PCIE2 0x3, 0x7
PCIE3 0x7
For MPC8544
Port cfg_io_ports
PCIE3 0x6, 0x7
Rename _BASE to _BUS, as it's actually a PCI bus address,
separate virtual and physical addresses into _VIRT and _PHYS,
and use each appopriately. This makes the code easier to read
and understand, and facilitates mapping changes going forward.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
The board_nand_init() function should return an int, not void.
Many of the Blackfin board linker scripts are preprocessed, so make sure we
output the linker script into the build tree rather than the source tree.
Make sure all .text sections get pulled in and the entry point is properly
referenced so they don't get discarded when linking with --gc-sections.
In order to boot an LDR out of parallel flash, the ldr utility needs a few
flags to tell it to generate the right header.
On newer CPUs, 8536, 8572, and 8610, the CLKDIV field of LCRR is five bits
instead of four.
In order to avoid an ifdef, LCRR_CLKDIV is set to 0x1f on all systems. It
should be safe as the fifth bit was defined as reserved and set to 0.
Code that was using a hard coded 0x0f is changed to use LCRR_CLKDIV.
Signed-off-by: Trent Piepho <tpiepho@freescale.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Acked-by: Jon Loeliger <jdl@freescale.com>
