path: root/board
2016-09-14fsl: csu: add an API to set R/W permission to PCIeHou Zhiqiang
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14fsl: csu: add an API to set individual device access permissionHou Zhiqiang
Add this API to make the individual device is able to be set to the specified permission. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14arm: fsl-layerscape: move forward the non-secure access permission setupHou Zhiqiang
Move forward the basic non-secure access enable operation, so the subsequent individual device access permission can override it. And collect the dispersed callers in board level, and then move them to SoC level. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-14board: ls1043ardb: move sec_init to board_initSumit Garg
sec_init() which was earlier called in misc_init_r() is now done in board_init() before PPA init as SEC block will be used during PPA image validation. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-09-09Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2016-09-07board: ks2: README: Update to add K2G supportLokesh Vutla
Update the README to add support for K2G EVM. Also - Add steps on how to use MMC boot - Fix load address when using CCS - Update build target to u-boot.bin from u-boot-dtb.bin as all ks2 platforms uses DT. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-09-07board: am57xx: Fix missing check for beagle_x15Nishanth Menon
When beagleboard-X15 is booted, we see the following log: Unidentified board claims BBRDX15_ in eeprom header This is because of the missing check for x15 (the default) and reports an error for a valid board configuration. Fix the same. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-09-07board: am57xx: MAINTAINERS: Update for current maintainerNishanth Menon
Felipe Balbi has move on from TI and the current email ID is no longer valid. So, replacing with Lokesh. While at it, update missing config file which was untracked. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-07ARM: am335x: select DM_GPIOMasahiro Yamada
We are supposed to not add config entries with only "default y" in board/SoC Kconfig files. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
2016-09-07ARM: armv7: move CONFIG_ARMV7_PSCI to KconfigMasahiro Yamada
Add ARCH_SUPPORT_PSCI as a non-configurable option that platforms can select. Then, move CONFIG_ARMV7_PSCI, which is automatically enabled if both ARMV7_NONSEC and ARCH_SUPPORT_PSCI are enabled. Reviewed-by: Alexander Graf <agraf@suse.de> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-09-06omap3logic: Fix PBIAS BugAdam Ford
The PBIAS fixing is done in the MMC driver, and doing it in the the board file conflicts with the driver causing intermittent hangs on reboot. Remove this from the board file and let the driver do it. Signed-off-by: Adam Ford <aford173@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06meson: odroid-c2: enable Ethernet support through the device treeBeniamino Galvani
Remove the device definition from board file, update the driver with the new compatible property and update config with necessary options. Signed-off-by: Beniamino Galvani <b.galvani@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-06serial: bcm283x_mu: Detect disabled serial deviceAlexander Graf
On the raspberry pi, you can disable the serial port to gain dynamic frequency scaling which can get handy at times. However, in such a configuration the serial controller gets its rx queue filled up with zero bytes which then happily get transmitted on to whoever calls getc() today. This patch adds detection logic for that case by checking whether the RX pin is mapped to GPIO15 and disables the mini uart if it is not mapped properly. That way we can leave the driver enabled in the tree and can determine during runtime whether serial is usable or not, having a single binary that allows for uart and non-uart operation. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-09-06warp7: Print secure/non-secure mode infoFabio Estevam
warp7 has two targets: - warp7_defconfig: boots in non-secure mode - warp7_secure_defconfig: boots in secure mode Print the mode that is being used to help users to easily identify which target is running on the board. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-09-06mx6ul_14x14_ev: Enable the CCGR clocks earlierFabio Estevam
To be in the safe side we need to enable the CCGR clocks prior to calling arch_cpu_init(). Inspired by Tim Harvey's commit d783c2744f9 ("imx: ventana: fix boot to SD"). Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Eric Nelson <eric@nelint.com> Tested-by: Eric Nelson <eric@nelint.com>
2016-09-06mx6ul_14x14_evk: Adjust SPL DDR3 settingsFabio Estevam
Adjust DDR3 initialization done in SPL by comparing them against the NXP DCD table. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Eric Nelson <eric@nelint.com>
2016-09-06mx6ul_14x14_evk: Pass refsel and refr fields to avoid hangFabio Estevam
When running a NXP 4.1 kernel with U-Boot mainline on a mx6ul-evk, we observe a hang when going into the lowest operational point of cpufreq. This hang issue does not happen on the NXP U-Boot version. After comparing the SPL DDR initialization against the DCD table from NXP U-Boot, the key difference that causes the hang is the MDREF register setting: DATA 4 0x021B0020 0x00000800 ,which means: REF_SEL = 0 --> Periodic refresh cycle: 64kHz REFR = 1 ---> Refresh Rate - 2 refreshes So adjust the MDREF initialization for mx6ul_evk accordingly to fix the kernel hang issue at low bus frequency. Reported-by: Eric Nelson <eric@nelint.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Eric Nelson <eric@nelint.com>
2016-09-06mx6: ddr: Allow changing REFSEL and REFR fieldsFabio Estevam
Currently MX6 SPL DDR initialization hardcodes the REF_SEL and REFR fields of the MDREF register as 1 and 7, respectively for DDR3 and 0 and 3 for LPDDR2. Looking at the MDREF initialization done via DCD we see that boards do need to initialize these fields differently: $ git grep 0x021b0020 board/ board/bachmann/ot1200/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/ccv/xpress/imximage.cfg:DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */ board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x7800 board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6qp.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6dlsabresd.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6slevk/imximage.cfg:DATA 4 0x021b0020 0x00001800 board/freescale/mx6sxsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/freescale/mx6sxsabresd/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/warp/imximage.cfg:DATA 4 0x021b0020 0x00001800 So introduce a mechanism for users to be able to configure REFSEL and REFR fields as needed. Keep all the mx6 SPL users in their current REF_SEL and REFR values, so no functional changes for the existing users. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Eric Nelson <eric@nelint.com>
2016-09-06mx7dsabresd: Directly write to register LDOGCTLFabio Estevam
Register LDOGCTL contains only bit 0 as a valid bit, so there is no need to do a read-modify-write operation. Simplify the code by writing directly to this register. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-09-06pico-imx6ul: Directly write to register LDOGCTLFabio Estevam
2016-09-06ARM: board: cm_fx6: fix mtd partition fixupChristopher Spinrath
ft_board_setup may return early in the case that the board revision cannot be obtained. In that case it is assumed that no revision specific correction in the fdt is neccessary. But the mtd partitions will not be fixed up either altough they are not revision specific. Move the call to fdt_fixup_mtdparts in front of the revision specific part to ensure that the partitions are fixed up even if the board revision cannot be obtained. While on it, fix a spelling mistake in a comment introduced by the same commit. Fixes: 62d6bac66038 ("ARM: board: cm_fx6: fixup mtd partitions in the fdt") Signed-off-by: Christopher Spinrath <christopher.spinrath@rwth-aachen.de> Reviewed-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Nikita Kiryanov <nikita@compulab.co.il>
2016-09-06mx6ul_14x14_evk: don't use array for SD2 card detect padEric Nelson
Only a single pad is changed to change sdhc2_dat3 from an SDIO pin to and from GPIO4:5, so remove the array and use the imx_iomux_v3_setup_pad() routine. Signed-off-by: Eric Nelson <eric@nelint.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-09-06warp: Fix RAM size runtime detectionFabio Estevam
Since commit a13d3757f7df ("warp: Use imx_ddr_size() for calculating the DDR size") warp board no longer boots. The reason for the breakage is that the warp board is using the DDR configuration from mx6slevk. A fundamental difference between warp and mx6slevk is that warp only uses one DDR chip select while mx6slevk uses two. The imx_ddr() function calculates the RAM size in runtime by reading the values of registers MDCTL and MDMISC. So in order to fix this warp boot issue, create a imximage DDR file specific to warp, where the MDCTL register is configured to only activates a single chip select. Reported-by: Breno Lima <breno.lima@nxp.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Breno Lima <breno.lima@nxp.com>
2016-09-06warp7: Add PMIC supportVanessa Maegima
Add PMIC support. Tested by command "pmic PFUZE3000 dump". Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2016-09-06arm: imx: Add support for Advantech DMS-BA16 boardAkshay Bhat
Add support for Advantech DMS-BA16 board. The board is based on Advantech BA16 module which has a i.MX6D processor. The board supports: - FEC Ethernet - USB Ports - SDHC and MMC boot - SPI NOR - LVDS and HDMI display Basic information about the module: - Module manufacturer: Advantech - CPU: Freescale ARM Cortex-A9 i.MX6D - SPECS: Up to 2GB Onboard DDR3 Memory; Up to 16GB Onboard eMMC NAND Flash Supports OpenGL ES 2.0 and OpenVG 1.1 HDMI, 24-bit LVDS 1x UART, 2x I2C, 8x GPIO, 4x Host USB 2.0 port, 1x USB OTG port, 1x micro SD (SDHC),1x SDIO, 1x SATA II, 1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2 Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com> Cc: u-boot@lists.denx.de Cc: sbabic@denx.de
2016-09-06mx7dsabresd: Print secure/non-secure mode infoFabio Estevam
mx7dsabresd has two targets: - mx7dsabresd_defconfig: boots in non-secure mode - mx7dsabresd_secure_defconfig: boots in secure mode Print the mode that is being used to help users to easily identify which target is running on the board. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-09-06sunxi: fix 64-bit compiler warning for SPL header parsingAndre Przywara
Casting "int"s to pointers is only valid for 32-bit systems. Add the appropriate pointer type cast to avoid a compiler warning when compiling for AArch64. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-09-06sunxi: Kconfig: rename non-existent SUN50I_A64 config symbolAndre Przywara
There is no "CONFIG_MACH_SUN50I_A64" in upstream U-Boot, so fix the name to prevent the option to be enabled. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-09-03sunxi: Add defconfig and dts file for the Orange Pi Plus2E SBCHans de Goede
The Orange Pi Plus2E is an extended version of the Orange Pi Pc Plus, with 2G RAM and an external gbit ethernet phy. The dts file is identical to the one submitted to the upstream kernel, except that it has the pending patch to enable the ethernet controller squashed in, as u-boot already has sun8i-emac support. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-09-03sunxi: Add support for A33-OLinuXino boardStefan Mavrodiev
A33-OLinuXino is A33 development board designed by Olimex LTD. It has AXP223 PMU, 1GB DRAM, a micro SD card, one USB-OTG connector, headphone and mic jacks, connector for LiPo battery and optional 4GB NAND Flash. It has two 40-pin headers. One for LCD panel, and one for additional modules. Also there is CSI/DSI connector. The dts files are identical to the ones submitted to the upstream kernel. Signed-off-by: Stefan Mavrodiev <stefan.mavrodiev@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-09-03sunxi: Add iNet D978 rev2 defconfigIcenowy Zheng
The iNet D978 rev2 is a tablet board designed by iNet, which is intended to use on 10" tablets with a appearance like Apple iPad. It has A33 SoC, 1GB RAM, 8GB/16GB NAND, SDIO Wi-Fi, a MicroUSB port and a MicroSD slot. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-09-01ARM: tegra: Add support for TK1-SOM board from Colorado EngineeringPeter Chubb
The Colorado TK1 SOM is a small form factor board similar to the Jetson TK1. The main differences lie in the pinmux, and in that the PCIe controller is set to use in 4lanes+1lane, rather than 2+2. The pinmux header here was generated from a spreadsheet provided by Colorado Engineering using the tegra-pinmux scripts. The spreadsheet was converted from v09 to v11 by me. Signed-off-by: Peter Chubb <peter.chubb@data61.csiro.au> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-30x86: qemu: efi: Add two boards for EFI 32-bit and 64-bit payloadBin Meng
This introduces two board defconfig files for generating EFI 32-bit and 64-bit payloads, to run on QEMU x86 target. With these in place, hopefully buildman will catch any build error with EFI payload support on x86. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-27Merge git://git.denx.de/u-boot-rockchipTom Rini
2016-08-27rockchip: rk3399: update MAINTAINER fileKever Yang
This patch add maintainer information for rk3399 evb. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Färber <afaerber@suse.de>
2016-08-26Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2016-08-26treewide: fix "followings" to "following"Masahiro Yamada
Most of them are my mistakes. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-26sun5i: Add defconfig and dts file for the Empire Electronix M712 tabletHans de Goede
Add a defconfig and dts file for the Empire Electronix M712 tablet, this is a 7" A13 tablet, with micro-usb (otg), headphone and micro-sd slots on the outside. It uses a Goodix gt811 touchscreen controller, a RTL8188CTV wifi chip and a DMART06 (1238a4) accelerometer. The dts file is identical to the one submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-08-26sun6i: Add defconfig and dts file for tablets using the inet-q972 PCBHans de Goede
Add a defconfig and dts file for tablets using the generic inet-q972 PCB. Tablets with this PCB feature a mini-hdmi output, micro-usb usb-host, micro-usb usb-otg, 3.5mm headphone jack, a micro sd slot, (mini) power-barrel and an usb wifi module. This has been tested on a 9.7" 1024x768 qware qw tb9718-qhd tablet. The dts files are identical to the ones submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-08-20Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
[trini: Drop CMD_BOOTI as it's now on by default on ARM64] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-17ARM: rmobile: lager: Move rcar-gen2-common to rcar-commonNobuhiro Iwamatsu
To common use of rcar-gen2-common directory in the R-Car SoCs, and change from rcar-gen2-common to rcar-common. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17arm: rmobile: Fix HDMI output for BLANCHE boardmasakazu.mochizuki.wd@hitachi.com
This commit fixes HDMI output for BLANCHE board Signed-off-by: Masakazu Mochizuki <masakazu.mochizuki.wd@hitachi.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17arm: rmobile: Add BLANCHE board supportmasakazu.mochizuki.wd@hitachi.com
BLANCHE is development board based on R-Car V2H SoC (R8A7792) This commit supports the following periherals: - SCIF, Ethernet, QSPI, MMC Signed-off-by: Masakazu Mochizuki <masakazu.mochizuki.wd@hitachi.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: rcar-common: Fix warning of type differenceNobuhiro Iwamatsu
2016-08-17ARM: rmobile: Add support salvator-x boardNobuhiro Iwamatsu
Salvator-x is an entry level development board based on R-Car H3 SoC (R8A7795). This commit supports SCIF only. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Add support R-Car Generation 3Nobuhiro Iwamatsu
This adds supporting R-Car Generation 3 (Gen3) as Renesas ARM64 SoC. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Move rcar-gen2-common to rcar-commonNobuhiro Iwamatsu
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2016-08-16x86: Add theadorable-x86-dfi-bt700 board supportStefan Roese
This patch adds support for the BayTrail based theadorable-x86-dfi-bt700 board which uses the DFI BT700 BayTrail Qseven SoM on a custom baseboard. The main difference to the DFI baseboard is, that it isn't equipped with a Super IO chip and uses the internal HS SIO UART (memory mapped PCI based) as the console UART. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
