path: root/board
2017-07-12wandboard: Remove unnecessary delayFabio Estevam
There is no need to add a 100us delay after the DDR initialization. Other imx6 boards do not have such delay either, so simply remove it. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-07-11Merge git://git.denx.de/u-boot-dmTom Rini
2017-07-11Merge branch 'master' of git://git.denx.de/u-boot-rockchipTom Rini
2017-07-11dm: scsi: Document and rename the scsi_scan() parameterSimon Glass
The 'mode' parameter is actually a flag to determine whether to display a list of devices found during the scan. Rename it to reflect this, add a function comment and adjust callers to use a boolean. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11dm: ahci: Rename struct ahci_probe_entSimon Glass
This is not a very useful name since once it is probed it still hangs around. With driver model we will use uclass data for this, so rename the struct. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11Kconfig: Add CONFIG_SATA to enable SATASimon Glass
At present CONFIG_CMD_SATA enables the 'sata' command which also brings in SATA support. Some boards may wish to enable SATA without the command. Add a separate CONFIG to permit this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11sandbox: README: fix partition command invocationAlison Chaiken
The instructions for creating a disk image that are presently in README.sandbox fail because sfdisk doesn't know about GPT. Signed-off-by: Alison Chaiken <alison@peloton-tech.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2017-07-11rockchip: evb-rk3328: enable boot on regulatorKever Yang
Enable all the boot-on regulator in default. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: Add basic support for phyCORE-RK3288 SoM based carrier boardWadim Egorov
The phyCORE-RK3288 is a SoM (System on Module) containing a RK3288 SoC. The module can be connected to different carrier boards. It can be also equipped with different RAM, SPI flash and eMMC variants. The Rapid Development Kit option is using the following setup: - 1 GB DDR3 RAM (2 Banks) - 1x 4 KB EEPROM - DP83867 Gigabit Ethernet PHY - 16 MB SPI Flash - 4 GB eMMC Flash Add basic support for the PCM-947 carrier board, a RK3288 based development board made by PHYTEC. This board works in a combination with the phyCORE-RK3288 System on Module. Signed-off-by: Wadim Egorov <w.egorov@phytec.de> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: rk3328: board: add support of dwc2 gadgetMeng Dongyang
Probe dwc2 udc in the function of board_usb_start to enable usb gadget function. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: add evb_rk3229 boardKever Yang
evb_rk3229 is a RK3229 based board, with: - 8GB eMMC; - 1GB DDR SDRAM; - 2 USB2.0 HOST port; - 1 MAC port; - 1 HDMI port; - IR; - WiFi; Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: correct the bank0 ram sizeKever Yang
The bank0 ram size should be the DRAM size minus reserved size, the DRAM size may be 1GB, 2GB, 4GB, we can not hard code it. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Added DECLARE_GLOBAL_DATA_PTR for RK3328, RK3368 and RK3399: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: use common sdram functionKever Yang
Replace the sdram_init() in board init and rockchip_sdram_size() in sdram driver for all the Rockchip SoCs which enable CONFIG_RAM. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Make dram_init() in rk3036-board.c conditional on CONFIG_RAM: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-10ARM64: poplar: hi3798cv200: u-boot support for Poplar 96BoardsJorge Ramirez-Ortiz
This port adds support for: 1) Serial 2) eMMC 3) USB It has been tested with ARM TRUSTED FIRMWARE running u-boot as the BL33 executable [see board's README] eMMC has been tested for reading and booting the loader and linux kernels as well as saving the u-boot environment. USB has been tested with ASIX networking adapter and SanDisk 7.4GB drive. PSCI has been tested via the reset call (PSCI executes from DDR) The firwmare upgrade process has been tested via TFTP and USB FAT filesystem containing the fastboot.bin image in one of the partitions. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-07-10ARM: k2g: Add K2G ICE DTB to the list of possible DTBsCooper Jr., Franklin
K2G ICE evm will have its own dtb. Therefore, add it to the list of dtbs located in the appended U-boot dtb FIT image. Therefore, when swapping out dtbs K2G ICE boards can grab the correct one. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ARM: k2g: Update board_name u-boot env variable at runtimeCooper Jr., Franklin
Enable CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to allow "board_name" to be set depending on the board it is being ran on. Update findfdt to use this new dynamic board_name value to determine which dtb should be used. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ARM: k2g: Use board detection to wrap K2G GP specific callsCooper Jr., Franklin
Certain peripherals used by K2G GP aren't used on K2G ICE evm. Or configuration is slightly different. Therefore, use board detection to deal with these variations. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10board: ks2: Use board detection to wrap code not specific to K2G ICE evmCooper Jr., Franklin
Some code doesn't apply to K2G ICE evm. Therefore, use board detection to wrap these calls. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ARM: k2g: Add DDR3 configuration for K2G ICE evmCooper Jr., Franklin
Add configuration settings used by the K2G ICE evm. Also use board detection to determine which DDR3 configuration to use. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ARM: k2g: Add pinmux support for K2G ICE evmCooper Jr., Franklin
Add basic pinmux data for new K2G ICE evm. Also add pinmuxing for a generic K2G evm which includes I2C 0 and 1 used for board detection purposes. Since multiple K2G boards are supported that means initially generic pinmuxing should be used when board detection hasn't ran. Once board detection runs the proper pinmuxing can be reran to match the board being ran on. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ks2_evm: Add EEPROM based board detection helper functionsCooper Jr., Franklin
Add a function that can be used to determine if the board being ran on is a K2G Industrial Communication Engine EVM or K2G General Purpose EVM based on values programmed on the EEPROM. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ARM: k2g: Program DDRPHY_DATX8 registers via mask and value variablesCooper Jr., Franklin
Different K2G evms may need to program the various KS2_DDRPHY_DATX8_X_OFFSET registers in different ways. Therefore, use the mask and val registers for each KS2_DDRPHY_DATAX_X_OFFSET to properly program the register. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ARM: k2g: Program DDR PHY MR2 register with the default valueCooper Jr., Franklin
K2G GP doesn't require the MR2 register to be programed since the default is good enough. However, newer K2G boards do need to change this register value. Therefore, instead of not writing this register if ran on a K2G board just program the value to be written to match the default/reset value. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ks2_evm: Add EEPROM based board detectionCooper Jr., Franklin
Some K2G evms have their EEPROM programming while most do not. Therefore, add EEPROM board detection to be used as the default method and fall back to the alternative board detection when needed. Also reorder board configuration. Perform bare minimal configuration initially since board detection hasn't ran. Finish board configuration once the board has been identified. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ARM: keystone2: Define board_fit_config_name_match for Keystone 2 boardsCooper Jr., Franklin
Now with support for U-boot runtime dtb selection each board needs to define board_fit_config_name_match so U-boot can determine what the correct dtb is within the FIT blob. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ARM: k2g: Define embedded_dtb_select for runtime DTB selection in U-bootCooper Jr., Franklin
For K2G, runtime DTB selection utilizes the embedded_dtb_select function. Therefore, define the function which will perform a EEPROM read and then retries selecting the correct dtb now that it can detect which board its on. For other Keystone devices use an empty function since they will still use the embedded FIT functionality but their FIT will only contain a single dtb. Most production K2G boards do not have their EEPROM programmed. Therefore, perform a test to verify a K2G GP is currently being used and if it is then set the values normally set by a EEPROM read. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ti: common: board_detect: Add function to determine if EEPROM was readCooper Jr., Franklin
When the EEPROM is first read its contents are stored in memory as a cache to avoid further I2C operations. To determine if the EEPROM was previously read the easiest way is to check the memory to see if the EEPROM's magic header value is set. Create a new function that can determine if the EEPROM was previously read or not without having to perform a I2C transaction. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10ti: common: board_detect: Allow settings board detection variables manuallyNishanth Menon
In some situations the EEPROM used for board detection may not be programmed or simply programmed incorrectly. Therefore, it may be necessary to "simulate" reading the contents of the EEPROM to set appropriate variables used in the board detection code. This may also be helpful in certain boot modes where doing i2c reads may be costly and the config supports running only a specific board. Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Franklin S Cooper Jr. <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-10km/common: remove unused function declarationsHolger Brunck
Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
2017-07-08MAINTAINERS: drop bcm283x/rpi maintainershipStephen Warren
It's been a while since I've touched U-Boot on the Raspberry Pi and other things have been taking my time. Drop my maintainership for this port. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2017-07-08powerpc, 8xx: Add support for MCR3000 board from CSSIChristophe Leroy
CS Systemes d'Information (CSSI) manufactures two boards, named MCR3000 and CMPC885 which are respectively based on MPC866 and MPC885 processors. This patch adds support for the first board. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-07-06km/common: remove unused codeHolger Brunck
The 82xx board mgcoge3ne was removed from the codebase, so this is dead code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-07-06igep003x: Falcon modeLadislav Michl
Implement spl_start_uboot to let Falcon mode work. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Heiko Schocher <hs@denx.de>
2017-07-06odroid-c2: Populate serial# environment variable from efuseMartin Böh
2017-07-03powerpc: remove 4xx supportHeiko Schocher
There was for long time no activity in the 4xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 4xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-29pico-imx7d: Remove bouncing emailFabio Estevam
Wig Cheng's email bounces, so remove it from the maintainers list. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-06-29Merge git://git.denx.de/u-boot-arcTom Rini
2017-06-29ARM: at91: ma5d4: Support both SF and eMMC SoMsMarek Vasut
Discern the SoMs based on the presence of SPI flash to support both variants of the SoM, one booting from SPI NOR and one booting from eMMC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Boot from MMC2 when using SAM-BAMarek Vasut
Continue loading U-Boot from MMC2 when the SPL was loaded using SAM-BA loader. This allows the board to boot system from the removable media instead of the eMMC, which is useful for commissioning purposes. When booting from the eMMC, always boot from it as it is not possible to boot from the SD interface directly. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Swap SD/MMC controller orderMarek Vasut
The SDHCI1 is the primary boot controller on rev. 2.1 SoM, which is the version available on the market. Swap the controller order to match this and future versions of the SoM. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Init SD/MMC controller in SPLMarek Vasut
Init the controllers, otherwise the board cannot boot from SD/MMC. This boot option is new on rev. 2.1 SoM . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Reset CAN controllers lateMarek Vasut
The CAN controllers need slight delay between toggling of their reset line. Move this action into board_init(), otherwise timer will not be initialized and the board might hang. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Switch DDR2 controller to sequencial address decodingMarek Vasut
According to the datasheet, sequential mapping is used for DDR SDRAM, while interleaved mapping is used for regular SDRAM. Incorrect configuration of this bit does indeed cause sporadic memory instability. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Wenyou Yang <wenyou.yang@atmel.com>
2017-06-29ARM: atmel: Rename MA5D4EVKMarek Vasut
The board is now manufactured by Aries Embedded GmbH , rename it. Signed-off-by: Marek Vasut <marex@denx.de>
2017-06-29arc: Add support for HS Development Kit boardAlexey Brodkin
ARC HS Development Kit board is a new low-cost development platform sporting ARC HS38 in real silicon with nice set of features such as: * Quad-core ARC HS38 with 512 kB L2 cache and running @1GHz * 4Gb of DDR (we use only lowest 1Gb out of it now) * Lots of DesigWare peripherals * Different connectivity modules: - Synopsys HAPS HT3 - Arduino-compatible connector - MikroBUS This initial commit supports the following peripherals: * UART (DW 8250) * Ethernet (DW GMAC) * SD/MMC (DW Mobile Storage) * USB 1.1 & 2.0 Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2017-06-29atmel, at91: fix taurus boardHeiko Schocher
since commit: f8b7fff1d5c5 "serial: atmel_usart: Add clk support" taurus board comes not up anymore. Fix it. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-06-29at91, dfu, smartweb: set serial numberHeiko Schocher
since commit 842778a09104 dfu-util shows serial="UNDEFINED". to see here again a serial number, we have to call g_dnl_set_serialnumber(). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-29atmel, at91: fix smartweb boardHeiko Schocher
since commit: f8b7fff1d5c5 "serial: atmel_usart: Add clk support" smartweb board comes not up anymore. Fix it. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Wenyou Yang <wenyou.yang@microchip.com>
