path: root/board
2012-03-19x86: Make RW unused section labels uniqueDuncan Laurie
BUG=none TEST=check fmap on generated binary for unique names Change-Id: Id1ac5cf223ec6a333fc8f4c587e972afd087f90d Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/18435 Reviewed-by: Stefan Reinauer <reinauer@google.com>
2012-03-16Reduce RW BIOS data sections to 512K from 976KDuncan Laurie
This saves 500ms in the RW BIOS path and still leaves 130K overhead from the current U-boot size (372K) which should be more than enough for any future updates on stumpy/lumpy. This should be re-visited if/when vboot is smart enough to just read+validate the actual binary within the section. BUG=chrome-os-partner:8518 TEST=boot lumpy/stumpy through RW BIOS path and gather timestamps to see 500ms improvement. Change-Id: Ia714b4b95245f02f6e781247f820ca915bb403f5 Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/18372 Reviewed-by: Stefan Reinauer <reinauer@google.com>
2012-03-15Use keyboard controller for hard reset instead of CF9Vadim Bendebury
For some still unknown reason writes to localtion 0xcf9 do not cause the Link to reboot, they cause it to shut down instead. While this will have to be investigated and fixed, this change modifies the code to use the keyboard controller (implemented by the EC on Link) to restart the system. Once the 0xcf9 problem is resolved, this change could be reverted. BUG=chrome-os-partner:8397 TEST=manual . when u-boot tires restarting the system it now reboots. before this change it would just shut down. Change-Id: I8076f897304f705e20ec8f2e30cce17d7fdd31c4 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/18332 Reviewed-by: Hung-Te Lin <hungte@chromium.org>
2012-03-15arm: Tegra3: pass board id through the dts filesVarun Wadekar
BUG=chromium-os:23496 TEST=build on Waluigi, Seaboard, Cardhu Change-Id: I9ccd3085fb551e9887815592e9b518b6944beda7 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14474 Reviewed-by: Simon Glass <sjg@chromium.org>
2012-03-13x86: Add an emeraldlake2 device treeGabe Black
BUG=chrome-os-partner:8180 TEST=Built u-boot for emeraldlake2. Change-Id: Iae62f047ddc102fbf530e1f8f9af34939971a6a3 Signed-off-by: Gabe Black <gabeblack@google.com> Reviewed-on: https://gerrit.chromium.org/gerrit/18057 Reviewed-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@google.com> Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
2012-03-08tegra: Remove keyboard support from fdtSimon Glass
This uses a format which is not supported by the upstream dtc, so remove this. BUG=chromium-os:23249 TEST=emerge-tegra2_kaen chromeos-u-boot with new dtc Signed-off-by: Simon Glass <sjg@chromium.org> Change-Id: I18b9420dbee20c2d115cc5ff1b13425faffe2a3e Reviewed-on: https://gerrit.chromium.org/gerrit/17630
2012-02-28Don't ever return from cold_reboot() functionStefan Reinauer
cold_reboot() should wait until the reset kicks in, instead of returning and continuing in an undefined code path. Without this patch, vboot_twostop will return, and secure_boot() will start printing an error message, which results in a sporadic # on the screen when pressing space or ESC on the dev screen in order to go to recovery mode. BUG=chrome-os-partner:7683 TEST=boot to dev screen on lumpy, press ESC or space. Observe there is no # character printed before going to recovery mode. Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: Ic2ee570032686e48603f0fb3b1ec9cbfae9451bc Reviewed-on: https://gerrit.chromium.org/gerrit/17007 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Duncan Laurie <dlaurie@chromium.org> Commit-Ready: Stefan Reinauer <reinauer@chromium.org>
2012-02-27Add flag fast-developer-mode to make default developer mode time on x86 2sStefan Reinauer
This will trigger setting gbb.flags to 1 in cros_bundle_firmware so the factory time is reduced. GBB.flags will be changed in the factory process. Also needs https://gerrit.chromium.org/gerrit/#change,16845 BUG=chrome-os-partner:7671 TEST=manual emerge-stumpy chromeos-bootimage gbb_utility -g --flags /build/stumpy/firmware/image.bin Should report "flags: 0x00000001" Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: Ie05433ad737005bd5dcca2f88232b0a5bbd00df9 Reviewed-on: https://gerrit.chromium.org/gerrit/16113 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Commit-Ready: Stefan Reinauer <reinauer@chromium.org>
2012-02-14arm: tegra2: split LP0 code to help future chipsVarun Wadekar
split the LP0 code for tegra2 into common LP0 code and chip specific warm boot code BUG=chromium-os:23496 TEST=build for Seaboard Change-Id: Ie04bf9ac17482a37afd0f4515dc3aafeb4f48ae7 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/15883
2012-02-08Revert "arm: tegra2: split LP0 code to help future chips"Brian Harring
This reverts commit 4c7502242627f64d91432cb4958be5f93f65fbff Don't think this is the cause of http://code.google.com/p/chromium-os/issues/detail?id=26116, but it was in the same batch so I'm reverting in the process. Change-Id: Icc013ced6c22e29d569ee4ca8ef73522154ec1a8 Reviewed-on: https://gerrit.chromium.org/gerrit/15561 Reviewed-by: Brian Harring <ferringb@chromium.org> Tested-by: Brian Harring <ferringb@chromium.org>
2012-02-08arm: tegra2: split LP0 code to help future chipsVarun Wadekar
split the LP0 code for tegra2 into common LP0 code and chip specific warm boot code BUG=chromium-os:23496 TEST=build for Seaboard Change-Id: Id9756c08f61502affa8beee636d883d01468e6ec Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13799
2012-02-07tegra3: fdt: change lcd frame buffer addressPuneet Saxena
For Waluigi, existing frame buffer address does not fall under external memory map. Setting it to the location set as per the default initialization. BUG=chromium-os:23496 TEST=Build ok for Cardhu, Waluigi and Seaboard. Tested on Waluigi. Change-Id: I2284d43c11f4d6622344429508b1f99e30929f19 Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14698
2012-02-07tegra: Rename "CONFIG_VIDEO_TEGRA2" to "CONFIG_VIDEO_TEGRA"Puneet Saxena
Enables common LCD support for Tegra2 and Tegra3 BUG=chromium-os:23496 TEST=Built ok for Cardhu, Waluigi and Seaboard. Change-Id: I938824045440cc4964c2ac6bf727a90ee5f129b4 Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14692
2012-02-06tegra3: fdt: Add Waluigi keyboard mapPuneet Saxena
Add Waluigi keyboard map in Waluigi fdt BUG=chromium-os:23496 TEST=Build and tested on Waluigi. Change-Id: Iaf39dabc2bef2f12c2f0b875cc3c397386dbb446 Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13929 Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2012-02-06tegra3: fdt: Add Tegra30 keyboard controller definitionPuneet Saxena
Add Keyboard controller option in tegra30 fdt. BUG=chromium-os:23496 TEST=Build ok for Waluigi, Seaboard and Cardhu. Change-Id: I20fe7feed42a96edea138dc32c532e0d1d535226 Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/14546 Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2012-02-06tegra: change Keyboard config namePuneet Saxena
Rename CONFIG_TEGRA2_KEYBOARD to common CONFIG_TEGRA_KEYBOARD BUG=chromium-os:23496 TEST=Build OK for Waluigi, Cardhu and Seaboard. Change-Id: Ice2741622fe6434ba25ece8fe7fbe2ca989c44ef Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13930 Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2012-02-06Arm: tegra3: Add 16x8 keyboard supportPuneet Saxena
Expand existing 4x6 keyboard support to 16x8 keyboard. Add Tegra2 specific changes under Tegra2 config "CONFIG_TEGRA2". BUG=chromium-os:23496 TEST=Tested on Waluigi.key press echoes the key on console. Built ok for Cardhu and Seaboard. Change-Id: Iab291a636d41b721d914014a5fe9ecc8775bf260 Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: https://gerrit.chromium.org/gerrit/13928 Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-19Enable frequency selection in VbExBeep().Bill Richardson
BUG=none TEST=manual In dev-mode, press "Ctrl-U" with no USB stick inserted. If "crossystem dev_boot_usb" is 0, you'll hear two 400Hz beeps. If "crossystem dev_boot_usb" is 1, you'll hear one 200Hz beep. Signed-off-by: Bill Richardson <wfrichar@google.com> Change-Id: Ifd45a067ec8b922863331f13f3f4525ef40f7346 Reviewed-on: https://gerrit.chromium.org/gerrit/14529 Tested-by: Bill Richardson <wfrichar@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Commit-Ready: Bill Richardson <wfrichar@chromium.org>
2012-01-12CHROMIUM: x86: Align the header for the MRC data cache.Duncan Laurie
This is to match a change made in coreboot to align both the header and the data to 16 bytes. BUG=none TEST=several cold boots to ensure that the MRC data cache is not written out on every boot. Change-Id: I6c9a01933264d6bd65958ddb93e8944c35e853c6 Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/14096 Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
2012-01-09[x86]: Add environment section to flash map.Stefan Reinauer
dev_cfg is used by vboot_reference, hence we can't store our u-boot environment there anymore. So create a section rw-environment for that purpose. Signed-off-by: Stefan Reinauer <reinauer@google.com> BUG=chrome-os-partner:7264 TEST=boot tested on Stumpy Change-Id: I15479f0f1a2aa111b742d2792052f48d660d122c Reviewed-on: https://gerrit.chromium.org/gerrit/13022 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Commit-Ready: Stefan Reinauer <reinauer@chromium.org>
2012-01-05tegra: Use board_late_init() to finalize LCD initSimon Glass
We need to make sure that the LCD is ready before we complete booting, so put this code into board_late_init(). BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: I97bd1fce6ac93d0639dd8fdb17bf83e8a78d2645 Reviewed-on: https://gerrit.chromium.org/gerrit/13213 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2012-01-05tegra: Tidy up LCD init code to use a state machineSimon Glass
The LCD init takes place over five stages. We want to hide this init behind other operations, so turn it into a state machine which we can call at any time. For now, call it in lcd_enable(). BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: Ia0b50ec74108ac4e015de12b7a9628426ea17656 Reviewed-on: https://gerrit.chromium.org/gerrit/13211 Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2012-01-03CHROMIUMOS: Issue SMI to finalize Coreboot in final stageDuncan Laurie
This will write magic value to APMC command port which will trigger an SMI and cause coreboot to lock down the ME, chipset, and CPU. BUG=chrome-os-partner:6609 TEST=boot on stumpy+celeron and lumpy+i5 and ensure the system still boots and that registers are locked Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Change-Id: Ib30ea83044f5123205531a5e8ee88ee37de2dd86 Reviewed-on: https://gerrit.chromium.org/gerrit/13604 Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
2012-01-03CHROMIUMOS: Add U-boot support for wear-leveling the MRC dataDuncan Laurie
- Depends on related Coreboot changes - There is a 64k region allocated so use it all - Write each data blob in a 4K aligned container - Find the last entry in the region to compare against coreboot copy - Detect a full region and erase it all and start over at zero BUG=chrome-os-partner:6962 TEST=manual I started writing an autotest for this, but it was taking more time than just doing a thorough manual test. I will finish the autotest but for now I relied on manual testing and using /sys/firmware/log to tell what happened in Coreboot/U-boot on each boot. TEST CASE 1 - newly flashed image: 1) Install the new bios with flashrom and reboot 2) Check that no MRC data was found by Coreboot in firmware log: "prepare_mrc_cache: invalid MRC data" 3) Check that U-boot wrote training data in firmware log: "handle_mrc_cache: cached storage mismatch (-1/2895)" "firmware_storage_spi: before adjustment" "firmware_storage_spi: offset: 0x1ec000" "firmware_storage_spi: length: 0xb58" "firmware_storage_spi: after adjustment" "firmware_storage_spi: offset: 0x1ec000" "firmware_storage_spi: length: 0x1000" "firmware_storage_spi: offset: 0x001ec000" "firmware_storage_spi: adjusted offset: 0x001ec000" 4) Check the flash to see if it has data in first slot > flashrom -r /tmp/bios.now > hexdump -Cv -s $((0x1ec000)) -n $((0x10000)) /tmp/bios.now TEST CASE 2 - ensure that it uses the saved training data: 1) Reboot 2) Check that Coreboot used the training data in firmware log: "prepare_mrc_cache: at ff9ec009, entry 0 size b4f checksum 9c" 3) Check that U-boot did not have to update the data in firmware log: "handle_mrc_cache: cached storage match" 4) Check the flash to see if it still only has data in first slot: > flashrom -r /tmp/bios.now > hexdump -Cv -s $((0x1ec000)) -n $((0x10000)) /tmp/bios.now TEST CASE 3 - ensure that it fills the next slot with new data: 1) Corrupt the seed checksum in CMOS: > io_write8 0x70 0x78 > io_write8 0x71 0x00 2) Reboot 3) Check that Coreboot did not use cached data in firmware log: "prepare_mrc_cache: invalid seed checksum" 4) Check that U-boot wrote new training data at new offset in firmware log: "handle_mrc_cache: cached storage mismatch (2895/2895)" "firmware_storage_spi: before adjustment" "firmware_storage_spi: offset: 0x1ed000" "firmware_storage_spi: length: 0xb58" "firmware_storage_spi: after adjustment" "firmware_storage_spi: offset: 0x1ed000" "firmware_storage_spi: length: 0x1000" "firmware_storage_spi: offset: 0x001ed000" "firmware_storage_spi: adjusted offset: 0x001ed000" Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Change-Id: Ifffce29c5f9324f110c047a44a3f66d2e21cd6a4 Reviewed-on: https://gerrit.chromium.org/gerrit/13589 Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Ronald G. Minnich <rminnich@chromium.org>
2011-12-31CHROMIUMOS: x86: Fix MTRR clear to detect which MTRR to useDuncan Laurie
Coreboot was always using MTRR 7 for the write-protect cache entry that covers the ROM and U-boot was removing it. However with 4GB configs we need more MTRRs for the BIOS and so the WP MTRR needs to move. Instead coreboot will always use the last available MTRR that is normally set aside for OS use and U-boot can clear it before the OS. BUG=chrome-os-partner:7350 TEST=boot 4GB stumpy with coreboot MTRR fixes and verify that U-boot does not clear MTRR 7 but does clear MTRR 9. Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Change-Id: Id6927325131b0b88043daa320a17847764626c0d Reviewed-on: https://gerrit.chromium.org/gerrit/13477 Reviewed-by: Ronald G. Minnich <rminnich@chromium.org> Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
2011-12-21tegra: Implement CONFIG_DELAY_CONSOLESimon Glass
Add plumbing to support this option to delay console init until after relocation. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: Iee3be9e2d0b51e6cf2f45a4408bfdde494c97d8b Reviewed-on: https://gerrit.chromium.org/gerrit/13210 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org>
2011-12-21tegra: Refactor serial init codeSimon Glass
Move the serial init code into its own function to collect this all in one place. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: I70162d836fddfabedd9cfbc07d8f0dc920602af8 Reviewed-on: https://gerrit.chromium.org/gerrit/13204 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-12-20CHROMIUM: config: Switch Kaen to 8-bit eMMCSimon Glass
We can support 8-bit eMMC and it is faster, so turn it on. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: I1509594832d317a086fa066d1a37c78a1a52c7c3 Reviewed-on: https://gerrit.chromium.org/gerrit/13201 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-12-20tegra: mmc: Support 8-bit wide interface for eMMCSimon Glass
The Tegra2 can support this faster interface, so use it. It can reduce data transfer time by about 40%. BUG=chromium-os:22938 TEST=build and boot on Kaen Change-Id: I656773c83083cd53d3ee52433e324e73fbcdc999 Reviewed-on: https://gerrit.chromium.org/gerrit/13200 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Tom Warren <twarren@nvidia.com> Commit-Ready: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2011-12-19tegra: Skip NAND init if fdt indicates it is not activeSimon Glass
This allows NAND to be disabled from the fdt easily. BUG=chromium-os:22938 TEST=build and boot on Kaen Signed-off-by: Fred Signed-off-by: John Change-Id: Ibf9259f8621e73fcf943f54a20327513288fef06 Reviewed-on: https://gerrit.chromium.org/gerrit/12913 Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-12-16Add beep for x86 chormeos.Dylan Reid
Implement the VbExBeep function so that the DEV screen can beep. Much of this code was coppied from coreboot. BUG=chrome-os-partner:7114 TEST=manual, check that Stumpy beeps on DEV screen timeout and when booting from USB with dev_boot_usb=0. Change-Id: Icd4eabb0b10cc3d226db71e6a2b52d3ed7eb25ef Signed-off-by: Dylan Reid <dgreid@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/13110 Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
2011-12-16x86: Move RO VPD to H2C's positionStefan Reinauer
BUG=chrome-os-partner:7185 TEST=emerge-* chromeos-u-boot chromeos-coreboot chromeos-bootimage Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: I5361c9ba9519dd726adf9e91747fe08b5e79e9a7 Reviewed-on: https://gerrit.chromium.org/gerrit/13106 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
2011-12-15[x86] FMAP: Move RW_VPD section and add RW_SHARED section backStefan Reinauer
This patch moves the RW VPD section to the same place they live at H2O and H2C for Stumpy and Lumpy, so we can preserve them more easily when switching back and forth. Also, add a RW shared section around the MRC cache and dev cfg, so they get wiped by a recovery firmware update. Signed-off-by: Stefan Reinauer <reinauer@google.com> BUG=chrome-os-partner:7185 TEST=boot tested on Stumpy Change-Id: I77778d17835b1fe4771370a3523b21c9e5a6b0a7 Reviewed-on: https://gerrit.chromium.org/gerrit/12990 Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
2011-12-14fdt: Tegra3: Add Cardhu device-tree fileTom Warren
BUG=chromium-os:23496 TEST=none Modeled on tegra3-waluigi.dts Signed-off-by: Tom Warren <twarren@nvidia.com> Change-Id: I3a31084fa747991484dda4a40e89deda97a1ff1f Reviewed-on: https://gerrit.chromium.org/gerrit/12939 Reviewed-by: Simon Glass <sjg@chromium.org>
2011-12-14Move RW section of on Sandybridge to lower 4MB of the flash chipStefan Reinauer
H2C splits the flash device in 2 equal partitions of 4MB each. In order to avoid having to adapt user space tools to coreboot, change the flash map on Sandybridge to have the following flash layout: 1.5MB SI_ (ME) sections 2.5MB RW sections 4.0MB RO sections BUG=none TEST=boot tested on Stumpy Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: Ida0864389644b07b2d284770be62447547fdfb2e Reviewed-on: https://gerrit.chromium.org/gerrit/12937 Reviewed-by: Duncan Laurie <dlaurie@chromium.org> Tested-by: Stefan Reinauer <reinauer@chromium.org>
2011-12-13tegra3: USB: Add/enable USB support in board initTom Warren
BUG=chromium-os:23496 TEST=built Seaboard and Waluigi OK Signed-off-by: Tom Warren <twarren@nvidia.com> Change-Id: I00f6cde99ec4473da3d571fffb1e4adde7828822 Reviewed-on: https://gerrit.chromium.org/gerrit/12443
2011-12-13tegra3: fdt: Add USB fields to T30 Waluigi .dtsTom Warren
BUG=chromium-os:23496 TEST=built Seaboard and Waluigi OK Signed-off-by: Tom Warren <twarren@nvidia.com> Change-Id: I40147ab6d07cc13ef255736f0ebdabe34f85addf Reviewed-on: https://gerrit.chromium.org/gerrit/12441 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2011-12-13tegra3: fdt: Add USB to T30 .dtsiTom Warren
BUG=chromium-os:23496 TEST=built Seaboard and Waluigi OK Signed-off-by: Tom Warren <twarren@nvidia.com> Change-Id: I918a326749272032a682dea7c27d86494da31a6f Reviewed-on: https://gerrit.chromium.org/gerrit/12440 Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org>
2011-12-09reorganize x86 fmapsStefan Reinauer
- obsolete alex fmap is not updated. - drop unused shared-section, ro-recovery, ro-data - make coreboot CBFS 1MB - make GBB 512KB - align RW-A and RW-B to 1MB - increase rw-mrc-cache to 64KB for RW level wearing BUG=chrome-os-partner:7172 TEST=boot coreboot on Stumpy and see it still booting Signed-off-by: Stefan Reinauer <reinauer@google.com> Change-Id: I4da3b6bf1023bacadaa9b2e07eb07500247e120c Reviewed-on: https://gerrit.chromium.org/gerrit/12704 Reviewed-by: Vadim Bendebury <vbendeb@chromium.org> Tested-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
2011-12-08Update 8MB flashmap layout to match new flash descriptor settings.Duncan Laurie
- SI_ME size is now 1.5MB (down from 2MB) - SI_BIOS size is now 6.5MB (up from 6MB) - coreboot-extra region increases by 512K to consume the new space BUG=chrome-os-partner:7147 TEST=boot on stumpy and lumpy with updated descriptor and ME Change-Id: I77e720e453901f9dcfe861e4c41447bf9832f919 Signed-off-by: Duncan Laurie <dlaurie@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/12654 Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
2011-12-08fdt: enable USB keyboard on StumpyVincent Palatin
detect keypress at startup on the USB keyboard since we have no internal keyboard. BUG=chrome-os-partner:5752 TEST=on Stumpy, check Ctrl+U, Ctrl+D and space are working as expected in dev mode. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Change-Id: I34762f528817ffd29fa5a1198473f030887990bd Reviewed-on: https://gerrit.chromium.org/gerrit/12583 Commit-Ready: Vincent Palatin <vpalatin@chromium.org> Tested-by: Vincent Palatin <vpalatin@chromium.org> Reviewed-by: Vincent Palatin <vpalatin@chromium.org>
2011-12-08add USB keyboard support for vboot.Vincent Palatin
If the primary input of the device is a USB keyboard (as defined by the FDT) and we are in developer mode, enumerate the USB devices at startup and get key strokes from USB keyboard. The keyboard reading is not working correctly yet on the recovery path due to the USB mass storage polling code doing continuous re-enumeration on the USB controller. BUG=chrome-os-partner:5752 TEST=tested on Stumpy and Lumpy, with and without usb-keyboard set in the device tree, check Ctrl+U, Ctrl+D and space are working as expected. Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Change-Id: Ib46d6086ae5e5ce631d5f91b467f7b2bf90644d0 Reviewed-on: https://gerrit.chromium.org/gerrit/12543 Commit-Ready: Vincent Palatin <vpalatin@chromium.org> Tested-by: Vincent Palatin <vpalatin@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2011-12-08Modify device tree files for LinkVadim Bendebury
The flash map needs to be reshuffled because the Ivy Bridge MRC does not fit into the room Sandy bridge MRC used to fit in (512K are required instead of 256K), so the entire boot stub gets now 1M instead of 512K. link.dts is also being modified as appropriate. BUG=chrome-os-partner:6707 TEST=none Change-Id: I2cb6ef9319d57233f5254063d7c35f135fd34a52 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/12605 Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
2011-12-08Prepare a new flash map for Ivy BridgeVadim Bendebury
This is a copy of the Sandy Bridge flash map and the device tree with no modifications. Ivy Bridge requires more room for the MRC, and as such it requires its own flash map, the SB map and the dts wrapper will be used as the prototypes. BUG=chrome-os-partner:6707 TEST=none Change-Id: I25b5f7006f98991724da7b28ab6170a333495400 Signed-off-by: Vadim Bendebury <vbendeb@chromium.org> Reviewed-on: https://gerrit.chromium.org/gerrit/12604 Reviewed-by: Stefan Reinauer <reinauer@chromium.org> Reviewed-by: Gabe Black (Do Not Use) <gabeblack@google.com>
2011-12-07tegra: Disable setting up of GMI_CS6_N on T30/33Simon Glass
Changing the pinmux on this pin breaks T33, so remove it from the list. BUG=chromium-os:23496 TEST=build and boot on Seaboard, T33, Kaen Change-Id: Iec78d9a3d1dcb5f0e45a5788f38a98d35048a378 Reviewed-on: https://gerrit.chromium.org/gerrit/12248 Tested-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org>
2011-12-05tegra: Enhance board_panic_no_console() to support T30Simon Glass
On T30 PLLP may run at a higher speed, so support printing a panic message in that case also. BUG=chromium-os:23496 TEST=build and boot on Seaboard, T33, Kaen Change-Id: I741dd8da0317c56614fcca3e5e73830b3d4fe0d5 Reviewed-on: https://gerrit.chromium.org/gerrit/12246 Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-12-05tegra: Add a clock rate parameter to clock_early_init()Simon Glass
Since PLLP can be set to two different values, make it a parameter to the function that sets up the PLLs. BUG=chromium-os:23496 TEST=build and boot on Seaboard, T33, Kaen Change-Id: I81ccc1cc3356796793ec2dd4ab22ed7fbd52f01d Reviewed-on: https://gerrit.chromium.org/gerrit/12245 Commit-Ready: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-12-01tegra: Move tegra_get_chip_type() to ap20.cSimon Glass
This function is better off in architecture code than board code. This is quite an invasive change unfortunately. BUG=chromium-os:23496 TEST=build and boot on Seaboard, T33, Kaen Change-Id: I17764b134c25b684666d2c0fae2d255ac80e61b1 Reviewed-on: https://gerrit.chromium.org/gerrit/12244 Reviewed-by: Che-Liang Chiou <clchiou@chromium.org> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Simon Glass <sjg@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org>
2011-12-01tegra: Add PLLP clock setting to fdtSimon Glass
This adds a setting for the required PLLP clock frequency. BUG=chromium-os:23496 TEST=build and boot on Seaboard, T33, Kaen Change-Id: I02ab35fcd496d4ac4cfa6b732fdd9a9b7eb2cc88 Reviewed-on: https://gerrit.chromium.org/gerrit/12242 Reviewed-by: Doug Anderson <dianders@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-11-22Remove second-stage U-Boot from 2MB firmware imageSimon Glass
There is barely enough space for U-Boot in the 2MB SPI flash. We are moving to eMMC firmware anyway, so for now let's remove the second-stage U-Boot from the image. This only affects Seaboard, not Kaen. BUG=chromium-os:19724 TEST=emerge chromeos-bootimage on Seaboard Change-Id: I6e3cadc2521b473cbea4ebbfeea2606780392fdb Reviewed-on: https://gerrit.chromium.org/gerrit/11942 Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org> Commit-Ready: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
