AT91sam9g20 is an evolution of the at91sam9260 with a faster clock speed.
The AT91SAM9G20-EK board is an updated revision of the AT91SAM9260-EK board.
It is essentially the same, with a few minor differences.
Here is the chip page on Atmel website:
http://www.atmel.com/dyn/products/product_card.asp?part_id=4337
Signed-off-by: Justin Waters <justin.waters@timesys.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
This patch adds support for the kmsupx4 board from Keymile,
based on a Freescale MPC852T CPU
- serial console on SMC1
- 32 MB SDRAM
- 32 MB NOR Flash
- Ethernet over SCC3
- I2C Bitbang
renaming the "mgsuvd" board port into "km8xx", because
there come more similar boards from keymile.
Compiling the mgsuvd board with "make mgsuvd_config"
remains.
The Nand flash was unable to read and write properly
due to Nand Chip Select (nCE) setup was in reverse
order. Also, increase the Nand time out value to 60.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
This patch fixes a problem spotted by Mikhail Zolotaryov on Sequoia with
the DDR2 configuration to only use one CS (rank). As this code is most
likely copied from the original Sequoia version, this error was copied
as well.
This patch also removes some dead code.
as well.
Sequoia board schematics (DES0211_11_SCH_11.pdf, page 5, unit U1D)
specifies that BankSel#1 is not connected, while bootloader memory
configuration is (board/amcc/sequoia/sdram.c):
mtsdram(DDR0_10, 0x00000300);
i.e. both Chip Selects used - not correct.
If we change to correct value here:
mtsdram(DDR0_10, 0x00000100);
memory is accessible OK also.
Signed-off-by: Mikhail Zolotaryov <lebon@lebon.org.ua>
Update CHANEGLOG, fix minor coding style issue.
Read and store OMAP3 die ID in U-Boot environment.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com>
We can built 'make sh7785lcr_32bit_config'. And add new command "pmb"
for this mode. This command changes PMB for using 512MB system memory.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
These were left in accidentally, and are not really useful unless the
code is as broken as it was when it was being developed.
Signed-off-by: Andy Fleming <afleming@freescale.com>
lib_ppc/board.c
old code implemented the QE_ENET10 errata only for Silicon
Revision 2.0. New code reads now the Silicon Revision
register and sets dependend on the Silicon Revision the
values as advised in the QE_ENET10 errata.
it is possible that some board variants have different DDR II
RAM sizes. So we autodetect the size of the assembled RAM.
This patch adds I2C support for the Keymile kmeter1 board.
It uses the First I2C Controller from the CPU, for
accessing 4 temperature sensors, an eeprom with IVM data
and the booteeprom over a pca9547 mux.
The SerDes initialization should be finished before negating the reset
signal according to the reference manual. This isn't an issue on real
hardware, but we'd better stick to the specifications anyway.
Suggested-by: Liu Dave <DaveLiu@freescale.com>
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
The "eet" variant of the imx31_phycore board has an OLED display, using a
s6e63d6 display controller on the first SPI interface, using GPIO57 as a
chip-select for it. With this configuration you can display 256 colour BMP
images in 16-bit RGB (RGB565) LCD mode.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
On MPC8377E-RDB and MPC8378E-RDB boards we have PCIe and mini-PCIe
slots. Let's support them.
If 36-bit addressing is enabled, print a message on the console
when we boot.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Clock pin must have input enabled for MMC3 to work.
Also enable pull-ups for cmd/data lines to be consistent
with remaining MMC host pin setup.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
This patch adds OMAP3 cpu type auto detection based on OMAP3 register
and removes hardcoded values.
Signed-off-by: Steve Sakoman <sakoman@gmail.com>
With BeagleBoard revision C some HW changes are introduced (e.g. PinMUX)
which might need different software handling. For this, GPIO pin 171 (GPIO
module 6, offset 11) can be used to check for board revision. If this pin
is low, we have a rev C board. Else it must be a revision Ax or Bx board.
To handle board differences you can call function beagle_get_revision().
E.g.:
if (beagle_get_revision()) {
/* do special revision C stuff here */
* Make Overo GPIO114 an input for touchscreen PENDOWN
* Make Overo GPIO144-147 readable
* Make Overo EHCI pinmux match beagle rev c setup
* Adjust pinmux for SMSC911X network chip support
* Remove unnecessary GPIO setup
* Fix merge error in Makefile
Taken all the duplicated code for enabling common modules and apply
software workarounds from the board specific code into common
functions. Also added comments explaining the workarounds
(from TI errata documents) and replaced some numerical bit numbers
with more meaningful defines.
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
This trivially enables Ethernet support in the debug board
by setting up the proper chip select.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stnwireless.com>
- activate CS4 for accessing the FPGA
- activate Rx buf len > 1 on SMC
- pram activated
- MTDPARTS_DEFAULT defined
- update the size of the flashes in the DTS
before booting Linux
- MONITOR_LEN updated to 384k
- added CONFIG_HOSTNAME
- added CONFIG_ENV_BUFFER_PRINT
- Environment size reduced to 16k
- pram activated
- update the size of the flash in the DTS
THe TQM8xxL use a ahnd-optimized linker script to efficiently use the
small boot sectors in the flash. This patch makes some room in the
first sector to prepare for a size increase of lib_generic/vsprintf.o
by a future patch.
Fix for these build problems:
error: static declaration of 'flash_get_info' follows non-static declaration
This patch prepares the good old PMC405 board support for
upcoming PMC405V2 patches.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch fixes coding style for PMC405 board support.
Also some unneeded features/code is removed.
The ecm variable in sdram.c was being declared for all 8548, but only
used by specific 8548 boards, so we make that variable require those
specific boards, too
The nand code was using an index "i" into a table, and then re-using "i"
to set addresses for each upm. However, then it relied on the old value
of i still being there to enable things. Changed the second "i" to "j"
