Add handling for the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is
loaded on V1.2 and later modules and resp. USB power enable signals
activated.
Rename IXORA_FAN_GPIO to FAN_EN as per schematics.
Use the correct compatible string for the i.MX6ULL GPMI device
tree node to make sure MTD partition passing to the Linux kernel
works.
In case USB serial downloader has been used to load U-Boot start the
serial download protocol (SDP) emulation. This allows to download
complete images such as Toradex Easy Installer over USB SDP as well.
This code uses the boot ROM provided boot information to reliably
detect USB serial downloader.
This makes sure that all Colibri iMX7 modules work with the
same timing. The changes are:
- Disable ODT on read (JEDEC standard JESD79-3F says in chapter
5.2.3 ODT during Reads: "As the DDR3 SDRAM can not terminate
and drive at the same time, RTT must be disabled at least half
a clock cycle..." and also MX7D SABRESD is disabling it)
This alone fixed memory issues for two Colibri iMX7 1GB modules
which showed issues before
- Make sure tRFC(min) is at least 260ns
- Make sure tRC is >50.625ns
- tRP needs to be >13.125ns, we can lower from 18.75ns to 15ns
- tFAW is not relevant, leave at reset
This adds support for Colibri iMX7 Dual 1GB modules which come
with on-board eMMC storage (whereas the other Colibri iMX7
modules use raw NAND). A subselection (variant) for the
Colibri iMX7 target is used to maximize sharing.
Setup all UARTs in DTE mode, so that when Linux does the pinmuxing
the data direction is already correct and no two outputs are working
against each other.
Make sure that with the switch also the UARTs' RI and DCD interrupts
are masked.
The resulting U-Boot boots at least from serial downloader mode.
Use similar info message as on other modules.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
If the config block is missing, various things may fail or behave
strangely on certain modules. This patch unifies that behaviour by
using a fake MAC address, until user updates the config block.
Allow optionally bringing up the Apalis type specific 4 lane PCIe port
as well as the PCIe switch as found on the Apalis Evaluation board. In
order to avoid violating the PCIe reset timing do this by overriding the
tegra_pcie_board_port_reset() function. Note however that both the
Apalis type specific 4 lane PCIe port as well as the regular Apalis PCIe
port are also left disabled in the device tree by default.
Fix PCIe port 2 on-module connected to the Intel i210 gigabit
Ethernet chip.
Introduce a weak tegra_pcie_board_port_reset() function by default
calling the existing tegra_pcie_port_reset() function. Additionally add
a tegra_pcie_port_index_of_port() function to retrieve the specific PCIe
port index if required. This allows overriding the PCIe port reset
functionality from board specific code as e.g. required for Apalis T30
and Apalis TK1.
Make sure the Apalis GPIO 8 aka FAN_EN is on when using Apalis TK1
modules.
If the Cortex-M4 is running we carve out 1MiB of memory for
rpmsg communication and/or the firmware running from DDR.
On the Colibri iMX7D this area is in the middle of its 512MiB
of memory. Linux seems not to handle the sparse memory area
well and shows only the first 254MiB of memory as available.
Enabling highmem seems to work around this issue. However,
enabling highmem is not ideal since memory from the highmem
area is more restricted then lowmem.
Aligning the carved out memory to ARM Linux' PMD (page middle
directory) size of 2MiB seem to allow allocating all available
memory as lowmem. Hence increase the carveout region to 2MiB.
Add an optional -y parameter to 'cfgblock create’ to simplify
automation.
By keeping RESET_MOCI_CTRL low we avoid explicitly releasing
RESET_MOCI#.
Please note that module hardware versions up to V1.1A will already
release RESET_MOCI# in hardware coming out of reset.
Please further note that with this change the USB hub on the Apalis
Evaluation board is kept in reset in U-Boot and therefore none of its
ports are operational in U-Boot.
Fix USB OTG power enable aka USBO1_EN which on Apalis T30 is connected
to the T30 ball GEN2_I2C_SCL.
Make sure CMA memory is not greater than 50% of available physical
memory.
Allow user to change the CMA memory via 'cma-size' U-Boot environment
variable.
If config block support is enabled, USB gadget modes unconditionally
use Toradex Product ID as USB PID. Some applications might prefer a
different and/or static USB PID. Add a Kconfig configuration option
to descide whether to use USB PID from config block or the fallback
config option CONFIG_G_DNL_PRODUCT_NUM.
Acked-by: Brandon Shibley <brandon.shibley@toradex.com>
We have two commands to change the bootmode fuses:
mfgr_fuse which set fuse 0/5 and 0/6
and
updt_fuse which burns bit 4 of 0/5.
Before Image 2.6 we fused in mfgr_fuse 0x5062, which boots
from the user partition of the eMMC.
To workaround certain hangs we moved to fastboot mode and
using the first bootpartition of the eMMC requiring a fuse
value of 0x5072 which could be achived by the then added
updt_fuse command. At the same time the mfgr_fuse command
was changed to also fuse 0x5072, revert that second change
so that one can fuse both values, one with just mfgr_fuse
and the later with mfgr_fuse;updt_fuse.
Note that the mfgr_fuse command is only needed at module
production time, a customer might need to use updt_fuse
when upgrading an older module to be compatible with a
newer image. The command is integrated into the image
update scripts.
Colibri iMX6 V1.1 HW can use the PMIC GEN3 to power the NVCC_SD1.
Change the settings fused into the PMIC's OTP to powerup with
GEN3 set to output 3.3V.
Discard the unused usdhc3_emmc_pads iomux table to prevent the following
build time warning:
u-boot-toradex.git/board/toradex/colibri_imx7/colibri_imx7.c:112:29:
warning: ‘usdhc3_emmc_pads’ defined but not used
[-Wunused-const-variable=]
static iomux_v3_cfg_t const usdhc3_emmc_pads[] = {
Discard the unused vga_pads iomux table to prevent the following build
time warning:
u-boot-toradex.git/board/toradex/apalis_imx6/apalis_imx6.c:580:29:
warning: ‘vga_pads’ defined but not used [-Wunused-const-variable=]
static iomux_v3_cfg_t const vga_pads[] = {
If the UART is used in DTE mode the RI and DCD bits in UCR3 become
irq enable bits. Both are set to enabled after reset and both likely
are pending.
Disable the bits also on UARTs not used in the boot loader to prevent
an interrupt storm when Linux enables the UART interrupts.
This adds a Kconfig SPL_SILENCE_CONSOLE which allows to suppress any
console output which in the normal program flow is printed in the SPL.
Error messages and the likes will still be printed.
Move Freescale/NXP Vybrid to a standard arch/board approach, similar
to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM:
mx6: move to a standard arch/board approach").
Use device-tree fixup to communicate the MTD partitions to the
kernel. Remove mtdparts from the kernel command line.
Disable 3.3V Ethernet and ARM rail when entering sleep mode.
Commit 3f353ceccbbb ("vf610: refactor DDRMC code") changed on-die
termination (ODT) values from 120 Ohm to 60 Ohm and enabled a static
read/write leveling which has not been tested with this board. This
commit reverts both changes and makes sure that memory gets
initialized as it has been done before the mentioned commit.
Fixes: 3f353ceccbbb ("vf610: refactor DDRMC code")
This adds a command which parses the SPL version from eMMC and
optionally compares it against a version string.
Usage:
Colibri iMX6 # splver
U-Boot SPL 2016.11-rc3-00017-gdf36bb9-dirty (Nov 01 2016 - 12:31:34)
Colibri iMX6 # splver "U-Boot SPL 2016" || echo update
Colibri iMX6 # splver "U-Boot SPL 2017" || echo update
update
Colibri iMX6 # splver "U-Boot SPL 2016.11-rc4" || echo update
update
Colibri iMX6 #
Implement board level USB PHY mode callback. On USB OTG Port 1
the Colibri standard foresees GPIO USBC_DET to decide whether the
port should run in Host or Device mode.
Use a completely independent USB Product ID for SPL. This allows
to differentiate a SDP running in SPL and SDP running in a U-Boot
which could not read the config block successfully.
Keep debug code at the end of the function.
Use a one line informational message for the PMIC only.
SATA is not accessible on the Colibri iMX6, so remove include and
conditionally executed code.
We rely on u-boot to patch up the "fsl,vf610-ddrmc" node to have
the fsl,has-cke-reset-pulls property without which the Vybrid PM
code does not enable suspend to mem option. If Toradex config
block option is enabled, patch up the device tree for the same.
Signed-off-by: Sanchayan Maity <sanchayan.maity@toradex.com>
In the linux device tree we use 40Ohm drive strenght. So use the same
value in U-Boot.
value in U-Boot.
Implement optional PCIe EvalBoard initialisation which properly reset the PLX
(now Avago) PEX 8605 PCIe switch plus PCIe devices on the Apalis Evaluation
carrier board.
Please note that you will have to enable the second PCIe port in the dts as well
e.g.:
diff --git a/arch/arm/dts/tegra30-apalis.dts b/arch/arm/dts/tegra30-apalis.dts
index be4f4d6..321c7d6 100644
--- a/arch/arm/dts/tegra30-apalis.dts
+++ b/arch/arm/dts/tegra30-apalis.dts
@@ -59,6 +59,7 @@
pci@2,0 {
+ status = "okay";
nvidia,num-lanes = <1>;
(cherry picked from commit 340f51a210df1da640a57267e6c7fa56b8a852ed)
If U-Boot was launched via USB recovery mode stop auto booting.
(cherry picked from commit 0a9606863b0e7b8edfad02467a4e63c6c68025ee)
Migrate Colibri T20 to U-Boot 2016.11.
(cherry picked from commit 92d747bf338ceb8d6dbdd3e5e5f7f72226ce0792)
Migrate Apalis/Colibri T30 to U-Boot 2016.11.
(cherry picked from commit 81a38df0631cfa6b3a85c97e631abf73dc0a2226)
