Add Nios GDB/JTAG Console support:
- Add stubs to support gdb via JTAG.
- Add support for console over JTAG.
- Minor cleanup.
Using external watchdog for KUP4 boards in mpc8xx/cpu.c;
load_sernum_ethaddr() for KUP4 boards in lib_ppc/board.c;
various changes to KUP4 board specific files
* Fixes for SL811 USB controller:
- implement workaround for broken memory stick
- improve error handling
* Increase packet send timeout to 10 ms in cpu/mpc8xx/scc.c to better
cope with congested networks.
binary image for all clock frequencies. Implement run-time
optimization of flash access timing based on the actual bus
frequency.
sticks (including FAT / VFAT filesystem support)
* Add SL811 Host Controller Interface driver for USB
* Add CFG_I2C_EEPROM_ADDR_OVERFLOW desription to README
* Patch by Pantelis Antoniou, 19 Apr 2004:
Allow to use shell style syntax (i. e. ${var} ) with standard parser.
Minor patches for Intracom boards.
* Patch by Christian Pell, 19 Apr 2004:
cleanup support for CF/IDE on PCMCIA for PXA25X
"miivals.h" is missing
* Patches by Mark Jonas, 13 Apr 2004:
- Remove CS0 chip select timing setting from cpu/mpc5xxx/start.S
- Add sync instructions to IceCube SDRAM init code
- Move SDRAM chip constants into seperate include files
- Unify DDR and SDR initialization code
- Unify all IceCube (Lite5xxx) target names
fix initdram function for utx8245 board
* Patch by Markus Pietrek, 14 Apr 2004:
use ATAG_INITRD2 instead of deprecated ATAG_INITRD tag
* Patch by Reinhard Meyer, 18 Apr 2004:
provide the IDE Reset Function for EMK 5200 boards
* Patch by Masami Komiya, 12 Apr 2004:
fix pci_hose_write_config_{byte,word}_via_dword problems
Update max RAM size for debris board
* Patch by Travis Sawyer, 08 Apr 2004:
Add TLB entry for second DIMM slot on ocotea
* Patch by Masami Komiya, 08 Apr 2004:
add RTL8169 network driver
- Add support for RPC/STx GP3, Motorola 8560 board
- Update 85xx TSEC driver so it searches MII for first available PHY
and uses that one.
- Add functions to support console MII commands.
* Patch by Tolunay Orkun, 07 Apr 2004:
Move initialization of bi_iic_fast[]
from board_init_f() to board_init_r()
* Patch by Yasushi Shoji, 07 Apr 2004:
Cleanup microblaze port
* Patch by Sangmoon Kim, 07 Apr 2004:
Add auto SDRAM module detection for Debris board
- add support for microblaze processors
- add support for AtmarkTechno "suzaku" board
* Configure PPChameleon board to use JFFS2 NAND support.
* Added support for JFFS2 filesystem (read-only) on top of NAND flash
- add support for a new version of an Intracom board and fix
various other things on others.
- add verify support to the crc32 command (define
CONFIG_CRC32_VERIFY to enable it)
- fix FEC driver for MPC8xx systems:
1. fix compilation problems for boards that use dynamic
allocation of DPRAM
2. shut down FEC after network transfers
- HUSH parser fixes:
1. A new test command was added. This is a simplified version of
the one in the bourne shell.
2. A new exit command was added which terminates the current
executing script.
3. Fixed handing of $? (exit code of last executed command)
add support for Intel Assabet board
Add support for Picture Elements JSE board
* Patch by Christian Pell, 01 Apr 2004:
Add CompactFlash support for PXA systems.
- add auto-complete support to the U-Boot CLI
- add support for NETTA and NETPHONE boards; fix NETVIA board
* Patch by Yuli Barcohen, 28 Mar 2004:
- Add support for MPC8272 family including MPC8247/8248/8271/8272
- Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS)
- Change configuration method for MPC8260ADS family
unconfiguring the board
* Adapt RMU board for bigger flash memory
* Test fix for ethernet problems on MPC5200
Add support for KUP4X Board
attempting to switch on USB on SX1 board.
* Patch by Josef Wagner, 18 Mar 2004:
- Add support for MicroSys XM250 board (PXA255)
- Add support for MicroSys PM828 board (MPC8280)
- Add support for 32 MB Flash on PM825/826
- new SDRAM refresh rate for PM825/PM826
- added support for MicroSys PM520 (MPC5200)
- replaced Query by Identify command in CPU86/flash.c
to support 28F160F3B
* Fix wrap around problem with udelay() on ARM920T
* Add support for Macronix flash on TRAB board
- Fix Gigabit Ethernet support for 440GX
- Add Gigabit Ethernet Support to MII PHY utilities
* Patch by Brad Kemp, 12 Mar 2004:
Fixes for drivers/cfi_flash.c:
- Better support for x8/x16 implementations
- Added failure for AMD chips attempting to use CFG_FLASH_USE_BUFFER_WRITE
- Added defines for AMD command and address constants
* Patch by Leon Kukovec, 12 Mar 2004:
Fix get_dentfromdir() to correctly handle deleted dentries
* Patch by George G. Davis, 11 Mar 2004:
Remove hard coded network settings in TI OMAP1610 H2
default board config
add support for ADS GraphicsClient+ board.
- add bitmap command and splash screen support in cfb console
- add [optional] origin in the bitmap display command
* Patch by Travis Sawyer, 11 Mar 2004:
Fix ocotea board early init interrupt setup.
* Patch by Thomas Viehweger, 11 Mar 2004:
Remove redundand code; add PCI-specific bits to include/mpc8260.h
- Add support for the SSV ADNP/ESC1 (Nios Softcore)
* Patch by George G. Davis, 9 Mar 2004:
fix recent build failure for SA1100 target
* Patch by Travis Sawyer, 09 Mar 2004:
Support native interrupt mode for the IBM440GX.
Previously it was running in 440GP compatibility mode.
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference
Platform support.
* Patch by Masami Komiya, 08 Mar 2004:
Don't overwrite server IP address or boot file name
when the boot server does not return values
* Patch by listmember@orkun.us, 5 Mar 2004:
Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
Fix early board initialization for Cogent CSB272 board
* Patch by Ed Okerson, 3 Mar 2004:
fix CFI flash writes for little endian systems
* Patch by Reinhard Meyer, 01 Mar 2004:
generalize USB and IDE support for MPC5200 with according
changes to IceCube.h and TOP5200.h
add Am29LV256 256 MBit FLASH support for TOP5200 boards
add info about USB and IDE to README
Fix problems with GCC 3.3.x which changed handling of global
variables explicitly initialized to zero (now in .bss instead of
.data as before).
* Patch by Leon Kukovec, 02 Mar 2004:
add strswab() to fix IDE LBA capacity, firmware and model numbers
on little endian machines
* Patch by Masami Komiya, 02 Mar 2004:
- Remove get_ticks() from NFS code
- Add verification of RPC transaction ID
* Patch by Pierre Aubert, 02 Mar 2004:
cleanup for IDE and USB drivers for MPC5200
Ocotea:
- Add IBM PPC440GX Ref Platform support (Ocotea)
Original code by Paul Reynolds <PaulReynolds@lhsolutions.com>
Adapted to U-Boot and 440GX port
440gx_enet.c:
- Add gracious handling of all Ethernet Pin Selections for 440GX
- Add RGMII selection for Cicada CIS8201 Gigabit PHY
ppc440.h:
- Add needed bit definitions
- Fix formatting
* Patch by Carl Riechers, 1 Mar 2004:
Add PPC440GX prbdv0 divider to fix memory clock calculation.
* Patch by Stephan Linz, 27 Feb 2004
- avoid problems for targets without NFS download support
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA)
- Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF)
- Added support for 64bit strtoul (CFG_64BIT_STRTOUL)
* Patch by Masami Komiya, 27 Feb 2004:
Fix rarpboot: add autoload by NFS
* Patch by Dan Eisenhut, 26 Feb 2004:
fix flash_write return value in saveenv
* Patch by Stephan Linz, 11 Dec 2003
expand config.mk to avoid trigraph warnings on NIOS
* Rename "BMS2003" board into "HMI10"
use redundand environment storage;
auto-set console on USB port (using preboot command)
add support for USB-based console
(enable with "setenv stdout usbtty; setenv stdin usbtty")
* Handle Auti-MDIX / connection status for INCA-IP
* Fix USB problems when attempting to read 0 bytes
add IDE support for MPC5200
* Patch by Masami Komiya, 26 Feb 2004:
add autoload via NFS
* Patch by Stephen Williams
Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses
elsewhere in the source.
NS9750 DevBoard added
* Patch by Pierre AUBERT, 24 Feb 2004
add USB support for MPC5200
* Patch by Steven Scholz, 24 Feb 2004:
- fix MII commands to use values from last command
* Patch by Torsten Demke, 24 Feb 2004:
Add support for the eXalion platform (SPSW-8240, F-30, F-300)
Fixes for for OMAP1610 board:
- shift some IRQ specific code to platform.S file
- remove duplicatewatchdog reset code from start.S
* Make Auto-MDIX Support configurable on INCA-IP board
* Fix license for mkimage tool
Add support for S3C44B0 processor and DAVE B2 board
* Patch by Steven Scholz, 20 Feb 2004:
- Add support for MII commands on AT91RM9200 boards
- some cleanup in AT91RM9200 ethernet code
Add support for the Xilinx ML300 platform
* Patch by Stephan Linz, 17 Feb 2004:
Fix watchdog support for NIOS
* Patch by Josh Fryman, 16 Feb 2004:
Fix byte-swapping for cfi_flash.c for different bus widths
* Patch by Jon Diekema, 14 Jeb 2004:
Remove duplicate "FPGA Support" notes from the README file
- update board/emk tree; use common flash driver
- Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c
[adapted for other PPC CPUs -- wd]
- Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c
* Patch by Jon Diekema, 13 Feb 2004:
Call show_boot_progress() whenever POST "FAILED" is printed.
* Patch by Nishant Kamat, 13 Feb 2004:
Add support for TI OMAP1610 H2 Board
Fixes for cpu/arm926ejs/interrupt.c
(based on Richard Woodruff's patch for arm925, 16 Oct 03)
Fix for a timer bug in OMAP1610 Innovator
Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2
* Patches by Stephan Linz, 12 Feb 2004:
- add support for NIOS timer with variable period preload counter value
- prepare POST framework support for NIOS targets
* Patch by Denis Peter, 11 Feb 2004:
add POST support for the MIP405 board
Fix buffer overflow in common/usb.c
* Patch by Tolunay Orkun, 10 Feb 2004:
Add support for Cogent CSB272 board
* Code cleanup
Add support for NET+50 CPU and ModNET50 board
* Patch by Sam Song, 10 Feb 2004:
Fix typos in cfi_flash.c
* Patch by Leon Kukovec, 10 Feb 2004
Fixed long dir entry slot id calculation in get_vfatname
* Patch by Robin Gilks, 10 Feb 2004:
add "itest" command (operators: -eq, -ne, -lt, -gt, -le, -ge, ==,
* Cleanup compiler warnings
* Fix problem with side effects in macros in include/usb.h
* Patch by David Benson, 13 Nov 2003:
bug 841358 - fix TFTP download size limit
* Fixing bug 850768:
improper flush_cache() in load_serial()
* Fixing bug 834943:
MPC8540 - missing volatile declarations
* Patch by Stephen Williams, 09 Feb 2004:
Add support for Xilinx SystemACE chip:
- New files common/cmd_ace.c and include/systemace.h
- Hook systemace support into cmd_fat and the partition manager
* Patch by Travis Sawyer, 09 Feb 2004:
Add bi_opbfreq & bi_iic_fast to 440GX bd_info as needed for Linux
o 440GX:
- Fix PCI Indirect access for type 1 config cycles with ppc440.
- Add phymode for 440 enet
- fix pci pre init
o XPedite1K:
- Change board_pre_init to board_early_init_f
- Add user flash to bus controller setup
- Fix pci pre init
- Fix is_pci_host to check GPIO for monarch bit
- Force xpedite1k to pci conventional mode (via #define option)
* Patch by Brad Kemp, 4 Feb 2004:
- handle the machine check that is generated during the PCI scans
on 82xx processors.
- define the registers used in the IMMR by the PCI subsystem.
* Patch by Pierre Aubert, 03 Feb 2004:
cpu/mpc5xxx/start.S: copy MBAR into SPR311
* Patch by Jeff Angielski, 03 Feb 2004:
Fix copy & paste error in cpu/mpc8260/pci.c
* Patch by Reinhard Meyer, 24 Jan 2004:
Fix typo in cpu/mpc5xxx/pci_mpc5200.c
* Patch by Josef Baumgartner, 10 Feb 2004:
Fixes for Coldfire port
* Patch by Brad Kemp, 11 Feb 2004:
Fix CFI flash driver problems
- Changed the incorrect FAT12BUFSIZE
- data_begin in fsdata can be negative. Changed it to be short.
* Code cleanup
1: - board/altera/common/flash.c:flash_erase():
o allow interrupts befor get_timer() call
o check-up each erased sector and avoid unexpected timeouts
- board/altera/dk1c20/dk1s10.c:board_early_init_f():
o enclose sevenseg_set() in cpp condition
- remove the ASMI configuration for DK1S10_standard_32 (never present)
- fix some typed in mistakes in the NIOS documentation
2: - split DK1C20 configuration into several header files:
o two new files for each NIOS CPU description
o U-Boot related part is remaining in DK1C20.h
3: - split DK1S10 configuration into several header files:
o U-Boot related part is remaining in DK1S10.h
4: - Add support for the Microtronix Linux Development Kit
NIOS CPU configuration at the Altera Nios Development Kit,
Stratix Edition (DK-1S10)
5: - Add documentation for the Altera Nios Development Kit,
6: - Add support for the Nios Serial Peripharel Interface (SPI)
(master only)
7: - Add support for the common U-Boot SPI framework at
RTC driver DS1306
Fix flash protection/locking handling for OMAP1610 innovator board.
* Patch by Rolf Peukert, 28 Jan 2004:
fix flash write problems on CSB226 board (write with 32 bit bus width)
* Patches by Mark Jonas, 16 Jan 2004:
- fix rounding error when calculating baudrates for MPC5200 PSCs
- make sure CFG_RAMBOOT and CFG_LOWBOOT are not enabled at the same
time which is not supported
Allow bzip2 compression for small memory footprint boards
* Patch by Brad Kemp, 21 Jan 2004:
Add support for CFI flash driver for both the Intel and the AMD
command sets.
* Patch by Travis Sawyer, 20 Jan 2004:
Fix pci bridge auto enumeration of sibling p2p bridges.
* Patch by Tolunay Orkun, 12 Jan 2004:
Add some delays as needed for Intel LXT971A PHY support
* Patches by Stephan Linz, 09 Jan 2004:
- avoid warning: unused variable `piop' in board/altera/common/sevenseg.c
- make DK1C20 board configuration related to ASMI conform to
documentation
