After determining how much DDR is actually in the system, set DBAT0 and
IBAT0 accordingly. This ensures that the CPU won't attempt to access
(via speculation) addresses outside of actual memory.
On 86xx systems, DBAT0 and IBAT0 (the BATs for DDR) are initialized to 2GB
and kept that way. If the system has less than 2GB of memory (typical for
an MPC8610 HPCD), the CPU may attempt to access this memory during
speculation. The zlib code is notorious for generating such memory reads,
and indeed on the MPC8610, uncompressing the Linux kernel causes a machine
check (without this patch).
Currently we are limited to power of two sized DDR since we only use a
single bat. If a non-power of two size is used that is less than
CONFIG_MAX_MEM_MAPPED u-boot will crash.
The ml300 board has a number of issues, but nobody cares about this
long-orphaned board any more. Remove it.
Acked-by: Michal Simek <monstr@monstr.eu>
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;'
Signed-off-by: Thomas Weber <swirl@gmx.li>
Add some more: neither Makefile nor config.mk need execute permissions.
Coding style cleanup, update CHANGELOG.
This code has compile problems and the company does not even exist any
more. So we take the liberty to drop support for it.
Signed-off-by: Detlev Zundel <dzu@denx.de>
CC: Wolfgang Denk <wd@denx.de>
CC: Ben Warren <biggerbadderben@gmail.com>
Also use hwconfig to configure whether the board has a FEC or not.
We then can adjust the DTS to tell Linux if there is a FEC present.
syntax:
hwconfig=fec:on if hardware has a FEC
hwconfig=fec:off if hardware has no FEC
* convert otc570 board to use c stucture SoC access
* change gpio access to at91_gpio syntax
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
This patch fixes following build warning
Invalid Kwbimage command Type - valid names are: BOOT_FROM, NAND_ECC_MODE, NAND_PAGE_SIZE, SATA_PIO_MODE, DDR_INIT_DELAY, DATA, , spi, nand, sata, pex, uart
Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
The patch removes warnings at compile time and provides
some cleanup code:
- Removed comment on NAND (not yet supported) from lowlevel_init.S
- Removed NFMS bit definition from imx-regs.h
The bit is only related to MX.25/35 and can lead to confusion
- Moved is_soc_rev() to soc specific code (removed from mx51evk.c)
Supporting new machine ids for SoCs spear310 and spear320
include/asm-arm/mach-types.h has to be updated before applying
this patch for build to work
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
Add support for the ARM part of the mgcoge2, named suen3.
This board is based on the Marvell Kirkwood (88F6281) SoC.
As there come more board variants, common config options
are collected in include/configs/km_arm.h. Also, this board
use common code for all keymile boards, which is stored in
board/keymile/common/common.c
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
This is an i.MX25 base board with only NAND
so it uses nand_spl to boot.
Signed-off-by: John Rigby <jcrigby@gmail.com>
Tune configuration, add support for (redundant) environment in NAND.
Acked-by: Wolfgang Denk <wd@denx.de>
CC: Fred Fan <fanyefeng@gmail.com>
CC: Tom <Tom.Rix@windriver.com>
The patch adds initial support for the Freescale mx51evk board.
Network (FEC) and SD controller (fsl_esdhc) are supported.
Signed-off-by: Fred Fan <fanyefeng@gmail.com>
edb93xx: Fix SDRAM initialization by issuing a precharge all command before
forcing the precharge and select mode register update mode before programming
the mode registers. Write to the SDRAM banks in order to force a precharge,
reading causes the edb93xx boards to hang
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
Configuration defines should be preceeded with CONFIG_SYS_. Renamed
some at91 specific defines to conform to this naming convention:
AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME
AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK
Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
linking eeprom with libgeneric.a is not really needed and causes following
error:
../../lib_generic/libgeneric.a(string.o): In function `strcmp':
/home/ladis/src/u-boot-ti/lib_generic/string.c:152: multiple definition of `strcmp'
../../examples/standalone/libstubs.a(stubs.o):include/_exports.h:24: first defined here
make[1]: *** [eeprom.srec] Error 1
Fix undefined reference to memset generated by some versions of gcc
to zero out initialized structure on the stack:
eeprom.o: In function `eeprom':
board/voiceblue/eeprom.c:152: undefined reference to `memset'
make[1]: *** [eeprom] Error 1
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Adds support for ethernet networking on the da830evm platform.
This platform uses an SoC EMAC interface and a 3 port ethernet
switch as a PHY with an RMII interface. The PHY also has a i2c
interface for configuring the switch functions.
Signed-off-by: Nick Thompson <nick.thompson@ge.com>
error:
Remove eeprom linker script as well and generate entry point object
(to start application by jumping on its beginning) on the fly.
Out-of-tree build tested as well.
Use shorter yet descriptive messages, replace printf() with
puts() where appropriate. This saves few bytes.
Defining partially initialized struct eth_device on stack means
gcc has to zero out it, and some gcc versions optimize this with
an implicit call to memset. Move definition to data section
to avoid that (it has also nice side effect that we need not
to pass it to helper functions anymore)
* new board (eb_cpux9k2)
* support for EB+CPUx9K2 board by BuS Elektronik GmbH & Co. KG
* select via make eb_cpux9k2_config
* this also demonstrates, how to use boards with AT91RM9200 cpu
in at91 arch tree
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
* convert at91sam9263ek board to use c stucture SoC access
The EVM UI extender card has a NAND device. This change will enable
saveenv to work with NAND and Linux to be booted using:
mtdparts default
nboot kernel
bootm
printf goes to uart1, but it will block forever waiting for
busy to go off unless the uart is enabled first.
Signed-off-by: Alessandro Rubini <rubini@gnudd.com>
Previous code compiled with gcc-4.2.2 makes a call to
__aeabi_uidiv to divide by 20. As a side effect it was
not inline any more, and so sdram_cfg used the stack
as well, but this is early code that has no stack yet.
The patch explicitly removes the division, so no stack is used.
The calculation of the counter calls a division by 20
Added support for the following EDB93xx boards:
EDB9301
EDB9302
EDB9302A
EDB9307
EDB9307A
EDB93012
EDB9315
EDB9315A
This patch removes debug junk leaked into eeprom utility.
This patch makes the crcit utility more readable
Use appropriate GPMC timings for the LAN9221 controller on the
Gumstix Overo expansion boards not the values in arch-omap3/mem.h
which are for a different ethernet controller.
Signed-off-by: Scott Ellis <scott@jumpnowtek.com>
Tidyup the pin muxer configuration using the Davinci table driven
pinmux configuration function and data tables.
This patch adds support for esd gmbh OTC570 board.
The OTC570 is based on an Atmel AT91SAM9263 SoC.
The EXBITGEN board has not been maintained for a long time; it has
build problems, but no hardware is available any more for testing.
Drop support for this board.
The init_coupler() function from board/esd/plu405/plu405.c
got lost somehow! This patch readds it.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api)
* enable driver with CONFIG_DRIVER_AT91EMAC
* generic PHY initialization
* modify AT91RM9200 boards to use NET_MULTI driver
* the drivers has been tested with LXT971 Phy and DM9161 Phy at
MII and RMII interface
There's no sensible reason to unite speed and interface type into
one variable. So split this variable enet_interface into two
vars: enet_interface_type, which hold the interface type and speed.
Also: add the possibility for switching between 10 and 100 MBit
interfaces on the fly, when running in FAST_ETH mode.
This patch add nand boot support for MPC8569mds board.
Signed-off-by: Liu Yu <yu.liu@freescale.com>
Normally the processor clock has a divisor of 2.
In some cases this this needs to be set to 4.
Check the user has set environment mdiv to 4 to change the divisor.
SPEAr320 SoC support contains basic spear320 support along with the
usage of following drivers
- serial driver(UART)
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
- emi driver(cfi support)
Signed-off-by: Vipin <vipin.kumar@st.com>
SPEAr310 SoC support contains basic spear310 support along with the
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
SPEAr310 and SPEAr320 SoCs contain an EMI controller to interface
Paraller NOR flashes. This patch adds the support for this IP
The standard CFI driver is used to interface with NOR flashes
SPEAr300 SoC support contains basic spear300 support along with the
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
This patch adds the support to read and write mac id from i2c
memory.
For reading:
if (env contains ethaddr)
pick env ethaddr
else
pick ethaddr from i2c memory
For writing:
chip_config ethaddr XX:XX:XX:XX:XX:XX writes the mac id
in i2c memory
SPEAr600 SoC support contains basic spear600 support along with the
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
A newer CPLD version on the 405EX evaluation board requires a different
EBC controller setup for the CPLD register access. This patch adds a CPLD
version detection for Kilauea and code to reconfigure the EBC controller
(chip select 2) for the old CPLD if no new version is found.
Additionally the CPLD version is printed upon bootup:
Board: Kilauea - AMCC PPC405EX Evaluation Board (CPLD rev. 0)
Cc: Zhang Bao Quan <bqzhang@udtech.com.cn>
