Add board_flash_wp_on() to check a pca9557 gpio pin to see
if non-volatile memory write protection is enabled.
Previously, write protected NOR flashes would fail initialization which
resulted in a bootup error such as:
DTT: 53 C local / 64 C remote (adt7461@4c)
DTT: 54 C local (ds1621@48)
FLASH: Executed from FLASH1
POST memory PASSED
FLASH: ## Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB
## Unknown FLASH on Bank 2 - Size = 0x00000000 = 0 MB
*** failed ***
### ERROR ### Please RESET the board ###
With this patch, NOR flash initialization is skipped:
POST memory PASSED
FLASH: Uninitialized - Write Protect On
L2: 1024 KB enabled
NAND: 1024 MiB
Note that flash related commands such as flinfo and saveenv will error
out when flash write protection is enabled.
Signed-off-by: John Schmoller <jschmoller@xes-inc.com>
Create a common checkboard() function to support all X-ES's Freescale
boards.
Also, add a get_board_derivative() function which reads hardware
strapping resistors to determine what model a board is. This allows one
U-Boot image to support multiple boards.
Common Freescale code for PCI initialization now exists, so migrate X-ES
boards to use it.
Until now, the Sequoia RAM-booting image disabled NOR flash support
as this image was mainly created for NAND-only boards. This patch
now enables NOR flash support for this RAM-booting version as well.
Update to use the recent, common FSL PCI initialization code.
CC: sr@denx.de
CC: joe.hamman@embeddedspecialties.com
800, 900, 1000, 1200MT/s data rate parameters are added for fixed sdram
setting. SPD based parameters and fixed parameters can be toggled by hwconfig.
To use fixed parameters,
hwconfig=fsl_ddr:sdram=fixed
To use SPD parameters,
hwconfig=fsl_ddr:ctlr_intlv=cacheline,bank_intlv=cs0_cs1
Signed-off-by: York Sun <yorksun@freescale.com>
Add a common helper that will set the PHY connection type based on enum.
We use this on eTSEC, UCC, and will with Fman in the future.
* update to support arm reloaction
* unnecessary environment variables removed
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
This patch adds support for the HP Jornada flashboards
that were made in 2008. Older flashroms should work if
memory registers are adjusted.
Signed-off-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
Adpted for TEXT_BASE -> CONFIG_SYS_TEXT_BASE rename.
Removed now redundant board/jornada/config.mk file.
Removed unused empty jornada_init() function to silence
"jornada.c:35: warning: 'jornada_init' defined but not used"
This file is not used, automatically generated u-boot.lds is used instead
Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com>
The following hardware is currently supported:
- UART
- USB Host
- FPGA
128MB NOR module support.
Define __io to get harddrive working.
Fix saving of environment into OneNAND.
Boot from harddrive when possible.
Add missing MAINTAINERS entry.
This patch adds support for the Palm Tungsten|C PXA255 board. The support
includes:
- LCD
- MMC
- UART
- NOR
arch/arm/include/asm/config.h
board/LaCie/edminiv2/config.mk
board/karo/tx25/config.mk
board/logicpd/imx27lite/config.mk
doc/README.arm-relocation
board/logicpd/imx31_litekit/config.mk
boards.cfg
This patch removes some functionality from at91rm9200ek board but the
remaining functionality does now work with newer at91 code and
arm-relocation.
Currently missing features are:
- dataflash booting (due to missing HW for testing)
- MMC/SD-Card
- first stage bootloader support is completely removed (not needed for
NOR)
Cause this board was (some days ago) reference for all at91rm9200 based
boards this should be a good starting point to convert all remaining
at91rm9200 borads to at91 code. Aside from that this is a good base to
get some drivers between at91sam/at91rm/avr32 merged.
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
The NC650 / CP850 boards have long been unmaintained and left broken.
As obviously nobody is interested in that code any more, we may as
well remove it.
Tested on hardware. Boots Linux nicely.
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
Commit 14d0a02a "Rename TEXT_BASE into CONFIG_SYS_TEXT_BASE" missed a
few places, especially for boards that were added inbetween. Fix the
remaining issues.
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Signed-off-by: Francesco Rendine <francesco.rendine@valueteam.com>
Signed-off-by: Damien Dusha <d.dusha@gmail.com>
Coding style cleanup; slight file restructuring.
Acked-by: Remy Bohmer <linux@bohmer.net>
After the recent cleanups, a number of config.mk files consist only of
a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed.
Remove such entries. In most cases, that means that the whole
config.mk file can be removed.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
When planning for more generalization and Makefile cleanup it became
obvious that the introduction of a separate CONFIG_MK_ name space for
config options that were set through scripting in the Makefile was
not a good idea.
Originally the idea was to provide a script-free approach to supply
configuration options - there was no real need for a separate name
space. But when we now convert the existing Makefile entries to make
use of this approach, it would mean that we have to touch a large
number of board config files and add #ifdef / #define sequences to
"convert" from the CONFIG_MK_ to the CONFIG_ name space.
It seems much cleaner to get rid of this somewhat arbitrary _MK
string now for the few boards that actually use it.
commit 6aa3d3bfaa986f1aff5e21a9b9f68d087715b1a9
"83xx: Remove warmboot parameter from PCI init functions" missed
one mpc83xx_pcie_init callsite, causing this build error:
Configuring for MPC837XEMDS_HOST board...
pci.c: In function 'pci_init_board':
pci.c:141: error: too many arguments to function 'mpc83xx_pcie_init'
this patch extends the commit to include that callsite.
Doubled use of DECLARE_GLOBAL_DATA_PTR caused compile warning:
pci.c:71: warning: register used for two global register variables
Cc: Kim Phillips <kim.phillips@freescale.com>
The logodl board has long been unmaintained and left broken.
As obviously nobody is interestedin that code any more, we may as well
remove it.
Cc: August Hoeraendl <august.hoerandl@gmx.at>
Cc: Robert Schwebel <r.schwebel@pengutronix.de>
Cc: Marek Vasut <marek.vasut@gmail.com>
commit 6d014adf dropped support for the forceenv() function, but failed
to remove references to it from board/davinci/schmoogie/schmoogie.c
Replace forceenv() by setenv() and set CONFIG_ENV_OVERWRITE instead in
the board config file to allow overwriting the serial number.
Cc: Sergey Kubushyn <ksi@koi8.net>
Acked-by: Sergey Kubushyn <ksi@koi8.net>
Rename mx51 to mx5 in order to support more mx51
like-style SOCs such as MX53 and the followings.
Signed-off-by: Jason Liu <r64343@freescale.com>
The current da850evm support in u-boot/master omits any use of
the davinci EMAC. This patch adds basic support for the EMAC using
the MII PHY found on the baseboard of the EVM. The MAC address is
read from the environment variable 'ethadd'. Note that this is
different from the da850evm support in the u-boot omapl1 tree
where the MAC address is read from SPI flash.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
CC: Sandeep Paulraj <s-paulraj@ti.com>
CC: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
CC: Ben Warren <biggerbadderben@gmail.com>
CC: Mike Frysinger <vapier@gentoo.org>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The default NAND flash timings are very conservative. This patch assigns the
timings reccomended in the recent linux kernel patch [1] from Sekhar Nori. The
speedup, as reported in that patch, is 5.3x for reads.
[1] http://www.spinics.net/lists/arm-kernel/msg100278.html
CC: Sekhar Nori <nsekhar@ti.com>
There is currently no NAND pinmux enabled by the da850evm board setup code.
This is fine when booting from NAND since the early boot code (UBL) will setup
the pinmux; however, when the boot mode is any other setting NAND is unusable
when enabled in the config.
This patch adds a pinmux list for NAND and enables it when NAND is enabled in
the config. Tested by booting from SPI on the da850evm and verifying NAND
was usable.
CC: Nick Thompson <nick.thompson@ge.com>
The IGEP module is a low-power, high performance production-ready
system-on-module (SOM) based on TI's OMAP3 family.The IGEP module
solution based upon TI OMAP3 provides a low-power/low-cost platform
for a variety of consumer/industrial/medical devices.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
The IGEP v2 board is a low-cost, fan-less and industrial temperature
range single board computer that unleashes laptop-like performance and
expandability without the bulk, expense, or noise of typical desktop
machines. Its architecture shares much in common with other OMAP3 boards.
Acked-by: Steve Sakoman <steve.sakoman@linaro.org>
Tested-by: Steve Sakoman <steve.sakoman@linaro.org>
