Moved ali512x.h from include/asm-i386/ic/ to /include
Signed-off-by: Graeme Russ <graeme.russ at gmail.com>
Options are now all uniformly CONFIG_SYS_SC520_<option>
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
The environment is the canonical storage location of the mac address, so
we're killing off the global data location and moving everything to
querying the env directly.
Rather than have common ppc code call a board-specific function like
load_sernum_ethaddr(), have each board call it in its own board-specific
misc_init_r() function.
The boards that get converted here are:
- kup4k/kup4x
- pcs440ep
- tqm8xx
CC: Ben Warren <biggerbadderben@gmail.com>
CC: Stefan Roese <sr@denx.de>
Also rename load_sernum_ethaddr() to misc_init_r() so we don't need to
handle this board specially in common ARM code.
Rather than have the common ppc code have board-specific hooks, move the
board_get_enetaddr() function into the board-specific init functions.
For the nx823, the serial number is moved out of load_sernum_ethaddr() and
into misc_init_r() as is the env setup. This lets us kill off the former
function in the process.
The boards that get converted here to use the environment for the mac
address rather than global data:
debris
mgcoge
mgsuvd
muas3001
netstal
pn62
sixnet
vcma9
xilinx (the ones that use xilinx_enet)
CC: Sangmoon Kim <dogoil@etinsys.com>
CC: Heiko Schocher <hs@denx.de>
CC: David Mueller <d.mueller@elsoft.ch>
CC: Niklaus Giger <niklaus.giger@netstal.com>
CC: Wolfgang Grandegger <wg@denx.de>
CC: Dave Ellis <DGE@sixnetio.com>
CC: Ricardo Ribalda <ricardo.ribalda@uam.es>
Always use the MAC address that is stored in the environment first before
falling back to the ROM. This also cuts out any comparison steps: if the
mac in the env is sane, the ROM is never consulted.
CC: Thomas Frieden <ThomasF@hyperion-entertainment.com>
This patch adds support for the kmsupx4 board from Keymile,
based on a Freescale MPC852T CPU
- serial console on SMC1
- 32 MB SDRAM
- 32 MB NOR Flash
- Ethernet over SCC3
- I2C Bitbang
renaming the "mgsuvd" board port into "km8xx", because
there come more similar boards from keymile.
Compiling the mgsuvd board with "make mgsuvd_config"
remains.
The Nand flash was unable to read and write properly
due to Nand Chip Select (nCE) setup was in reverse
order. Also, increase the Nand time out value to 60.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
This patch fixes a problem spotted by Mikhail Zolotaryov on Sequoia with
the DDR2 configuration to only use one CS (rank). As this code is most
likely copied from the original Sequoia version, this error was copied
as well.
This patch also removes some dead code.
as well.
Sequoia board schematics (DES0211_11_SCH_11.pdf, page 5, unit U1D)
specifies that BankSel#1 is not connected, while bootloader memory
configuration is (board/amcc/sequoia/sdram.c):
mtsdram(DDR0_10, 0x00000300);
i.e. both Chip Selects used - not correct.
If we change to correct value here:
mtsdram(DDR0_10, 0x00000100);
memory is accessible OK also.
Signed-off-by: Mikhail Zolotaryov <lebon@lebon.org.ua>
Update CHANEGLOG, fix minor coding style issue.
Read and store OMAP3 die ID in U-Boot environment.
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Signed-off-by: Yusuke Goda <goda.yusuke@renesas.com>
We can built 'make sh7785lcr_32bit_config'. And add new command "pmb"
for this mode. This command changes PMB for using 512MB system memory.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
These were left in accidentally, and are not really useful unless the
code is as broken as it was when it was being developed.
Signed-off-by: Andy Fleming <afleming@freescale.com>
lib_ppc/board.c
old code implemented the QE_ENET10 errata only for Silicon
Revision 2.0. New code reads now the Silicon Revision
register and sets dependend on the Silicon Revision the
values as advised in the QE_ENET10 errata.
it is possible that some board variants have different DDR II
RAM sizes. So we autodetect the size of the assembled RAM.
This patch adds I2C support for the Keymile kmeter1 board.
It uses the First I2C Controller from the CPU, for
accessing 4 temperature sensors, an eeprom with IVM data
and the booteeprom over a pca9547 mux.
The SerDes initialization should be finished before negating the reset
signal according to the reference manual. This isn't an issue on real
hardware, but we'd better stick to the specifications anyway.
Suggested-by: Liu Dave <DaveLiu@freescale.com>
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
The "eet" variant of the imx31_phycore board has an OLED display, using a
s6e63d6 display controller on the first SPI interface, using GPIO57 as a
chip-select for it. With this configuration you can display 256 colour BMP
images in 16-bit RGB (RGB565) LCD mode.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
On MPC8377E-RDB and MPC8378E-RDB boards we have PCIe and mini-PCIe
slots. Let's support them.
If 36-bit addressing is enabled, print a message on the console
when we boot.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Clock pin must have input enabled for MMC3 to work.
Also enable pull-ups for cmd/data lines to be consistent
with remaining MMC host pin setup.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
This patch adds OMAP3 cpu type auto detection based on OMAP3 register
and removes hardcoded values.
Signed-off-by: Steve Sakoman <sakoman@gmail.com>
With BeagleBoard revision C some HW changes are introduced (e.g. PinMUX)
which might need different software handling. For this, GPIO pin 171 (GPIO
module 6, offset 11) can be used to check for board revision. If this pin
is low, we have a rev C board. Else it must be a revision Ax or Bx board.
To handle board differences you can call function beagle_get_revision().
E.g.:
if (beagle_get_revision()) {
/* do special revision C stuff here */
* Make Overo GPIO114 an input for touchscreen PENDOWN
* Make Overo GPIO144-147 readable
* Make Overo EHCI pinmux match beagle rev c setup
* Adjust pinmux for SMSC911X network chip support
* Remove unnecessary GPIO setup
* Fix merge error in Makefile
Taken all the duplicated code for enabling common modules and apply
software workarounds from the board specific code into common
functions. Also added comments explaining the workarounds
(from TI errata documents) and replaced some numerical bit numbers
with more meaningful defines.
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
This trivially enables Ethernet support in the debug board
by setting up the proper chip select.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stnwireless.com>
- activate CS4 for accessing the FPGA
- activate Rx buf len > 1 on SMC
- pram activated
- MTDPARTS_DEFAULT defined
- update the size of the flashes in the DTS
before booting Linux
- MONITOR_LEN updated to 384k
- added CONFIG_HOSTNAME
- added CONFIG_ENV_BUFFER_PRINT
- Environment size reduced to 16k
- pram activated
- update the size of the flash in the DTS
THe TQM8xxL use a ahnd-optimized linker script to efficiently use the
small boot sectors in the flash. This patch makes some room in the
first sector to prepare for a size increase of lib_generic/vsprintf.o
by a future patch.
Fix for these build problems:
error: static declaration of 'flash_get_info' follows non-static declaration
This patch prepares the good old PMC405 board support for
upcoming PMC405V2 patches.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch fixes coding style for PMC405 board support.
Also some unneeded features/code is removed.
