i.MX 7's Cortex-M4 core can run from DDR and uses DDR memory for
the rpmsg communication. Both use cases need a fixed location of
memory reserved. For the rpmsg use case the reserved area needs
to be in sync with the kernel's hardcoded vring descriptor location.
Use the linux,usable-memory property to carve out 1MB of memory
in case the M4 core is running. Also make sure that the i.MX 7
specific rpmsg driver does not get loaded in case we do not carve
out memory.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit c671d8af0bb07b028d808b994b83b2ec25578a44)
Introduce imx6ull-colibri-u-boot.dtsi for u-boot specific properties to
keep original imx6ull-colibri.dts in sync with Linux.
Move all contents of imx6ull-colibri.dts to imx6ull-colibri.dtsi +
additionally fix checkpatch warnings.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
(cherry picked from commit 7d6ca12313377bad4ceafc3fa1da414d101f6b77)
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is
loaded on V1.2 and later modules and resp. USB power enable signals
activated.
Signed-off-by: Tom Warren <twarren@nvidia.com>
(cherry picked from commit 4c63a601b90db131e92d3f6f6da6a4bc2b287df1)
When mainline kernels reboot TK1 they use SW_RESET,
that reset mode does not reset PMIC. Some rails
need to be off for RAM Re-repair to work correctly.
(cherry picked from commit 5a20adf446bc248a8db02f6d262b43b14587812d)
Make sure the Apalis GPIO 8 aka FAN_EN is on when using Apalis TK1
modules.
(cherry picked from commit 538ab6c0a1a51da0caf9525607499e8cd6ef12b7)
By keeping RESET_MOCI_CTRL low we avoid explicitly releasing
RESET_MOCI#.
Please note that module hardware versions up to V1.1A will already
release RESET_MOCI# in hardware coming out of reset.
Please further note that with this change the USB hub on the Apalis
Evaluation board is kept in reset in U-Boot and therefore none of its
ports are operational in U-Boot.
(cherry picked from commit 5b5de78b4a6ff8c2bbd71a6b51d6fdf32f420eef)
Fix issue as reported by checkpatch.pl. Leave long lines as line
continuation in text output is not recommended.
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
The Apalis iMX8 was missing the interactive part should a customer have
bricked his module and want to re-create the configuration block. Fix
this.
The Colibri iMX8X target got re-named late in the cycle which we forgot
to reflect here. Furthermore, it was missing the interactive part should
a customer have bricked his module and want to re-create the
configuration block. Fix this.
Make the interactive Wi-Fi/BT handling generic by pulling it out of the
Colibri iMX6ULL interactive part to be re-used for Apalis iMX8 and
Colibri iMX8X.
If the module is in serial downloader mode, we do no longer read the
environment from eMMC. Therefor, the eMMC is unitialized when trying
to read the config block. Use mmc_init to initialize the selected
MMC device before using it.
Note: In case the MMC has already been initialized, the mmc_init
detects that and returns immediately.
Extend the driver to build with DM_VIDEO enabled. DTS files
must additionally include 'u-boot,dm-pre-reloc' property in
soc and child nodes to enable driver binding to fsl_dcu_fb device.
Currently display timings aren't obtained from DT.
Move dcu-related code to fsl_dcu_probe_common, keep in video_hw_init()
only legacy video stack (filling GraphicPanel struct etc.).
Add wrappers for all init functions, that will let to provide
struct fb_info as an additional param (needed for further moving it from
the global scope to driver private data struct in DM converted driver).
Add missing mailing-list to the amlogic boards MAINTAINERS file.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
After the conversion to DM the U-Boot proper binary name
is 'u-boot-dtb.img', so adjust it accordingly.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
After the transition to DM, only the mx6dl/solo wandboard
is supported.
Add FIT image support so that all the wandboard variants
can be supported, like it was prior to the DM conversion.
Successfully booted Linux on mx6q/solo/qp wandboards.
https://gitlab.denx.de/u-boot/custodians/u-boot-atmel
Second set of u-boot-atmel fixes for 2019.07 cycle
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2019.07
- menlo board
- allow SDB on Sabre
- HAB for mx6sl
- apalis board
Enable DM Video support on iMX53 M53Menlo and fix minor details
to restore previous behavior of the system.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Enable DM block and DM MMC and DM USB support on iMX53 M53Menlo .
Convert board code to match the DM support. This also enables DM
pincontrol to configure the SDHI pins.
Enable DM GPIO support on iMX53 M53Menlo and fix up board code where
applicable. Enable MALLOC_F to let the GPIO controllers bind early on.
After the conversion to DM the U-Boot binary is called u-boot-dtb.imx,
so fix the README file accordingly.
Acked-by: Joris Offouga <offougajoris@gmail.com>
In case someone detects a PDA and u-boot sets the 'pda' variable,
and the user does a saveenv, the pda is set in env, and if the
screen is removed, u-boot will still have in the env the 'pda'
variable, even if no screen is attached.
In order to fix this, we have to reset the 'pda' variable,
such that it's not just set if the screen is detected, but also unset
if no screen is detected.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
The new common rockchip pinctrl driver does not support explicit
requests for a particular pinctrl function. As a result, the
board_init() function bails out early before enabling the boot-on
regulators. Fix this by simply removing the request for pwm0, pwm2
and pwm3. The generic DM code already does the necessary
configuration if necessary.
Reported-by: Levin Du <djw@t-chip.com.cn>
Signed-of-by: Mark Kettenis <kettenis@openbsd.org>
Support common spl_board_init by moving code from puma
board file into, common rk3399-board-spl.c.
Part of the code has sysreset-gpio, regulators_enable_boot_on
but right now only puma board is using this with relevant
config options rest remains common for all targets.
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
preloader_console_init is used for printing SPL boot banner that
usually called from spl_board_init.
The current spl_board_init in evb and rock960 is enabling explicit
pinctrl, debug uart prior to calling preloader_console_init which
eventually not required since board_init_f is already enabled
debug uart.
So, drop those explicit enablement calls from spl_board_init of
evb, rock960.
Tested this by enabling CONFIG_SPL_BOARD_INIT and adding
u-boot,dm-pre-reloc property for uart node.
Add u-boot.itb BUILD_TARGET for Rockchip platform when SPL_LOAD_FIT
is being used.
This can get rid of building itb explicitly with 'make u-boot.itb'
so, from now all required images will build just by make.
Right now puma rk3399 board need to copy bl31-rk3399.bin and
rk3399m0.bin into u-boot source directory to make use of building
u-boot.itb.
So, add environment variable
- BL31 for bl31.bin (instead of bl31-rk3399.bin to compatible with other
platform BL31 env)
- PMUM0 for rk3399m0.bin
If the builds are not exporting BL31, PMUM0 env, the fit_spl_atf.sh will
notify with warning about which document to refer for more information
like this:
WARNING: BL31 file bl31.bin NOT found, resulting binary is non-functional
Please read Building section in doc/README.rockchip
WARNING: PMUM0 file rk3399m0.bin NOT found, resulting binary is non-functional
The ROCK64 is a credit card size SBC based on Rockchip RK3328
Quad-Core ARM Cortex A53.
This series allow building u-boot SPL and u-boot.itb for Rock64
board. The proprietary TPL is stil required for deploy:
./tools/mkimage -n rk3328 -T rksd \
-d ./rkbin/bin/rk33/rk3328_ddr_333MHz_v1.16.bin idbloader.img
cat ./spl/u-boot-spl.bin >> idbloader.img
dd if=idbloader.img of=/dev/sdcard seek=64 conv=notrunc
dd if=u-boot.itb of=/dev/sdcard seek=16384 conv=notrunc
Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
Avnet Ultra96 dts file should be also cover by MAINTAINERS fragment.
Signed-off-by: Moses Christopher <BollavarapuMoses.Christopher@in.bosch.com>
Misspelling of SPDX-License-Identifier is rather fatal than other
general typos, so must be fixed.
This file spells SPDX-Licence-Identifier.
I also moved it to the very top of the file with // comment style.
Detected by grepping the source tree:
$ git grep --not -e SPDX-License-Identifier --and -e SPDX-
board/armltd/vexpress64/pcie.c: * SPDX-Licence-Identifier: GPL-2.0+
Acked-by: Liviu Dudau <liviu.dudau@foss.arm.com>
Extra "not DM" controllers support is disabled.
u-boot BSP still good enough to upgrade and run images.
Signed-off-by: Oleksandr Zhadan <oleks@arcturusnetworks.com>
Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com>
- PCIe driver change to support DM model
- T2080QDS migrated to use PCIe DM model
Compile the legacy PCIe initialization reoutines only when DM_PCI
is not enabled.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
- LS1046AFRWY support
- USB errata fix and secure boot defconfig support for LS1028A
- Enabled SDHC and SATA for LX2160
- LS1046A serdes fixes
- other minor fixes
Uboot prompt must not be available while running
secure boot. TO ensure this bootdelay must be set
to -2.
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com>
LS1046AFRWY board supports LS1046A family SoCs. This patch
add base support for this board.
Board support's 4GB ddr memory, i2c, micro-click module,microSD card,
serial console,qspi nor flash,ifc nand flash,qsgmii network interface,
usb 3.0 and serdes interface to support two x1gen3 pcie interface.
Signed-off-by: Camelia Groza <camelia.groza@nxp.com>
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com>
Signed-off-by: Pankit Garg <pankit.garg@nxp.com>
Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com>
Add secure boot defconfig for ls1028aqds and ls1028ardb boards.
Signed-off-by: Yuantian Tang <andy.tang@nxp.com>
fsl-mc lazyapply command applies dpl from efi_exit_boot_services().
Status of fsl-mc node in working fdt is updated at this stage.
However, an efi application like grub may already have copied the fdt.
So the updates to fdt done at efi_exit_boot_services() may not be
visible to the OS. Fix it by updating fdt earlier if fsl-mc lazyapply
command is used.
Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de>
when compiling dts file using DTC_FLAG='-@', the device tree compiler
reports these warnings:
Warning (alias_paths): /aliases: aliases property name must include
only lowercase and '-'
Fixed the node aliases to silence these warnings.
Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com>
- Drop zipitz2 board (Tom)
- Add DEPRECATED option (Tom)
- Mark legacy or non-dm drivers as DEPRECATED (Jagan)
- More board removal
Change my email address, too many mails
gets to my private mail, created specific email
account just for developmement.
Signed-off-by: Ramon Fried <ramon.fried@gmail.com>
Last change to this board was done in 2016, has no prospects of
ever being converted to DM, drop it.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Chris Brandt <chris.brandt@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro.uh@renesas.com>
