path: root/board
2011-05-18at91: reworked support for otc570 boardDaniel Gorsulowski
The otc570 board support was broken. Within this opportunity, I completely reworked the board files. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2011-05-18hammerhead: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18mimc200: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
2011-05-18favr-32-ezkit: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
2011-05-18atstk100x: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
2011-05-18atngw100: move CONFIG_SYS_TEXT_BASE to headerAndreas Bießmann
2011-05-18avr32: use single linker scriptAndreas Bießmann
This patch move the atstk100x linker script to $(CPUDIR) and delete other pure copies of this file in each board directory. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32/config.mk: simplify PLATFORM_RELFLAGSAndreas Bießmann
This patch removes PLATFORM_RELFLAGS from board specific config.mk files and define them in arch specific config.mk file. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: fix linkingAndreas Bießmann
This patch fixes following error: ---8<--- avr32-linux-ld: --gc-sections and -r may not be used together --->8--- Since 8aba9dceebb14144e07d19593111ee3a999c37fc all avr32 boards are broken due to linking error as seen above. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: fixup definitions to ATMEL_BASE_xxxAndreas Bießmann
2011-05-18avr32: rename memory-map.h -> hardware.hAndreas Bießmann
2011-05-12Fix a few gcc warnings.Joakim Tjernlund
Noticed while building all of mpc8xx. Also constify usage string in timer.c Warnings fixed are: timer.c: In function 'timer': timer.c:189: warning: format not a string literal and no format arguments timer.c:258: warning: format not a string literal and no format arguments atm.c: In function 'atmUnload': atm.c:99: warning: array subscript is above array bounds atm.c: In function 'atmLoad': atm.c:65: warning: array subscript is above array bounds codec.c: In function 'codsp_write_pop_int': codec.c:678: warning: array subscript is above array bounds codec.c: In function 'codsp_write_cop_short': codec.c:585: warning: array subscript is above array bounds codec.c: In function 'codsp_write_sop_int': codec.c:512: warning: array subscript is above array bounds Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2011-05-12MPC8260: Fix compile problems with "hymod" boardWolfgang Denk
Commit 9d8fbd1 "powerpc, 8xx: Fixup all 8xx u-boot.lds scripts" broke building of the MPC8260 based "hymod" board. Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Murray Jensen <Murray.Jensen@csiro.au> Cc: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-05-11Initialize second PHY on OpenRD-Client and OpenRD-UltimateClint Adams
Though the OpenRD-Base only has one gigabit Ethernet port, both the OpenRD-Client and OpenRD-Ultimate each have two. On the Ultimate, the PHY addresses are consecutive, but on the Client they are not. (based on <62a0952ce368acc725063a00a5ec680a639d6c27.1301040318.git.julian.pidancet@citrix.com> <ad0a2dc1e422698b005d6f0ceb6dd6f75a87e00a.1301040318.git.julian.pidancet@citrix.com> ) Signed-off-by: Clint Adams <clint@debian.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Julian Pidancet <julian.pidancet@citrix.com>
2011-05-11Add definitions for OpenRD-Client and OpenRD-UltimateClint Adams
2011-05-11Rename openrd_base files to openrdClint Adams
2011-05-11MX31: mx31pdk: Add watchdog supportFabio Estevam
2011-05-11da850evm: fix NAND WSTROBE and TA timingsBen Gardiner
The current NAND timings, introduced in commit a3f88293ddd13facd734769c1664d35ab4ed681f da850evm: setup the NAND flash timings , incorrectly set WSTROBE and TA to 0. A more recent inspection of the values set by the Linux kernel indicates that these should be set to 1. Set the WSTROBE and TA field of the EMIFA cycle-count timings configuration to 1 to match the values set by linux. Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> CC: Stefano Babic <sbabic@denx.de> CC: Sandeep Paulraj <s-paulraj@ti.com> CC: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-05-10km/common: implement setboardid commandHolger Brunck
Read out board id and HW key from the IVM eeprom and set these values as an environment variable. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-05-10powerpc/km82xx: add mgcoge3ne and remove mgcoge2ne supportHolger Brunck
This patch adds support for the MPC8247 based board mgcoge3ne. Additionaly mgcoge2ne board supprot was removed, because due to the mgcoge3ne, this board is obsolete and not longer maintained. The board is similar to mgcoge. The difference is that a NUMONYX flash is used and a different SDRAM (256MB). Also introduce CONFIG_KM_82XX to collect ppc82xx common settings and remove staticness from the common set_pin function. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-05-10powerpc/km82xx: rework DIP switch detectionHuber, Andreas
Introduce a struct for the BFTICU FPGA to increase the readability of the code. And the define CONFIG_SYS_BFTICU_BASE was removed because the CONFIG_SYS_FPGA_BASE is already the base value for BFTICU registers. Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de>
2011-05-10powerpc/km82xx: rename mgcoge files to km82xxHolger Brunck
The directory and file mgcoge was renamed to km82xx. Because other keymile 82xx will follow and will use the same platform code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-05-10powerpc/km82xx: cleanup coding style for mgcoge.cHolger Brunck
2011-05-10km/common: remove hdlc_enet implementationHolger Brunck
The hdlc implementation for mgcoge was initially developed, but later on not used. Remove the C files, the references in mgcoge.c and the Makefile to decrease maintenance effort. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Acked-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-05-10MIPS: Introduce --gc-sections for MIPSDaniel Schwierzeck
All architectures but MIPS are using --gc-sections on final linking. This patch introduces that feature for MIPS to reduce the memory and flash footprint. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Thomas Lange <thomas@corelatus.se> Cc: Vlad Lungu <vlad.lungu@windriver.com> Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com>
2011-04-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-04-30keymile, common: add setting of some environment variablesHeiko Schocher
This patch adds last_stage_init to all keymile boards. And in the last stage init some environment variables for u-boot were set. Currently these are pnvramaddr, pram and var address. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Kim Phillips <kim.phillips@freescale.com>
2011-04-30keymile boards: add CONFIG_PIGGY_MAC_ADRESS_OFFSETHeiko Schocher
Normaly the PIGGY_MAC_ADRESS can be read directly from the IVM on keymile boards. On mgcoge3 it differs. Because there are two piggy boards deployed the second MAC adress must be calculated with the IVM mac adress and an offset. This patch allows to set such a offset in the board config. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Heiko Schocher <hs@denx.de>
2011-04-30arm, keymile: updates for the arm based boards from keymileHeiko Schocher
define KM_IVM_BUS and KM_ENV_BUS macros KM_IVM_BUS is used to define the EEprom_ivm environment variable. These macros allow the reuse of these I2C addresses in other code locations. remove unneeded code On first HW versions the BOCO FPGA was behind a MUX device. These HW versions are not supported anymore. And therefore this code can be removed. added LED initialization for SUEN3 The bootstat LED required to be initialized so to have a green colour after start-up. define CONFIG_SYS_TEXT_BASE This is needed by the relocation code and is not the same for our ARM BEC and thus needs to be defined. remove memsize variable An environment variable for memsize is not needed. this can be get via the board info struct. remove unneeded double access to bi_dram[i].size field Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Luca Haab <luca.haab@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30keymile, common; fix i2c deblocking supportHeiko Schocher
This patch fix the i2c deblocking facility with the i2c HW-Controller. The required delays for byte reading, the enhanced criteria for stop the dummy read and required 5 start/stop sequences are added. Add i2c deblocking before ivm eeprom read. Improve i2c deblocking sequence by respecting stop hold time. Cleaned function for deblocking. Have now one function i2c_make_abort() available for bitbang, mpc82xx and mpc83xx harware controller. Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30ppc, 8321: cleanup tuxa1, tuda1 and suvd3 supportHeiko Schocher
For the kmsupx5 a new header file was introduced km8321-common.h. Now the common stuff from tuxa1, tuda1 and suvd3 was removed and the new header file included. The defines CONFIG_SYS_PIGGY_BASE and CONFIG_SYS_PIGGY_SIZE are confusing. Because they actually describe the KMBEC FPGA values. The KMBEC FPGA can be PRIO on kmeter1 or upio on mgcoge. Therefore all the defines were renamed. remove unneeded variable CONFIG_KM_DEF_NETDEV, as it is already declared in keymile-common.h Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Wolfgang Denk <wd@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30km_arm: change some register values for SDRAM initializationHeiko Schocher
These new values are: - enables UART0 and UART1 pins in MPP - define some L2 cache settings - changes a SDRAM timing to better fit the hardware - removed three writes that were the same as the reset values Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Holger Brunck <holger.brunck@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30km-arm: i2c support for suenx based boardsHeiko Schocher
This patch renames the suen3 defines and functions to KM_KIRKWOOD which is more generic and more precise, because these values and functions where used by all suenX boards and not only suen3. Signed-off-by: Lukas Roggli <lukas.roggli@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30ppc: add support for ppc based board mgcoge2neHeiko Schocher
The mgcoge2 board from keymile deploys two different processors. An ARM based Kirkwood for the "unit" part of the SW and a PPC for the "ne" part of the SW. Therefore in Linux and U-Boot the names for the board are mgcoge2un and mgcoge2ne. This patch adds the mgcoge2ne part of the board. The ppc part of mgboge2 is quite similar to mgcoge, therefore a generic header km82xx-common.h was introduced to collect all similiarities. Currently the only difference is that mgcoge2ne has a 64 MB numonyx NOR flash with a single die. The mgcoge has a dual die flash 2*32MB from spansion. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30mpc832x: add support for the mpc8321 based suvd3 boardHeiko Schocher
- serial console on UART1 - Ethernet RMII over UCC4 - PHY SMSC LAN8700 - 64MB Flash - 128 MB DDR2 RAM - I2C - bootcount This board is similiar to the kmeter1 (8360) board, so common config options are extracted into the include/configs/km83xx-common.h file. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-04-30keymile: Fix Coding style issues for keymile boards.Heiko Schocher
- use I/O accessors -> For accessing the FPGA therefore a struct km_bec_fpga is introduced. - no longer externs needed - to defines, that only select functions, don;t assign a numeric value - Codingstyle changes to prevent checkpatch errors/warnings Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> cc: Kim Phillips <kim.phillips@freescale.com> cc: Holger Brunck <holger.brunck@keymile.com> cc: Wolfgang Denk <wd@denx.de> cc: Detlev Zundel <dzu@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-30arm, keymile: rename MACH_SUEN3 to MACH_KM_KIRKWOODHolger Brunck
The MACH_TYPE SUEN3 is now to specific for keymile boards, because other boards similar to suen3 will follow. So the MACH_SUEN3 was renamed to MACH_KM_KIRKWOOD. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Heiko Schocher <hs@denx.de> cc: Wolfgang Denk <wd@denx.de> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com>
2011-04-29Merge branch 'master' of git://git.denx.de/u-boot-mmcWolfgang Denk
2011-04-29powerpc/85xx: Enable eSPI support on P1022DSJiang Yutang
Signed-off-by: Jiang Yutang <b14898@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-29ARMV7: Vexpress: Add MMC supportMatt Waddel
Added the board specific definitions to use the MMCI device. Signed-off-by: Matt Waddel <matt.waddel@linaro.org>
2011-04-28powerpc/fsl: add 'pixis_reset dump' commandTimur Tabi
Add the 'pixis_reset dump' command, which displays the contents of the PIXIS registers. This command is only available if DEBUG is defined. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-28powerpc/86xx: remove empty board_early_init_f()Timur Tabi
Remove an empty board_early_init_f() from the MPC8641HPCN board. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-28powerpc: use 'video-mode' environment variable to configure DIUTimur Tabi
Use the 'video-mode' environment variable (for Freescale chips that have a DIU display controller) to designate the full video configuration. Previously, the DIU driver used the 'monitor' variable, and it was used only to determine the output video port. The old definition of the "monitor" environment variable only determines which video port to use for output. This variable was set to a number (0, 1, or sometimes 2) to specify a DVI, LVDS, or Dual-LVDS port. The resolution was hard-coded into board-specific code. The Linux command-line arguments needed to be hard-coded to the proper video definition string. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-04-27powerpc: Add P3041DS/P5020DS board support (uses corenet_ds code)Kumar Gala
The P3041DS & P5020DS boards are almost identical (except for the processor in them). Additionally they are based on the P4080DS board design so we use the some board code for all 3 boards. Some ngPIXIS (FPGA) registers where reserved on P4080DS and now have meaning on P3041DS/P5020DS. We utilize some of these for SERDES clock configuration. Additionally, the P3041DS/P5020DS support NAND. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Shaohui Xie <b21989@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-27powerpc/85xx: Add support for 2nd USB controller on p1_p2_rdbRamneek Mehresh
Second USB controller only works for SPI and SD boot because of pin muxing Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2011-04-28mpc52xx, digsy_mtc: protect default flash sectorsHeiko Schocher
call flash_protect_default() to protect default sectors. Signed-off-by: Heiko Schocher <hs@denx.de>
2011-04-28mpc52xx, digsy_mtc: change phy addr for rev5 boards.Heiko Schocher
- rev5 board has phy addr 1 -> adapt CONFIG_PHY_ADDR define in board config file. - also fixup the phy addr entry in dts, before booting Linux. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-27nhk8815: add support for relocationAlessandro Rubini
This patch defines all the needed symbols in the header file and removes the now-unused config.mk in board directory. Changes to board C file as requested. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
