path: root/board
2010-11-17Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-11-14mpc85xx: Fix SERDES/eTSEC message indentationPeter Tyser
Previously some mpc85xx boards printed indented messages such as the following on bootup: printf(" eTSEC4 is in sgmii mode.\n"); printf(" Serdes2 disalbed\n"); The bootup appearance looks cleaner if the indentation is removed which aligns these messages with other bootup output. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> CC: galak@kernel.crashing.org
2010-11-14fsl: Clean up printing of PCI boot infoPeter Tyser
Previously boards used a variety of indentations, newline styles, and colon styles for the PCI information that is printed on bootup. This patch unifies the style to look like: ... NAND: 1024 MiB PCIE1: connected as Root Complex Scanning PCI bus 01 04 01 8086 1010 0200 00 04 01 8086 1010 0200 00 03 00 10b5 8112 0604 00 02 01 10b5 8518 0604 00 02 02 10b5 8518 0604 00 08 00 1957 0040 0b20 00 07 00 10b5 8518 0604 00 09 00 10b5 8112 0604 00 07 01 10b5 8518 0604 00 07 02 10b5 8518 0604 00 06 00 10b5 8518 0604 00 02 03 10b5 8518 0604 00 01 00 10b5 8518 0604 00 PCIE1: Bus 00 - 0b PCIE2: connected as Root Complex Scanning PCI bus 0d 0d 00 1957 0040 0b20 00 PCIE2: Bus 0c - 0d In: serial ... Signed-off-by: Peter Tyser <ptyser@xes-inc.com> CC: wd@denx.de CC: sr@denx.de CC: galak@kernel.crashing.org
2010-11-13Merge branch 'master' of git://git.denx.de/u-boot-tiWolfgang Denk
2010-11-12Merge branch 'master' of /home/wd/git/u-boot/masterWolfgang Denk
2010-11-12TQM85xx: Fix bug introduced by 83xx/85xx/86xx: LBC register cleanupBecky Bruce
The size of the other bank needed to be added to the br0 setting; this got dropped in the LBC cleanup. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-12powerpc/corenet_ds: display the RCW at bootTimur Tabi
Display the 64-byte Reset Configuration Word (RCW) during boot, so that there's no confusion as to what RCW U-boot is using. Reset Configuration Word (RCW): 00000000: 4a500000 00000000 18181818 00008888 00000010: 28402400 00002000 fe800000 01200000 00000020: 00000000 00000000 00000000 000b0000 00000030: 00000000 00000000 00000000 00000000 Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-12p1_p2_rdb: to set SQW/INT pin of RTC as INT linePriyanka Jain
SQW/INT pin in RTC can be used for generating square wave(by default) or as interrupt line. U-boot is registering this pin for interrupts. Configuring SQW/INT bit as interrupt line during board initialization to avoid spurious interrupts generated by square wave. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-04omap3evm: Fix mechanism to identify board revisionSanjeev Premi
Function omap3_evm_get_revision() - to identify the board revision was called at end of setup_net_chip(). Board revision can be ascertained only by identifying the Ethernet chipset - but combining setup operations with revision detection isn't a good idea. So, moved the function after call to setup_net_chip(). Function setup_net_chip() should be ideally be called only when CONFIG_CMD_NET is defined. But this leaves the board revision "undetected". This patch allows static definition of revision or default fallback to the latest revision. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04omap3evm: Wrap function under CONFIG_USB_OMAP3Sanjeev Premi
The function omap3_evm_need_extvbus() is required only when USB support is configured. Wrapped this function in #ifdef CONFIG_USB_OMAP3. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04omap3evm: Support relocationSanjeev Premi
This patch adds relocation support for omap3evm. Content of the patch is based on changes for Beagleboard. Signed-off-by: Sanjeev Premi <premi@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Use generic mmc driver on OMAP3 IGEP moduleEnric Balletbo i Serra
This patch switches from the legacy mmc driver to the new generic mmc driver Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Use generic mmc driver on IGEP v2Enric Balletbo i Serra
2010-11-04ARMV7: OMAP3: Add expansion board detection for BeagleKoen Kooi
Beagle expansion boards contain an i2c eeprom to identify themselves. This patch adds code to read and parse the eeprom contents. It prints the expansion board name and revision and modifies environment variables as appropriate. This patch is based on the Overo expansion board code. Signed-off-by: Koen Kooi <k-kooi@ti.com> Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Add expansion board detection for OveroSteve Sakoman
Overo expansion boards contain an i2c eeprom to identify themselves. This patch adds code to read and parse the eeprom contents. It prints the expansion board name and revision and modifies environment variables as appropriate. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: IGEP: Rename TEXT_BASESteve Sakoman
Commit 14d0a02a "Rename TEXT_BASE into CONFIG_SYS_TEXT_BASE" missed the IGEP boards since they were just added. Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-marvellWolfgang Denk
Conflicts: include/configs/km_arm.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-samsungWolfgang Denk
2010-10-29Drop support for CONFIG_SYS_ARM_WITHOUT_RELOCWolfgang Denk
When this define was introduced, the idea was to provide a soft migration path for ARM boards to get adapted to the new relocation support. However, other recent changes led to a different implementation (ELF relocation), where this no longer works. By now CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it actually hurts because it obfuscates the actual code by sprinkling it with lots of dead and non-working debris. So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-28kirkwood: get rid of config.mk filesPrafulla Wadaskar
After moving the definition of CONFIG_SYS_TEXT_BASE to the respective board config files, all Marvell kirkwood board have just a single and common entry in their config.mk files: KWD_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/kwbimage.cfg Replace the only reference to KWD_CONFIG in the top level Makefile by an equivalent setting, and remove all kirkwood config.mk files. Signed-off-by: Wolfgang Denk <wd at denx.de> Cc: Prafulla Wadaskar <prafulla at marvell.com> Cc: Siddarth Gore <gores at marvell.com> Cc: Simon Kagstrom <simon.kagstrom at netinsight.net> Cc: Heiko Schocher <hs at denx.de> Cc: Eric Cooper <ecc at cmu.edu> Acked-by: Wolfgang Denk <wd at denx.de> Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-10-28mx51evk: support new relocation schemeShawn Guo
This patch is to fix build breakage and support new relocation scheme for mx51evk. - Correct IRAM base address and add size definition The IRAM starts from 0x1FFE0000 on final revsion i.mx51 than 0x1FFE8000 which is for older revision. - Include imx-regs.h in mx51evk.h Definitions like CSD0_BASE_ADDR and IRAM_BASE_ADDR can be referred to. - Define CONFIG_SYS_INIT_RAM_ADDR and CONFIG_SYS_INIT_RAM_SIZE They are used to define init RAM layout. - Remove comment for CONFIG_SYS_GBL_DATA_SIZE which has been buried by Wolfgang's commit below 25ddd1fb: Replace CONFIG_SYS_GBL_DATA_SIZE by auto-generated value Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
2010-10-28mx51evk: Fix 2 hours reset issueShawn Guo
The mx51evk u-boot has an issue that system will get reset every 2 hours. MC13892 has an inside charge timer which expires in 120 minutes. If ICHRG and CHGAUTOB are not set properly, this timer expiration will get system power recycled. Since mx51evk has no Li-Ion battery on board, the patch sets ICHRG in externally powered mode and sets CHGAUTOB bit to avoid automatic charging, so that system will not get reset by this timer expiration. The patch also corrects the bit field definition of register 48 (Charger 0) per latest MC13892 Reference Manual. Signed-off-by: Shawn Guo <shawn.gsc@gmail.com>
2010-10-28MX5:use common u-boot.lds of cpu layerJason Liu
Remove u-boot.lds from mx5 and use the common u-boot.lds of cpu layer. This patch also fix the building errors: arch/arm/cpu/armv7/start.o: In function `_rel_dyn_start_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__rel_dyn_start' arch/arm/cpu/armv7/start.o: In function `_rel_dyn_end_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__rel_dyn_end' arch/arm/cpu/armv7/start.o: In function `_dynsym_start_ofs': arch/arm/cpu/armv7/start.S:283: undefined reference to `__dynsym_start' Signed-off-by: Jason Liu <r64343@freescale.com>
2010-10-28MX51: add CONFIG_SYS_TEXT_BASE to vision2 board, use general ld scriptStefano Babic
Recent patch changed TEXT_BASE to CONFIG_SYS_TEXT_BASE and vision2 board was not updated. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-28Add generic support for samsung s3c2440C Nauman
This patch adds generic support for the Samsung s3c2440 processor. Global s3c24x0 changes to struct members converting from upper case to lower case. Signed-off-by: Craig Nauman <cnauman@diagraph.com> Cc: kevin.morfitt@fearnside-systems.co.uk Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2010-10-27Coding Style cleanupWolfgang Denk
2010-10-27mcu25: fix out of tree buildingWolfgang Denk
Out of tree building of the Netstal mcu25 board failed like that: Configuring for mcu25 board... Assembler messages: Fatal error: can't create /work/wd/tmp-ppc/board/netstal/mcu25/../common/fixed_sdram.o: No such file or directory Assembler messages: Fatal error: can't create /work/wd/tmp-ppc/board/netstal/mcu25/../common/nm_bsp.o: No such file or directory Adapt (and simplify) the Makefile. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Niklaus Giger <niklaus.giger@netstal.com>
2010-10-26Remove config.mk for da8xxevm based boards.Sughosh Ganu
Move CONFIG_SYS_TEXT_BASE to the board's config file, and remove the now unnecessary config.mk file. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
2010-10-26Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2010-10-25ppc4xx: Add Io and IoCon 405EP board supportDirk Eibach
Board support for the Guntermann & Drunck CATCenter Io. Board support for the Guntermann & Drunck IoCon. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2010-10-24hcu4, hcu5: fix out of tree buildingWolfgang Denk
Out of tree building of the Netstal hcu4 and hcu5 boards failed like that: Assembler messages: Fatal error: can't create /work/wd/tmp-ppc/board/netstal/hcu4/../common/fixed_sdram.o: No such file or directory Assembler messages: Fatal error: can't create /work/wd/tmp-ppc/board/netstal/hcu4/../common/nm_bsp.o: No such file or directory make[1]: *** [/work/wd/tmp-ppc/board/netstal/hcu4/../common/fixed_sdram.o] Error 2 Adapt (and simplify) the respective Makefiles. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Niklaus Giger <niklaus.giger@netstal.com>
2010-10-24lite5200b_PM: fix compile warningWolfgang Denk
Fix warning: icecube.c: In function 'lite5200b_wakeup': icecube.c:83: warning: format '%08lx' expects type 'long unsigned int', but argument 2 has type 'void (*)(void)' Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-10-23Merge branch 'for-wd-master' of git://git.denx.de/u-boot-pxaWolfgang Denk
2010-10-23Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2010-10-23Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2010-10-23Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2010-10-22XPedite5500 board supportJohn Schmoller
Initial support for Extreme Engineering Solutions XPedite5500 - a P2020-based PMC/XMC single board computer. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Make X-ES board names more genericPeter Tyser
Some U-Boot images for X-ES boards support multiple products in the same family. For example, the XPedite5370, XPedite5371, and XPedite5372 are similar enough that one U-Boot image can work on all 3 cards. To make it clear that a U-Boot image can work on boards of the same family, rename the boards with the least significant digit of 'x'. While we're at it, change the board config file and make targets to be lowercase. Also change the default uImage and fdt filenames to "board.uImage" and "board.dtb" to be more generic. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Add board_flash_wp_on()John Schmoller
Add board_flash_wp_on() to check a pca9557 gpio pin to see if non-volatile memory write protection is enabled. Previously, write protected NOR flashes would fail initialization which resulted in a bootup error such as: ... DTT: 53 C local / 64 C remote (adt7461@4c) DTT: 54 C local (ds1621@48) FLASH: Executed from FLASH1 POST memory PASSED FLASH: ## Unknown FLASH on Bank 1 - Size = 0x00000000 = 0 MB ## Unknown FLASH on Bank 2 - Size = 0x00000000 = 0 MB *** failed *** ### ERROR ### Please RESET the board ### With this patch, NOR flash initialization is skipped: ... DTT: 53 C local / 64 C remote (adt7461@4c) DTT: 54 C local (ds1621@48) FLASH: Executed from FLASH1 POST memory PASSED FLASH: Uninitialized - Write Protect On L2: 1024 KB enabled NAND: 1024 MiB ... Note that flash related commands such as flinfo and saveenv will error out when flash write protection is enabled. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Consolidate checkboard()John Schmoller
Create a common checkboard() function to support all X-ES's Freescale boards. Also, add a get_board_derivative() function which reads hardware strapping resistors to determine what model a board is. This allows one U-Boot image to support multiple boards. Signed-off-by: John Schmoller <jschmoller@xes-inc.com> Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22xes: Use common PCI initialization codePeter Tyser
Common Freescale code for PCI initialization now exists, so migrate X-ES boards to use it. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-22PXA: Remove "xsengine" boardMarek Vasut
This board is broken and it's not possible to repair it. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-22PXA: Remove "wepep250" boardMarek Vasut
This board is broken and impossible to repair without deep knowledge or availability of the hardware. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-22PXA: Remove "delta" boardMarek Vasut
2010-10-22PXA: xm250: Fix for relocMarek Vasut
2010-10-22PXA: xaeniax: Fix for relocMarek Vasut
2010-10-22PXA: trizepsiv: Fix for relocMarek Vasut
