path: root/board
2006-10-09Add missing files for EP82xxM boardsWolfgang Denk
Patch by Aaron Sells, 20 Jun 2006
2006-10-09Coding style cleanupWolfgang Denk
2006-10-05Merge with /home/m8/git/u-bootWolfgang Denk
2006-10-04Fix TLB setup for Ocotea boardStefan Roese
Patch by Stefan Roese, 30 Sep 2006
2006-10-04Fix reset problem in sequoia sdram init codeStefan Roese
Patch by Stefan Roese, 23 Sep 2006
2006-10-03Update for CAM5200 board:Marian Balakowicz
- Map in a additional chip selects CS4 and CS5. - Modify the port configration, configure six UARTs and no PCI, ATA and USB. - Add custom flash driver to handle specific byte swapping
2006-09-13Add support for AMCC Rainier PPX440GRx eval boardStefan Roese
Patch by Stefan Roese, 13 Sep 2006
2006-09-13Disable autoboot abort for FO300 when silent mode is enabledWolfgang Denk
(according to S1 switch setting). Patch by Marian Balakowicz, 12 Sep 2006
2006-09-12Add NAND environment support for PPC440EPx Sequoia NAND boot configStefan Roese
Patch by Stefan Roese, 12 Sep 2006
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2006-09-04Fix build problems on sorcery board.Wolfgang Denk
2006-09-04Merge with /home/m8/git/u-bootWolfgang Denk
2006-09-01Remove the board/netstar/crcit binary from git repository.Marian Balakowicz
2006-08-30Add splashscreen support for MCC200 board.Wolfgang Denk
2006-08-29PCIe endpoint support for AMCC Yucca 440SPe boardStefan Roese
Patch by Tirumala R Marri, 26 Aug 2006
2006-08-29Improve DIMM detection for AMCC Yucca 440SPe boardStefan Roese
Improved the memory DIMM detection for the Yucca 440SPe board for the case where a memory DIMM is falsely detected as present. This issue is seen on some AMCC Yucca 440SPe validation boards if only one 512MB memory DIMM is installed, i.e. DIMM slot 0 is populated and DIMM slot 1 is empty. In this case, U-Boot does not correctly detect that there is only one DIMM memory module installed and will falsely detect two DIMM memory modules are present and therefore U-Boot will not calculate the correct amount of total memory and u-boot will not booting up. Patch by Adam Graham, 24 Aug 2006
2006-08-27Code cleanupWolfgang Denk
2006-08-24Updates for MCC200 / PRS200 boards:Wolfgang Denk
- support for configurations with SDRAM or DDR memory, - support for highboot and lowboot - adjusting environment definitions
2006-08-18Minor cleanupWolfgang Denk
2006-08-18Add support for WTK FO300 board (TQM5200 based).Marian Balakowicz
2006-08-17MCC200: restrict addressable flash space to 32 MBWolfgang Denk
2006-08-13Merge with /home/sr/git/u-boot/denxWolfgang Denk
2006-08-11Merge with /home/raj/git/u-bootWolfgang Denk
2006-08-11Fix PCI-Express on PPC440SPe rev. A.Rafal Jaworowski
2006-08-10Merge with /home/raj/git/u-bootWolfgang Denk
2006-08-10Add support for PCI-Express on PPC440SPe (Yucca board).Rafal Jaworowski
2006-08-10Fix compiler warning for TRAB board.Wolfgang Denk
Patch by Martin Krause, 07 Aug 2006
2006-08-07Add Macronix MXLV320T flash support for AMCC BambooStefan Roese
Patch by Stefan Roese, 07 Aug 2006
2006-07-28PPC440 DDR setup: Set SDRAM0_CFG0[PMU]=0 for best performanceStefan Roese
AMCC suggested to set the PMU bit to 0 for best performace on the PPC440 DDR controller. Please see doc/README.440-DDR-performance for details. Patch by Stefan Roese, 28 Jul 2006
2006-07-27AMCC bamboo (440EP) U-Boot image reduced to 384kbyteStefan Roese
Please see doc/README.bamboo for details. Patch by Stefan Roese, 27 Jul 2006
2006-07-23MCC200: set default configuration to low_boot DDR,Wolfgang Denk
and support for configurable options high_boot and/or SDRAM.
2006-07-22Add support for 256 MB SDRAM on CPU87Wolfgang Denk
Patch by Josef Wagner, 25 Nov 2005
2006-07-22Add configuration for cam5200 board (based on TQM5200S).Wolfgang Denk
2006-07-21Code cleanupWolfgang Denk
2006-07-21Code cleanup.Wolfgang Denk
2006-07-21More code cleanupWolfgang Denk
2006-07-21Update NetStar boardWolfgang Denk
Patch by Ladislav Michl, 03 Nov 2005
2006-07-21Add support for friendly-arm SBC-2410X boardWolfgang Denk
Patch by JinHua Luo, 01 Sep 2005
2006-07-21Add support for KVME080 boardWolfgang Denk
Patch by Sangmoon Kim, 18 Aug 2005
2006-07-21* Cleanup TQM5200 board configurations:Wolfgang Denk
- make highboot configurations use environment at high end, too, to avoid flash fragmentation - always use redundand environment - don't enable video code for modules without graphics controller - provide useful (though different) mtdparts settings - get rid of CONFIG_CS_AUTOCONF which was always set anyway * Extend mkconfig tool to print more useful target name
2006-07-19Add support for high-boot on TQM5200 and TQM5200S boards.Wolfgang Denk
Hint: the CPLD on the TQM5200 must be programmed with a software version supporting the high boot option! The new TQM5200S is already supporting this option. On the TQM5200 this option will be supported in configurations with MPC5200 rev B processors. To actually "high boot", set jumper X30 on the STK52xx. Patch by Martin Krause, 12 Jul 2006
2006-07-19Add support for new TQM5200 revisionsWolfgang Denk
- Support for TQM5200S (short version without graphic controller) - Support for modules with 'N' type S29GL128N Spansion flashes (requires changes to flash layout) - Support for MPC5200B cpu (mostly support for second SDRAM bank)
2006-07-19Fix support for PS/2 keyboard on TQM85xx boardsWolfgang Denk
The PS/2 keyobard driver for the TQM85xx modules only supports the internal DUART of the MPC85xx CPU. Since the MPC8560 doesn't include a DUART, the TQM8560 modules can't be used with the PS/2 keyboard controller on the STK85xx board. The PS/2 keyboard driver should work with the modules TQM8540, TQM8541 and TQM8555, but it only has been tested on a TQM8540, yet. Make sure the PS/2 controller on the STK85xx is programmed. Jumper settings: X66 1-2, 9-10; X61 2-3 Patch by Martin Krause, 21 Jun 2006
2006-07-19Adjust filenames for USB update images on TRAB board.Wolfgang Denk
During an automatic update via USB stick, U-Boot searches for images with the name "firmware.img" and "kernel.img". This names are now changed to "firmw_01.img" and "kernl_01.img". This is done, to prevent updates of new boards (with the new macronics "c" step flashes) with old, incompatible firmware or kernel versions. Patch by Martin Krause, 21 Jun 2006
2006-07-19Bugfix in VFD routine on TRAB board.Wolfgang Denk
Make sure upper lext pixel can be set to blue, too (so far only red was possible). Patch by Martin Krause, 15 Feb 2006
2006-07-19Fix some bugs in TRAB board flash driver.Wolfgang Denk
- increase CFG_FLASH_ERASE_TOUT from 2 to 15 seconds - use CFG_FLASH_WRITE_TOUT for programming instead of CFG_FLASH_ERASE_TOUT - remove "Unlock Bypass" mode, because macronix flashes do not support this mode officially - fix flash reset command from 0x00FF to 0x00F0. 0x00FF is only specified for Intel compatible flashes, not for AMD compatible. Patch by Martin Krause, 15 Feb 2006
2006-07-19Add additional error messages to flash driver on TRAB boardWolfgang Denk
(for erase errors and timeout errors) Patch by Martin Krause, 14 Feb 2006
2006-07-19Add support for TB5200 boardWolfgang Denk
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module integrated in a little aluminium case. Patch by Martin Krause, 8 Jun 2006 Some code cleanup
