Linux crashes if the GPMC isn't configured for the dm9000.
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
CC: Tom Rini <tom.rini@gmail.com>
CC: Stefano Babic <sbabic@denx.de>
CC: Wolfgang Denk <wd@denx.de>
The variable "rc" is the return of board_eth_init() function. Initialize
it with an error code, so that this function can return an error when
CONFIG_SMC911X is not set.
This is needed to support Freescale-supplied userspaces.
At the moment, both the IPU and VPU libraries provided by Freescale
in the "imx-lib" package contain routines which scrape the system
revision from /proc/cpuinfo. In the VPU library, this information is
used to load the proper firmware, allowing a single binary to be used
across various i.MX processors.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
for environment
nand.c: In function ‘pdnb3_nand_read_buf’:
nand.c:107:4: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
nand.c: In function ‘pdnb3_nand_dev_ready’:
nand.c:124:18: warning: variable ‘val’ set but not used [-Wunused-but-set-variable]
Remove the 4-byte-at-time read mode altogether, the most is bogus and will
likely cause unaligned accesses.
Cc: Bryan Hundven <bryanhundven@gmail.com>
Cc: Michael Schwingen <rincewind@discworld.dascon.de>
These symbols are no longer defined in Linux-ARM's mach-types files. Replace
these with CONFIG_MACH_TYPE instead.
This prototype version SoM is unused and not available to public.
Support this only for internal debugging purposes.
The LCD pins configuration was wrong in U-Boot, configure pins properly.
Cc: Detlev Zundel <dzu@denx.de>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Jason Liu <jason.hui@linaro.org>
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
Configuring for zipitz2 board...
zipitz2.c: In function ‘board_mmc_init’:
zipitz2.c:85:2: warning: implicit declaration of function ‘pxa_mmc_register’ [-Wimplicit-function-declaration]
This link script seems old and incompatible with relocation and its
own sa1000 start.S file. It isn't used because the CPU's link script
was picked up in preference to this.
Acked-by: Kristoffer Ericson <kristoffer.ericson@gmail.com>
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Recent bootstage commits made the code grow, which caused linker
errors. Adjust the linker script to fix that.
Common code has a mdelay() func, so use that instead of the usb-specific
wait_ms() func. This also fixes the build errors:
ohci-hcd.c: In function 'submit_common_msg':
/usr/local/src/u-boot/blackfin/include/usb.h:202:44: sorry, unimplemented: inlining failed in call to 'wait_ms': function body not available
ohci-hcd.c:1519:9: sorry, unimplemented: called from here
ohci-hcd.c:1816:10: sorry, unimplemented: called from here
ohci-hcd.c:1827:10: sorry, unimplemented: called from here
ohci-hcd.c:1844:10: sorry, unimplemented: called from here
ohci-hcd.c:1563:11: sorry, unimplemented: called from here
ohci-hcd.c:1583:9: sorry, unimplemented: called from here
make[1]: *** [ohci-hcd.o] Error 1
These calls should not be made directly any more, since bootstage
will call the show_boot_...() functions as needed.
This changes over the network-related progress numbers to use enums
from bootstage.h.
This changes the number 15 as used in boot_stage_progress() to use the
new name provided for it. This is a separate patch because it touches
so many files.
A few subsystems are using the same define "NAMESIZE". This has been
working so far because they define it to the same number. However, I
want to change the size of eth_device's NAMESIZE, so rather than tweak
the define names, simply drop references to it. Almost no one does,
and the handful that do can easily be changed to a sizeof().
This patch adds support for the esd CPCI-HD/2 board to u-boot for CPCI-CPU/750.
As the primary devices on the CPCI-HD/2 board are connected to device 1 and 3,
the device must be swapped.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
Fixes building after recent readline updates with timeouts.
This function was defined as an extern in net/eth.c, drop that and use
standard means of calling it.
Cc: Stefan Roese <sr@denx.de>
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Boards can select either the 'built-in' parser or the hush parser. We
should not call builtin_run_command() if we are using the hush parser.
We use run_command() instead, since it knows how to call the correct
parser.
The current run_command() is only one of the parsing options - the other
is hush. We should not call run_command() when the hush parser is being
used. So we rename this function to better explain its purpose.
The reference implementation of the PCI initialization code almost
everywhere contain this fragile loop of "a few usecs", and its
use of volatile variables to delay a number of bus cycles is indeed
uncertain.
Reading the manual "Integrator/AP Users Guide", page 5-15 it is
clearly stated:
"Wait until 230ms after the end of the reset period before
accessing V360EPC internal registers. The V360EPC supports the
use of a serial configuration PROM and the software must wait for
the device to detect the absence of this PROM before accessing any
registers. The required delay is a function of the PCI Clock, but
at the lower frequency (25MHz) is 230ms".
So let's simply wait 230ms per the spec.
This solves the compilation error that looked like this:
pci.c: In function ‘pci_init_board’:
pci.c:286:18: warning: variable ‘j’ set but not used
Reported-by: Wolfgang Denk <wd@denx.de>
Fixing build regressions for the Integrator I get find that a few
boards try to work around the missing declaration of
pciauto_config_init() by declaring it in the local scope. This
does not make sense when the sibling functions are in <pci.h>
so move the function to the header, ridding the build error
in the Integrator and getting rid of the local declarations
here and there.
Fix build error for ethernut5 board due to prototype change
for function board_mmc_getcd().
ethernut5.c:238: error: conflicting types for 'board_mmc_getcd'
u-boot/include/mmc.h:318: note: previous declaration of 'board_mmc_getcd'
was here
make[2]: *** [ethernut5.o] Error 1
Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Cc: Tim Schendekehl <tim.schendekehl@egnite.de>
Cc: Thierry Reding <thierry.reding@avionic-design.de>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: egnite GmbH <info@egnite.de>
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
The video setup for the Epson display is provided. Addtionally
some extra info is displayed next to the Linux logo.
Make get_cpu_rev() publicly available (added to sys_proto.h).
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
Define CONFIG_PHY_MICREL, and
minimize the tx clock delay.
There is an issue with 1000 baseTx mode on early revs
of the SabreLite boards. The center tap pin 9 of the mag RJ45
USB combo was connected to the 3.3 filtered supply. Letting
this pin float solved the problem. Symptoms of the problem
were packets with many extra zeroes tacked on the end, and random
bit flips causing a high rate of CRC errors. 10/100 baseTx worked
fine on all revs. To disable 1000 baseTx for these boards, simply
define the environment variable disable_giga. ie.
setenv disable_giga 1
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
Boards may have things they want done before or after normal phy config.
Letting the boards call drv->config allows them more flexibilty.
Boards affected by this change are corenet_ds and mpc8544ds.
The PCI support for the Integrator AP has apparently never
been finished and I strongly suspect that it has never worked,
so let's fix it. This is a list of the more or less
un-splittable changes done in this driver rewrite:
- Replace the register definitions stashed into the config
file (!) with a copy if the register file from the Linux
kernels arch/arm/include/asm/hardware/pci_v3.h
- Delete the unreadable gigantic macros that perform the
config accesses and replace them with copyedited code from
Linux arch/arm/mach-integrator/pci_v3.c
- Rewrite the rest of the setup code to use the
v3_[read|write][lwb]() accessors.
- Enable PCI by default in the AP board configuration.
- Fix checkpatch warnings and make code more conformant.
Tested-by: Will Deacon <will.deacon@arm.com>
The U-Boot startup infrastructure already makes sure pci_init() is
called at a proper time, calling it again from within the board
setup code will not make things better.
davinci_dm6467Tevm
In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header
file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h.
The substantial difference between the davinci_dm6467evm and the
davinci_dm6467Tevm configuration is a single bit in the hardware revision
that is passed to the Linux kernel and davinci_dm6467evm has
REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a
REFCLK_FREQ = 33000000.
This patch removes include/configs/davinci_dm6467Tevm.h. Instead the
include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and
renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined
in boards.cfg.
Cc: Tom Rini <trini@ti.com>
add support to read mac address for AM18x EVM manufactured from
Spectrum digital which have mac address stored in I2C EEPROM manufactured
by WINBOND. This patch reads mac address from I2C EEPROM and sets the
environment variable if not set, If mac address is already present in
environment compare it with the mac address in EEPROM and warn on
mismatch.Introduced a config option CONFIG_MAC_ADDR_IN_EEPROM to where
to look for the mac address.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
Cc: Mike Frysinger <vapier@gentoo.org>
add support to read mac address for da850/L138 evm manufactured by
Logic PD which store mac address in SPI flash manufactured by ST
Microelectronics. This patch adds support to read mac address from
SPI flash and set the mac address if it hasn't been set in environment,
If it has been set in the environment it compares the value one with
SPI flash and warns on mismatch. Introduced a config option
CONFIG_MAC_ADDR_IN_SPIFLASH indicating where to look mac address for.
this patch addresses the issue that there is no DVI output on beagleboard-xm in
u-boot; the TFP410 is not powered on, DVI_PUP needs to be set high
this is done differently on beagleboard-xm rev. B/C versus earlier boards:
beagleboard-xm B/C need to set GPIO2 of the TWL4030
earlier boards need to set GPIO170
note that the change occured somewhere inbetween beagleboard-xm rev. A2 and A3
note that beagleboard-xm rev. A and rev. B cannot be distinguished using
get_board_revision(), REVISION_XM_A/REVISION_XM_B is bogus
due to this glitch, the patch cannot work correctly on some beagleboard-xm
rev A/B boards
tested on beagleboard-xm rev. C (you should see orange color on a monitor)
note that the framebuffer is NOT yet set up, this could be done along the
lines below (for 800x480 resolution and RGB24) before calling omap3_dss_enable()
static void configure_frame_buffer() {
writel(0x80500000, (uint *) 0x48050480); // address
writel(0x80500000, (uint *) 0x48050484);
writel(0x01df031f, (uint *) 0x4805048c); // size
writel(0x00000091, (uint *) 0x480504a0); // RGB24
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
MX35PDK board does not need to print CPU revision and reset cause in board file
because this is printed by common code when CONFIG_DISPLAY_CPUINFO is selected
Use gpio_direction_input prior to gpio_get_value.
Cc: Jason Liu <r64343@freescale.com>
Acked-by: Jason Liu <r64343@freescale.com>
Acked-by: Jason Liu <jason.hui@linaro.org>
Tested-by: Jason Liu <jason.hui@linaro.org>
This patch adds SPI support for the MX28EVK. Support for
an optionally installed SPI flash is also added. An example
configuration for redundant envrionment from SPI flash is also
added but disabled by default.
This patch has been tested on a MX28EVK Rev. D with an installed
SST25VF032B 32Mbit SPI flash.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
