path: root/board
2014-07-29Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-07-28Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2014-07-28Merge branch 'u-boot-ti/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-07-28Merge branch 'u-boot-sh/rmobile' into 'u-boot-arm/master'Albert ARIBAUD
2014-07-28Merge branch 'u-boot-sunxi/master' into 'u-boot-arm/master'Albert ARIBAUD
2014-07-26Merge branch 'u-boot-microblaze/zynq' into 'u-boot-arm/master'Albert ARIBAUD
2014-07-25board: k2e-evm: add board supportHao Zhang
This patch adds Keystone2 k2e_evm evaluation board support. Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25keystone: ddr3: move K2HK DDR3 configuration to a common fileHao Zhang
It's convenient to hold configurations for DDR3 PHY and EMIF in separate common place. This patch moves K2HK DDR3 PHY and EMIF configuration data with different rates and memory size to a common ddr3_cfg.c file. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25ARM: keystone2: move K2HK board files to common KS2 board directoryHao Zhang
This patch moves K2HK board directory to a common Keystone II board directory. The Board related common functions are moved to a common keystone board file. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25keystone2: add env option to do unitrd dt fixupMurali Karicheri
With latest v3.13 kernel, unitrd dt fixup is not needed. However for older kernel versions such as v3.8/v3.10, it is needed. So to work with both, add a u-boot env variable that can be set to do dt fixup for older kernels. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25k2hk: use common KS2_ prefix for all hardware definitionsKhoronzhuk, Ivan
Use KS2_ prefix in all definitions, for that replace K2HK_ prefix and add KS2_ prefix where it's needed. It requires to change names also in places where they're used. Align lines and remove redundant definitions in kardware-k2hk.h at the same time. Using common KS2_ prefix helps resolve redundant redefinitions and adds opportunity to use KS2_ definition across a project not thinking about what SoC should be used. It's more convenient and we don't need to worry about the SoC type in common files, hardware.h will think about that. The hardware.h decides definitions of what SoC to use. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25keystone2: move cpu_to_bus() to keystone.cHao Zhang
The SoC related common functions in board.c should be placed to a common keystone.c arch file. Acked-by: Murali Karicheri <m-maricheri2@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25keystone2: ddr: add DDR3 PHY configs updated for PG 2.0Hao Zhang
Add DDR3 PHY configs updated for PG 2.0 Also add DDR3A PHY reset before init for PG2.0 SoCs. Acked-by: Murali Karicheri <m-maricheri2@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25keystone: ddr3: add ddr3.h to hold ddr3 APIKhoronzhuk, Ivan
It's convinient to hold ddr3 function definitions in separate file such as ddr3.h. So move this from hardware.h to ddr3.h. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25am335x_evm / gumstix pepper: Correct DDR settingsTom Rini
As noted by clang, we have been shifting certain values out of 32bit range when setting some DDR registers. Upon further inspection these had been touching reserved fields (and having no impact). These came in from historical bring-up code and can be discarded. Similarly, we had been declaring some fields as 0 when they will be initialized that way. Tested on Beaglebone White. Reported-by: Jeroen Hofstee <jeroen@myspectrum.nl> Cc: Ash Charles <ash@gumstix.com> Signed-off-by: Tom Rini <trini@ti.com> Tested-By: Ash Charles <ashcharles@gmail.com>
2014-07-25k2hk_evm: add script to automate NAND flash processKhoronzhuk, Ivan
Add script to automate NAND flash process. As for now the board has two burn scripts - burn to boot from SPI NOR flash and burn to boot from AEMIF NAND flash, rename burn_uboot script to burn_uboot_spi. Also update README to contain NAND burn U-boot process description. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Acked-by: Murali Karicheri <m-karicheri2@ti.com>
2014-07-25tps65218/am43xx_evm: Add power framework support to TPS65218Tom Rini
Add in an init function for the drivers/power framework so we can dump and read the registers via i2c. Cc: Ɓukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-07-25ARM: dra7_evm: Add Ethernet support for dra72x platformMugunthan V N
Set the active_slave to 1 as slave 1 is pinned out in dra72x base board Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2014-07-25ARM: DRA7xx: Add cpsw second port pinmuxMugunthan V N
Add cpsw second slave port pinmux to use it as primary ethernet port Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
2014-07-24arm: rmobile: Add support Alt boardNobuhiro Iwamatsu
The alt board has R8A7794, 1GB DDR3-SDRAM, USB, Ethernet, QSPI, MMC, SDHI and more. This commit supports the following functions: - DDR3-SDRAM - SCIF - I2C - Ethernet - QSPI Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
2014-07-23zynq: disable -Wstrict-prototypes option for ps7_init.cMasahiro Yamada
The files ps7_init.c and ps7_init.h are supposed to be generated by hw projects such as Vivado, PlanAhead and then to be copied into board/xilinx/zynq directory. But some prototypes in them cause annoying warning messages: CC spl/board/xilinx/zynq/ps7_init.o In file included from board/xilinx/zynq/ps7_init.c:50:0: board/xilinx/zynq/ps7_init.h:137:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.h:138:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.h:139:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.h:145:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.c:12602:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.c:12723:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.c:12742:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.c:12761:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] board/xilinx/zynq/ps7_init.c:12854:6: warning: function declaration isn't a prototype [-Wstrict-prototypes] The prototypes should be int ps7_init(void); int ps7_post_config(void); int ps7_debug(void); rather than int ps7_init(); int ps7_post_config(); int ps7_debug(); We do not want to be bothered because of automatically generated files. But we cannot touch the external projects for now. What we can do is to disable -Wstrict-prototypes for ps7_init.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Tested-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-07-23stdio: Pass device pointer to stdio methodsSimon Glass
At present stdio device functions do not get any clue as to which stdio device is being acted on. Some implementations go to great lengths to work around this, such as defining a whole separate set of functions for each possible device. For driver model we need to associate a stdio_dev with a device. It doesn't seem possible to continue with this work-around approach. Instead, add a stdio_dev pointer to each of the stdio member functions. Note: The serial drivers have the same problem, but it is not strictly necessary to fix that to get driver model running. Also, if we convert serial over to driver model the problem will go away. Code size increases by 244 bytes for Thumb2 and 428 for PowerPC. 22: stdio: Pass device pointer to stdio methods arm: (for 2/2 boards) all +244.0 bss -4.0 text +248.0 powerpc: (for 1/1 boards) all +428.0 text +428.0 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2014-07-23stdio: Remove redundant code around stdio_register() callsSimon Glass
There is no point in setting a structure's memory to NULL when it has already been zeroed with memset(). Also, there is no need to create a stub function for stdio to call - if the function is NULL it will not be called. This is a clean-up, with no change in functionality. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2014-07-22powerpc/t4240qds: fix offset of serdes when checking reference clockShaohui Xie
T4240 has 4 serdes, each serdes has 4k memory space, two PLLs. We use PLL1CR0 to check the serdes reference clock. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-22powerpc/mpc85xx: Check return value of find_tlb_idxYork Sun
find_tlb_idx() is called in board_early_init_r() on multiple boards. The return value is not checked before being used to disable a TLB. In normal case the return value wouldn't be -1. In case of a mis- configuration during porting to a new board, checking the return value may be helpful to reveal some user errors. Signed-off-by: York Sun <yorksun@freescale.com>
2014-07-22powerpc/t1040qds: Initialize EPHY2 clock to RGMII onlyvijay rai
Setting FPGA register brdcfg9 EPHY2 bits to '0' to initialize EPHY2 clock to RGMII mode. Signed-off-by: Vijay Rai <vijay.rai@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-22powerpc/mpc85xx: Remove P1023 RDS supportLijun Pan
Since P1023RDS is no longer supported/manufactured by Freescale, we clean up P1023RDS related code. Since P1023RDB is still supported by Freescale, we keep P1023RDB releated code. Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-07-22m68k: fix an undefined behavior warning of M5253DEMO boardMasahiro Yamada
The latest GCC is so clever that it reports more warnings than old ones did: ------------------------------>8------------------------------ board/freescale/m5253demo/flash.c: In function 'flash_get_offsets': board/freescale/m5253demo/flash.c:65:23: warning: iteration 2047u invokes undefined behavior [-Waggressive-loop-optimizations] info->start[k + 1] = info->start[k] + CONFIG_SYS_SST_SECTSZ; ^ board/freescale/m5253demo/flash.c:64:3: note: containing loop for (k = 0, j = 0; j < CONFIG_SYS_SST_SECT; j++, k++) { ^ ------------------------------8<------------------------------ The cause of the warning is like this: The for statement iterates 2048 times in flash_get_offsets() func. (Notice CONFIG_SYS_SST_SECT is defined as 2048) The last iteration does info->start[2048] = info->start[2047] + CONFIG_SYS_SST_SECTSZ; causing an undefined behavior. (Please note the array size of info->start is 2048. CONFIG_SYS_MAX_FLASH_SECT is defined as 2048 for this board.) This commit fixes that so as not to overrun the info->start array. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jason Jin <Jason.jin@freescale.com>
2014-07-22sparc: merge LEON2 and LEON3 linker scriptsMasahiro Yamada
There is only one line diff between LEON2 and LEON3 linker scripts: - arch/sparc/cpu/leon2/start.o (.text) + arch/sparc/cpu/leon3/start.o (.text) They can be written in the same way: */start.o (.text) So, board/gaisler/grsim_leon2/u-boot.lds and arch/sparc/cpu/leon3/u-boot.lds can be merged into arch/sparc/cpu/u-boot.lds. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-07-22sparc: merge LEON3 linker scriptsMasahiro Yamada
The linker scripts of LEON3 - board/gaisler/grsim/u-boot.lds - board/gaisler/gr_cpci_ax2000/u-boot.lds - board/gaisler/gr_ep2s60/u-boot.lds - board/gaisler/gr_xc3s_1500/u-boot.lds are the same (except cosmetic differences such as indentation). This commit merges them into arch/sparc/cpu/leon3/u-boot.lds. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-07-22esd:cmd_loadpci.c: Switch from "do_source" to "source"Tom Rini
Rather than calling do_source directly (which is not officially exported from cmd_source.c) call 'source' which is exported and requires a little less code to do so as well. Signed-off-by: Tom Rini <trini@ti.com>
2014-07-18board: rpi_b: include mmc header and fix prototypeJeroen Hofstee
While at it add fdt_support.h as well. cc: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-07-18sunxi: add Cubieboard2 supportIan Campbell
This is a sun7i (A20) based followup to the sun4i (A10) Cubieboard. It has GMAC using MII mode. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com>
2014-07-18sunxi: use random parts of SID to set ethaddrJonathan Liu
Similar to the USB NIC found on OMAP5uEVM, PandaBoard and BeagleBoard-XM boards, the sunxi SoCs have a NIC onboard without an embedded MAC address. Just like the omap used on these boards, the sunxi SoCs do have a unique chip id, in the form of the 128 bit SID register: http://linux-sunxi.org/SID_Register_Guide So mimick the BeagleBoard-XM board code (commit 548a64d8) and use the chip id to generate a unique fixed MAC address. We check for the SID not being all 0, since some early A20 batches shipped without having there SID programmed. Note we use specific parts of the 128 bits, since some parts indicate the SoC family / revision, and thus are fixed. The algorithm for this was taken from the linux-sunxi.org kernels. Signed-off-by: Jonathan Liu <net147@gmail.com> [hdegoede@redhat.com: Expanded the commit message with some more info] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-18sunxi: Add axp152 pmic supportHans de Goede
Add support for the x-powers axp152 pmic which is found on most A10s boards and enable it for the r7-tv-dongle board. Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-18sunxi: Add axp209 pmic supportHenrik Nordstrom
Add support for the x-powers axp209 pmic which is found on most A10, A13 and A20 boards. And enable AXP209 support for the Cubietruck and Cubieboard boards. Signed-off-by: Henrik Nordstrom <henrik@henriknordstrom.net> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-07-18sunxi: Add i2c supportHans de Goede
Add support for the i2c controller found on all Allwinner sunxi SoCs, this is the same controller as found on the Marvell orion5x and kirkwood SoC families, with a slightly different register layout, so this patch uses the existing mvtwsi code. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-By: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Heiko Schocher <hs@denx.de> [ ijc -- updated u-boot-spl-fel.lds ]
2014-07-14ARM: DRA7xx: Update the board_name env variableLokesh Vutla
Update the board_name env variable and accordingly populate the dtb file. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2014-07-07board: iocon: Modify iocon hardware startupDirk Eibach
To avoid peer "ChReceivePathStatus"-messages on iocon startup, initialize PHYs as soon as possible. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: gdsys: Enable scrambling on DP501Dirk Eibach
For proper displayport performance, scrambling has to be enabled, but is turned off on DP501 by default. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: gdsys: Make gdsys osd hardware detection more robustDirk Eibach
2014-07-07board: gdsys: Configure bridge on DP501 to support DDC onlyDirk Eibach
The I2C bridge on DP501 supports EDID, MCCS and HDCP by default. Allow EDID only to avoid I2C address conflicts. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: iocon: Support DisplayPort hardwareDirk Eibach
There is a new iocon hardware flavor, supporting DisplayPort finally. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07board: controlcenterd: Use new API for setting i2c busDirk Eibach
2014-07-07board: gdsys: Adapt sdhc_boot.c to mmc_get_env_addr API changeDirk Eibach
2014-07-07board: controlcenterd: Fix pci accessDirk Eibach
readl was called with values instead of pointers to these values. Why this ever did work is a mystery... Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2014-07-07mpc8xx: remove spc1920 board supportMasahiro Yamada
This board is old enough and has no maintainer. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-07mpc8xx: remove v37 board supportMasahiro Yamada
2014-07-07mpc8xx: remove fads board supportMasahiro Yamada
These boards are old enough and have no maintainers. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
