This was done automatically with the following bits of scripting.
The Kconfig choice content was generated with this script snippet:
for i in $(git grep -l CONFIG_ARCH_SUNXI configs/*) ; do
TARGET=$(sed -n -e 's/CONFIG_SYS_EXTRA_OPTIONS="\([^,"]\+\).*/\1/p' $i);
MACH=$(sed -n -e 's/.*CONFIG_\(MACH_SUN.I\)=./\1/p' $i)
echo "config TARGET_$TARGET"
echo " bool \"$TARGET\""
echo " depends on $MACH"
echo
done
defconfigs were updated with a sed script (t):
# Extract board from first entry of CONFIG_SYS_EXTRA_OPTIONS,
/^CONFIG_SYS_EXTRA_OPTIONS/ {
s/^\(CONFIG_SYS_EXTRA_OPTIONS="\)\([^,"]\+\),\?\(.*\)/\1\3\nCONFIG_TARGET_\2=y/;
# Print and delete first line (CONFIG_SYS_EXTRA_OPTIONS), leaving
# CONFIG_TARGET_<BOARD> in pattern space
P;D;
# Move CONFIG_TARGET_<BOARD> to hold space
/^CONFIG_TARGET/{h;n}
# Print CONFIG_TARGET_<BOARD> after CONFIG_MACH_<SOC> in either SPL or
# normal mode.
/^CONFIG_MACH/{p;g;p;n};
/^\+S:CONFIG_MACH/{p;g;s/^CONFIG_TARGET/+S:&/;p;n};
# Print any remaining lines normally
p;
Run as:
sed -i -n -f t $(git grep -l CONFIG_ARCH_SUNXI configs/*)
and then manually removing the one instance of CONFIG_SYS_EXTRA_OPTIONS="" from
Colombus_defconfig
board/sunxi/Makefile was updated with:
sed -e 's/^\(obj-\$(CONFIG_\)\(.*\)\().*+= dram_.*\)/\1TARGET_\2\3/g' board/sunxi/Makefile
and manually retabbing a few lines to line up again.
The board descriptions could certainly be improved.
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
It's unfortunate that this needs to be present in both .config and spl/.config
since it makes it slightly hard to enable FEL mode for a regular defconfig. It
can be done with:
echo CONFIG_SPL_FEL=y >> .config
echo CONFIG_SPL_FEL=y >> spl/.config
Ideally only one of those would be needed.
Now we have CONFIG_ARCH_SUNXI as the toplevel, CONFIG_MACH_SUN[45678]I as the
per-SoC option and leave CONFIG_TARGET_BLAH free for individual boards in the
future.
Done automatically with:
sed -i -e 's/TARGET_\(SUN[45678]I\)/MACH_\1/g' $(git grep -l TARGET_SUN[45678]I)
And make TARGET_SUN[45678]I a choice variable under this.
configs updated with:
sed -i -e 's/^\(\+S:\)\?CONFIG_TARGET_SUN.I=y/\1CONFIG_ARCH_SUNXI=y\n&/g' configs/*
The defconfig for Ippo-q8h-v5 was incorrectly committed as
"Ippo_q8h". This patch renames it correctly, as well as
correct a typo in my name in the maintainers listing.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Defining CONFIG_SYS_TEXT_BASE in config.mk is very old style.
Create CONFIG_SYS_TEXT_BASE option in Kconfig, but let it
depend on CONFIG_SPARC because we do not want to disturb
the other architectures that still define CONFIG_SYS_TEXT_BASE
in their header files.
Cc: Daniel Hellstrom <daniel@gaisler.com>
For now, all the SPARC boards in U-Boot are provided by Gaisler.
The vct board can be built with various variants which are
configured via CONFIG_SYS_EXTRA_OPTIONS. This is deprecated. Thus
add new Kconfig options for those board variants.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
The dbau1x00 board can be built with various variants which are
Now the user can separately select the CPU type. Thus the
targets qemu_mips and qemu_mips64 can be merged to a single
target.
Now the user can select the CPU type for each target. Thus
CONFIG_SYS_CPU could be set globally.
Commit f91c09acf5c58c ("ARM: mx6: Add support for Kosagi Novena") missed to
add a MAINTAINERS file, so add Marek as the maintainer.
[1] arch/arm/include/asm/arch-at91/at91_shdwn.h
The top9000 was the last board to use this header file.
It was removed by commit d58a9451e733 (ppc/arm: zap EMK boards).
[2] board/matrix_vision/common/*
Some Matrix Vision boards were dropped by commit e7a565638a7a
(powerpc: mpc83xx: remove board support for MERGERBOX and MVBLM7)
and commit af55e35d3389
(powerpc: mpc5xxx: remove board support for MVBC_P and MVSMR).
Since then these files have been unused.
[3] include/usb/omap1510_udc.h
The omap5912osk was the last board to use this header file.
It was removed by commit 62d636aa2ac2
(omap: remove omap5912osk board support).
Acked-By: Wolfgang Denk <wd@denx.de>
Setting gpio value before dm gpio init has no effect,
so now, odroid gpio settings are moved after the gpio uclass init.
Using non-requested gpio pin cases printing error messages.
To avoid this, gpio_request() is added for those gpios.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
The following bard configurations have been without active maintenance
for a long time, and the board maintainer agrees to have them removed:
MPC5200: TOP5200, MINI5200, EVAL5200
MPC860: TOP860
at91sam9xeXXX: top9000eval_xe, top9000su_xe
Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de>
[trini: Add missing Kconfig removals]
- switch to GENERIC_BOARD
- fix env support from eeprom
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This file should contain the bin_hdr generated by the original Marvell
U-Boot implementation. As this is currently not included in this
U-Boot version, we have added this placeholder, so that the U-Boot
image can be generated without errors.
If you have a known to be working bin_hdr for your board, then you
just need to replace this text file here with the binary header
and recompile U-Boot.
In a few weeks, mainline U-Boot will get support to generate the
bin_hdr with the DDR training code itself. By implementing this code
as SPL U-Boot. Then this file will not be needed any more and will
get removed.
LaCie Wireless Space has no defined maintainer.
Set myself as maintainer, since I own one of these.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This board is old and is using CONFIG_I2C_X, which is wrong.
Cc: Tom Rini <trini@ti.com>
This is the only used of CONFIG_SPI_X macro, just zap this.
Remove this board as this is the only one last user of eeprom_probe(),
which is pretty non-standard stuff.
This patch also removes all the PHP, SQL and CSS stuff from U-Boot,
which probably makes U-Boot a bit less IoT ;-)
This board uses eeprom accessors in an incorrect way. The board
is old and unsupported, just zap it.
This board is the only user of CONFIG_SYS_EEPROM_X40430 , remove
it so the EEPROM command code can be cleansed of the related code
as well.
The file board/Marvell/include/mv_gen_reg.h is incompatible with
the GPL (see for example the "MARVELL RESERVES THE RIGHT AT ITS SOLE
DISCRETION TO REQUEST THAT THIS CODE BE IMMEDIATELY RETURNED TO
MARVELL" clause). As this cannot be fixed, we remove the file and all
code that depends on it. Fortunately this only affects some very old
boards that have long reached EOL:
CPCI750
DB64360
DB64460
p3m750
p3m7448
Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Roger Meier <r.meier@siemens.com>
The config targets described in README are not present
any more, update the info to currently used targets.
Fix a trivial conflict over adding <dm.h>
arch/arm/cpu/armv7/omap3/board.c
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Add a Kconfig option which users can select when they want to boot older
kernels, e.g. the linux-sunxi 3.4 kernels. For now this just forces the pll5
"p" value to 1 (divide by 2) as that is what those kernels are hardcoded too,
in the future this may enable further workarounds.
Reviewed-by: Tom Rini <trini@ti.com>
Changes in v2:
-s/CONFIG_OLD_KERNEL_COMPAT/CONFIG_OLD_SUNXI_KERNEL_COMPAT.
-Move the code block setting P(1) for old kernels to where P gets cleared
Ippo q8h is a series of A23 tablet boards. This defconfig
is for v5 of these boards, though for u-boot purposes they
are mostly the same.
See: http://linux-sunxi.org/Ippo_q8h
Acked-by: Ian Campbell <ijc@hellion.org.uk>
The basic blocks of the A23 are similar to the A31 (sun6i). Re-use
sun6i code for initial clock, gpio, and uart setup.
There is no SPL support for A23, as we do not have any documentation
or sample code for DRAM initialization.
Unify the sunxi Kconfig code, instead of having separate code blocks for
each of sun4i - sun7i.
None of the known sunxi devices actually use mmc1 routed through PH, where
as some devices do actually use mmc1 routed through PG, so change the routing
of mmc1 to PG. If in the future we encounter devices with mmc1 routed through
PH, we will need to change things to be a bit more flexible.
sunxi SOCs can boot from both mmc0 and mmc2, detect from which one we're
booting, and make that one "mmc dev 0" so that a single u-boot binary can
be used for both the onboard eMMC and for external sdcards.
When we're booting from mmc2, we make it dev 0 because that is where the SPL
will load the tertiary payload (the actual u-boot binary in our case) from,
see: common/spl/spl_mmc.c, which has dev 0 hardcoded everywhere.
Note we also drop the SPL check for initializing the 2nd mmc slot, the SPL
check is not necessary with Kconfig, because only options explicitly marked
as also being for the SPL get set during SPL builds.
