path: root/board
2013-08-09nds32: fix the missing COBJS-y changeken kuo
There is a missing in previous commit 951344b778d6ac67b94011d942a5a55da7202027 (nds32: Convert Makefiles to use COBJS-y style) will cause compile error. Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com> Cc: Andes <uboot@andestech.com> Signed-off-by: Andes <uboot@andestech.com>
2013-08-02dt: don't use ARCH_CPU_DTSStephen Warren
Now that we assume dtc supports the -i option, we don't need to use ARCH_CPU_DTS in *.dts{,i}; we simply specify the include filename directly, and dtc will find it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-08-02xilinx: move microblaze-generic .dts to standard locationStephen Warren
Aside from microblaze, all other SoCs/boards/vendors store their DT files in board/$vendor/dts/$soc-$board.dts. Move microblaze-generic.dts to this location for consistency. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Michal Simek <monstr@monstr.eu>
2013-07-26powerpc/ppc4xx: Convert new gdsys files to SPDX license tagsTom Rini
2013-07-25powerpc/ppc4xx: Consider gdsys FPGA OSD sizeDirk Eibach
OSD size was constant 32x16 characters. Now the size is set as announced by the FPGA. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-25powerpc/ppc4xx: Support gdsys multichannel iocon hardwareDirk Eibach
2013-07-25powerpc/ppc4xx: Add gdsys mclink interfaceDirk Eibach
mclink is a serial interface for communication between gdsys FPGA. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-25powerpc/ppc4xx: Use generic accessor functions for gdsys FPGADirk Eibach
A set of accessor functions was added to be able to access not only memory mapped FPGA in a generic way. Thanks to Wolfgang Denk for getting this sorted properly. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
2013-07-25Merge branch 'master' of git://git.denx.de/u-boot-nds32Tom Rini
2013-07-25qemu-malta: Update for SPDX license identifiersTom Rini
2013-07-25Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
Conflict over SPDX changes means that one change was effectively dropped as it was fixing typos in a removed hunk of text. Conflicts: arch/mips/cpu/mips64/start.S Signed-off-by: Tom Rini <trini@ti.com>
2013-07-25nds32: Convert Makefiles to use COBJS-y styleken kuo
2013-07-24MIPS: qemu-malta: bring up ethernetGabor Juhos
Qemu emulates a PCNET PCI card for the Malta CoreLV board. Enable the pcnet driver and add board specific ethernet initialization function to bring it up. Also enable the CONFIG_CMD_NET and CONFIG_CMD_PING options. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-07-24MIPS: qemu-malta: add PCI supportGabor Juhos
Qemu emulates the Galileo GT64120 System Controller which provides a CPU bus to PCI bus bridge. The patch adds driver for this bridge and enables PCI support for the emulated Malta board. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-07-24MIPS: qemu-malta: setup GT64120 registers as done by YAMONGabor Juhos
Move the GT64120 register base to 0x1be00000 and setup PCI BAR registers as done by the original YAMON bootloader. This is needed for running Linux kernel. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-07-24MIPS: qemu-malta: add reset supportGabor Juhos
The MIPS Malta board has a SOFTRES register. Writing a magic value into that register initiates a board reset. Use this feature to implement reset support. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-07-24MIPS: qemu-malta: add support for emulated MIPS Malta boardGabor Juhos
Add minimal support for the MIPS Malta CoreLV board emulated by Qemu. The only supported peripherial is the UART. This is enough to boot U-Boot to the command prompt both in little and big endian mode. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-24nds32: Enable two banks of SDRAM on Andes boardken kuo
The original adp-ag101/adp-ag101p initialize only one bank(64MB) by default at boot time, but it is not enough for some application, so increasing to two banks(128M). Signed-off-by: Kuan-Yu Kuo <ken.kuoky@gmail.com> Cc: Macpaul Lin <macpaul@gmail.com>
2013-07-24nds32: adp-ag102: use 'faraday/ftpci100.h' for pci_ftpci_initGabor Juhos
Due to improper external function declaration, building U-Boot for the adp-ag102 board shows this warning: adp-ag102.c: In function 'pci_init_board': adp-ag102.c:95: warning: function declaration isn't a prototype Include the 'faraday/ftpci100.h' header which provides the proper declaration and remove the local declaration to get rid of the warning. Compile tested only. Cc: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-07-23vf610: Add I2C support for Vybrid VF610 platformAlison Wang
This patch adds I2C support for Vybrid VF610 platform and adds I2C0 support to VF610TWR board. Signed-off-by: Alison Wang <b18965@freescale.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-07-23tegra: i2c: Enable new CONFIG_SYS_I2C frameworkSimon Glass
This enables CONFIG_SYS_I2C on Tegra, updating existing boards and the Tegra i2c driver to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Heiko Schocher <hs@denx.de>
2013-07-23i2c, multibus, keymile: get rid of EEprom_ivm envvariableHeiko Schocher
as the keymile boards use now the new i2c multibus/multiadapter framework, remove the EEprom_ivm Environmentvar, as not longer needed. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Holger Brunck <holger.brunck@keymile.com> Tested-By: Holger Brunck <holger.brunck@keymile.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-22arm: at91sam9n12: change EBI IO to high drive modeBo Shen
As both the DDR SDRAM and NAND flash connect to EBI on at91sam9n12 and share the lower 8 bits data line. If use low drive of the data line, it will cause DDR data access corrupt in lower address, so change the data line to high drive mode This will fix the Linux kernel boot issue when use Lower address Signed-off-by: Bo Shen <voice.shen@atmel.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-07-20ddr cfg: DRAM_RESET needs 0x00020030Troy Kisky
The old value of 0x000e0030 will cause ethernet timeout issues on the sabrelite and possibly other boards using the KSZ9021. I have no explanation as to why. But this is a correct change, the TRM will be updated to show that 00b is the only valid setting for bits 19-18 of DRAM_RESET. My thanks go to Liu Hui(Jason) for this information. Acked-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-07-16mpc85xx: Add gdsys ControlCenter Digital boardDirk Eibach
The gdsys ControlCenter Digital board is based on a Freescale P1022 QorIQ SOC. It boots from SPI-Flash but can be configured to boot from SD-card for factory programming and testing. On board peripherals include: - 2x GbE - Lattice ECP3 FPGA connected via PCIe - mSATA RAID1 - USB host - DisplayPort video output - Atmel TPM Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Reinhard Pfau <reinhard.pfau@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-16arm:samsung:trats:fix: Restore proper orientation of TRATS's LCD panelŁukasz Majewski
Before setting: mipi_lcd_device.reverse_panel = 1, the Trats's LCD panel was flipped by 180 degrees. The flip was caused by following change: Exynos: Change get_timer() to work correctly SHA1: 3d00c0cb96ff93a929700b80d89cb905e5ab5315 This commit fixed udelay(), which is necessary (due to HW LCD controller oddity) for mipi-dsi correct operation. As a result the display orientation has been switched. As a follow up, the hwrevision() function has been removed, since it was used only in this particular place. Test HW: Trats Exynos4210 rev 0. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-15PPC MPC83xx: Fix MPC8323ERDB build warningWolfgang Denk
Fix: mpc8323erdb.c: In function 'mac_read_from_eeprom': mpc8323erdb.c:198:3: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Wolfgang Denk <wd@denx.de> cc: Timur Tabi <timur@tabi.org> cc: Kim Phillips <kim.phillips@freescale.com>
2013-07-15Revert "MIPS: Jz4740: Add qi_lb60 board support"Tom Rini
The files board/qi/qi_lb60/qi_lb60.c and include/configs/qi_lb60.h were licensed under the GPL v3 or later, and not v2 or later. As this is incompatible with the project, revert this board support until the responsible parties are available to re-license (if so desired) under GPL v2. Signed-off-by: Tom Rini <trini@ti.com>
2013-07-12Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Fix a trivial conflict in arch/arm/dts/exynos5250.dtsi about gpio and serial. Conflicts: arch/arm/dts/exynos5250.dtsi Signed-off-by: Tom Rini <trini@ti.com>
2013-07-11ARM: tegra: enable LCD panel on VentanaStephen Warren
Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-11ARM: tegra: enable LCD panel on HarmonyStephen Warren
2013-07-11ARM: Tegra: USB: EHCI: Add support for Tegra30/Tegra114Jim Lin
Tegra30 and Tegra114 are compatible except PLL parameters. Tested on Tegra30 Cardhu, and Tegra114 Dalmore platforms. All works well. Signed-off-by: Jim Lin <jilin@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-11ARM: Tegra: FDT: Add USB EHCI function for T30/T114Jim Lin
Add DT node for USB EHCI function. Add support for T30-Cardhu, T30-Beaver, T114-Dalmore boards. Signed-off-by: Jim Lin <jilin@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-10Merge branch 'u-boot-samsung/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-07-10EXYNOS: Resolve the i2c compilation errorAmar
This patch resolves the below mentioned compilation error of i2c driver for non-FDT case Compilation error: s3c24x0_i2c.c: In function 'board_i2c_init': s3c24x0_i2c.c:544:18: error: 'CONFIG_MAX_I2C_NUM' undeclared (first use in this function) s3c24x0_i2c.c:544:18: note: each undeclared identifier is reported only once for each function it appears in s3c24x0_i2c.c:545:3: warning: implicit declaration of function Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Amar <amarendra.xt@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS: Move files from board/samsung to arch/armRajeshwari Shinde
This patch performs the following: 1) Convert the assembly code for memory and clock initialization to C code. 2) Move the memory and clock init codes from board/samsung to arch/arm 3) Creat a common lowlevel_init file across Exynos4 and Exynos5. Converted the common lowlevel_init from assembly to C-code 4) Made spl_boot.c and tzpc_init.c common for both exynos4 and exynos5. 5) Enable CONFIG_SKIP_LOWLEVEL_INIT as stack pointer initialisation is already done in _main. 6) exynos-uboot-spl.lds made common across SMDKV310, Origen and SMDK5250. TEST: Tested SD-MMC boot on SMDK5250 and Origen. Tested USB and SPI boot on SMDK5250 Compile tested for SMDKV310. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS4210: Configure GPIO for uartRajeshwari Shinde
This patch configures the gpio values for UART on Origen and SMDKV310 using pinmux Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-05EXYNOS: LDS file move to commonRajeshwari Shinde
smdk5250-uboot-spl.lds is moved to common folder, so that it can be reused. It is renamed to exynos-uboot-spl.lds Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-07-01omap: cm_t35: Fix cm_t35 for weak splash_screen_prepareRobert Winkler
Signed-off-by: Robert Winkler <robert.winkler@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-06-28Merge branch 'u-boot-imx/master' into 'u-boot-arm/master'Albert ARIBAUD
2013-06-28SMDK5250: Remove reduntant codeRajeshwari Shinde
enum boot_mode is defined twice once in spl.h and also in spl_boot.c, hence removing the same from spl_boot.c and including the header file. Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2013-06-27Merge branch 'master' of git://git.denx.de/u-boot-74xx-7xxTom Rini
2013-06-27PPC 74xx_7xx: Fix build warnings for ELPPC boardWolfgang Denk
Fix: misc.c: In function 'misc_init_r': misc.c:210:3: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] misc.c:211:3: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] misc.c:212:3: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Wolfgang Denk <wd@denx.de>
2013-06-26m28evk: Move README file inside board directoryFabio Estevam
Board specific READMEs should be located inside the respective board directory. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-06-26mx28evk: Move README file inside board directoryFabio Estevam
