bcm11130
bcm11130_nand
Signed-off-by: Steve Rae <srae@broadcom.com>
bcm911360_entphn
bcm911360_entphn-ns
bcm911360k
bcm958300k-ns
bcm958305k
- updates to support Cygnus and NSP board families better
- add functions so CONFIG_ARMV7_NONSEC can be enabled on Cygnus boards
U-Boot has never cared about the type when we get max/min of two
values, but Linux Kernel does. This commit gets min, max, min3, max3
macros synced with the kernel introducing type checks.
Many of references of those macros must be fixed to suppress warnings.
We have two options:
- Use min, max, min3, max3 only when the arguments have the same type
(or add casts to the arguments)
- Use min_t/max_t instead with the appropriate type for the first
argument
Acked-by: Pavel Machek <pavel@denx.de>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
[trini: Fixup arch/blackfin/lib/string.c]
The gdsys hrcon board is based on a Freescale MPC8308 SOC.
It boots from NOR-Flash, kernel and rootfs are stored on
SD-Card.
On board peripherals include:
- 1x GbE (optional)
- Lattice ECP3 FPGA connected via eLBC and PCIe
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Wolfgang Denk found this issue using cppcheck:
(error) Uninitialized variable: fpga_features
The code for this board supports following features:
- Boot media support: NAND flash/SD card/SPI flash
- Support LCD display (optional, disabled by default)
- Support ethernet
- Support USB mass storage
Signed-off-by: Bo Shen <voice.shen@atmel.com>
- Support ethernet
replaces the at91bootstrap code with SPL code.
make the spl image with:
./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin
this writes the length of the spl image into the 6th
execption vector. This is needed from the ROM bootloader.
Reviewed-by: Bo Shen <voice.shen@atmel.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Gose board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of
dram_init_banksize instead.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Lager board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of
Koesch board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of
Alt board is defined CONFIG_SYS_SDRAM_BASE, and this can use a basic function of
* fdt_fixup_mtdparts is called from ft_board_setup
* Run "mtdparts default" to create NAND partition on uboot
* Use mtdparts to create partitions dynamically rather
than using static partitions in device tree
Signed-off-by: Ashish Kumar <Ashish.Kumar@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
* run "mtdparts default" to create NAND, NOR partition on uboot
-A_007662 states that for x1 link width, PCIe2 controller trains in
Gen1 speed while configured for Gen2 speed.
Workaround:Set the width to x1 and speed to Gen2 by writing to
CCSR registers in PBI phase
-A_008007 states that PVR register may show random value.
Workaround: Reset PVR register using DCSR space in PBI phase
Add PBI based software workaround for A_007662 and A_008007
in t104x_pbi.cfg. This is required for SPL-based bootloaders
like NAND-boot, SD-boot, SPI-boot
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
This support of CPLD includes
- Files and register definitions
- Command to switch alternate bank
- Command to switch default bank
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
Add initial support for TBS2910 Matrix ARM miniPC.
Support includes MMC, Ethernet, UARTs, HDMI, USB, SATA, PCI, I2C, RTC.
Signed-off-by: Soeren Moch <smoch@web.de>
Annotate 'static' when appropriate for the variables used locally.
When an invalid USDHC port is passed we should return -EINVAL instead of 0.
Also, return the error immediately on fsl_esdhc_initialize() failure.
This patch will enable the support for SPL on iMX6 SabreSD.
It tested on SD2 and SD3 mmc port (Switch 1 or 2 of SW6)
Signed-off-by: John Tobias <john.tobias.ph@gmail.com>
It's a trim version of mx6q_4x_mt41j128.cfg. It just removed
the related settings for DDR
The i.MX6Q/DL sabreauto board has one NAND socket, set the
CONFIG_NAND_MXS and relevant NAND configurations to enable the
MXS NAND flash driver.
Add board level codes to set IOMUX and clock for GPMI-NAND and
BCH module.
Signed-off-by: Ye.Li <B37916@freescale.com>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Today I got the final board and found out that a different
connector is used as the one on my development board. The
new connector has swaped pins for cd and wp.
This change is tested on a production ready board.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Since kernel 3.15 there are two dtb's for the imx53-qsb board:
imx53-qsb.dtb - For the boards with DA9053 PMIC
imx53-qsrb.dtb - For the boards with MC34708 PMIC
Change the 'fdt_file' dynamically, so that the correct dtb can be used depending
on the board variant.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
The magic bit toucher needs to be updated to reflect the new board Kconfig structure
Signed-off-by: Zoltan HERPAI <wigyori@uid0.hu>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Add support for the 2 ehci controllers found on the sun6i (A31) soc.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Add proper Kconfig options to select the usb Vbus gpio-s, besides moving to
Kconfig being the right thing to do, an added advantage of this is that it
allows for boards without Vbus gpio-s.
Enable the SPL now that we've all the necessary bits in place.
The A31 uses the AXP221 pmic for various voltages.
Signed-off-by: Oliver Schinagl <oliver@schinagl.nl>
Changes in v2:
-Rebase
Changes in v3:
-Add support for all dldo and aldo-s
-Add Kconfig option to select building AXP221 and to select voltage of
dldo and aldo-s
Changes in v4:
-Add axp221_setbits helper function
-Use symbolic names for enabled bits in CTRL1 - CTRL3 registers
This commit adds "select CPU_V7" for some new boards that were not
covered by commit 2e07c249a67e
(kconfig: arm: introduce symbol for ARM CPUs).
Redundant "SYS_CPU" defines and "string" directives should be removed.
Acked-by: Georges Savoundararadj <savoundg@gmail.com>
Now each board selects one of CONFIG_CPU_SH2, CONFIG_CPU_SH3,
CONFIG_CPU_SH4, so let's move CONFIG_SYS_CPU definition to
arch/sh/Kconfig.
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
mcc200 and prs200 are old and have no maintainer. Remove the boards.
This also removes the mcc200 specific 1bpp BMP support from
common/lcd.c
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: York Sun <yorksun@freescale.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Adjust the text to mention that rev C of the board is also supported.
The latest Xilinx tools generate ps7_init files that are explicitly
available under GPL. Change the makefile to allow drop in of those files
for building the SPL.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
Acked-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Reviewed-and-tested-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
cppcheck reports:
[board/esd/common/auto_update.c:458]: (error) Uninitialized variable: cnt
The variable is not really used anywhere, so remove it.
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
The i2c_init function is no longer necessary.
PowerIC connected to channel 1 of sh-i2c, not channel 2.
Alt board was connected Power IC to channel 1 of sh-i2c. Source code that
controls this is already included, but channel 1 of sh-i2c is not enabled.
This enables channel 1 of sh-i2c, and can use.
