path: root/board
2009-07-18ARM: make split_by_variant.sh output more usefulWolfgang Denk
The board/armltd/integrator/split_by_variant.sh script used to print "Configuring for integrator*p board..." no matter which board name was being compiled. This made it difficult to match MAKEALL output to board names. This patch fixes this. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18MIP405T: fix compile problemWolfgang Denk
The "stdio/device: rework function naming convention" patch (commit 52cb4d4f) broke the MIP405T board; this patch fixes it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18CPCI750: fix compile problemWolfgang Denk
Commit bc0d3296 removed ppc_error_no.h from Marvell boards but forgot to update board/esd/cpci750/mv_eth.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-16mpc83xx: MPC837xEMDS: Use hwconfig instead of pci_external_arbiter variableAnton Vorontsov
Since we have simple hwconfig interface now, we don't need pci_external_arbiter variable any longer. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-16mpc83xx: MPC8315ERDB: Use hwconfig for board type selectionAnton Vorontsov
This patch simply converts the board to the hwconfig infrastructure. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-16mpc83xx: MPC837XEMDS: Fixup eSDHC nodes in device treeAnton Vorontsov
fdt_fixup_esdhc() will either disable or enable eSDHC nodes, and also will fixup clock-frequency property. Plus, since DR USB and eSDHC are mutually exclusive, we should only configure the eSDHC if asked through hwconfig. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-16mpc83xx: MPC837XERDB: Add support for FSL eSDHCAnton Vorontsov
This patch adds support for eSDHC on MPC837XERDB boards. The WP switch doesn't seem to work on RDB boards though, the WP pin is always asserted (can see the pin state when it's in GPIO mode). FSL DR USB and FSL eSDHC are mutually exclusive because of pins multiplexing, so user should specify 'esdhc' or 'dr_usb' options in the hwconfig environment variable to choose between the devices. p.s. Now we're very close to a monitor len limit (196 bytes left using gcc-4.2.0), so also increase the monitor len by one sector (64 KB). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-16Merge branch 'asm-generic' of git://git.denx.de/u-boot-microblazeWolfgang Denk
2009-07-14aria: enable NAND flash supportWolfgang Denk
2009-07-14MPC512x: factor out common codeWolfgang Denk
Now that we have 3 boards for the MPC512x it turns out that they all use the very same fixed_sdram() code. This patch factors out this common code into cpu/mpc512x/fixed_sdram.c and adds a new header file, include/asm-ppc/mpc512x.h, with some macros, inline functions and prototype definitions specific to MPC512x systems. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-07-14mecp5123: fix build errorWolfgang Denk
The mecp5123 board did not compile because the MSCAN Clock Control Registers were missing; these got added, but as an array instead of 4 individual registers. Adapt the code so it builds. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-07-14Merge branch 'master' of /home/wd/git/u-boot/masterWolfgang Denk
2009-07-13Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-07-13Merge branch 'master' of git://git.denx.de/u-boot-shWolfgang Denk
2009-07-12versatile: update config and merge to cfi flash driverJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Peter Pearse <peter.pearse@arm.com> Cc: Catalin Marinas <catalin.marinas@arm.com>
2009-07-12at91: Introduction of at91sam9g10 SOC.Sedji Gaouaou
AT91sam9g10 is an ARM 926ej-s SOC. It is an evolution of the at91sam9261 with a faster clock speed: 266/133MHz. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-12at91: Introduction of at91sam9g45 SOC.Sedji Gaouaou
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz. It embeds USB high speed host and device, LCD, DDR2 RAM, and a full set of peripherals. The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. On the board you can find 2 USART, USB high speed, a 480*272 LG lcd, ethernet, gpio/joystick/buttons. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
2009-07-12OMAP3 pandora: Fix CKE1 MUX setting to allow self-refreshGrazvydas Ignotas
Pandora is using both SDRC CSes. The MUX setting is needed for the second CS clock signal to allow the 2 RAM parts to be put in self-refresh correctly. Based on similar patch for beagle and overo by Jean Pihet and Steve Sakoman.
2009-07-12OMAP3 pandora: setup pulls for various GPIOsGrazvydas Ignotas
Set pullups or pulldowns for GPIOs which need them. Disable them for others, which have external pulls. Also make disabled pull setting consistent (some pins had type set to "up" even if pull type selection was disabled).
2009-07-12OMAP3 pandora: setup pin mux for pins used on rev3 boardsGrazvydas Ignotas
Setup pin mux for GPIO pins connected on rev3 or later boards. Also change NUB2 IRQ pin. This should not affect older boards because they don't have any nubs (analog controllers) attached to them.
2009-07-12OMAP3 pandora: pin mux cleanupGrazvydas Ignotas
Remove configuration of not unused pins, effectively leaving them in safe mode.
2009-07-11sh: Add support ESPT-GIGA boradNobuhiro Iwamatsu
ESPT-Giga is SH7763-based reference board. Board support is relatively sparse, presently supporting serial, gigabit ethernet, USB host, and MTD. More information (in Japanese) available at: http://www.cente.jp/product/cente_hard/ESPT-Giga.html Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-10board support patch for phyCORE-MPC5200B-tinyJon Smirl
Add support for the Phytec phyCORE-MPC5200B-tiny. Code originally from Pengutronix.de. Created CONFIG_SYS_ATA_CS_ON_TIMER01 define for when IDE CS is on Timer 0/1 Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2009-07-09asm-generic: Consolidate errno.h to asm-generic/errno.hMichal Simek
This patch use blackfin errno.h implementation which correspond Linux kernel one. MIPS implemetation is different that's why I keep it. I removed ppc_error_no.h from Marvell boards which was the same too. I have got ack from ppc40x, blackfin, arm, coldfire and avr custodians. Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-08Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-07-08ppc4xx: Fix FDT EBC mappings on CanyonlandsFelix Radensky
This patch fixes 2 problems with FDT EBC mappings on Canyonlands. First, NAND EBC mapping was missing, making Linux NAND driver unusable on this board. Second, NOR remapping code assumed that NOR is always on CS0, however when booting from NAND NOR is on CS3. Signed-off-by: Felix Radensky <felix@embedded-sol.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-08sh: Revised the build with newest compilerNobuhiro Iwamatsu
The check of data became severe from newest gcc. This patch checked in gcc-4.2 and 4.3 . Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all sh boards use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk tested on r2dplus Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh: make the linker scripts more genericJean-Christophe PLAGNIOL-VILLARD
currently we need to sync the linker script enty and TEXT_BASE manualy and the reloc_dst is based on it instead provide it now from the ldflags tested on r2dplus Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-07-08sh7785lcr: fix out of tree buildJean-Christophe PLAGNIOL-VILLARD
2009-07-07mtd: nand: new base driver for memory mapped nand devicesMike Frysinger
The BF537-STAMP Blackfin board had a driver for working with NAND devices that are simply memory mapped. Since there is nothing Blackfin specific about this, generalize the driver a bit so that everyone can leverage it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-07davinci_nand chipselect/init cleanupDavid Brownell
Update chipselect handling in davinci_nand.c so that it can handle 2 GByte chips the same way Linux does: as one device, even though it has two halves with independent chip selects. For such chips the "nand info" command reports: Device 0: 2x nand0, sector size 128 KiB Switch to use the default chipselect function unless the board really needs its own. The logic for the Sonata board moves out of the driver into board-specific code. (Which doesn't affect current build breakage if its NAND support is enabled...) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-07Coding style cleanup; update CHANGELOGWolfgang Denk
2009-07-07Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
Conflicts: drivers/spi/Makefile Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-07Merge branch 'master' of git://git.denx.de/u-boot-mpc5xxxWolfgang Denk
2009-07-06MX31: Add NAND SPL boot support to i.MX31 PDK board.Magnus Lilja
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2009-07-06arm nomadik: allow Nand and OneNand to coexistsAlessandro Rubini
The evaluation kit has both Nand and OneNand, both drivers are there and the two configurations only select a different default for the jffs partition. This adds the OneNand driver and cleans up storage. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2009-07-06arm nomadik: rename board to nhk8815Alessandro Rubini
This is an error in my side in the initial submission: nobody calls it ""nmdk8815", it's "nomadik hardware kit", nhk8815, instead. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com>
2009-07-06xscale: add support for the polaris boardStefano Babic
The Polaris board is based on the TrizepsIV module of Keith & Koep (http://www.keith-koep.com). Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-07-06xscale: fix USB initialization for Trizepsiv moduleStefano Babic
Due to change in the usb_board_init() prototype, the USB for the TrizepsIV was not correctly initialized. Removed dummy print from usb_board_stop(). Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-07-06at91: Add esd gmbh MEESC board supportDaniel Gorsulowski
This patch adds support for esd gmbh MEESC board. The MEESC is based on an Atmel AT91SAM9263 SoC. Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
2009-07-06MX31: Add basic support for Freescale i.MX31 PDK board.Magnus Lilja
Add support for Freescale's i.MX31 PDK board (a.k.a. 3 stack board). This patch assumes that some other program performs the actual NAND boot. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com> Acked-by: Fabio Estevam <fabioestevam@yahoo.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-07-06OMAP3EVM: fix typo. replace CS6 by CS5, no functionality changeMatthias Ludwig
Signed-off-by: Matthias Ludwig <mludwig@ultratronik.de>
2009-07-06at91sam9260/9263: add back up for the rst(reset controller).Sedji Gaouaou
On the boards at91sam9260ek, at91sam9263ek and afed9260, the rstc register was set to 0 after being set to 500 ms for the PHY reset. Do backup the old reset length and restore it after the MACB initialisation. Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com> Signed-off-by: Stelian Pop <stelian@popies.net>
2009-07-03fsl: Fix compiler warnings from gcc-4.4 in sys_eeprom codeKumar Gala
sys_eeprom.c: In function 'do_mac': sys_eeprom.c:323: warning: dereferencing type-punned pointer will break strict-aliasing rules sys_eeprom.c: In function 'mac_read_from_eeprom': sys_eeprom.c:395: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-0283xx: Replace CONFIG_ECC_INIT_VIA_DDRC referencesPeter Tyser
Update 83xx architecture's CONFIG_ECC_INIT_VIA_DDRC references to CONFIG_ECC_INIT_VIA_DDRCONTROLLER, which other Freescale architectures use Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-0186xx: XPedite5170 board supportPeter Tyser
Initial support for Extreme Engineering Solutions XPedite5170 - a MPC8640-based 3U VPX single board computer with a PMC/XMC site. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-01fsl_dma: Break out common memory initialization functionPeter Tyser
2009-07-018xxx: Move dma_init() call to common codePeter Tyser
