path: root/board
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19Drop CONFIG_ISA_KEYBOARDSimon Glass
This option is mentioned but does not do anything. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19input: Support the German keymapSimon Glass
Add support for the German keymap, taken from i8042.c. This can be selected when the input library it initialised. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19sandbox: add a sandbox timer and basic testThomas Chou
Add a sandbox timer which get time from host os and a basic test. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-19input: Add the keycode translation tables separatelySimon Glass
Require the caller to add the keycode translation tables separately so that it can select which ones to use. In a later patch we will add the option to add German tables. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-18km/powerpc: fix ft_board_setup prototype for km82xx & km83xxValentin Longchamp
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18powerpc/83xx: add support for kmtegr1 boardValentin Longchamp
This board uses the same CPU (8309) as VECT1. The memory however is different since it has NAND Flash, the NOR Flash partitioning is different and of course the FPGAs as well. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Christoph Dietrich <christoph.dietrich@keymile.com>
2015-11-18board/keymile/km82xx: setting dip_switch 3 and 4 will run bootloaderBagavathiannan Palanisamy
Setting dip_switch 3 and 4 also will run bootloader in COGE3 and COGE6 It is required remove local mgmt IP address, when DIP Switch PIN3 is enabled. DIP Switch 4 also enabled to avoid u-boot update in future for DIP switch enhancements. Signed-off-by: Bagavathiannan Palanisamy <Bagavathiannan.Palanisamy@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18km/powerpc82xx: remove unused functionHolger Brunck
commit 0a4f88b98 removed the usage of our setports function, but the function itself were not removed. So toss it it's dead code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18km/powerpc: remove unneeded definesHolger Brunck
We use CONFIG_OF_LIBFDT and CONFIG_OF_BOARD_SETUP on all our powerpc targets, so there is no need to check these defines within our C code. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18powerpc/82xx/km: add testpin detection for mgcoge3neHolger Brunck
On mgcoge3ne we also want to start the test application if the testpin is asserted. But we don't have a full POST test support yet. So simply add a function to read the testpin value. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18powerpc/82xx: make set/get_pin for km82xx more flexibleHolger Brunck
The get_pin and set_pin funciton was only used for pins on Port D and therefore the value was hard coded in the function. Enhance this with a parameter, that we are able to use this functions for other ports too. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18powerpc/83xx: add support for kmtepr2 boardChristoph Dietrich
This board is similar to TUXX1, but it has differend FPGAs. Signed-off-by: Christoph Dietrich <christoph.dietrich@keymile.com> Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18km/scripts: search for kernel/DTBs at serverip:/PRODUCTNAME via TFTP in ↵Tobias Müller
develop mode Search for the kernel and DTBs in a folder named PRODUCTNAME (found in the IVM) at the TFTP server instead of the u-boot boardname. Signed-off-by: Tobias Müller <Tobias.Mueller@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-18km/scripts: load fdt_bid_kwkey.dtb when working with tftpHolger Brunck
When loading the dtb file via tftp we should load the one which matches boardId and hwKey and not a common one for the boardname. We have boards were different hwKeys are used and then we may load an incorrect dtb file. If no fdt_bid_kwkey.dtb file is not a fallback to boardname.dtb is used. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Tobias Müller <Tobias.Mueller@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-18arm/km_kirkwood: fix the #ifdef for KM_COGE5UN dip switchValentin Longchamp
There was a small typo for KM_COGE5UN that resulted in the dip switch not to behave as expected. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18arm/mgcoge3un: check dip_switch at startupHolger Brunck
Similar to kmcoge5un we need to check the dip switch at startup connected to the kirkwood at MPP43. If it's set we need to set the actual_bank to zero to boot from SW bank zero. Additional to kmcoge5un we need to check also the pin in misc_init to decide wether we wait for the ne to start or not. If the dip_switch is set we don't wait and continue immediately. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18arm/km: Fix LED configuration for 88E1118R PHY (PIGGY3)Tobias Müller
Configure PHY LED register for Marvell 88E1118R PHY used on PIGGY3 to match with printed descriptions on PCB Signed-off-by: Tobias Müller <Tobias.Mueller@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> [trini: Fix typo, CRTL_PAGE -> CTRL_PAGE] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-18board/ti/am335x: add support for BeagleBone Greenrobertcnelson@gmail.com
SeeedStudio BeagleBone Green (BBG) is clone of the BeagleBone Black (BBB) minus the HDMI port and addition of two Grove connectors (i2c2 and usart2). This board can be identified by the 1A value after A335BNLT (BBB) in the at24 eeprom: 1A: [aa 55 33 ee 41 33 33 35 42 4e 4c 54 1a 00 00 00 |.U3.A335BNLT....|] http://beagleboard.org/green http://www.seeedstudio.com/wiki/Beaglebone_green In Mainline Kernel as of: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?id=79a4e64c679d8a0b1037da174e4aea578c80c4e6 Patch tested on BeagleBone Black (rev C) and BeagleBone Green (production model) Signed-off-by: Robert Nelson <robertcnelson@gmail.com> CC: Tom Rini <trini@konsulko.com> CC: Jason Kridner <jkridner@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-18omap3: cm-t3517: add board specific get_board_rev()Dmitry Lifshitz
CM-T3517 has several HW revisions. Add board specific get_board_rev() callback to retrieve revision number. Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il> Reviewed-by: Igor Grinberg <grinberg@compulab.co.il>
2015-11-18arm: mx6: cm-fx6: define fallback boot devices for splNikita Kiryanov
Use spl alternate boot device feature to define fallback to the main boot device as it is defined by hardware. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2015-11-18board: ti: beagle_x15: Rename to indicate support for TI am57xx evmsKipisz, Steven
BeagleBoard X15 (http://beagleboard.org/x15) support in u-boot does actually support two different platform configuration offered by TI. In addition to BeagleBoard X15, it also supports the TMDXEVM5728 (or more commonly known as AM5728-evm). Information about the TI AM57xx EVM can be found here http://www.ti.com/tool/tmdxevm5728 The EVM configuration is 1-1 compatible with BeagleBoard X15 with the additional support for mPCIe, mSATA, LCD, touchscreen, Camera, push button and TI's wlink8 offering. Hence, we rename the beagle_x15 directory to am57xx to support TI EVMs that use the AM57xx processor. By doing this we have common code reuse. This sets the stage to have a common u-boot image solution for multiple TI EVMs such as that already done for am335x and am437x. This sets the stage for upcoming multiple TI EVMs that share the same code base. NOTE: Commit eae7ae185335 ("am437x: Add am57xx_evm_defconfig using CONFIG_DM") introduced DT support for beagle_x15 under am57xx_evm platform name. However, this ignored the potential confusion arising for users as a result. To prevent this, existing beagle_x15_defconfig is renamed as am57xx_evm_nodt_defconfig to denote that this is the "non device tree" configuration for the same platform. We still retain am57xx-beagle-x15.dts at this point, since we just require the common minimum dts. As a result of this change, users should expect changes in build procedures('make am57xx_evm_nodt_defconfig' instead of 'make beagle_x15_defconfig'). Hopefully, this would be a one-time change. Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Schuyler Patton <spatton@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-11-17Merge git://git.denx.de/u-boot-marvellTom Rini
2015-11-17arm: mvebu: a38x: serdes specification cleanupKevin Smith
Instead of allocating space in the driver for the serdes specification table, just allow the board file to set a pointer to it. Also, allow the board to only specify the lanes that are used instead of including unused lanes. Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-11-17arm: mvebu: a38x: Remove unsupported topologiesKevin Smith
A lot of extra configuration information was left over in the Marvell serdes and DDR3 initialization code for boards that U-boot does not support. Remove this extra config information, and the concept of fixing up board topologies with information loaded from an EEPROM. If this needs to be done, it should be handled in the board file, not in core code. Signed-off-by: Kevin Smith <kevin.smith@elecsyscorp.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-11-18board: axs10x switch serial port and Ethernet to driver modelAlexey Brodkin
With this change Synopsys DesignWare SDP board is switched to driver model for both serial port (serial_dw) and Ethernet (Designware GMAC). This simplifies include/configs/axs101.h and allows for reuse of Linux's Device Tree description. For simplicity Linux's .dts files are not blindly copied but only very few extracts of them are really used (those that are supported in U-Boot at the moment). Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-11-16Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-11-16arm: mx6: cm-fx6: add splash locations to cm-fx6Nikita Kiryanov
Add the following splash locations to cm-fx6: * filesystem formatted mmc * filesystem formatted usb * filesystem formatted sata Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-11-16splash_source: add support for filesystem formatted mmcNikita Kiryanov
Add support for loading splash image from an SD card formatted with a filesystem. Update boards to maintain original behavior where needed. Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Tom Rini <trini@konsulko.com> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2015-11-13x86: qemu: Convert to use driver model ethBin Meng
Move to driver model for ETH (e1000) on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-12Merge branch 'master' of git://git.denx.de/u-boot-tegraTom Rini
2015-11-12pengwyn: nand and ethernet fixesVincent BENOIT
-> Add National instrument ethernet transceiver configuration used (DP83848) -> Change cpsw slave phy address -> modify nand configuration to use the correct ECC and correct nand features
2015-11-12board: gdsys: Enable osd on output onlyDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12board: gdsys: Add osdsize commandDirk Eibach
osdsize adjusts the gdsys IHS osd dimensions in characters. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12hrcon: Add fan controllersDirk Eibach
2015-11-12hrcon: Add support for the DH variantDirk Eibach
hrcon DH(dual head) has two video outputs per FPGA. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12hrcon: Fix videoboard i2c setupDirk Eibach
- i2c addresses for the videoboard port expanders were wrong. - the fpga reset signal was not initialized. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12hrcon: Use generic ioep-fpga supportDirk Eibach
The strider platform moved some generic code into ioep-fpga.c. Make use of that on hrcon platform. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12mpc83xx: Add strider boardDirk Eibach
The gdsys strider board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card. On board peripherals include: - 1x 10/100 Mbit/s Ethernet (optional) - Lattice ECP3 FPGA connected via eLBC Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> [trini: Drop setting CONFIG_SYS_GENERIC_BOARD, this is always true now] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-12iocon: reset FPGAs in last_stage_init()Reinhard Pfau
- Reset FPGAs in last_stage_init() Signed-off-by: Reinhard Pfau <pfau@gdsys.de> Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12controlcenterd: Disable sideband clocksDirk Eibach
2015-11-12dlvision-10g: Support displayportDirk Eibach
Support dlvision-10g hardware with displayport output. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12board: gdsys: Consider DP501 limits on link trainingDirk Eibach
DP501 only supports DP 1.1a. Limit settings for link bandwidth and lane count to values allowed by DP 1.1a. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12board: gdsys: Increase DP501 I2C retry intervalDirk Eibach
With Club 3D dual link adapter there are AUX-channel timeouts when EDID is read. Increasing retry interval time to max (400us) fixes this. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-12board: gdsys: Configure DP501 SPDIF inputDirk Eibach
2015-11-12board/ti/am335x: beaglebone stop muxing i2c1_pin_muxrobertcnelson@gmail.com
On the BeagleBone these i2c1 pins are routed to the expanasion header, where they can be defined as either pr1_usart0_Xxd/pwm0/spi0/i2c1, dont assume i2c1 Fixes: https://e2e.ti.com/support/arm/sitara_arm/f/791/p/313894/1387696 Signed-off-by: Robert Nelson <robertcnelson@gmail.com> Reported-by: Matthijs van Duin <matthijsvanduin@gmail.com> CC: Tom Rini <trini@konsulko.com>
2015-11-12board/BuR/kwb: use bootvx(...) (with bootline feature) instead go(...)Hannes Petermaier
Since we don't have for sure a valid IP-setup during board_late_init(...) because it maybe allready stored in environment or not, we cannot form a proper vxWorks bootline at this place. So we move to the way, forming the bootline just before executing/launching vxWorks. To do this we use the bootvx command instead go. We only have to form the "othbootargs" environment variable, the rest is done pretty good by the "bootvx" commannd. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-12imx: mx7dsabresd: support lcdifPeng Fan
Support LCDIF for mx7dsabresd board: 1. Add pinmux settings 2. Add VIDEO related macro definition and videomode env settings. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Adrian Alonso <aalonso@freescale.com>
2015-11-12imx: mx6ul_14x14_evk: support lcdif displayPeng Fan
Support lcdif display: 1. Add pinmux and pad settings for LCDIF 2. Introduce setup_lcd to do the settings for LCDIF 3. Enable VIDEO related macros in board header files 4. Add a new env videomode which is needed by mxsfb.c. The settings for videomode in this patch is for TFT43AB. 5. Tested on mx6ul 14x14/9x9 evk. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de>
2015-11-12xfi3: correct function namePeng Fan
board_mxsfb_system_setup must be renamed mxsfb_system_setup. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de>
