path: root/board
2015-02-17Merge branch 'master' of git://git.denx.de/u-boot-avr32Tom Rini
2015-02-17avr32: convert to dram_init()Andreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-17avr32: rename mmu.h definitionsAndreas Bießmann
Prefix mmu.h PAGE_xxx definitions with MMU_ in order to prevent a naming conflict with other definitions. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-02-17Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-02-16KM/IVM: remove ivm_read_eeprom(void)Valentin Longchamp
This is not used anymore since the procedure was split into a simple read function and a later alaysis. The ivm_read_eeprom name is now used for the previous ivm_simple_read_eeprom function. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-02-1682xx/km82xx: read the IVM eeprom earlierValentin Longchamp
This allows to define the ethaddr env variable according to the the IVM content by reading the IVM in misc_init_r. Later, when HUSH is available the content read earlier is analyzed to populate some non env variables. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-02-1683xx/km83xx: read the IVM eeprom earlierValentin Longchamp
2015-02-1685xx/kmp204x: read the IVM eeprom earlierValentin Longchamp
2015-02-16kirkwood/km_arm: read the IVM eeprom earlierValentin Longchamp
2015-02-16KM/IVM: split the IVM reading and parsing in 2 partsValentin Longchamp
This allows to first read the IVM content (earlier in the boot sequence) and define the ethaddr env variable thanks to the ivm_read_eepromi(). Later, the IVM content can be parsed and used to define some hush variables, when the hush subsystem is available thanks to ivm_analyze_eeprom(). To avoid the HW read to happen twice, the buffer passed to ivm_read_eeprom() has to be reused by ivm_analyze_eeprom (and thus allocated before calling ivm_read_eeprom()). Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-02-16sunxi: Normalise FEL supportSimon Glass
Make sunxi's FEL code fit with the normal U-Boot boot sequence instead of creating its own. There are some #ifdefs required in start.S. Future work will hopefully remove these. This series is available at u-boot-dm, branch sunxi-working. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16arm: Allow lr to be saved by board codeSimon Glass
The link register value can be required on some boards (e.g. FEL mode on sunxi) so use a branch instruction to jump to save_boot_params() instead of a branch link. This requires a branch back to save_boot_params_ret so adjust the users to deal with this. For exynos just drop the function since it doesn't do anything. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16sunxi: MAINTAINERS: drop no longer existing felconfig-s from MAINTAINERSHans de Goede
2015-02-16sunxi: Ampe A76 supportPaul Kocialkowski
Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-16keystone2: ddr3: eliminate using global ddr3_size variableVitaly Andrianov
KS2 ddr3 initialization uses ddr3_size global variable before u-boot relocation. Even if the variable is not being used after relocation, writing to it corrupts relocation table. This patch removes the global ddr3_size variable and uses local one instead. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Tested-by: Nishanth Menon <nm@ti.com>
2015-02-16ARM: DRA7: EMIF: Update SDRAM_REF_CTRL register valueLokesh Vutla
The value in SDRAM_REF_CTRL controls the delay time between the initial rising edge of DDR_RESETn to rising edge of DDR_CKE (JEDEC specs this as 500us). In order to achieve this, SDRAM_REF_CTRL should be written with a value corresponding to 500us delay before starting DDR initialization sequence, and configure proper value at the end of sequence. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-02-16Merge git://git.denx.de/u-boot-marvellTom Rini
2015-02-16lsxl: add a README fileMichael Walle
The README describes the recovery method which can be used if the NAS box is not reachable anymore. Addionally, it describes the different boot scripts. Signed-off-by: Michael Walle <michael@walle.cc>
2015-02-13Merge git://git.denx.de/u-boot-samsungTom Rini
2015-02-13Merge git://git.denx.de/u-boot-dmTom Rini
2015-02-13Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2015-02-13odroid: fix g2d sclk rateJoonyoung Shim
G2D core should be provided 200MHz clock rate. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-02-13samsung: board: support eMMC reset using DTJoonyoung Shim
Some exynos boards require special handling of nRESET_OUT line for eMMC memory to perform complete reboot e.g. Odroid X2/U3/XU3 boards. This will support eMMC reset using DT from reset_misc of samsung common board file. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-02-13ARM: rmobile: silk: Remove initialization of ACTLR.SMPNobuhiro Iwamatsu
Initialization of ACTLR.SMP is in lowlevel_init. This remove duplicate function. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-13arm: rmobile: Add missed header file for Silk boardVladimir Barinov
This file was missed in the commit https://patchwork.ozlabs.org/patch/427801/ Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-13arm: rmobile: Add SILK board supportVladimir Barinov
SILK is an entry level development board based on R-Car E2 SoC (R8A7794) This commit supports the following peripherals: - SCIF, I2C, Ethernet, QSPI, MMC, USB Host Signed-off-by: Vladimir Barinov <vladimir.barinov@cogentembedded.com> Reviewed-by: Tom Rini <trini@ti.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: omap3: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: exynos: Move driver model CONFIGs to KconfigSimon Glass
2015-02-12powerpc: ppc4xx: Enable CONFIG_DISPLAY_BOARDINFOStefan Roese
This also displays the "Board:" line in the bootup text with the generic board support code. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: powerpc: ppc4xx: Move glacier to use driver model for serialSimon Glass
Adjust Kconfig to default to driver model for glacier, canyonlands and arches. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Use CONFIG_OF_CONTROL for canyonlands boardsSimon Glass
Enable CONFIG_OF_CONTROL so that U-Boot on these three boards uses a device tree for its configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Add ramboot config for glacierSimon Glass
Add a new ramboot config for glacier so that it is possible to test U-Boot loaded over Ethernet instead of using JTAG. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: Move CANYONLANDS/GLACIER/ARCHES to KconfigSimon Glass
Move these options to Kconfig and remove them from the CONFIG files. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12powerpc: ppc4xx: canyonlands: config: Tidy up CONFIGs and config.mkSimon Glass
Many CONFIG options have an unnecessary value of 1. CONFIG_440 is set in the various board config files. Also simplify the CONFIG_440 check in config.mk Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-x86Tom Rini
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2015-02-10Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
Conflicts: include/splash.h Signed-off-by: Tom Rini <trini@ti.com>
2015-02-10Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-02-10lcd: dt: extract simplefb supportNikita Kiryanov
We now have api functions that can support compiling simplefb code as its own module. Since this code is not part of the display functionality, extract it to its own file. Raspberry Pi is updated to accommodate the changes. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bo Shen <voice.shen@atmel.com> Tested-by: Josh Wu <josh.wu@atmel.com> Cc: Simon Glass <sjg@chromium.org> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stephen Warren <swarren@wwwdotorg.org>
2015-02-10mx53loco: Fix boot hang during reboot stress testFabio Estevam
Currently by running the following test: => setenv bootcmd reset => save => reset , we observe a hang after approximately 20-30 minutes of stress reboot test. Investigation of this issue revealed that when a single DDR chip select is used, the hang does not happen. It only happens when the two chip selects are active. MX53 reference manual states at "28.6.2 Memory ZQ calibration sequence": "The controller must keep the memory lines quiet (except for CK) for the ZQ calibration time as defined in the Jedec (512 cycles for ZQCL after reset, 256 for other ZQCL and 64 for ZQCS)." According to the SDE_0 and SDE_1 bit descriptions from register ESDCTL_ESDCTL: "Writing 1 to SDE0 or SDE1 will initiate power up delays as JEDEC defines. Power up delays are a function of the configured memory type (DDR2/DDR3/LPDDR2)" So make sure to activate one chip select at time (CS0 first and then CS1 later), so that the required JEDEC delay is respected for each chip select. With this change applied the board has gone through three days of reboot stress test without any hang. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-02-10imx: mx6qsabreauto: Change to use common GPMI IO clock functionYe.Li
Since a clock function setup_gpmi_io_clk is implemented for GPMI IO clock settings, change to use this common function in GPMI setup. Signed-off-by: Ye.Li <B37916@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-02-09Merge branch 'microblaze' of git://git.denx.de/u-boot-microblazeTom Rini
2015-02-09Merge git://git.denx.de/u-boot-arcTom Rini
2015-02-09microblaze: Move architecture to use generic board initMichal Simek
Compile code with -fPIC to get GOT. Do not build SPL with fPIC because it increasing SPL size for nothing. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-02-09arc: add selection of endianess in KconfigAlexey Brodkin
This change allows to keep board description clean and minimalistic. This is especially helpful if one board may house different CPUs with different features. It is applicable to both FPGA-based boards or those that have CPUs mounted on interchnagable daughter-boards. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-07ARM: atmel: sama5d4_xplained: enable spl supportBo Shen
Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-02-07ARM: atmel: sama5d4ek: enable SPL supportBo Shen
The sama5d4ek support boot up from NAND flash, SD/MMC card and also the SPI flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2015-02-06x86: Add basic Intel Galileo board supportBin Meng
New board/intel/galileo board directory with minimum codes, plus board dts, defconfig and configuration files. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-06x86: Add support for Intel Minnowboard MaxSimon Glass
This is a relatively low-cost x86 board in a small form factor. The main peripherals are uSD, USB, HDMI, Ethernet and SATA. It uses an Atom 3800 series CPU. So far only the dual core 2GB variant is supported. This uses the existing FSP support. Binary blobs are required to make this board work. The microcode update is included as a patch (all 3000 lines of it). Change-Id: I0088c47fe87cf08ae635b343d32c332269062156 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
