path: root/board
2014-11-25x86: Remove board_early_init_r()Simon Glass
This function is not needed. Remove it to improve the generic init sequence slightly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-24Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
2014-11-24Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-11-24Merge git://git.denx.de/u-boot-dmTom Rini
Conflicts: drivers/serial/serial-uclass.c Signed-off-by: Tom Rini <trini@ti.com>
2014-11-24Merge git://git.denx.de/u-boot-x86Tom Rini
Conflicts: arch/x86/cpu/Makefile Signed-off-by: Tom Rini <trini@ti.com>
2014-11-24mx6boards: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Cc: Eric Benard <eric@eukrea.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-24nitrogen6x: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Cc: Eric Nelson <eric.nelson@boundarydevices.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-24ot1200: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-24arm: mx6: cm_fx6: implement board specific sata stopNikita Kiryanov
Provide board specific implementation for sata stop command for cm_fx6. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de>
2014-11-24gw_ventana: Use the generic spl_sd.cfgFabio Estevam
gw_ventana can boot from SPI or NAND and both of these interfaces boot from the same 0x400 offset. This means that we could simplify the code and replace the custom gw_ventana.cfg with the generic spl_sd.cfg, as it provides the same boot offset of 0x400. Cc: Tim Harvey <tharvey@gateworks.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-24ARM: Add arch/arm/cpu/armv7/Kconfig with non-secure and virt optionsHans de Goede
Add arch/arm/cpu/armv7/Kconfig with non-secure and virt options, this is a preparation patch for adding an env variable to choose between secure / non-secure boot on non-secure boot capable systems, specifically this prepares for adding CONFIG_ARMV7_BOOT_SEC_DEFAULT as a proper Kconfig option. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-23fs: API changes enabling extra parameter to return size of type loff_tSuriyan Ramasami
The sandbox/ext4/fat/generic fs commands do not gracefully deal with files greater than 2GB. Negative values are returned in such cases. To handle this, the fs functions have been modified to take an additional parameter of type "* loff_t" which is then populated. The return value of the fs functions are used only for error conditions. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Update board/gdsys/p1022/controlcenterd-id.c, drivers/fpga/zynqpl.c for changes] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23fat: Prepare API change for files greater than 2GBSuriyan Ramasami
Change the internal FAT functions to use loff_t for offsets. Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> [trini: Fix fs/fat/fat.c for min3 updates] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23board/esd/common/auto_update.c: Use <flash.h>Tom Rini
A number of prototypes here are now found in <flash.h>. use. Signed-off-by: Tom Rini <trini@ti.com>
2014-11-23kbuild: Descend into SOC directory from CPU directoryMasahiro Yamada
Some CPUs of some architectures have SOC directories. At present, the build system directly descends into SOC directories from the top Makefile, but it should generally descend into each directory from its parent directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-11-23ARM: bcm: Enable bcm11130 boardsSteve Rae
bcm11130 bcm11130_nand Signed-off-by: Steve Rae <srae@broadcom.com>
2014-11-23ARM: bcm: Enable five Cygnus boardsSteve Rae
bcm911360_entphn bcm911360_entphn-ns bcm911360k bcm958300k-ns bcm958305k - updates to support Cygnus and NSP board families better - add functions so CONFIG_ARMV7_NONSEC can be enabled on Cygnus boards Signed-off-by: Steve Rae <srae@broadcom.com>
2014-11-23linux/kernel.h: sync min, max, min3, max3 macros with LinuxMasahiro Yamada
U-Boot has never cared about the type when we get max/min of two values, but Linux Kernel does. This commit gets min, max, min3, max3 macros synced with the kernel introducing type checks. Many of references of those macros must be fixed to suppress warnings. We have two options: - Use min, max, min3, max3 only when the arguments have the same type (or add casts to the arguments) - Use min_t/max_t instead with the appropriate type for the first argument Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Pavel Machek <pavel@denx.de> Acked-by: Lukasz Majewski <l.majewski@samsung.com> Tested-by: Lukasz Majewski <l.majewski@samsung.com> [trini: Fixup arch/blackfin/lib/string.c] Signed-off-by: Tom Rini <trini@ti.com>
2014-11-21mx53ard: Fix error handling in board_mmc_init()Fabio Estevam
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-21mx53evk: Fix error handling in board_mmc_init()Fabio Estevam
2014-11-21mx53smd: Fix error handling in board_mmc_init()Fabio Estevam
2014-11-21mx6qarm2: Fix error handling in board_mmc_init()Fabio Estevam
2014-11-21mx51evk: Fix error handling in board_mmc_init()Fabio Estevam
2014-11-21tbs2910: Fix error handling in board_mmc_init()Soeren Moch
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure. Based on similar patches by Fabio Estevam for mx6sabresd, mx53loco, wandboard Signed-off-by: Soeren Moch <smoch@web.de> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-21dm: tegra: Add platform data for the GPIO driverSimon Glass
Add platform data for the GPIO driver. It doesn't need to contain anything since the GPIO driver will actually use information from the CONFIGs for now. This merely serves to ensure that the GPIO driver is bound. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21dm: at91: Add myself as maintainer for snapper9260Simon Glass
The old maintainer has left, so take this over. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21dm: at91: Convert snapper9260 to use driver modelSimon Glass
Convert this at91sam9260-based board to use driver model. This should serve as an example for other similar boards. Serial and GPIO are supported so far. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-11-21x86: Rename chromebook-x86 to corebootSimon Glass
Rename this vendor since it is intended to be used on any platform where coreboot runs at reset and then loads U-Boot. So far it is only tested on link. When other boards are supported it is likely that we will need to move to multiple board names, all under the 'coreboot' vendor. So while it would be possible to remove the vendor for now, that would be short-sighted. Suggested-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: chromebook_link: Enable GPIO supportSimon Glass
Enable GPIO support and provide the required GPIO setup information to the driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: chromebook_link: Implement CAR support (cache as RAM)Simon Glass
Add support for CAR so that we have memory to use prior to DRAM init. On link there is a total of 128KB of CAR available, although some is used for the memory reference code. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21x86: Emit post codes in startup code for ChromebooksSimon Glass
On x86 it is common to use 'post codes' which are 8-bit hex values emitted from the code and visible to the user. Traditionally two 7-segment displays were made available on the motherboard to show the last post code that was emitted. This allows diagnosis of a boot problem since it is possible to see where the code got to before it died. On modern hardware these codes are not normally visible. On Chromebooks they are displayed by the Embedded Controller (EC), so it is useful to emit them. We must enable this feature for the EC to see the codes, so add an option for this. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2014-11-21x86: Add chromebook_link boardSimon Glass
This board is a 'bare' version of the existing 'link 'board. It does not require coreboot to run, but is intended to start directly from the reset vector. This initial commit has place holders for a wide range of features. These will be added in follow-on patches and series. So far it cannot be booted as there is no ROM image produced, but it does build without errors. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-20imx: imx6q/dlsabreauto: Add PMIC Pfuze100 supportYe.Li
Add the pfuze100 initialization in power_init_board for imx6q/dl sabreauto board. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-11-20imx: mx6sxsabresd: Use the pfuze common init functionYe.Li
Modify the pfuze init for mx6sxsabresd to use the shared "pfuze_common_init" function. And move this initialization to power_init_board. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-11-20imx: mx6sabresd: Use the pfuze common init functionYe.Li
Modify the pfuze init for mx6sabresd to use the shared "pfuze_common_init" function. And move this initialization to power_init_board. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-11-20imx: mx6sabre common: Factorize the Pfuze init functionYe.Li
Since the Pfuze initializations are similar on various mx6 SABRE boards. Factorize the initialization to a common function in file board/freescale/common/pfuze.c. So that all SABRE boards BSP can share the function. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-11-20imx: mx6sxsabresd: Add board support for USDHC2 and USDHC3Ye.Li
Add full support for USDHC2, USDHC3, USDHC4 on mx6sx sabresd board. The default boot socket is USDHC4, so the MMC environment device and mmcdev variable are set to this device. Signed-off-by: Ye.Li <B37916@freescale.com>
2014-11-20mx6sabresd: Access SRC_SBMR1 register via structureFabio Estevam
In U-boot it is preferred to access the register via structure pointer, so convert it such style. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-20tqma6: use imx_ddr_sizeMarkus Niebel
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2014-11-20tqma6: add warning on failed setup_i2cMarkus Niebel
setup_i2c has a return value. Use it to give feedback on error. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2014-11-20tqma6: add missing includeMarkus Niebel
Add include needed to have prototype for board_spi_cs_gpio Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2014-11-20mx6sabresd: Add mx6sabresd_spl_defconfig to MAINTAINERS entryFabio Estevam
Let's add mx6sabresd_spl_defconfig entry into MAINTAINERS, so that we avoid getting a warning that the mx6sabresd_spl is not maintained. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-20mx6sxsabresd: Simplify the return value of setup_fec()Fabio Estevam
We can simply the return the value from enable_fec_anatop_clock() to make the code smaller and simpler. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-20mx6slevk: Simplify the return value of setup_fec()Fabio Estevam
2014-11-20mx6sabresd: State that only mx6q is supported in SPLFabio Estevam
Make clear that current SPL code only supports the mx6q variant. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-20mx53loco: Fix error handling in board_mmc_init()Fabio Estevam
2014-11-20wandboard: Fix error handling in board_mmc_init()Fabio Estevam
2014-11-20mx6qsabreauto: Add parallel NOR flash supportFabio Estevam
mx6sabreauto boards come with 32 MiB of parallel NOR flash. Add support for it: U-Boot 2015.01-rc1-18107-g1543636-dirty (Nov 14 2014 - 11:11:04) CPU: Freescale i.MX6Q rev1.2 at 792 MHz Reset cause: POR Board: MX6Q-Sabreauto revA I2C: ready DRAM: 2 GiB Flash: 32 MiB NAND: 0 MiB Due to pin conflict with I2C3, only define configure I2C3 IOMUX when flash is not used. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-11-20mx6: Use a common SPL configuration fileFabio Estevam
Many boards use a minimal .cfg file in the SPL case. Introduce spl_sd.cfg so that we can reuse it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2014-11-20novena: Move the DCD settings to spl codeFabio Estevam
mx6sabresd_spl.cfg configures CCM registers, GPR registers and CCM_CCOSR. Move the configuration to the spl code. CCM_CCOSR setting is no longer required to get audio functionality in the kernel, so remove such setting. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Marek Vasut <marex@denx.de>
