Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com>
Signed-off-by: Steve Rae <srae@broadcom.com>
This introduces a coherent scheme for naming USB download gadget and functions
config options. The download USB gadget config option is moved to
CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each
function's config option is moved to a CONFIG_USB_FUNCTION_ prefix.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
DSPI has pin muxing with SDHC and other IPs, this patch check the
value of RCW SPI_PCS_BASE and SPI_BASE_BASE fields, it also check
the "hwconfig" variable. If those pins are configured to DSPI and
"hwconfig" enable DSPI, set the BRDCFG5 of QIXIS CPLD to configure
the routing to on-board SPI memory. Otherwise will configure to SDHC.
DSPI is enabled in "hwconfig" by appending "dspi", eg.
setenv hwconfig "$hwconfig;dspi"
Signed-off-by: Haikun Wang <Haikun.Wang@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
"hwconfig" enable DSPI, set the BRDCFG5 of QIXIS FPGA to configure
Signed-off-by: Haikun Wang <haikun.wang@freescale.com>
As SCFG_ENDIANCR register is added to choose little-endian or big-endian
for audio IPs on Rev2.0 silion, little-endian mode is selected.
Signed-off-by: Alison Wang <alison.wang@freescale.com>
Export functions required by Aquntia PHY firmware load application.
functions are memset, strcpy, mdelay, mdio_get_current_dev,
phy_find_by_mask, mdio_phydev_for_ethname and miiphy_set_current_dev
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
The agreed split of the top of memory is 256M for debug server and 256M
for MC. This patch implements the split.
In addition, the MC mem must be 512MB aligned, so the amount of memory
to hide must be 512MB to achieve that alignment.
Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com>
This patch allows u-boot to expose the complete DDR region(s) to Linux
(after subtracting the memory hidden via MEM_TOP_HIDE mechanism).
This allows the u-boot to support the 48-bit VA support provided by
ARM64 Linux in flavors 3.18 and above, by passing the appropriate
'memory' DTS nodes.
Signed-off-by: Bhupesh Sharma <bhupesh.sharma at freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar at freescale.com>
Board rev C and earlier has duplicated SPD address on 2nd DDR
controller slots. It is fixed on rev D and later. SPD addresses
need to be updated accordingly.
Signed-off-by: York Sun <yorksun at freescale.com>
LS2085A supports 6 personalities i.e. LS2045AE, LS2045A, LS2080AE,
LS2080A, LS2085AE and LS2085A personlities.
Instead of hard-coding, board name should change as per selected
personality.
As per updated board document, no need to substract 1 from arch[BRD]
bit field. Default value + 'A' represents the board revision.
So update board version print logic to reflect the same.
SYSTEM ID EPPROM always store SYSTEM version info in big endian format.
SoC with ARM or PowerPC core should read/write version info from eeprom
in BIG endian format.
So use cpu-specific APIs to read SYSTEM version.
Signed-off-by: Jaiprakash Singh <b44839 at freescale.com>
FPGA BRDCFG9[SFP_TX] should be clear in order to enable XFI ports.
Signed-off-by: Dai Haruki <Dai.Haruki at freescale.com>
SerDes Protocol 0x49 enables 4 SGMII, PEX4, SATA1 and SATA2.
Add support of 0x49 SerDes protocol to enable 4SGMII on slot4 of
ls2085aqds platform.
Add hwconfig setting for eSDHC since it shares some pins with other
IP block.
Signed-off-by: Yangbo Lu <yangbo.lu at freescale.com>
Add support for board eth initialization and support for loading phy
firmware. PHY firmware needs to be loaded from board_eth_init() because
all the MACs are not initialized by ldpaa_eth driver.
Signed-off-by: pankaj chauhan <pankaj.chauhan at freescale.com>
MARK_GRAPHICS_MEM_WRCOMB is not referenced anywhere in the code,
hence remove it.
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Adds the 'F:' entry for the board's defconfig
When "scripts/get_maintainer.pl" parses "board/.../MAINTAINERS",
it uses the line containing board name as delimiter.
Without this line, the script happily mixes the lines from current
board MAINTAINERS file with lines from another file.
Fix it by adding a reasonable board name.
Tested by comparing output of:
cat board/st/stm32f429-discovery/MAINTAINERS
./scripts/get_maintainer.pl -f board/st/stm32f429-discovery
Signed-off-by: Antonio Borneo <borneo.antonio@gmail.com>
To: u-boot@lists.denx.de
To: Kamil Lulko <rev13@wp.pl>
This action is need to make I2C communication with PMIC
stable for low temperature. Print current I2C speed in
SPL for visual control.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
If board is booted with transitions happening on DCAN1 pins then
the following warning is seen in the kernel at boot when the
hwmod layer initializes.
"omap_hwmod: dcan1: _wait_target_disable failed"
This is because DCAN1 module's SWAKEUP mechanism is broken
and it fails to correctly turn OFF if it sees a transition on the
DCAN1 pins. Suggested workaround is to keep DCAN1 pins in safe mode
while enabling/disabling DCAN1 module.
The hwmod layer enables and disables all modules at boot
and we have no opportunity to put the DCAN1 pins in safe mode
at that point.
DCAN1 is not used by u-boot so it doesn't matter to it if these
pins are in safe mode. The kernel driver correctly configures
the right mode when DCAN1 is active.
Signed-off-by: Roger Quadros <rogerq@ti.com>
[trini: s/PULLUP/PULL_UP/ based on DRA7xx EVM version of this patch]
at that point.
we currently use in-development IODelay values for DRA72x which are
proposed in the data sheet, however, DRA72x EVM uses DP83865 ethernet
Phy over RGMII. The PHY characteristics and routing choices made on
the EVM, make the current iodelay values fail ethernet communication.
Instead, we need to choose custom values for DRA72x-evm specifically
designed for the PHY and routing on the platform for ethernet to
function.
Cc: Nishanth Menon <nm@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Tested-by: Lokesh Vutla <lokeshvutla@ti.com>
Reviewed-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
am43xx_evm_ethboot/usbhost_boot_defconfig entries are
missing in MAINTAINER file. Adding entries for them.
Reported-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
This removes the following two warnings from buildman:
WARNING: no status info for 'cairo'
WARNING: no maintainers for 'cairo'
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
Sinlinx SinA33 is a core/daughter board SDK kit from Sinlinx. It has
the A33 SoC, USB host, USB OTG, audio input/output, LCD, camera, SDIO
and GPIO headers.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
configs/tbs2910_defconfig
configs/tqma6q_mba6_mmc_defconfig
configs/tqma6q_mba6_spi_defconfig
configs/tqma6s_mba6_mmc_defconfig
configs/tqma6s_mba6_spi_defconfig
include/configs/mx6_common.h
stv0991 has cadence qspi controller for flash interfacing, this
patch configures the device pads & clock for the controller.
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
Reviewed-by: Jagannadh Teki <jteki@openedev.com>
Looks like I forgot to add myself as a maintainer for AXS103 defconfig.
Fixing this now.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
With new SMP-enabled CPUs with ARC HS38 cores and corresponding support
in Linux kernel it's required to add basic SMP support in U-Boot.
Currently we assume the one and only core starts execution after
power-on. So most of things in U-Boot is handled in UP mode.
But when U-Boot is used for loading and starting Linux kernel right
before jumping to kernel's entry point U-Boot:
[1] Sets all slave cores to jump to the same address [kernel's entry
point]
[2] Really starts all slav cores
In ARC's implemetation of SMP in Linux kernel all cores are supposed to
run the same start-up code. But only core with ID 0 (master core)
processes further while others are looping waiting for master core to
complete some initialization.
That means it's safe to un-pause slave cores and let them execute kernel
- they will wait for master anyway.
Cc: Vineet Gupta <vgupta@synopsys.com>
NAND memory"
This reverts commit f76eba38b3eda905ff3bdc18dd1240d3dcbc6e5a.
This patch did not have a full and proper copyright/S-o-b chain.
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
include/configs/sun6i.h
include/configs/sun8i.h
this finally removes the need for extra settings in
defconfig
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
Now that we have the Kconfig based CPU type selection,
use this to fill the IMX_CONFIG automatically
This is the first patch to remove the
CONFIG_SYS_EXTRA_OPTIONS.
This patch implements CPU type selection from Kconfig.
Further Kconfig stuff is added later.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
Update new naming scheme.
Signed-off-by: Samuel Egli <samuel.egli@siemens.com>
Acked-by: Heiko Schocher <hs@denx.de>
rastaban is a draco version with more flash, more RAM
and faster CPU. Number of partitions is the same but
rootfs partition is different.
BeagleBoard-X15 uses a vtt regulator for DDR3 termination
and this is controlled by gpio7_11. Configuring gpio7_11.
updates for the siemens am335x based boards:
- draco: add delay for DDR3 configuration
- change MTD partition layout and add a possibility
to redefine MTD layout in board header.
- move ubi support to common header file
- draco: improve dtb naming
- draco: set CONFIG_SYS_CBSIZE to 1024
- add generic env based led
Leds can now be defined in Environment
- add generic env based dfu button
Which gpio is used for the dfu button can be defined
through the Environment
- set MACH_TYPE only if defined
- draco: increase CPU freq to 300MHz
- Add time command to siemens am33xx boards
- DDR3: increase default tRFC
- draco: enable pullup for DFU and ERST pin
- change print format DDR3
This fix is necessary to avoid booting the default ITB configuration.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
in future we support yet another b&r am335x based board, where Timer 5 is
wired to backlight-driver.
So we introduce a new driver-type '2' to setup timer5 instead timer6.
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
